I am considering of changing my fluorescent tubes with these new LED tubes that can operate with ballast. So far I know that Cree and Philips can provide such LED tubes but I did not find any reviews or user comments about them.
Could anyone help me and suggest which ones should buy?
Does anyone have any experience with them, what about their performance?
Feit has some. Only about 1000 lumens per tube, but I really like it. I got mine with a fixture from Costco a couple months ago. There's a thread here about it.
im curious as well. my aquarium still uses the t8 or maybe even the t12 hahah
but im also running some t5’s with it two.
its a 300 gallon aquarium , so lots of lighting.
i would love to get some led’s for it though.
Time to redo a 1920s desk lamp — adding a ground wire, taking the old suspicious GE 3-watt ballast to the toxic waste dump, replacing the cracked wiring.
I can find a ballast and fluorescent but would like to find a LED tube replacement.
It’s not for me, or it’d become a massive heat sink with multiple stars — but it’s for someone who’d like it to either look like the same thing or not too weird ….
those don’t include 18” tubes, so I suspect I’m going to use a new fluorescent.
Still poking around for something.
The old lamp has a “15 watt” GE 18” x 1” (no other numbering on the lamp) and the ballast is 4” long between mounting points and rated for 3 watts.
It’s a pretty dim desk lamp by modern standards, though still working — flickery cool white, tired — and as i said not even grounded and not a polarized plug.
I finally convinced my employer to purchase some led replacements. Our ceiling lights are super hard to get to, because of several layers of process piping.
I looked into the LED Floors on Amazon. Some good info in the reviews there.
All of mine in my house are the older T12’s. I think I need to change the whole fixture. I thought I read that all you have to do is take out the ballast, and add a shunt to make the Led work?
Wish someone here would do a budget rig and post a killer thread with great instructions on it.
that might be old enough to leave alone.its not 1920’s.
1939 at earliest.if you gut it i may want the bulb,ballast,sockets,ect.no pcb’s to be afraid of in that.its a simple choke with no oil filled cap.
So sorting out the two different threads — this is where I got to on finding LEDs to fit an 18” space:
I’d rather go with LEDs …
Well, two of these COB strips for instance would fit end to end inside the lamp housing, adding up to about the same length as the fluorescent tube:
Those are described as 18w apiece
but a review said “Give em 12V and it consumes a third of an amp (only 4W!)”
— so a pair would need a power supply providing um, 36watts? or 8 watts? (sigh)
and maybe a dimmer.
I’m dubious a power supply would fit in the base, so it’d be a wall wart or a brick.
