Difference between Opus BT-C3400 & BT-C3100 v2.1?
703 posts / 0 new
teacher
teacher's picture
Last seen: 26 min 8 sec ago
OK, I could find no suitable power supply locally yesterday; so that’s out.
My laptop supply has the right plug it seems, but it is 19v/2,37a. That would be to much voltage wouldn’t it? ( 19 V )
I really don’t want to fry the thing. Wink
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
wolfdog1226
wolfdog1226's picture
Last seen: 3 days 5 hours ago
Some questions/concerns assuming Jon will let me keep my Opus and test it with a new power supply AND Return it for a new one if it fails!
What will the quality be for a Power supply that was shipped for $6.99?!
Will it meet the advertised specs of 12V/5A or will it fall into the category of so many falsified capacities/specs. of numerous Chinese batteries?*****Fire, ect.
No way for me to know until I get it because I have no equipment to test it!
________________________________________________________________________________________________________________________
This is just a guess! It is sold for $6.99,,probably cost $1 to make, ebay guy buys it for $2 and pays $2 or$3 to ship to me and gets a $2 or $3 profit!!! LOL
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
teacher
teacher's picture
gauss163 wrote:
teacher wrote:
My laptop supply has the right plug it seems, but it is 19v/2,37a. That would be to much voltage wouldn’t it? ( 19 V ). I really don’t want to fry the thing. Wink
19V is out of the 8-16V range stated by Opus engineer Henry Xu. Most likely it would cause damage.
Thanks gauss, that is kinda what I figured….. Sad
teacher
teacher's picture
Well, look at it this way, unless it blows up, burns up, or shocks you…. it can’t be any worse than the one you have now and you not notice it. Big Smile
wolfdog1226
chops728 wrote:
Have you tried it with 3 cells--that way you'd know if the charger is still working or not
Successfully charged 3 X NCR 18650 @ 1AMP.
DMM Measured: In @ 3.80v, Out @ 4.17v
        WOLFDOG
teacher
teacher's picture
@ wolfdog
Did you just Charge… or did you do Charge – Discharge – Charge?
Speed4goal
See even though I brought this issue to light. I’ve never had it happen on a charge discharge test. Only a regular charge. And usually when cells are complelty done for not only half completed. And not everytime just occasionally.
To me its not heat related. I literally have a window ac unit maybe 2.5feet from it blowing directly on it. Shares the same plug with the unit. There’s no way within 3-4 mins it could overheat with 60degree air blowing across it. A good bit of the time the fan won’t even come on. Or cycles briefly with 6000btu air-conditioning blowing right on it
Edit
I’ve done hundreds of charge discharge test 4 at a time at 1amp. Just did 68 last weekend not a issue. (3day weekend for me) ran non stop literally
What made me notice it me and the wife have 3 tomo v8 powerbanls. They charge uber slow. So we change out the batteries. The batteries are at 3-3.2 volts when being charged. And I’ve seen the problem only at the most power draw of a charge cycle. Once the batteries get 3.7-3.8 the power loading shouldn’t be as hard
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
wolfdog1226
teacher wrote:
@ wolfdog Did you just Charge… or did you do Charge – Discharge – Charge?
I just charged them per “Chops” suggestion to see if the charger worked.
He probably asked me because the “Failures” happen when transitioning from Discharge to charge.
That is when the battery is ~ 2.80V and “May” need the most energy to get the charge started? Hence, the thought process that it probably needs more powerful Power Supply.
        WOLFDOG
teacher
teacher's picture
HKJ wrote:
wolfdog1226 wrote:
I asked HKJ earlier today if 12v/3a is enough for 4 batteries @ 1amp?: Easily, 12V 3A is 36 watt, 4 batteries with each 4.2V charged at 1A is 16.8 watt, there is a lot of spare power for display and heat.
What I did not say was that it requires that the charger know how to handle the power. The first versions of the C3100 charger was very bad on that, in later versions it was improved, but not perfect. This means that a sensitive power supply may give the charger problems.
But you have the problem during discharge and that do not make any sense, the charger is not supposed to be loading the power supply when doing discharges.
HKJ wrote:
wolfdog1226 wrote:
The discharge process was over and it was transitioning to charge. that is when it kept turning off and defaulting to 500mAh.
That means you power supply is rather sensitive, try a more powerful one. The opus charger do have some nasty spikes in its power draw, a large capacitor in the power supply will handle it (or a slow over current limiter). The problem is not the average current draw, but the peak current draw, the power supply supplied for my test had no problems with the “fixed” version of the Opus, but a power supply with very fast over current protection will have a problem.
A guess would be that Opus has change supplier of power supply, without checking if it can handle the requirements of the charger.
HKJ wrote:
wolfdog1226 wrote:
Jon from Liionwholesale’s guess is that it is overheating and/or may have a failing/bad thermal sensor?
I doubt it, in my opinion the most likely cause is the power supply. The Opus will draw more than 3A in peak current, in my test I measured 6A for nearly 0.02 second. Then 0A for 0.03 seconds, bringing the average below 3A
All this “detective work” is kinda fun. Wink
Our chargers have the exact same issues. I am gonna hitch my cart to our power supply being the problem theory (inadequate supply for occasional demand in certain instances) .. (Thanks HKJ…. Wink . )
It will be interesting to see how it all plays out. Wink
wolfdog1226
I ordered my Power supplies[Two]! ,,,,,,,,,,and I hope it is the solution because I like my capacity test results and a 0.03v additional charge compared to my original Opus!
        WOLFDOG
teacher
teacher's picture
I hope it is too……… Thumbs Up
wolfdog1226
If the Power supply I ordered is as efficient and impressive as the Ebay dealer and USPS, I will be very happy!
I ordered it Friday night. It is coming from Oregon and I live in Pennsylvania[Subs. of Philly]. It is “OUT FOR DELIVERY”!
The USPS gets ripped a lot..I have done my share. I will give them credit for this. They may NOT deliver on Sundays but the packages are still moving!
I am going to do several “Charge/Tests which is where it failed. That was minute or Two into The charge phase AFTER discharge was complete.
I will report back possibly tonight and hopefully w/ all good news!
        WOLFDOG
chops728
Last seen: 3 min 20 sec ago
For some reason Items I purchase from Washington/Oregon area get to me faster than from anywhere else
I forgot to mention the other night—I usually charge my cells first —let them rest—then I do a charge test—the charger tops them off first before the discharge as normal—I don’t like charging for 2 hours then discharging for another 2 + hours and again charging for 2+ more hours—seems abusive to me
teacher
teacher's picture
That is good info then, as it is a totally different scenario than what Wolddog is describing. And my charger does the exact same thing his does.
wolfdog1226
chops728 wrote:
For some reason Items I purchase from Washington/Oregon area get to me faster than from anywhere else I forgot to mention the other night—I usually charge my cells first —let them rest—then I do a charge test—the charger tops them off first before the discharge as normal—I don’t like charging for 2 hours then discharging for another 2 + hours and again charging for 2+ more hours—seems abusive to me
Even California[Illumns] will get here in 2 days for First class mail!
I agree, that is exactly what I did as I wait for delivery. Otherwise the CHARGE/TEST can take 8 to 10 hours!
The only time I don’t do that is for a First time capacity test with new batteries where I let the Opus do the whole cycle. The New batteries are usually ~ 3.60 when I get them.
        WOLFDOG
wolfdog1226
I could be wrong, but I think you are somewhat misunderstanding what Chops is saying. Maybe a little more abuse, but I take it as time saving.
MINE FAILED when I put the batteries in at a mostly charged state and then the Opus discharged, then tried to charge them @ 1amp but reset instead!
INSTEAD of Charging/discharging and charging for the CHARGE/TEST. It save s time if the batteries are mostly charged or at rest after charging then put them in for Charge/Test. that way you save ~ 3 hours.
The Opus is still discharging and charging so you can get the capacity. My failures have been shortly after discharge when the batteries are @ 2.80v and they begin charging again.I believe the INITIAL charge has nothing to do with failure shortly after the battery is discharged.
Again, where mine failed is what HKJ talked about where the charger spikes in output because it needs that surge of energy when the batteries are ALL @ 2.80v. I think he said it jumps to ~ 6 amps for 0.03 of a second!! He elaborated on that last Friday. Smile
EDIT: Besides ALL of that the Opus should be able to do ALL Three stages without an issue!
Jon from Liionwholesale who sold it to me has about 5 of them running constantly doing capacity tests!
        WOLFDOG
teacher
teacher's picture
OK, I did misunderstand how you were doing it. I thought you were letting the OPUS do the whole thing….. CHARGING almost empty cells – then DISCHARGING for Capacity – then going back into CHARGE Mode (where the problem occurred shortly after)
My bad, I’ve got it now. You and chops728 are on the same “program”. It is me that is different as most of the time I did it as described above.
Soooooo…… that tells me that part has nothing to do with the problem…… Thumbs Up
wolfdog1226
I also need to say!!! That I have done it both ways[no wise cracks I LOVE woman!].
I already mentioned that when I get Brand new batteries I make sure the Opus charges it from the beginning. Older batteries for the FIRST test I may have them charged, but no more than 4.10v so the opus can top it off to where it is accurate for ALL batteries and ALL capacity tests in the Opus.
However,the recent failures the batteries have all been mostly charged and then the Opus tops it off, goes to discharge and then charge.
        WOLFDOG
teacher
teacher's picture
Got it……. Thumbs Up
wolfdog1226
Off Topic!
The mail use to come b/w 1 and 2pm,now after about 3 or 4 mailman changes over the years, It comes b/w 3 and 5! A Flashaholics nightmare! Facepalm
I wanted to get this test done b/4 8 pm when I go on my nightly hike w/ Capo. Does not look like that will happen as it takes about 4 hours,it will take 1 hour just to top the batteries off!
        WOLFDOG
wolfdog1226
ok,,,,everything is in order!! Came 10 minutes ago,batteries charged in 2 minutes and went into discharge mode,,,,,,It should be done ~ 7:45!
I will give a report when it’s done! I really hope this is the solution!
I bought 2 Power supplies in case one did not work!!!,,the first one did not leave Calif. yet and I ordered that 12 hours before this one that came from Portland, Oregon!
        WOLFDOG
chops728
Arrival from California is a whole different deal—sometimes twice as long to get to the Swamps
wolfdog1226
Plus they are shipping it FedX and they do not deliver Monday. A label has been created,,,that is it.
Illumn must be an exception……but then again they ship it First Class US Mail not FedX.
        WOLFDOG
wolfdog1226
For ALL my fans that may be waiting! lol!
I had a brain fart and had to start the test over! Facepalm
The results will be posted before the night is over. ~ 10/10:30.
        WOLFDOG
wolfdog1226
First test was a SUCCESS! Thumbs Up
Transition from discharge to charge was smooth and NO reset!
I am going to do a few more 4 X 18650 3400mAh tests @1Amp for complete verification, satisfaction and enjoyment!!!
        WOLFDOG
teacher
teacher's picture
Thumbs Up .. So far… so good!! Smile
chops728
Aww come on now —You know you want to use your old chargers
PS— if you dont have any extra fans for the Opus—get some—I buy them by the half dozen
wolfdog1226
Do the fans wear out quickly? Where did you get them?
I saw a video a month or so of a guy replacing one,,,,,,,,,,looks kind of easy, even for a guy like me!
EDIT: I should have researched b/4 I ask questions!! I will guess you get them at Fasttech! ~$2/each.
        WOLFDOG
chops728
I think I found them at Bangood—Nothing to changing them at all—lately I prop up the fan end on something to give better air flow from underneath
wolfdog1226
gauss163 wrote:
Great. That confirms my initial hunch – that it was due to a power supply overload (also surmised by HKJ in a later post).
Which SMPS fixed it? Based on your mention of Oregon, it looks like it may be the Supernight in the eBay auction I linked. If that seems to work well then it might be helpful to post a photo of the label, to help others locate it.
Yes,,,,,,,,,,,the Supernight is doing a Super job,,,,,,,test #3 to start in an hour or 2!
I can get a picture after test #2 is complete.
        WOLFDOG
