Another 2D Maglite Mod?? Well, maybe this one is just a little different. O-L and C_K team up to do an RGBW Maglite - It Lives!!
102 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
The build is done, as of 11/29/14. Thanks to C_K for making the driver!
Two members were approached by a third member, about doing a Maglite mod. The member who contacted us was rockhound42 and the two members he approached were Cereal_Killer and I.
C_K and O-L will be modding a 2D Maglite. It will have lots of things in it... Lots of different things...
  • File work on the light
  • Copper heat sinks
  • Nichia LEDs
  • RGB LEDs
  • C_K's Custom Driver
  • A Charger built in the light The charger project is dead. It will just be a dummy cell. Maybe a second chance is coming.Wink
I guess that's about it for now, so on to the start of the build...
But first, a little music
OK, let's start with the Maglite
ckol1a
Well, you didn't think I would show the whole thing yet, did you? I've already done the file work, so I won't be showing that till the end. But, it is a Black 2D Incan Maglite.
ckol1b
So we start with a copper heat sink that sits down in the head and a smaller copper heat sink, (the one shown is not the one I will use), for the center 3-up. Then there are some Noctigons and some TIR optics. The large heat sink is made from 5 copper discs and they were soldered together under pressure and brought down to size with the drill press and a Dremel bit. The diameter is made for a tight fit in the head and overall it came out with about 0.005" out of round, which is not perfect, but not bad for hand work either. It will have to suffice.
ckol1c
The 3-up has to be higher than the three outside, because of the difference in the TIR optics. It's going to be 10# of stuff in a 5# light, with all the leds and wiring, but it ought to be quite different when it's fired up. The RGB will be in the center 3-up and the Nichias on the outside.
ckol1d
This is the idea. There's lots to do to make them fit. All the optics have to be shaved down to fit into the 50mm diameter head.
ckol1e
I have the leds too. XP-E for the RGB and of course, the Nichia 219s.
I have all of this in my "mind's eye". This is how I do a build. I look at it and I immediately "see" what it will be. The challenge is finding a way to make it work as I see it. That is sometimes too much for my little mind, but it keeps me going.Smile
I have a long four day week-end, so I imagine it will all be done, except for the custom driver. C_K is working on that already, but I will let him talk about that, when he's ready to go over it with us.
Friday - 11-07-14
ckol2a
The idea for holding the TIR optics is to use a plastic Maglite lens and cut out the openings for the TIRs. The first thing I have to do, is to get them all to fit into the diameter of the lens. They have to be cut down to do that. The center 3-up has been modified, by removing the posts and sanding cut outs where they were, so the outer optics can get in closer.
ckol2b
I did that with a sanding drum on the drill press.
ckol2c
Next thing is to remove the outer lip from the three larger TIR optics, where they will touch the 3-up. I did this with a hand file.
ckol2d
ckol2e
So, the optics are all shaved down and they fit in the Mag lens diameter. I have used double sided tape, so I can flip it over and mark where I will cut out the openings.
ckol2g
I drilled starter holes and then used the Dremel tool, to open them up.
ckol2h
ckol2l
Now everything is in place and it's time to epoxy them together.
ckol2i
ckol2j
Crap! I forgot about the star and the heat sink. They won't fit in any more due to the taper of the outer TIR optics. Well, it's now a triangle shaped star and the heat sink will be too.
ckol2k
I still have a little copper bar stock that was sent to me by another member. It's just about the right thickness, so I might as well use it.
ckol2m
Hacksaws and files make for a nice hand made pedestal.
ckol2n
ckol2o
Checking the stack up, I see that the center heat sink is not tall enough, so it's time to add some sheet stock. 0.025" +or- ought to do it.
ckol2p
Pressure soldering the sheet stock to the heat sink.
ckol2q
The reason I use the pressure, is to get as thin a layer of solder as possible. It makes a stronger joint and solder is not the best heat conductor, so I only want a very thin layer. If it's pressed together while soldering, the seam shouldn't hardly show.
That's all for now. I have been at it from 8AM till 3PM and I need a break. See y'all later.
 11-07-14 7PM
ckol3a
LEDs are reflowed and everything is in the head.
ckol3b
The stack up height was perfect. The bezel tightens down all the way. It won't stay that way, because I have to make a cover plate over that ugly plastic one. I have some brass plate. I probably will make it out of that. It's 0.050" thick, so it's good and sturdy. I just don't want to try to make it with a Dremel. Anyhow, I will probably go and work on the other end of the light for a while. Time for the battery charger project.
 EDIT: Finished the Brass cover for the optics.
4zb1
Since I will not get the light done this week-end and since I said I would show the file work, here is it. The light is going in a specific vehicle and I tried to make it something that would look like it fit in that vehicle.
4w
I don't know what else I will work on now. Probably finish the head and run all the wires. I just can't finish the tail end now, till the parts come in.
11/09/14
Finishing up the head and the battery holder, as far as I can go without the rest of the parts.
ckol6a
I drilled three holes for wires and three more holes for screws, to hold the heat sink down.
ckol6b
The screws go down in between the head and body. That way, the head can't be turned unless the heat sink is removed.
ckol6g
Wired up. 12 wires in all. Each led is individual. The three Nichias will end up being run parallel.
ckol6c
I used a 3xAAA holder and AAA  Alkalines, so I wouldn't give out a lot of amps, for DD testing. Here the RGB are on, but the red overpowers the blue and especially the green. From seeing this, I would think maybe 350mA for the red, 700mA for the blue and 1050 mA for the green, to balance them out, but I know C_K already has it all under control, with the driver he is going to make.
The shots below are just the individual RGB and then the 3 Nichias.
ckol6d
ckol6e
ckol6f
ckol6h
ckol6j
The charger project is scrapped. I ended up ruining the tail cap and two charger boards, so it will just be a dummy cell. I think this dummy can make that much. The Phoenix may arise from the ashes, time will tell, but you know I just hate to be defeated, especially by myself.Tongue Out
 11-15-14
So, I just cannot stand failing on the charger. I have to try again. Of course, it's got to be more involved this time.
usb11a
Since the tail cap was so hard, let's just make it harder and put it in the body!  Well, in some ways, it will be easier. It will go in front of the cell, up against the switch housing, so wires will be easier. I had a piece of plastic rod that was a little bigger than the body of the light, so I split it and worked it down till it is a tight fit in the body.
usb11b
Now the split is not centered, but some things just never go the way you plan, well most things... Actually, it will still work, because of how I will mount the USB charger.
usb11c
I am going to remove the USB socket off the board. I will put the USB socket up in the plastic, as shown in the photo above. The USB is in the upper left corner. I plan on making it so that I can use two small springs under the outside tabs of the socket, so it will be spring loaded.  The board will go over on the bottom right and the wires are shown. I think it will work, but you know how it goes. I will not have the boards till next week, but I just had to post and say it's not over till the fat charger sings. (well I can't say fat lady or I will get in trouble, so fat charger is as close as I can go).
I decided not to separate components, but keep the board whole, see farther down the post for more info.
More when I get more...
11-18-14
The boards came in
az1a
I got 4 of them, so I could wreck 3 and still have one left for the build.
az1b
I think I can fit the whole board in, so I don't have to disassemble it.
az1c
and still have room for it to be spring loaded.    Maybe...
az1d
A little "mill work"
az1d
and the pocket is made for the board.
az1f
Then it's time to cut the spring holes.
az1g
They have to be cut on the other half too.
az1h
Looks like this, kinda, sorta
az2a
Bottom side
az2b
Top side, those springs push up the board and when compressed, they give quite a lot of tension. That's what I want.
az2e
It will slide inside the body tube and when in position, the USB plug should pop up in place, in the slot in the body.
Lots more to do, till it's ready. I just don't have any more time today. Time to go to work!
11/19/14
A little more on the charger assembly.
za1a
18Ga wires are in place for the +/-
za1b
That leaves the problen with the signal leds again.
za1c
I have discovered that I can split a fiber optic down the middle, with a sharp razor blade.
za1d
So, that will allow for the optic to lie flat on the leds and I can use them that way. What I will now play around with is making two spots in the optic, so I can lay one fiber across both leds. That way I only have to run one fiber up and thru. If it works, it will be a cleaner look on the finished light and since both leds don't come on at the same time, it shouldn't be a problem.
That's it for now. It's colder than something in February around here. Oh, I know it's only in the 20s at night, but when it's in the hundreds in the summer, the 20s are too darned cold! The garage is cold as the outside, so no relief there either.
xs1a
The fiber optic is in place. I used clear epoxy first and then used JB Weld over top, to contain the light and hopefully make the fiber brighter.
Now it's time to go make a hole in the body... Hope this works out.
11/21/14  The charger is DONE!!!
ch1a
The cap is just a rubber Micro USB dust cap that I have pressed in so it stays in place and seals fairly well. It's not the best, but it does work till I figure something out. The port is on the underside of the light, 180 degrees off the switch.
ch1b
The socket popped right up in, once I got it aligned in the hole. The spring idea worked nicely.
ch1c
The fiber optic was the best part of this mod. Here it is, with no charge. The hole is filled with epoxy for waterproofing.
ch1d
Same optic with a charge. Both leds shine out the single fiber optic.
You will never know just how relieved I am, that the charger mod is over.
That is all till the driver comes in. I am done until then! I am so happy I could..., well never mind.
 11/29/14
Here's the rest of the story.
ck1a
The driver cam in today. C_K sent me a spare and had it all marked out for me. Ha! I guess he took me seriously when I told him I would get lost wiring it up. Good for him.
ck1b
Here's a couple photos of the driver he sent.
cj1c
ck1d
and I printed out the instructions...   5 pages, LOL.  Well, I used larger font, since I can't see all that well any more, but it was a waste, since I'm so dyslexic that I can't read it anyhow..
ck1e
I put 2 vises together, so I could hold everything and get all the wires on. 16 wires all together. Which one was next again?
ck1f
All wired and ready for testing.
Here's a short video to prove it actually worked. I still can't figure out how to makr it run through all the modes. As I say in the video. To me, it's too complicated if it has high and low and off.
 ch1a
 The final test - Charging a cell in the light. It charged to 4.12 volts.
Glamour shots
d1a
d2a
d3a
Beam shots tonight, at least with the white leds.
That's it folks.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 11/29/2014 - 17:31
Old-Lumens
Just the Nichias.
nb1
nb2
nb3
I can't get the color leds to turn on solid, no matter what I do. I don't think this momentary switch is going to work. It's an SMD momentary and under the stock rubber button, so it's not as "fast" or reactive as it has to be, to get from one mode to the other. I also think somehow I shut off the colors part of the program, but for the life of me, I can't figure any of it out. I imagine. I can't change the switch now. Not without a complete rework of the whole light and I am not going to do that. I may write to C_K and see if he can do another driver with "slower presses", cause this one ain't happening.
MRsDNF
MRsDNF's picture
Last seen: 12 hours 19 min ago
Interesting. On a side note they dropped the charges. Not the drug ones though.
Edit. This is going to be as unique as anything you have built pushing the imagination again. You gotta love that. If your going to hide your lights from public view its about time you had a body double light. The colored tir's what angle are they and where did they come from as they dont have the outer cover of the more common variety we see. Have fun on your four day weekend. We had one last weekend.Smile
WarHawk-AVG
WarHawk-AVG's picture
OOOOH this is gonna be GOOD!
subscribed for sure Smile
djozz
djozz's picture
Last seen: 1 hour 18 min ago
That is a fantastic build you two are doing, with your combining expertise this will be great project.
One suggestion, (I guess the three Nichia's will be parallel), this picture...
...makes it clear: go for 6 Nichia's parallel instead of three, that will be a bit more efficient, but mainly it will look better IMO.
Ricflair
Ricflair's picture
Last seen: 1 year 3 months ago
Gonna follow this one! I like where you are going here.
Also the ACDC link was kinda funny.
Link from yesterday.
http://www.foxnews.com/entertainment/2014/11/06/prosecutors-drop-murder-...
RicFlair is on the air with blonde hair & pink underwear!! Whaoooooo!
pyro1son
pyro1son's picture
If you rotate the triple board 60 degrees in one direction you could shave out where the posts on the triple optic is saving damage happening to the opitcs?
Pastebin                                      &nbs
RaceR86
RaceR86's picture
Last seen: 4 years 1 month ago
Weee... A "classic" Old-Lumens maglite mod thread. Something truly new and unique.. What`s not to like. Ill be following this build! Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Triple A
Last seen: 1 year 6 months ago
ANOTHER O.L.  ...... Amazing build .....
Watching with anticipation .....
Thanks O.L.
Cereal_killer
Cereal_killer's picture
Last seen: 3 months 2 days ago
I’ve got the driver ordered, 30 7135’s (15 for the nichia’s in parallel, 5 each for the XP-E2’s) on a 33mm board was NOT easy (they fit ok but routing was a freaking nightmare). I’m not gonna post render’s, I’ll just wait till the board’s are here and built and post pic’s.
Old-Lumens
True, but also space/fit is a problem, as pyro1son, in the next post, already touched on. The three outer TIR optics will fit into the three areas in between the triple optic, so that the outer TIRs don't have to be flattened on one side and possibly mess the beam up. The areas where thew three posts are, on the 3-up TIR could be hacked out because that TIR can just sit down on the led subsrtates of the three leds. All of the TIRs will be held in a top ring of some type, as I have done before. I don't know if it will be metal or plastic yet.
Cereal_killer
Justin, will you be able to see threw the lens down to the MCPCB’s or will the top ring / holder block the view?
This light is so full of awesomeness it almost deserves a setup like Matt did on his Medusa but with cutout’s for the MCPCB’s.
Old-Lumens
C-K, once the top plate is made, you won't see into the head. It will be a metal plate. Right now you can, but that will be covered, for a cleaner look.
Triple A
Hey O.L.,
Have you ever put a clock on your creations ? Maybe you wouldn't want to know how many hours it takes, a real "Labor of Love" to complete.   How 'bout a little tease of your hand file work on the body ?
What kind of beam pattern do you expect?
(hope your videoing for your YouTube channel)
FmC
FmC's picture
Last seen: 7 hours 24 min ago
Some real nice work going on here, love it! Beer Beer Beer
fellfromtree
fellfromtree's picture
Last seen: 5 years 4 months ago
I think the trick to singing like that is to always be squeezing one out Smile then you become micheal bolton..
This is gonna be pretty cool looking.. I know CK knows his stuff on the rgb end- I like that copper block you made.
WWW
Last seen: 2 weeks 1 day ago
Two great modders joining forces is too much awesomeness for a saturday morning!! If you guys don’t mind I would like to know if instead of going RGBW, is it possible to add a UV emitter (or whatever they’re called)? Something like a RUVW? Sorry for hijacking the thread, looking forward for the results.
gamezawy
gamezawy's picture
Last seen: 1 month 20 hours ago
Modders union wow , now i wish to live in the US nice and creative mod you doing there my eyes will be on this build
Old-Lumens
Triple A wrote:
Hey O.L.,
If I put a clock on my light builds and/or charged by the hour, well, it wouldn't be pretty.
I will post the file work, by the end of Monday, because the light will be done, to the point of awaiting a driver by that time.
These are all TIR optics, so the beams will be smooth across and floody. Just an even lighting. It won't throw, but it should light up a good wide area in front.
Old-Lumens
WWW wrote:
Two great modders joining forces is too much awesomeness for a saturday morning!! If you guys don't mind I would like to know if instead of going RGBW, is it possible to add a UV emitter (or whatever they're called)? Something like a RUVW? Sorry for hijacking the thread, looking forward for the results.
I imagine UV could be used, but C_K would know better about that.
ImA4Wheelr
Last seen: 1 week 4 days ago
Very awesome.  Two powerhouse modders at work.
Old-Lumens
11-08-14 More progress in the OP.
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 2 weeks ago
Pretty cool. I have some of those charge modules on the way myself. Great file work as always.
Scott
gaston01
gaston01's picture
Last seen: 4 months 3 days ago
Congratulations! Great job Wink thanks for sharing Smile
Sorry for my bad English…
MRsDNF
MRsDNF's picture
Fibre what? Yes I need pics to understand it, thanks. I'm a bit bedazzled to be honest. Smile
Old-Lumens
Finished the brass cover for the optics.
axsw
I'm done for the night. Going to go sit down and relax.
Old-Lumens
Fiber who?
fib1
Triple A
Seriously O.L.   somebody at Maglight should put you on payroll as a Consultant, Chief Designer, something ....
There sales would explode, (in a good way) .
Thanks for sharing, looks AMAZING.
MRsDNF
MRsDNF's picture
Why is the cover plate looking immaculate? It should be full of crease marks and an odd looking shape. Are you sure you dont have a laser cutter out back hiding with your elves? So the light is going to have fibre optic feelers. Neat. Tongue Out
wight
Last seen: 2 weeks 2 days ago
C_K and O-L will be modding a 2D Maglite. It will have lots of things in it… Lots of different things…
  • Copper heat sinks
  • Nichia LEDs
  • RGB LED
  • C_K’s Custom Driver
We don’t always get the luxury of a lot of new & different stuff around BLF. This project is refreshing!
You can’t really do UV behind plastic windows or TIR lenses as I understand it. You must use a reflector and a glass window.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
musicmagic
Last seen: 5 years 1 month ago
hmmm. You say the light is going in a specific vehicle, my first thought was a charger. Am I right?
If you can’t blind them with your brilliance, baffle them with your bullcrap.
The real currency in the world is not money, it’s trust.
