Lowe's Lux Pro MAX 2D LXII flashlight Video tear down, + photos and Mod to MT-G2/6xAA NiMHs - Beam Shots are up!
34 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
Here is a video tear down of the $12.97 at Lowe's right now, Lux Pro MAX 2D LXII flashlight.
Along with the video are some photos and then a quick mod.
Mod components are;
MT-G2 on 20mm Noctigon
Q-lite 3040mA driver with zener mod ( 3mode - L/M/H)
6xAA Battery holder
qaa
qab
Tail Cap
qac
Body
qad
Switch from Bat end
swaz
From front end
qae
qaf
 qaza
led side of pill
qazb
Driver side of pill
qazc
Driver
MOD
zab
MT-G2 on Noctigon, Q-lite Driver
6aab
6xAA battery holder, series
zaa
Qlite with a 20mm blank board for the contact plate
zac
zad
Driver in place
zaf
LED in place - it's 22ga teflon coated wire
zag
Reflector opened up. The reflector can't be opened up to go over the die substrate, because the led end of the reflector is smaller around than the die substrate square. Also, it would change the stack height too much.  I also sanded down the back of the reflector, to make the seat thinner.
zah
zaqa
Finished. It was very simple to do and if you use two 26650, it's even easier, cause you only need the 26650 sleeve instead of making a holder.
One spring it for the Li-ions and the other is for the 6xAA holder. The shortened spring was a cut down out of a Maglite D.
Beam Shots
The beam shots will be of the Stock light, the 1D mod and the MT-G2 mod. The stock light and the 1D light will be mouseover photos. Stock will be Mouse Out and 1D will be Mouse Over.
m1
mt1
The photos above are at 1/125 of a second shutter speed, to show more of what the hot spot is.
m2
mt2
These three were done at 1/25 of a second shutter speed.
m3
mt3
The three photos above are at 1 second shutter speed
m4
mt4
These last photos are at 2 seconds shutter speed.
The MT-G2 pulls a little less than 3 amps with 6xAA and it pulls 3020mA with my Sony 26650
I do not understand the 1D. I put one of the led4power drivers in it and it will barely do 3 amps on high. I have double checked everything and can't find a problem. I also cannot get any turbo. I thought it was supposed to have turbo, but maybe I just need to go read again. My Sony cell will do 10 amps flat out, so it's not the cell. I just don't get it, but it's not impressive like it should be.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 11/23/2014 - 20:41
will34
will34's picture
Last seen: 9 hours 10 min ago
Great mod! I like how these assembled lights targeted for the “average consumer” are easy to mod.
Does it handle the heat well at 3A?
Old-Lumens
It does pretty good. Better than I thought. No matter what, with an MT-G2 it will get hot fast, but the pill and the section it screws into are fairly thick, so there is quite a bit of mass there.
MRsDNF
MRsDNF's picture
Last seen: 2 hours 5 min ago
Very nice mod. Have you completed any run time tests with it? I gave up trying to run an MTG-2 with 8 Eneloops and the cheap five amp driver. It kept blowing drivers up.
dchomak
Last seen: 1 year 9 months ago
Nice tear down vid.
By now you just have in stock most any part to mod any light. Smile
How about some beam shots of the modded light compared to the unmodded one?
Edit:
Good news for modders. When I did my tear down, I noticed and forgot to check. The plastic reflector that comes with this light, shaped for an XP-G2 is the same width and height as the aluminum XM-L reflector in the C8’s.
The XM-L shape is optimized for the the larger XM-L and therefore should be a closer match for the MT-G2.
Also the glass lens for the C8 is a perfect fit.
It doesn’t look like it from this pic but the height is the same. This reflector and lens will drop right in.
ImA4Wheelr
Last seen: 4 days 8 hours ago
^ Very excellent discoveries and report dchomak.  Thank you.
O-L,
As always, you make some of the best tear down and mod threads.  All kinds of good info in your words and pictures.  Love all the power options your light has.  That 6AA holder you made here is already coming in handy.
Old-Lumens
dchomak wrote:
Nice tear down vid. By now you just have in stock most any part to mod any light. Smile How about some beam shots of the modded light compared to the unmodded one? Edit: Good news for modders. When I did my tear down, I noticed and forgot to check. The plastic reflector that comes with this light, shaped for an XP-G2 is the same width and height as the aluminum XM-L reflector in the C8's. The XM-L shape is optimized for the the larger XM-L and therefore should be a closer match for the MT-G2. !  Also the glass lens for the C8 is a perfect fit.  This reflector and lens will drop right in. !
Yep, when I measured and found it was 41-42mm, I just about knew C8 would work. I just don't have any C8 stuff as I hate those lights, LOL. I will do beam shots tonight. It has been raining, so I held off.
Sirius9
Sirius9's picture
Last seen: 1 day 4 hours ago
That black thing on the driver (end of the video) is probably reverse polarity diode…
Stittville Ed
Stittville Ed's picture
Last seen: 10 hours 39 min ago
I have been Banned from buying anything until after Christmas by my Wife.
She claims that I am to hard to buy for………………..
But I did get a call from her while she was at Lowe’s asking for the details on the light.
She did pick up 2 for me and they had the XP-G2 emitter.
So now the wait begins for Christmas, much like ordering a light from China Smile
Old-Lumens
1d
Cut down for one Li-ion 26650 or 18650. led4power driver with turbo. XP-G2 with the dome shaved off and on a Copper mcpcb.
Beam shots tonight of a stock light, the MT-G2 light and the 1D light.
Stittville Ed
Justin,
Great job on the video and other information on this light Smile
I like the idea of the MT-G2 using the two 26650 batteries.
What is the story on the reducer tube to make the 26650 batteries fit????
Thanks
Old-Lumens
Stittville Ed wrote:
Justin, Great job on the video and other information on this light Smile I like the idea of the MT-G2 using the two 26650 batteries. What is the story on the reducer tube to make the 26650 batteries fit???? Thanks
Keeney Mfg. Co. 12-in Plastic Straight Coupling  just cut to fit and use an O ring or two around it, for less play.
Stittville Ed
Thanks for the info and for some strange reason I think that I have something like that in stock.
ImA4Wheelr
Oh my, that shorty looks great.
Turby3Pots
Turby3Pots's picture
Last seen: 2 weeks 1 day ago
Do yall think it’s possible to use blf20dd-z in this application?
Old-Lumens
Beam shots are in the OP now. Stock light, 1D light, MT-G2 light
Martini
Martini's picture
Last seen: 5 months 4 weeks ago
I sometimes don’t know if it’s a good or bad thing that I live 75 miles from the nearest Big Box Store.
scdaf wrote:
It’s important to have your restraints within walking distance, lest someone needs restraining. Wink
texaspyro
I’m waiting for you to mod a Taco Bell burrito with an MTG2 … Party
Old-Lumens
Brrrrrrpppp!
Turby3Pots
I am posting to say that I went to Lowes today, got the light. It is different. The driver is different, and the driver retaining ring does not unscrew; it is a press fit job (that I managed to mangle trying to “unscrew”)
ImA4Wheelr
^ Hmm, is that one of the older XP-G (Not the newer XP-G2) model?  The pill looks different then both models though.
dchomak
When I revisited my store this morning, I finally located the original display of these lights. Remember up until now they came thru with an XP-G. This new deal has the XP-G2. Here is a pic of both versions and the bar codes on each package is identical. That means both will ring up at 12.97, but what we all want is the newer XP-G2. Just make sure the one you grab is the right one.
Stittville Ed
I did stop at Lowe’s today and near the checkout cash registers they had the older XP-G lights for the higher price but on the big display with the signs that say Christmas Gifts For Under $…. they had the newer XP-G2 lights for the lower price.
So you have to look before you buy with both being available.
Turby3Pots
Yes it appears I didn’t pay close attention!
And I knew OL had said xp-g2.. Wondered why different
Stittville Ed
Take them back for a refund or a exchange.
xjsnake
xjsnake's picture
Last seen: 7 months 1 week ago
My local Lowes only had out the XP-G (which I bought one of) version till yesterday when they put out a display of 50 of the XP-G2’s of which I promptly bought 4 and will be returning the XP-G version.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 5 months 3 days ago
Excellent review and mod OL…if anyone can make a silk purse out of a sow’s ear you can sir.
Any pics on the 1D mod (walkthru)?
Awesome…simply awesome!
Turby3Pots
Would 26700 king kongs fit in this light?
What high drain batteries will fit if not?
Old-Lumens
wdkingery wrote:
Would 26700 king kongs fit in this light? What high drain batteries will fit if not?
With two cells? If you do the MT-G2 way and use 2 Li-ions, they have to be unprotected cells. A shorter spring is needed for protected cells. I still use my Sony flat top cells, which are discontinued, but high drain 18650 could be used too, with the proper sleeve. The spring has to be shortened to keep from damaging cells from excessive spring pressure.
EDITED: to correct my comments.
Turby3Pots
Let me ask you,
Which 2 26650’s would you buy from Richard to run an mt-g2 in DD with the 20mm fet driver with zener mod in this light?
Old-Lumens
I will correct my statemrnt. Protected will fit, with a short spring.
The D cells are standard D cells. 34.2 × 61.5.  You could drop yours in, but the spring is very stiff. I would suspect you will damage the end of the cell. With a very weak spring, it might be ok. I had to shorten the spring. I shortened it so protected cells will barely fit in and unprotected still touch the spring. Just try your cells and see how much room is left. It's the best way to know for sure. I suspect they will be tall enough that they will be going into the tail cap a hair and that would definitely need a shorter spring.
