Amazon Deal Alerts & Discussion Thread
2606 posts / 0 new
Lightbringer
Lightbringer's picture
Last seen: 57 min 1 sec ago
gchart wrote:
LB, always can be counted on for a laugh. If I have any luck sharpening them, I’ll make sure to disclose my method. Ughh
Well, I had a set of Swiss Army Earmuffs, only I could never stuff them into my jeans pockets.
pennzy
pennzy's picture
Last seen: 2 hours 42 min ago
LOL. Maybe if you can get them rotating fast enough. Mine are coming Fri also. They sound like a good buy. I wish I could get more than one per Amazon account. They would make good stocking stuffers.
Rexlion
Last seen: 2 hours 17 min ago
Lightbringer wrote:
gchart wrote:
Hopefully they’ll be good for mowing or something.
Mmm, you’d probably have to sharpen them first.
They’d take the ears clean off!
kuoh
Last seen: 40 min 18 sec ago
A different approach to mowing and noise cancelation for sure. I’m working on a breakthrough jello hammer invention, just need startup funding from some forward looking venture capitalists. Cash
KuoH
BT100
Last seen: 9 min 42 sec ago
Hi all, is MPOW H18 for $20 a good deal??
thanks
raccoon city
raccoon city's picture
Last seen: 1 min 39 sec ago
^ Good question.
Lightbringer
Whoa… where ya see that?
I paid 30, and like ‘em, so 20 would be an even better deal.
Lightbringer
Looked, H12s 10bux off, with a vipon brings ‘em down to like 14 or so.
Fire-sale at mpow?? LOL
cccpull
cccpull's picture
Last seen: 3 hours 49 min ago
Saw the H12's  with Vipon $13 off comes out to $10.50  The H16's going for $15 with Amazon clip coupon.
Also saw the H20's in Amazon at $39.99 with amazon clip $20 off, total $20.  Mind you I just bought the H10's and have no idea about the difference between those and the H18's.
chops728
Last seen: 1 hour 24 min ago
I received the H12s today— they are very similiar to the H10 —- They look a little more refined—blacked out
They could very well be the same headphones with a different look
I didn’t realize the ANC worked even if the headphones weren’t on
BT100
saw that deal on amazon . 39.99 – 20 off coupon.
chops728
I wonder when MPOW runs out of numbers — will they change the fore letter (H) — Man they have a lot of models
Lightbringer
Sumbitch… I’ve been forgetting to “turn ‘em on” but just kicking in the ANC. Facepalm
Sounded pretty good, regardless. LOL
chops728
Yup—when the wife starts —just click on the ANC—Or maybe we can rename it WNC
kuoh
The power is for bluetooth functionality, if you’re just using it wired, there is no need to turn on anything other than ANC.
KuoH
Lightbringer
Aha. Thought it was a combo of bt and internal amp.
Forgot how my [Bose] QC15s worked (got killed by an alkaleak). Wired-only, no bt, but iirr they needed to be turned on for the internal amp to work. Ie, don’t recall if they worked “passively” with no power. Probably did, but ain’t sure.
caramba
caramba's picture
Last seen: 22 hours 42 min ago
I can’t see on the pictures if the MPOW headphones have a 3.5mm jack and come with a replaceble audio cable (3.5mm on both sides) or the audio cable is permanently attached?
raccoon city
caramba wrote:
I can't see on the pictures if the MPOW headphones have a 3.5mm jack and come with a replaceble audio cable (3.5mm on both sides) or the audio cable is permanently attached?
You might have to read Amazon reviews for the first two questions.
For the last question, if the headphones have bluetooth, the audio cable is not permanently attached.
caramba
caramba's picture
got it thanks
Pete7874
Pete7874's picture
Last seen: 1 hour 40 min ago
Which Mpow model are you referring to?
Lightbringer
All. I’m using the cable from my B3s.
YogibearAl
Last seen: 20 hours 53 min ago
For $10 hope it works for music when mowing the lawn. Smile
Will give it a whirl, compare with some of my other headphones, possibly test on my several headphone amps.
Thanks for posting the deal.
Narmattaru
Narmattaru's picture
Last seen: 1 day 8 hours ago
i found good coupon. that is not flashlight or tech stuff, but discount is good
Nakey Memory Foam Pillow, Orthopedic Contour Ergonomic Bed Pillow with Double Cores
coupon code 34YU6EKC was $69.99 coupon price $39.89
valid until 31 july
"Updated list of Aliexpress coupons and promocodes":http://budgetlightforum.com/node/64307 | "How to choose flashlight, Main things in simple words":http://budgetlightforum.com/node/68418
Rexlion
Music headphones with active noise cancellation won’t eliminate the lawnmower sound (won’t protect your hearing one bit); it might just mask it so it isn’t as irritating. I use regular earmuffs to block the noise when I mow. But then, I already have some hearing loss. (Probably from certain forum members yelling at me from halfway across the globe Ughh .)
Rat_Racer
Rat_Racer's picture
Last seen: 8 hours 8 min ago
1 single 3.5mm jack, on the left can. Also, 1- 1M 3.5mm M/M cable included.
Got my H10’s yesterday. They sound decent for the $. You definitely won’t be going deaf using Bluetooth with your phone volume on high, but is just below too loud to be enjoyable. Sound & vocal definition is pleasantly crisp and a bit neutral.
Lightbringer
Yeh, for actual noise, I got myself a set of osha-rated earmuffs.
caramba
caramba's picture
Thanks for the feedback, sounds like a decent buy, I tend to damage the cable all the time, so a replaceable option is great
Mtonne
Last seen: 49 min 25 sec ago
Got my H10 set yesterday and it's very impressive for $10. Used them before bed last night. Great buy.
Lightbringer
Yeh, these all use the same cable, so you can interchange them at-will.
My QC15s, though, when I misplaced the cable or something (forgot why I had to do it in the first place, or maybe I was just being proactive), I had to wire up my own plug on one end, because the “pinout” was intentionally non-standard. Ground was like at the tip vs at the sleeve, and L/R were reversed, something retarded like that.
Just got’n‘replaced new earpads for ‘em, too, before that hateful little alkaleak took a dump down that hole. No way to get at it without completely disassembling the earmuffs.
So… rechargeable Li cell vs alkaleak? standard TRS-to-TRS cable vs mangled pinout? Ain’t looking back.
YogibearAl
Just got my H10 today. Definitely good for $11 shipped (tax in WA). The microphone is pretty meh, but the drivers are definitely worth it. Clear and crisp. I have some custom 3.5mm cables I use on other headsets, and it also works good without the bluetooth processing of the audio.
Over ear isolation is pretty decent. ANC is ok for around the house, definitely not as good as my old QC15 (with cable and with bluetooth adapter when needed – only used on air planes). But for clarity and soundstage on my headphone amps (Elekit 882 Tube AMP, Massdrop THX AAA 789, and SMSL SH-8), it is as good as some $100 headphones, I would say balanced but a little bass heavy. Enjoyable. Will burn in and re-evaluate.
Definitely not up to $200+ headphones like my trusty Sennheiser HD600 open air headphones (custom cables) Silly
My only complaint so far is the built in microphone, and it clamps my ears a little hard.
Thanks for the post. This so far is definitely worth the $11 spent.
