KronoReview: Cigar C2 Powerbank/Flashlight-Revised rating
KronoReview of the Hasky Cigar C2 Powerbank . This item was provided by samilou/EachBuyer for review.
www.ihasky.com
Hasky Cigar C2 product website.
EachBuyer regular price: $19.99.
KRONOREVIEW:
The Cigar C2 is a single 18650 powerbank mated to an XP-E R3 light. The flashlight comes with a Changjiang 18650 battery (same company that makes BAK) with a claimed 2200 mAh rating, USB charging cord, useable English manual all in an attractive retail box.
The flashlight ‘head’ easily attaches to the powerbank battery section via the USB port. Interesting that Manufacturer lists lumens at 80-90 lumens, and EachBuyer ‘upped’ the lumens to 350…hmm. At least they didn’t rate the battery at 6000 mAh :wink:
PROS:
Nice, anti-roll design.
Clean look with comfortable, rounded edges. Like the mfr. website says, Apple inspired design.
Glass lens.
Solid construction.
No blinkies.
Battery change is easy with coin or even your thumbnail.
Can replace with your own favorite 18650 battery if desired.
Charge your devices when no outlet is available.
Reverse polarity protection (confirmed).
Over-discharge protection. (not confirmed).
Edit: Changjiang batteries test well on OPUS charger. Rated at 2200mAh. Actual 2427 and 2342 on my two samples.
CONS:
Flashlight is one mode only.
Not tremendously bright, but decent considering it is a powerbank first.
Questionable battery quality(unknown brand).- -Edit: Changjiang brand battery.
Not much of a thermal path for LED, but shouldn’t be a problem with low amps.
EACHBUYER WEBSITE SPECS:
“Function: it can be used as power bank, high-bright LED torch and battery charger.
Features:
  1. With CREE LED parts, 320~350 LM, 200~250 meter lighting distance, it can be used to business traveling, camping, climbing late at night.
  2. Standard 5V/1A input/output, strong compatibility for mobile digital products.
  3. Replaceable, removable & rechargeable battery, longer life and safer usage.
  4. Intelligent circuit system with six protection design: wrong polarity, over charging, over discharging, short circuit, high temperature, wrong contrary connecting.
    Intelligent Design:
  5. Self-test Function: If battery stuffed into the right direction, after 5 seconds, the LED light will automatically on. If wrong, no response.
  6. Auto Shutdown: no connection with USB port for 30 seconds, it will shutdown into the power saver state.
  7. Power Saver Setting: while working, LED light will auto-off after 10 seconds and enter the power saver state.
  8. Coin screwdriver: replace the battery with a coin.
    Using Notice:
    -Please refer to the operation for actual data.
    -Once you find it doesn’t work, please check as followed:
  9. Confirm whether the cable is suitable or not and cable connection is right or not.
  10. Confirm whether the negative and the positive of battery.
  11. Confirm whether the power of battery is enough for working.
  12. Confirm whether the button is tighten or not.
  13. Install the battery, connect with PC USB port for charge testing, check whether the key is lighting.
    -Due to power conversion efficiency lose, the power bank’s capacity is not as large as chargeable capacity.
    -Do not open or puncture it and expose it to fire, high temperatures, water or corrosive substances.
    -Please stop using and change the battery immediately if there is any leakage.
    -Children must use under the guidance of parents.
    -Protect your eyes from glare light.
    Exterior Color: Black
    Material: Aluminium Alloy
    Light Color: White
    Light Mode: Constant On
    LED Quantity: 1 x Light Emitting Diode
    LED Type: CREE R3
    Lumen: 350LM
    Battery: 1 x 3.7V 2200MAH 18650 Lithium Battery (detachable)
    Specification: 13.3 x 2.3 x 2.3 cm
    -The switch is in the middle.
    -Micro USB input port (DC5V,1A), USB2.0 input port (DC5V,1A)
    -The function of the portable power: when connecting the mobile phone or other digital products by the cable, you can press the button once then the indicator light is on and the portable power bank is working. Press it for 5 seconds to shut it down.
    -Illumination function: press the button once then the indicator light is on and the light is working. Press again for 5 second to shut it down.
    -Battery Charging: when connecting the computer or USB charger, the indicator light is flashing (red). When the color changes to green, it means it is fully charged.
    1 x Flashlight
    1 x Micro USB Cable
    1 x English Instruction Book
    Packaged in colorful box”
KRONOPICS:
Standard packaging.
Standard white foam packing.
Box a tad crushed…no harm to powerbank.
What was inside.
Headstand view. You can see the coin slot battery access door.
Front of head/emitter view.
Tailstanding and on.
Front view/on.
Side views/on. (Note: Beam is not blue as in this pic. Camera exposure must have been off).
Head removed, charging head exposed.
Charging plate removed.
Driver exposed!
Flashlight head removed.
Pill removed.
USB side of pill.
Star lifted. Thermal grease underneath.
Head with o-ring and reflector.
Plastic reflector. 1/2 orange peal (O.P.) and 1/2 smooth.
Included Changjiang brand battery.
Battery and inside of battery door.
Battery w/o wrapper. White spacer, but no writing anywhere on metal. Anyone know who mfr. is?
Edit: Batteries are from Chinese manufacturer Chiangjiang. This battery is rated at 2200mAh, but tested higher as you can see above. I’m shocked!
Charging via USB.
In hand.
BEAM SHOT:
!http://i42.photobucket.com/albums/e331/krono_logical/100_0941_zpsa2604220.jpg !
Control shot.
From approx. 50 yards away. Beamshot does not do it justice. Much brighter with nice spill.
SUMMARY:
I like the idea of mating of an LED light with a powerbank. Although not an original idea, this one is done reasonably well. The flashlight head fits snuggly into the battery base, and should stay there without fear of popping off randomly. The beam has a nice, tight hot spot with a reasonable amount of spill (provided by a hybrid-type reflector). Tint is definitely Cool White. My DMM measures tailcap current at .5 amps. Pricing seems reasonable considering the overall quality of the components and attractiveness of the shell, but perhaps could be a few bucks cheaper. My only big reservation is the questionable Chinese made Changjiang battery that is supplied with the unit. Edit: 2200mAh Changjiang batteries actually tested higher than rating. My two samples rated at 2427mAh and 2342mAh. Nice!
Patented KronoMeter rating: 4 out of 5 stars.
(Rating raised from 3.75 due to positive mAh testing of supplied battery)
I updated review and revised my rating due to the positive battery test on OPUS charger. Battery rated at 2200mAh, but actually tested higher.
Updated in OP/review.
I like the fact that your able to swap in your own 18650.
Yep…and EASY to do. Simply unscrew the back plate with a coin, drop it in and you are good to go.
I had missed this nice and thorough review when it came out, thanks! That is a pretty nice design! Did you came across a charging chip of any sort, that takes care of a correct charging process? I can't see one on the pictures.
“Charging chip”? The only electronic components are the items in the pics above. Maybe I missed something?
Nice!
Is there any electronic components on the back side of this image?
Definitely an interesting setup…did you check the cutoff voltage of the charge in portion, and the charge current?
Wonder if a spring bypass could help (even though the output is 5vdc thru a resistor bridge)
Thanks…for $10~ I would get a few of these, they just don’t look like $20 lights to me
$12.20 at fasttech for C2, $14.24 for C3
https://www.fasttech.com/products/0/10007972/1702003-c2-cigar-style-3-in-1-led-flashlight-mobile-power <-black
https://www.fasttech.com/products/0/10007972/1702002-c2-cigar-style-3-in-1-led-flashlight-mobile-power <-silver
https://www.fasttech.com/products/1601/10007972/1702001 <-C3 black
Does anyone have one of these? http://www.gearbest.com/led-flashlights/pp_236474.html
I wonder if this is as good as the C2 and C3…
