Carbide Lights
25 posts / 0 new
Richwouldnt
Richwouldnt's picture
Last seen: 10 months 1 week ago
Location: Reno, NV, USA, Terra, Sol, Milky Way, Known Universe
Carbide Lights
Someone mentioned these a bit ago so I did a bit of web searching and came up with multiple sources. One of the more exotic, and expensive these days, forms of lighting but still apparently used by some cavers.
Made in India. https://www.lehmans.com/c-31-carbide-lamp.aspx
Petzl Aceto Carbide Lamp: http://www.amazon.com/Petzl-Aceto-Headlamp/dp/B002IAHGWK/ref=sr_1_1?ie=U...
Petzl Ariane Headlamp: http://www.amazon.com/Petzl-Ariane-Headlamp-One-Size/dp/B002SQCSB8/ref=s...
The Ariane takes up to 400 grams of carbide per the description so is apparently sizable.
I know that I have seen a number of pre WWI cars and motorcycles with carbide lighting. Pretty well gone by about 1912 for cars due to electric starters requiring a sizable generator and battery. Motorcycle use lasted a bit later.
Rich Wood
Reno, NV
Mike C
Mike C's picture
Last seen: 7 hours 8 min ago
I have a Petzl Ariane which I have used for caving. The flickering flame gives of a very pleasant light, triggering a primal feel of comfort from fire. In cold caves we can all put our helmets in front of us and stand in a ring around them to get a little warmer. Sometimes this little moral booster is surprisingly effective.
It is however a pain in the *** in tight squeezes, and can leave ugly burn marks if your head is too close. I generally don’t bring it, but if I’d be going to a cold wet cave and knew that others would be bringing them I would, just for that little campfire feeling during a break.
Fritz t. Cat
Fritz t. Cat's picture
I suppose carbide cannon must still be available. They are mostly cast iron with water and flint. My son’s could shoot a Star Wars action figure across the yard.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
hank
hank's picture
Last seen: 1 hour 15 min ago
What kind of carbide cannon? I’ve always wondered if the “Conestoga” company was lying when they say
“*Big-Bang® Cannons won’t fire projectiles. Putting objects in the barrel will only inhibit the full effect of the cannon’s blast.”
Richwouldnt
Considering that they use the same general principle as a potato gun, or even a true gun, I suspect that it is BS. The problem might be to get adequate blocking of the barrel by the projectile if the front opening is necked down compared to the barrel behind it. You need decent sealing between the projectile and barrel.
Rich Wood
Reno, NV
IN Caver
IN Caver's picture
Last seen: 2 years 9 months ago
I’ve used a very old Justrite lamp for caving. They do give off a nice light but man they smell like crap.
Streamer
Streamer's picture
Last seen: 2 hours 47 min ago
LOL...yep..that's Acetylene gas they give off...big stinker for sure.Sealed
DanielM
DanielM's picture
Last seen: 2 weeks 13 hours ago
LOL we used to use artisanal carbide cannons primarily for noise during winter holidays when I was a kid. Try to do that now and you’d probably get in jail or worse.
We used carbide burners when camping in the Danube Delta for light cooking and such. Great use of carbide but not very safe.
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
djozz
djozz's picture
Last seen: 10 min 4 sec ago
Ah, this is about carbid cannons now Smile
In the Netherlands old milk churns are used as carbid cannons, with a football pressed in the opening for the right pressure build-up, they shoot the ball 100+ meters away. It still is a national pastime everywhere outside the cities, although milk has not been collected in milk churns anywhere for decades now.
Racer
Racer's picture
Last seen: 2 years 7 months ago
Love the photo, but that thing does look a little scary. Was that everyone’s EDC in the 1800s?
DanielM
DanielM's picture
Or you could stick a piece of carbide in a plastic bottle with water, put the cap on then run away. Don’t try it folks !!!
djozz
djozz's picture
DanielM wrote:
Or you could stick a piece of carbide in a plastic bottle with water, put the cap on then run away. Don't try it folks !!!
The blast is aided by some sort of ignition Smile
Mike C
Mike C's picture
I’ve heard of cavers running out of water and peeing in them… Now that’s a smell I’d rather not experience!
texaspyro
Last seen: 1 year 3 months ago
Gotta love the Dutch…
texaspyro
The one thing you don’t want to do is fill a beach ball/inner tube from an oxy-acetylene torch. Some lady did that around Austin a few years back (thinking it was just compressed air). Blew up in her car and totally shredded it. And there was a guy that did it on purpose in his back yard… broke just about every window for a block around.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 weeks 4 days ago
Carbide lights..neato
Wanna see something crazy…Google “Punkin chunkin”
texaspyro
Real men toss anvils… http://en.wikipedia.org/wiki/Anvil_firing
WarHawk-AVG
no no no
Real men CATCH anvils
Big SmileBig SmileBig Smile
That’s some wicked cool stuff blasting an anvil in the air for sure
texaspyro
People take anvil shooting rather seriously. Precision machined surfaces, etc. People put thousands of dollars into their anvils.
A friend of mine makes cannons. You can shoot a golf ball up to around 7 miles. Past that and the cover comes off. He also has one that shoots D-cells.
hank
hank's picture
I saw a report today that the huge explosion in China involved calcium carbide — that’s the fuel used by miner’s lamps.
CaC2 + 2 H2O → C2H2 + Ca(OH)2
C2H2 is acetylene gas. Inside the miner’s light, as the gas evolves it quickly pushes out any air, and the stream of pure acetylene coming out of the tip burns.
But acetylene mixed in air is explosive over a wide range.
One common experience using a miner’s lamp for caving I recall was — they’re ignited with a little spark made by turning a rough steel wheel on a flint (typical mechanical spark lighter). Cup your hand over the reflector, feel the gas, whip your hand away over the spark wheel. POP and then a flame. If you did it too quickly, sometimes some acetylene in the delivery tube behind the flame tip would POP throwing the tip out (it was a press fit tip, as a safety factor, so you wouldn’t blow up the brass container).
Chasing down those little tips was — something to plan not to need to do.
The report on the China explosion mentioned that the firefighters knew there was calcium carbide in there somewhere but not where, so they had to keep pouring water on the fire.
hank
hank's picture
Well, here’s a new gas source:
https://www.newscientist.com/article/2142693-nano-aluminium-offers-fuel-...
Put crumbs of that alloy in the bottom of a carbide lamp, light it, and you’ve got a hydrogen flame coming out the tip.
Nowhere near as bright as acetylene though, and not particularly useful for illumination:
http://www.nature.com/nature/journal/v5/n128/abs/005461d0.html
A possibility for cheaply refueling internal combustion engines though.
Just shovel the metal alloy in, add water, burn the hydrogen for energy, and shovel the powdered aluminum hydroxide out of the exhaust bin.
x8353
Last seen: 7 months 1 week ago
1964 or so, I got a new Justrite carbide lamp. Tested, demonstrated, used it on a few Boy Scout camping trips, then broke something off in the tip. Got it down from the attic a couple of days ago, cleaned up lamp, polished reflector, soaked the tip in alum solution and cleared it out.
It works.
DSC00694
Little or no odor unless the carbide compartment is leaking, no smoke, no flicker.
Kindle
Kindle's picture
Last seen: 2 days 5 sec ago
Robowski
Robowski's picture
Last seen: 1 month 1 week ago
I remember as a child in South Africa in the 60’s there were still carbide lamps around. Being a large gold mining country, some were still used on the mines. A lot of the poorer people still used carbide lamps for bicycle lights, but the newer lights were generator driven off the wheel of the bike.
Batteries were expensive and had little capacity in those days so I don’t think many people would have used them in flashlights as bike lights.
Kids were obsessed with making explosive devices, and fire crackers were still legal to buy.
On the 5th of November (Guy Fawkes night) we used to have huge fireworks parties and displays.
My older brothers used to buy carbide at the hardware shop to make some sort of cannons out of old coffee or baby formula tins.
By the time I joined the scouts and got into camping, we used LPG cylinders with cooking or lamp attachments.
These gas lamps became very popular for many years before batteries became as advanced and affordable as they are these days.
samreg77
Useful thread
