Tmart Deal - Ultrafire 668 for $9.99 with coupon code. Good till 10/29/14, See inside.
Here's a deal from Tmart, the Ultrafire 668.
Specifications
Brand Ultrafire
Model 668
Emitter Brand Cree
LED Type XM-L
Emitter BIN U2
Light Color White
Number of Emitters 1
Casing Color Black
Material Aluminum Alloy
Lumen 1000 Lumens
Power Supply 1 x 18650 or 3 x AAA Batteries (Not Included)
Modes 5 (High >Middle> Low > Strobe>SOS)
Switch Type Clicky
Switch Location Middle
Strap/Clip No
Lens Glass
Adjustable Focus No
Dimensions (7.36 x 2.17)" / (18.7 x 5.5)cm (L x Dia.)
Weight 10.34oz / 293g
Package Includes
  • 1 x Flashlight
  • 1 X AAA Battery Holder
  • 1 X 18650 Battery Holder
  • 1 x Charger
Coupon Code is 306ec5d55a
Brings it to $9.99
Good till 10/29/2014
I'm just the messenger
55mm head and some decent looking cooling fins. Looks interesting. Thanks for sharing.
“… Unique switching system may be its most remarkable highlight.
Plus, this flashlight does not support adjustable focus.
Non-thermal radiation, safe, stable and reliable
A portable lighting fairy for outdoor sport, travel, and machinery repairing etc.”
5.5 cm is a big head as ImA4Wheelr mentioned. It’s bigger than C8 and MX900. Wonder about the throw comparison with those.
Didn’t Tmart have issues with owner change and Web site change?
Cannot locate the thread on a site feedback/review/rating.
[EDIT]
The negative TMart comment post in a thread that should not have comments:
FWIW, I ordered 3 items from TMart a year ago without any issues.
Thanks for the deal OL
I can’t help but wonder if the side switch is a momentary button or a physical power disconnect switch.
Nothing special.
Standard bulky cheap flashlight.
You can already see scratched edges on the product images.
tint, pwm and next mode is a big gamble
charging port and side switch is nice - until it gets wet
26650 option would suit its size much more and 3xAA holder would make it an must-have item. It’s absurd thinking of using AAAs in something as big as this.
appears to be reverse-clicky “If you would like to turn on/off the flashlight, you should press the button into 100% end. And there is a click to be heard.
If you would like to change the modes, you just need to gently press the button into about 50% end several times. And there is not a click to be heard.”
Thought this was funny: “Do not meddle with the head of torch or separate the reflector and the bulb”
Couldn’t help thinking that this might be a good host for thrower modding, taking advantage of large head.
Nice light for only $10. Even to use as a host
pilotdog68 - I lived in Iowa for a few years, both in Fort Madison, working at Scheaffer Pen and then I lived in Belle Plain for a couple years and worked in Victor at Victor plastics, which I think got sold off. I miss Iowa. I used to love fishing some of the lakes and larger ponds there.
No kidding. To be honest, I’ve only lived here a couple years, and I’m not much of a fisherman. I’m the type that sits at his desk and reads lots of forums :wink:
Discontinued, ROFL
you will be lucky if Tmart will send them
Able to put in the Cart and proceeded to Checkout.
Could you clarify what your problem was?
Probably temporary
Doesn't show discontinued when I go there. Put one in the cart and checked out no problem.
