Springs!!
113 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 39 min 56 sec ago
You don’t want too much or it’ll clog the spring action.
Bocian
Bocian's picture
Last seen: 2 days 9 hours ago
Djozz, very interesting measurements Smile ~0,3V voltage drop for 6A current makes such spring a nice heater :bigsmile: Some time ago I’ve done similar test (for current 3A) and I must tell that Your test doesn’t include one, but very important parameter (surface of electric contact to battery cells terminal). It will be different for every spring (hard to calculate) but also generating voltage losses.
Calmaja
Last seen: 6 months 16 min ago
Thank you again djozz for your contribution to this community. Beer
HarleyQuin
HarleyQuin's picture
Last seen: 1 year 1 month ago
Thx djozz,
that is very very useful testing. Beer
I will braid even more springs from now on.
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
Firelight2
Firelight2's picture
Last seen: 1 hour 11 min ago
What we need is a spring that is composed of a spring steel core with a pure copper outer layer. And the copper layer needs to be more than just a coating. It needs to have some thickness to it. Big Smile
Ledsmoke
Ledsmoke's picture
Last seen: 9 months 2 weeks ago
TY Smile
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
M4D M4X
M4D M4X's picture
Last seen: 1 hour 12 min ago
great test djozz! Beer
(again…)
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
eebowler
eebowler's picture
Last seen: 2 days 1 hour ago
Yes, I think surface area matters. Usually when braiding, I fill the top of the spring with solder then file flat.
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
dthrckt
dthrckt's picture
Last seen: 4 months 2 days ago
very nice test, thanks for posting this
____________________
Girls can shoot!
djozz
djozz's picture
Last seen: 1 hour 4 min ago
eebowler wrote:
Bocian wrote:
Djozz, very interesting measurements Smile ~0,3V voltage drop for 6A current makes such spring a nice heater :bigsmile: Some time ago I've done similar test (for current 3A) and I must tell that Your test doesn't include one, but very important parameter (surface of electric contact to battery cells terminal). It will be different for every spring (hard to calculate) but also generating voltage losses.
What I usually assume is that although the contact surface area may be very small, the resitance is also determined by the length of the narrow section. With two flat surfaces touching, that length is so short that the resistance is still negligible. If one surface is bended (the spring) the resistance may be a bit higher but still very low. Bocian, is there any measured data on this contact resistance? (there must be somewhere).
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 1 month ago
Thanks for the Test! I think steel springs are the best, gold plated or just simply plated. With the braid, (copper or the silver plated stuff), the spring can then be just what it is, a spring and the current will go through the braid. It will also help with heat stress on the spring, so a little longer life span for the spring. Excessive heat really kills those little springs. When you solder the braid on, you can always solder a copper button on top too, for a good smooth contact to the battery.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
wight
Last seen: 2 months 15 hours ago
Hmm, good points OL.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
WarHawk-AVG
WarHawk-AVG's picture
Good call OL
I usually use a hobby file and smooth the solder joint on the braid, I can never seem to make it solder smooth, but a few passes with a hobby file and smooth as silk
djozz
djozz's picture
Being a bit conservative, are you? Wink
I think that if you are DBCstm, TomE or Vinh, you are right, copper braided (steel) springs are the best for high drain hotrods.
On the other hand, if you are Old Lumens and into beautifully made moderate Nichia 219 mods, a clean looking phosfor-bronze spring like the one I tested is just great and mechanically thusfar it seems similar to steel (nice and stiff and 'springy'). At non-critical currents like 2 or 3 A this spring does help to get more efficiency out of the flashlight compared to steel springs, while copper braiding will not be drastically better but will look much messier.
wight
On the other hand, if you are Old Lumens and into beautifully made moderate Nichia 219 mods, a clean looking phosfor-bronze spring like the one I tested is just great and mechanically thusfar it seems similar to steel (nice and stiff and ‘springy’). At non-critical currents like 2 or 3 A this spring does help to get more efficiency out of the flashlight compared to steel springs, while copper braiding will not be drastically better but will look much messier.
OTOH OL uses that flashy 9A driver for stuff: http://budgetlightforum.com/node/34124
DB Custom
DB Custom's picture
the old dude can crank out some mean hot rods of his own! Silly
wight
While we’re both here, can you fill me in on the kinds of problems you’ve run into when soldering to steel springs? EG are there specific springs you had trouble with, was the trouble purely cold solder joints because of the way steel acts, does being plated help, etc. TIA
djozz
djozz's picture
OTOH OL uses that flashy 9A driver for stuff: http://budgetlightforum.com/node/34124[/quote]
I forgot that new powerful side of OL Wink, how could I !!
Tom E
Tom E's picture
Last seen: 5 days 17 hours ago
Thanx Again djozz!!
fellfromtree wrote:
Did the drill a hole through the board mod the other day. So a wire went right to the driver. Anyone have thoughts on the best copper braid to use? This cheap stuff I got probably won't hold up. Pick up some of those copper springs too- have to order some stuff today.
I posted detailed pics (somewhere??) in a BLF thread comparing the cheap stuff to the better grade Chemtronics braid (ex: http://www.techni-tool.com/Top-Brands/Chemtronics-Desolder-Braid). The difference is radical in my opinion in the design, weave, density - it also solder wicks better! I converted from the cheap stuff to Chemtronics, but eventually switched to quality 22 or 24 AWG wire because I feel the wire is still better to work with and holds up better. I've had numerous failures over time of the cheap braid on springs.
Also a big +1 to O-L's post. Most of the time the spring is seems to be 95% of the volt->amp drop of the tailcap - surprisingly  the switch's do pretty well, accept the low budget light ones. I don't have hard #'s to back this up - only from lots of testing of hard-wiring around the tailcap assembly vs. stock tailcap vs. copper wired spring tailcaps.
DB Custom
DB Custom's picture
wight, yes
not plated, it takes so much heat to get the solder solidly adhered that it weakens the spring. plated, the plating starts cracking off. I’ve found steel springs have let go of my bypass, usually on the really cheap lights. Pretty much replace springs as a habit now. Been doing that for a while and really haven’t had much trouble since.
Rufusbduck
Rufusbduck's picture
Last seen: 10 months 2 weeks ago
Thanks for the testing Djozz. Nice how well your spring compares to the much smaller nanjg spring. It looks like the solder points shorten the effective length of the IO spring more than yours.
I wonder if rather than even trying to solder to the spring one just soldered to a contact plate that sat on top of the spring and solder the other end of the wick or wire to the pcb pad. Use the spring for its compression strength and don’t worry about an electrical connection through it. Also, if using insulated wire is it even necessary to go down the inside of the spring.
Scott
Tom E
Tom E's picture
A common technique in spring bypass wiring is the wire outside the spring - depends on clearances, pinch points, etc. which method is better I suppose. I believe vinh uses that a lot, think others do as well. An inner bypass wire certainly is more at risk to reduce spring compression, but I try to carefully test that out. I haven't used outer bypass's much - I'll tend to use a 24 AWG wire in smaller diameter springs. I do though try to get the bypass wire soldered to the pad and spring at the bottom, not just the spring. The top soldering is more problematic. I suppose a nice little copper/brass disc to solder would be a better solution - then that disc gets soldered to the top of the spring. So even for a crappy spring, if the disc loosens from the spring, it would hopefully still be dangling over the spring (could be manually positioned) but if the wire holds well, you still got a rock solid electrical connection.
Downside of outer spring bypass's (in my mind??) is if the top solder joint breaks, that wire is really dangling out there. My thinking would be that under compression, a broken connection for an inner wire would still be making electrical contact somewhat - less risk to ground out on something.
fellfromtree
fellfromtree's picture
Last seen: 5 years 2 months ago
I went with double braids on mine.. Just sent it out this morning.. Goodbye sweet light. I tried DBC method and I couldn’t get the spring to compress enough. I have to try that copper button top OL.
If you have a good electrical path and good copper heat path to the pill, you can go dd without noticeable sag. Smile
Agree with OL- unless you don’t plan to braid. Intl has the best but like 3 bucks a spring Flat Stare Better come with some boobs
luminarium iaculator
luminarium iaculator's picture
Last seen: 3 days 7 hours ago
Djozz,
You are hard worker and you are 100% into your hobby...
Glad that you tested that Phosphor broze springs because I new that they are better than original steel springs only by my luxmeter, always 10-15% more brightness when I swap steel with this phosphor bronze guys (they look like a copper to me).
Your custom spring looks excellent. Need that kind of spring with ∅ 10mm bottom base and 11-12mm height.  This springs are much more flexible than steel ones and they are battery friendly not pressing pcb so hard as steel. Excellent for single cell 18650 lights up to 3A.They also accepts solder paste better so they can be braided or wire bypassed to if needed.
I tried braiding steel springs with braid and wires(contact and switch) but lux results were same as stock until I tried copper bronze ones. I really don't know what happened but lux number instantly jumps.
I only wish to try beryllium copper springs but no one has this puppies(at least at China stores).
I found some interesting suppliers for copper like springs here: http://www.aliexpress.com/item/Free-shipping-Phosphor-Bronze-spring-for-... and here: http://www.aliexpress.com/item/10X8mm-Solid-Copper-Spring-For-High-Outpu...
djozz
djozz's picture
The phosfor bronze springs that you link and the Fasttech one are all about the same size, perhaps they all sell the same bit smallish spring?
bugsy36
bugsy36's picture
Last seen: 7 months 2 weeks ago
Nice springs and nice work! There is nothing wrong with them and given the "actual size" (diameter and length of "wire") you are almost neck and neck with CB springs. If you are willing to dispose of some at the cost you mentioned you may get rid of the majority. I would definitely take a few to a dozen Wink
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
Yes it seems all selling same stuff. There is only difference in their description (copper, carobronze, phosphor bronze).
They should get more sizes for them, and more thickness options although you can rework them with some conical tool (strecth here and stretch there) To bad beryllium springs for flashlight are not broad on the market...
djozz
djozz's picture
Hank of intl-outdoor asked me about the precise height of the tested intl-outdoor spring. I understand he is concerned about tests of the springs that he sells. I post my answer to him here as well because I think that it is fair to tell any concerns about my limited tests.
djozz wrote:
Hi Hank,
Here’s a picture of what happened, left is a non-tested spring, but I did compress it to flat a few times first, right is the tested spring, I unsoldered the leads for best comparison. The untested spring was 5.5mm, the tested one was 4.7mm. That difference is not that great but as you can see it deformed as well (the Fasttech ‘carobronze’ spring did that too).
I just tried to deform an untested spring by compressing it even further than flat and the height is reduced now to 4.7mm as well, it was not deformed now.
I am not 100% sure if the deformation was really caused by the high current/temperature, or that it is doing it anyway when compressed ‘unevenly’ because of solder blobs interconnecting parts of the spring.
It is difficult with such a short spring to see what really happened, I would be curious what a larger spring would do. BTW, it would be great if you would sell a larger spring as well, suitable as tail-spring or larger driver-spring.
My tests on BLF are not scientifically perfect, it is a hobby after all, but I know how influential they can be on the modding community so I try to do them in a good and honest way
I will post this in the spring-thread as well.
Cheers, Jos
Yes Hank from IO should not be to concerned about this issue this is small spring anyway and most of springs will compress a bit especially when they are tight fit with battery.
Springs with bottom base from 9-10mm and height 10-12mm thickness 1mm are most common bigger springs. Hank as your old buyer please get that famous Beryllium copper springs...
For bigger springs my vote goes to this dimension: ∅ 10mm bottom, height 11mm, 1mm(or bit larger) wire thickness which should fit to most tail switches.
or smaller one: ∅ 7mm bottom, height 10mm, thickness 0,8mm (that could replace nanjg spring also)
MustSimon
MustSimon's picture
Thanks for the testing Djozz Smile
