I have a 2D maglite with a 5 watt diamond led, powered by 3 cr123s as a drop in with a glass lens. Its bright but very much a flood. Given the way the lens and heat sink are made it would be very hard to mod this set up. Does anyone have a good recipe for a bright budget spot (or at least more throw than the diamond setup) LED or HID conversion for this host. I have read the ROP threads but would like to stick with 2 18650s, 2 D cells or 3 RCR123s for power.
I can't help myself, I have always liked 2 D mags. It is just that I never use mine because it is so pathetic compared to my other LED light. I hate having a safe queen, which is what my Maglite has become. Plus I love to design and build stuff!
Thanks for the recommendations guys. I am leaning towards the P7. I have a lathe and mill so the machine work is not an issue. I will fab up a 2X18650 sleeve and run the drop in at 8.4 volts. Thanks for the hint on pulling the coating off in the bead blasting cabinet, I will do the same! I will look for the drop in on the manafont site as I have been happy with the customer service I got when ordering the UF 980l
Thats a very nice light, but for me I really want to build something on the mag host so that I will not have a 2D maglite sitting on the desk that I never use and I would like to get the pleasure of making my own. For instance I machined a sleeve and twist switch for my costco LED for an 18650. Much brighter, no more battery drain. I turned off the bumps on the bezel and bead blasted the body. It was a lot of time on a cheap light and makes no sense financially. But it was fun and helps me build my mod skills so I don't screw up a nice light the first time I try something new!
So tonight I decided that I really did not like the Diamond 5 watt LED enough to not use it for a host for my 2D maglite project. So I pulled it apart and found the parts to easily host the pill and emitter from one of the costco "tactical" lights. I made a non conducting post for the bulb holder with a SS centre post and the diamond housing for the ground circuit. I turned 2.4 mm of the outside of the costco emitter housing and it dropped into the Diamond housing and onto the centre post that I made. I used a spare reflector that I had from a Lumapower Hunter M1 and the front end was done.
I turned up a sleeve and spacer for a single 18650 and it had power.
I wasn't sure what to expect, but I like it. Nice throw with decent spill, so much brighter than it was. These Cree XP-E emitters driven directly from a single 18650 seem to be a great and inexpensive combo for the value conscious modder. With three lights at $20 bucks, it is a pretty cheap way to get decent parts as you (I) find your way around the DIY flashlight game.
I wish I could take and post pictures with any skill, but I feel pretty self conscious with the professional quality pictures and reviews I see up here everyday against my rudimentary skills.
Man I hear you, I have already released the magic smoke from a couple of emitters, I think a variable power supply would be a nice addition to the work bench.
I put that same drop-in into an old 3D Mag running off of 3*18650 cells a few weeks ago. LOVE it!! Not much of a thrower because the reflector is fairly shallow and orange peeled but it kicks a lot of light and has a brutal strobe. Great light for walking at night and for personal defense.
