Difference between Opus BT-C3400 & BT-C3100 v2.1?
701 posts / 0 new
wolfdog1226
wolfdog1226's picture
Last seen: 12 hours 10 min ago
gauss163 wrote:
wolfdog1226 wrote:
How do I know that these are better quality? How do I know how long they have been used and the duration of use per day? Don’t they sell those kind new?
If you’d rather not take a (slight) risk on a used high-quality SMPS, then you can get them new for slightly more, e.g. here is a Hitachi 12V/5A ADP-60WB, which is manufactured by Delta, a top-tier SMPS manufacturer (analogous to Panasonic for batteries). They are $14 or Best Offer, so probably you can get it with a $10 offer.
As I mentioned before, I didn’t say the SuperNight was high-quality. Rather, I gave it as an example of very cheap SMPS on eBay.
ok,,,,maybe I will use that as a main one and my SUPERNIGHT as a backup!!
How come these used ones never tell what size the barrel connectors are?
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
wolfdog1226
As I mentioned before, I didn’t claim that the SuperNight was high-quality. Rather, I gave it as an example of a very inexpensive 12V/5A SMPS on eBay.
ok,,so where is the NEW ones?!! This is another used one!
        WOLFDOG
wolfdog1226
Last comment on Supernight!
I never said you claimed that it was high quality. I am saying that you recommended it and have badgered it several times since! You want me to open it up because it may be shabby. Shortly after you recommended it you posted others for Teacher that are supposedly better!
Supernight is doing fine ,,,,,,does not get hot and has gotten the job done so far!
….It is way past my bed time,,,,I get up at 5 every day to take the BOSS out!
        WOLFDOG
wolfdog1226
I am IMPRESSED!!! I got a refund already for the SMPS that did not work right!!! I guess they do not want the piece of crap back!
I saw some reviews on it and a guy said it could not deliver more than 1 amp!
        WOLFDOG
wolfdog1226
gauss163 wrote:
They must have run out of new Hitachi’s since I last saved that link. I have updated the post to a LITEON, which is a good deal.
ok,,,,,,,,,,,,I found a “supposed” new one on Amazon for $6.99,,,,,,,,,,,has to be a fake!
What do you think?
https://www.amazon.com/UpBright%C2%AE-Adapter-HITACHI-ADP-60WB-Monitor/d...
I emailed the Ebay Hitachi seller to find out what size the barrel connector is. I want it to be 2.1mm NOT 2.5mm even if the latter fits, I am sure it would be losse.
        WOLFDOG
wolfdog1226
gauss163 wrote:
If you prefer not to take a (slight) risk on a used high-quality SMPS then you can get a new one for slightly more, e.g. $10.45 for a 12V/66W LITEON PA-1660-2SA1. This was probably manufactured in the past year or so given the FCC ID application date of 2015-10-29, and the fact that it meets the latest efficiency Level VI. So it is a latest tech SMPS from a top-tier manufacturer at a great price.
It is listed for .99 cents!!!! I guess that is an error!
The barrel connector is the 2.5mm NOT the 2.1mm.
Do they sell an adapter/converter piece to attach to the 2.5mm and converts to 2.1mm? I would think the 2.5mm would be loose and I do not want that.
EDIT:Yes they do Wolfdog!! Lets NOT complicate this!! Less than $3 on amazon. Keep it simple Wolfdog,just get one w/ a 2.1mm!!
How about this brand NEW Hitachi…only $41.79!!!!! More than I paid for my opus! Its connector is the 2.5mm…….I would assume the Ebay one is the same. Facepalm
http://www.cheap-chargers.com/ac-adapter-12v-5a-60w-for-hitachi-compatib...
        WOLFDOG
wolfdog1226
gauss163 wrote:
wolfdog1226 wrote:
ok,,,,,,,,,,,,I found a “supposed” new one on Amazon for $6.99,,,,,,,,,,,has to be a fake! What do you think?
The photo shows it is an “Upbright”, not a Hitachi/Delta. When it says “for XYZ” it means it is a generic/clone replacement compatible with XYZ.
Many 2.5mm barrels include a spring so they are also compatible with 2.1mm pins. If not you can buy an inexpensive adapter.
The LITEON is in a multi-item listing. You need to choose the SMPS from the “Model” selection box.
Ok,thanks,,,,,,,,,,,,
Yes they do sell adapters Wolfdog!! Lets NOT complicate this!! Less than $3 on amazon. Keep it simple Wolfdog,just get one w/ a 2.1mm!!
        WOLFDOG
wolfdog1226
@ Gausse163
I need you to verify this Dr. Gausse!! I may change my mind again if you believe this is a winning combo!!!
If I get THIS:
https://www.amazon.com/uxcell-5-5mm-Connector-Female-Adapter/dp/B00MJU7N...
I want to make sure it will work in this recommendation of yours!:
http://www.ebay.com/itm/12V-DC-Power-Supply-AC-DC-Adapter-Transformer-5A...
I already have 2 power cords. SUPERINGHT and the faulty SMPS one where they do not want it back,,,,,I guess shipping a faulty piece of junk would be more of a loss for them. No complaints,,,,,,free power cord and reimbursed in 3 hours!
        WOLFDOG
wolfdog1226
gauss163 wrote:
^^^ No, that’s the wrong conversion – enlarging the hole (which is far more commonly needed since you can’t plug a fat center pin into a skinny hole). Instead you need to shrink the hole. So the adapter’s center pin should be a fat 2.5mm, and it’s opposite hole should be a skinny 2.1mm. Often there is confusion about which connector is male and which is female, so you need to be careful. This listing makes it clear that it is the correct choice.
There’s a good chance you won’t need an adapter. Even if you don’t these common DC connector converters are useful to have around since eventually you may need one (both directions are useful, i.e shrinking and enlarging the hole).
OK,,,,,,,,,,,,Thanks,,,,,,,,,,,,,glad I asked. It is confusing because when I saw 5.5mm/2.5mm to 5.5mm to 2.1mm I thought it was right. the female/male part was what Screwed[!] me up!
Is Lite-on as good as Hitachi? I am glad the lite on is new.
Thanks Gausse,,,,Your intelligence is comparable to My Friend Dr. Eissler whose mom was from Germany!!,,,,,,,still a step behind from my 1/8 German and Italian people!!!!!!!!!!
EDIT: GAUSSE,,,that adapetr is coming from China!!
Item location: guangzhou,guangdong, China Delivery: Estimated between Fri. May. 5 and Mon. Jun. 12
I need to find one in the USA!
        WOLFDOG
wolfdog1226
gauss163 wrote:
LITEON is a top-tier SMPS manufacturer, the OEM for many laptop SMPS (e.g. Dell), etc. The Hitachi is made by Delta, which is also top-tier. The Delta is probably older than the LITEON, but I can’t be sure since I see no markings that reveal its age.
If you bought either from DigiKey or Mouser they’d probably cost $40 or more shipped.
The Lite on is brand new.
Item location: guangzhou,guangdong, China Delivery: Estimated between Fri. May. 5 and Mon. Jun. 12 Facepalm
        WOLFDOG
wolfdog1226
gauss163 wrote:
wolfdog1226 wrote:
EDIT: GAUSSE,,,that adapetr is coming from China!! I need to find one in the USA!
Why? As I said, there’s a good chance you won’t need it, and you can always use the SuperNight till then. You can probably find the 2.5 to 2.1 connector adapter in USA (if not on eBay then try DigiKey or Mouser).
Ok Gausse!!!
I pulled the trigger on Both of them! I have my SUPERNIGHT to guide me through the night until they arrive!!
I found one place,,can not remember the name is was ~ $19 for 2 including shipping! Cash
        WOLFDOG
tatasal
Last seen: 6 min 22 sec ago
Or you may try this: I have experimented with these years ago on my Opus. (for a more stable but overkill 12VDC)
wolfdog1226
Got my LITE-ON SMPS Today. 12V/5.5A/66W. Works like a charm…..not even close to warm. Thumbs Up Supernight demoted to back up.
Thank you Settimio for recommending it. Qui Riposa in Pace. Wink
        WOLFDOG
teacher
teacher's picture
Last seen: 1 hour 1 min ago
Nice!! Can you put a link to where you got it Wolfdog please.
Was the barrel plug the right size or did you get an adapter?
Thanks for your research & testing on this. Smile
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
wolfdog1226
Sorry,,can not provide the info,,,u never answered my email!!!!! Evil
I do not have the adapters yet. However, it fits fine,,,,you can barely tell it is slightly bigger. Adapter really is not needed but since I ordered a few I will probably us them. Mr. Opus is happy.
Settimio told me about it. $10.45 ,,3 days from Calif. to Suburban Philly. Thumbs Up
http://www.ebay.com/itm/391689318983
        WOLFDOG
teacher
teacher's picture
Crap……. I forgot. Facepalm
I’ll get right on that. .. cause it was a good one! Big Smile
Turby3Pots
Turby3Pots's picture
Last seen: 3 days 13 hours ago
can you no longer buy from Ebay without an account??
wolfdog1226
My guess is that you would need to have an account to order from them, I do not know for sure.
        WOLFDOG
wolfdog1226
teacher wrote:
Crap……. I forgot. Facepalm I’ll get right on that. .. cause it was a good one! Big Smile
If you decide to get barrel connector adapters I would recommend the ones below. They are at a right angle which saves me room because my Fenix ARE-C2 is right in front of the Opus.
Plus its arrival date is anywhere b/w 10 and 26 days earlier than the first Two I got which are straight. I could get mine next week. These are coming from China like the first two I ordered.
http://www.ebay.com/itm/172544489681
        WOLFDOG
wolfdog1226
!{width:60%}https://s19.postimg.org/hu3d73k1v/LITE-_ON33.jpg!
Keep in mind, Wolfdog1226/Capolini and others that the Inside temp. was:
EDIT: It is 84F outside and 77F in my condo. The SUPERNIGHT MAX TEMP. was 94F.
The indoor temp for yesterdays initial test was 67F and today is 66F. The Lite-on has the pleasure of being in 10 and 11 degree cooler testing environment.
With that said, I doubt if the Lite-on would reach 94F under the same circumstances as the Supernight in 77F degree flashlight laboratory temperatures! Wink
My 4 X 18650 Orbtronics are at 3.70V now,,charging after the discharge test. The external temp. of the Lite-on is 68F. The peak temp is ~ 4.10v .I will re check it then.
ALL in all this is not a fair test until Flashlight laboratory is the same temp. for the Lite-on! It does give an indication that Lite-on is working well and not under stress! Cool
        WOLFDOG
wolfdog1226
Since the room temperatures have been different. This is the Only comparison I can give.
Test: SMPS Max external Temperature when charging 4 X 18650 3400mah
Starting Voltage: 2.80v immediately after Discharge/Test
Ending Voltage: 4.20V
Participants: Supernight 12V/5A/60W…….Lite-on 12V/5.5A/66W
Supernight
Indoor temperature- 77F/25C
Max external temp.-94F/34C
Difference:17F/9C
Lite-on
Indoor temperature:66F/19C
Max external temp.-69F/20C
Difference:3F/1C
When The temperature reaches 77F/25C in my condo I will do another test w/ the Lite-on. MY guess is that its external temperature will not exceed 84F/29C. Cool
        WOLFDOG
wolfdog1226
Photos of the S’night 2.1mm Barrel Connector and the Lite-on 2.5mm Barrel connectors.
The holes themselves seem identical in SIZE. The smaller S’night 2.1mm seems to use a spring loaded pin/clip, almost like a flexible cotter pin to reduce the size.
Supernight 2.1mm
Lite-on 2.5mm-Angle shot I turned this around in Post image,,,it will Not display that way on here???
Lite-on on TOP-Sorry for the blurry picture.
Side by side. Lite-on is on top. It has a shorter :exposed” barrel.
        WOLFDOG
wolfdog1226
Upon further review I would definitely get the adapters. It works but connectivity can be a problem at times. I just moved the unit slightly and it shut off. A proper 2.1mm connection will make it much more secure.
I got a 10’ cable 5.5mm X 2.5m female to 5.5mm X 2.1mm Male coming on Friday!!! Cool YES,IT IS 10’!! But I can use it for a few weeks at least until the single pieces come from China!
        WOLFDOG
teacher
teacher's picture
Wolf-dawg….. I crown you—— Power Supply & Adapter Connector —- Finder & Tester Extraordinaire. Crown ….
With the help of your willing & worthy assistant guass163 giving technical advice of course. Thumbs Up
I just ordered one of THESE and two of THESE
I went for the free shipping, but I already have a tracking number for both…. so hopefully that is a good sign. Thumbs Up
Thanks to you and everyone who helped in solving this mystery problem. Thumbs Up
wolfdog1226
AFAIK You should be good to go as long as they send “Us” the right ones!! Thumbs Up
The right angle ones are more beneficial for my use[mentioned in earlier post] and according to their time line and my calculations they will be here 10 to 26 days sooner than the Straight ones from China.
Straight ones I ordered first!
http://www.ebay.com/itm/142340377628
-Then I ordered a 10’ cable w/ the proper connectors from USA [Indiana]! That should be here Friday.
-Then the 90 degree angle ones! I think I will have plenty of adapters! Wink
        WOLFDOG
wolfdog1226
That is why I listened to my Cousin Settimio and got one. Only $3.50 more than my Supernight! Thumbs Up
        WOLFDOG
wolfdog1226
I was meant to have the Lite-on. Cool
The Hitachi was not meant to be. I said I wanted a brand NEW SMPS.Not a USED one like the Hitachi was.
However,along with a BLF members suggestion[can’t recall his name]and before my Cousin Settimio[Electrical engineer] convinced me, I emailed the Ebay Hitachi dealer to see if it was a 2.1mm connector:
Hitachi OEM Genuine 60W 12V 5A ADP-60WB AC Power Adapter Supply for LCD Monitor
New message from: usefulgadget Top Rated Seller(232,595RedShooting Star)
Sadly it is no longer available. We will be doing a sweep later to close these listings when we doublecheck the system for inventory count.
For this item, it was a 5.5mm outer by 2.1mm inner.
Best regards
        WOLFDOG
wolfdog1226
No reason to get defensive.
All I said was I was meant to have the Lite-on. I did not want a used SMPS and the Hitachi eliminated itself by not being in stock anymore. Wink
Here is a breakdown for the credit of my purchase:
Cousin Settimio-50%
Wolfdog-25.1%
G163-24.9%
Thanks everyone! Thumbs Up
        WOLFDOG
Dutcheee
Last seen: 1 day 14 hours ago
I just bought This to be able to use my Opus in the car.
wolfdog1226
Let us know how it works. I hope it serves you well. Wink
        WOLFDOG
