lamps from flashlights?
Not sure if this is the correct forum. Don’t wanna insult the uber geeks.
I would like some ideas about making a simple shade for a flashlight to use it for a lamp.
Something like hanging it from it’s lanyard.
Safety issues (heat) are a concern.
Please point out the obvious.
pics maybe?
thanks
I’ve used Olight S20 with silicone diffuser as a lantern. Works well.
There are different sizes that fit different flashlights
An old-school Fuji film canister is the correct diamter to slip over the head of a 501b IIRC... They are the translucent white canisters, and make a fairly decent budget diffuser if you have one laying around. I treasure my old film canisters...
For some much larger lights cutting the top off of a 1/2 gallon plastic milk jug to the right diameter works as a good diffuser taped onto the light front. Fenix makes a shallow cup shaped diffuser that works with their TK50 and TK60 For indoor lantern use you want a dome shaped diffuser so that you get light to the sides as well as out the front.
Yeah, sounds like a typical diffuser is what you want to try.
-Garry
Most zoomies have sliding heads that can be removed, usually by unscrewing the pill, taking the head off it and screwing it back in. That gives a bare led that illuminates about a half sphere or a little less. You can put that under some sort of diffuser or under a regular lamp shade to get soft general lighting.
I don’t see any safety hazards unless the battery is badly abused or very poor quality.
Dang, I thought I’d have ta roll my own!
Thanks on other comments also.
