Difference between Opus BT-C3400 & BT-C3100 v2.1?
701 posts / 0 new
Photons Away
Photons Away's picture
Last seen: 12 months 4 days ago
This may have been missed but what is the difference between these two chargers? It is noticed that the BT-C3400 is not available until 6 OCT 2014. It is found both on ebay and Amazon.
Thank you for any thoughts on the matter.
wight
This is the first I’ve heard of the BT-C3400.
Break’s over for now. That was a long one! wight catchup WinkWinkWink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Turby3Pots
Turby3Pots's picture
Last seen: 19 hours 28 min ago
I know what a let down.
Gonna be mad if I jumped on the 2.1 GB from gearbest too early.
how2
Last seen: 4 years 3 months ago
wight
how2 wrote:
BT-C2000 Battery Charger Analyzer Version 2.1
BT-C3400 Battery Charger Analyzer Li-ion NiMH NiCd
The BT-C2000 really isn’t part of this discussion. It’s not a Li-Ion charger.
At a glance I still don’t see any significant difference between the C3100 and the C3400. So… huh.
Ejected Filament
Ejected Filament's picture
Ill be waiting for HKJs review, just like I did with each version so far. Im yet to buy one of their chargers, theyre close, but never quite there for me. I dont care about saving $10 so was not motivated by group buy deadline pressures.
Photons Away
Amazon: http://www.amazon.com/BT-C3400-Universal-Analyzer-rechargeable-batteries/dp/B00NR77SL2/keywords=opus+bt-c3400
ebay: http://www.ebay.com/itm/BT-C3400-Battery-Charger-Analyzer-Tester-Li-ion-NiMH-NiCd-18650-Lithium-ion-V2-1-/331325504524?pt=Battery_Chargers&hash=item4d2489fc0c
The BT-C3400 is advertised as the v2.1 also as noted on the ebay page.
 Hello rdana! Please elucidate. Thank you.
UPDATE! AHA! Just learned the answer of the differences: (From Amazon)
A:
The C3100 had problems. One was overloading the power adapter when charging 4 cells. Those issues have all been resolved in the C3400.
tempo
Last seen: 6 hours 9 min ago
So many similar versions of basically the same charger, just with slight revisions to improve the product. Very confusing.
Will there be a BT-C3500 as very final revision version?
Ejected Filament
A:
Yet there is still 3 amps output on the supplied PSU. On one of the links supplied, this makes no sense…
Quote:
Adatper Power Supply output: 12Vdc 3.0A.
Charge current: maximum 2000 mA. (1000 mA max all 4 channels)
Unless it means each channel can do 1 amp (1 amp to two channels at a time max), but not all 4 at the same time???
Am I doing this right??
tatasal
Last seen: 57 min 49 sec ago
I have sent Henry Xu an email about this. No other guy is more qualified to answer this question.
dangerous
dangerous's picture
Last seen: 4 years 1 month ago
The comment on Amazon is from a random user and should not be taken as gospel. I wouldn’t be surprised if the C3400 is the same as the C3100 V2.1.
I don’t like how they are having all these minor updates and different versions within a few months. I think it is better to update every year with substantial changes and a different model number.
BLF
dchomak
Last seen: 8 months 3 weeks ago
My take on this is exactly as yours, that the 3400 is identical to 3100 v2.1
I think it is actually better marketing wize to differentiate this way.
tatasal
+ 1, as there was neither a 1.0 or 2.0 BT-C3400
fellfromtree
fellfromtree's picture
Last seen: 4 years 4 months ago
I knew it Smile Well getting back later this month so by then there’ll probably be a 4000
HKJ
HKJ's picture
Last seen: 15 min 14 sec ago
My guess is that is one is updated hardware.
The 3000 did get some software updates to fix the problem with current pulses. This made the current pulses small enough that the power supply could handle it, but they where still above 3A.
The 3400 probably has changed hardware to get rid of the current pulses.
At the current time I have not been promised any review copies of it.
eas
eas's picture
No, it’s from the seller, and called out as such.
I suspect that you are right though about it being the same as the C3100 v2.1. Someone realized that giving it a new name and label is a lot better way to clearly communicate that it is the new and improved version, and avoid people passing off old stock as new.
dchomak
Or it could be as simple as they wanted to first use up all the cases that they had made up that said BT-C3100. I don’t think they expected to update the unit so soon after the release of v2.0
HKJ suggested that maybe there is an included hardware upgrade. From the Amazon site this C3400 has been in their hands since September. Is it possible OPUS could have made a hardware change that quickly after the release of v2.1?
Buwuve
Buwuve's picture
Last seen: 1 year 9 months ago
Maybe it now possible to change the charging end voltage (3,6, 4,2, 4,35V) without opening the charger. It's crazy, that the feature is inside and not changeable without removing the screws.
Light up the darkness.
Ejected Filament
Anyone find it officially from Opus? I looked over their alibaba pages, and couldnt find a BT-C3400.
Electrified
Last seen: 4 years 5 months ago
Just emailed Robert ( rdana from ebay)
This is what he said…..
The BT-C3400 is essentially the C3100 V2.1. This model number is exclusive to me.
Thanks,
I’m gonna buy one from him since it is the new 2.1 version.
tatasal
Thanks,
http://budgetlightforum.com/node/33690
Photons Away
Thank you, Electrified, for doing the leg work and getting us all a good answer.
Electrified
This group buy ENDED mid Sept. I tried contacting gearbest on oct 1st but they will not honor the price.
tatasal
Oh, sorry, I didn’t know. You are correct, I just checked.
Edit: Just now, the OP3100 coupon (promotion) code still works for a net price of $42. perhaps I interchanged the codes, they should be:
v2.0 – gb3100 for $36
v2.1 – btc3100 ($45), this code no longer used
v2.1 – op3100 – code to be used for $42
Serville
Serville's picture
Thanks,
So, there is no group buy for BTC-3400 this time :bigsmile:
Good. My BTC-3100 is still in waiting for final delivery from the post office. Maybe I’ll receive it in 1-2 days.
I’d better kill myself if there is already another groupbuy for a newer version even before I receive my BTC-3100 2.1 |(
tatasal
Thanks,
Confirmed by Henry Xu from his reply to email inquiry.
Tacoboy
Last seen: 6 days 7 hours ago
Is the BT-C3400 still considered a relabeled BT-C3100 v2.1?
tatasal
Yes
Tacoboy
Anyone have a link to where i could download the manual for the C3100/C3400?
tatasal
http://imageshack.com/f/547/y8v.pdf
Tacoboy
Thanks, now I’ll be able to read up before my BT-C3400 arrives (by Saturday).
Ended up ordering the BT-3100 with the European ac/dc power adapter (KYT120300BV), come with a Euro/US add-on adapter, which I guess I lost.
Where in the USA can I order a replacement AC/DC power unit, for my BT-3100?
(I would rather just get the whole power unit, and not have to use the euro/US adapter)
