Tried this headlamp? I’m looking for a decent one ,for when I try and solder it helps me to see and walking my two dogs I had 1 get hit by a rattlesnake that never rattled and couldn’t see , luckily she made it but a decent light would free up my hands when trying to walk two dogs on leashes.
When I switched it on, no lights lit up, only the 'LED HEADLIGHT' indicator on the back of the battery house lit up, indicating the the batteries were fine.
Measured them and indeed, they were not the cause.
Also the led light functioned, (checked that simply with multimeter to test the circuit before and after the led light. easy enough when you screw loose the glass of the light)
Solution:
I opened the back of the center lamp (where the switch is located) and found out two wires were broken loose from the board.
I soldered them back on and everything worked fine again.
So my tip: check soldering, they are not the best!
I’ve got one of these; actually received it as a Christmas gift last year. I’ve been very happy with it for what it is… I have a smaller floody headlamp (modded with high-CRI Nichia) that I use for up-close work like soldering but the Boruit seems to be a decent cheap option for when you need a brighter light for long range use. I actually had this exact light in my GB shopping cart and had planned to order one for myself.
Mine has LB XM-L type clones for all three emitters, with two behind the TIRs on the side. The central LB emitter actually has a really nice tint and works well. Nicely focused hotspot, so I’ll probably leave that one as-is. Also, the battery pack has a parallel configuration, so it’s safer when strapped to your head than if you had them in series.
The secondary LB emitters are slightly warmer tinted. Not unpleasantly, but they have a slight yellow cast that contrasts with the output from the center emitter.
Mode selection is odd, and a bit disappointing as it has no low modes.
1. Central LED on - good hotspot with reasonable throw
2. Outer LEDs on - Wider beam, but not floody enough
3. All three LEDS on - Not much use to this mode…
4. Strobe…
…and all modes have to be cycled through to turn the light off.
My hope is to eventually replace the TIRs on the side emitters with some wider angle optics to make the secondary mode more floody. I haven’t measured to verify yet, but the cheap 25/45/60-degree optics available from FT and other sources appear to be the same size when the ring is removed. That would give me a dedicated throw mode, and a dedicated flood mode, all from the same headlamp.
I may also consider replacing the side emitters with High-CRI Nichia emitters, but that’s not a high priority.
