Gearbest New Arrival: March 22nd, Convoy H1 CREE 29.99$
Dear folks,
GearBest New Arrival is running now in this thread, we will update it when having the recommended new ones.
Which new arrival will be your favorite, please don’t hesitate to post here, then we will stock the hottest items as soon as possible.
ps: New arrival estimated shipping time usually is about 4-10 business days, not 3-5 business days, but subject to special shipping time description on the product page
Up to 50% OFF
LED Lights & Flashlights https://www.gearbest.com/promotion-flashlight-sale-special-2078.html
More category coupon (up to 15% ) could be here
September 11th New Arrival:
1.HKV A15 LED High Power Diving Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009789576955.html?wid=1433363
Main Features:
• Aviation aluminum alloy shell has excellent scratch resistance and corrosion resistance
• It can be used for 100 meters underwater
• 3 kinds of light can be adjusted underwater: white, blue and red
• Dual-lubricated O-rings provide dual safety for underwater use
• High performance integrated cooling surface on the base ensures low heat
• 4 x 18650 lithium-ion battery ( not included )
2.MT35Plus Super Bright Outdoor USB Charging Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009939052333.html?wid=1433363
Main Features:
• Aluminum alloy, practical and durable
•Key breath lamp design to detect the voltage and remaining power in time
30 percent above, green light is on, 10 to 30 percent, red light is on, 10 percent, red light is flicker.
• PTZ hole design, can be used for fixed lighting
• Underwater 1m waterproof capacity, 1.5m anti-fall rating
• Four modes: moonlight file, medium bright file, high brightness file, very bright file
• Silicone button, widened and non-slip
• 2 x 18650 battery / 4 x 18650 battery ( not included )
3.WUBEN A21 Portable Super Bright LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009529056619.html?wid=1433363
Main Features:
●Aluminum body material
Using aluminum body material, it is non-slip, waterproof, and abrasion resistance.
● Side button switch design, easy to use
●Light modes
5 modes / strobe / stepless dimming design, so many brightness options are convenient for us.
● LED will give you stable and bright light, nonthermal radiation, safe and reliable
●IP - X8 waterproof
● Powered by 1 x 21700 battery ( included )
● Light source: CREE XHP70 LED beads
September 6th New Arrival:
1.Haikelite MT01 Waterproof Long Shots Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009983851378.html?wid=1433363
Main Features:
●Ultra clear double-sided AR coated toughened glass lens, the light transmission is up to 99pct
●Waterproof level up to IPX - 8, the flashlight can work normally even on heavy rain days
● The shot distance is up to 300 meters with the wide beam range
●Five brightness level: extremely low: 50lm; low: 250lm; mid: 850lm; high: 2500lm; strobe: 2500lm
● When the light is on, fast single click and long press to lock out the switch
● Multifunctional flashlight anti-reverse protection, anti-discharge protection, battery power detection function, low-voltage protection, temperature control protection
● The flashlight powered by 3 x 18650 / 18700 battery ( not included )
2.HKV A11 LED High Power Diving Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009157508212.html?wid=1433363
Main Features:
• Scope of application: outdoor diving, hunting, patrolling, camping
3.HaikeLite MT07S XHP70 II 5000lm Portable LED Flashlight - BLACK 6500K
https://www.gearbest.com/led-flashlights/pp_009671498460.html?wid=1433363
Main Features:
●Utilize a CREE XHP70.2 bead that can produce a blazing 5000lm illumination
●SMO aluminum reflector with double side AR coating glass lens for extreme reflector performance
●Lockout function: a single click followed by a long click to lockout the switch, repeat to unlock
● Digital full current regulation, anti-reverse protection, anti-discharge protection, thermal control remove / activation, last mode memory function
● Power indication light: 100 - 50pct: blue LED on; 50 - 9pct: blue LED flashes; below 9pct red LED flashes
●5 brightness levels: low ( 200lm ); mid I ( 550lm ); mid II ( 1300lm ); high ( 2300lm ); hidden turbo ( 5000lm )
●2 special mode: strobe ( 5000lm ); hidden moonlight ( 2lm )
4.HaikeLite MT07S - HI Portable CREE XHP35 HI LED Flashlight 7 Modes for Outdoor - BLACK COLD WHITE
https://www.gearbest.com/led-flashlights/pp_009791663221.html?wid=1433363
Main Features:
● 7 brightness levels: hidden turbo - high - medium II - medium I - low - hidden strobe - hidden moonlight
● Utilize a CREE XHP35 HI bead that can produce a blazing 3000LM illumination
● Waterproof IPX - 8, suitable for usage in rainy weather
● Powered by 4 x 18650 Li-ion battery ( not included )
● SMO aluminum reflector with double side AR coating glass lens for extreme reflector performance
5.HKV A28 Outdoor Portable LED Diving Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009662776193.html?wid=1433363
Main Features:
• Using high-quality CREE - XHP70 II chip, max output of 4000lm and beam distance of 500m
• High / medium / low / flash modes, suitable for using in different situations
• Power supply: 2 x 18650 ( not included ) / 2 x 26650 battery ( not included )
• LED will give you stable and bright light, nonthermal radiation, safe and reliable
August 13th New Arrival:
1.Boruit BC09 Super Bright Portable LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009895787548.html?wid=1433363
Main Features:
• Using high-quality CREE XM - L2 chip, max output of 750lm and beam distance of 180m
•Made of aluminum alloy, comfortable hand feeling
• Mid-size and lightweight, convenient to carry
• Power supply: 1 x 18650 ( not included ) / 2 x CR123A battery ( not included )
• IPX - 8 waterproof
2.Nitecore C1 Portable 1800lm Waterproof LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009933401264.html?wid=1433363
Main Features:
● Featuring a premium CREE XHP35 HD E3 LED for a super bright 1800 lumens max output
●High efficient constant current circuit board provides constant illumination
● Crystal coating technology combined with precision digital optics technology for an extreme reflector performance
●Power indicator beneath the side switch displays remaining battery power and blinks to report battery voltage to the nearest 0.1V
● The built-in ATR module automatically regulates its output and adapts to the ambient environment, maintaining optimal performance
● Powered by one 18650 battery or two CR123A batteries ( battery not included ), the C1 offers up to 300 hours of runtime on low and up to 30 minutes on the turbo
● Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish with a magnetic tail cap
● Toughened ultra-clear mineral glass with anti-reflective coating; waterproof level is up to IPX8, two meters submersible
3.Boruit BC05 Super Bright Portable LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009823667715.html?wid=1433363
Main Features:
• Using high-quality CREE XP - L2 chip, max output of 1180lm and beam distance of 285m
• High / medium / low / strobe / SOS modes, suitable for using in different situations
• Power supply: 1 x 18650 ( not included ) / 2 x CR123 battery ( not included )
July 12nd New Arrival:
You can use the coupon code: CA%LA704
1.SUNREI Rechargeable Smart Sensor Fishing Headlight - DARK KHAKI
https://www.gearbest.com/headlights/pp_009850577828.html?wid=1433363
4 Lighting Modes, Last up to 110 Hours,
Adjustable Strap,
IPX6 Waterproof Headlamp for Camping Running Hiking
Product Specification
Technical Parameters (Mode, Lumen, Lighting distance, Burn time):
Middle in Spotlight (70 lumen, 46m, 18hours)
High in Spotlight (230 lumen, 85m, 5.6 hours)
Low in Spotlight (9 lumen, 15m, 110 hours)
Sensing (140 lumen, 65m, 5.6hours)
2.SUNREI Youdo2s Outdoor LED Waterproof Super Bright Hiking Headlights - GREEN YELLOW
https://www.gearbest.com/headlights/pp_009440823245.html?wid=1433363
Headlight Brand: SUNREI
Type: LED Headlamp
Main Emitters: Cree XP-G2
Emitters Quantity: 3
Luminous Flux: 190
Battery Type: 3 x AAA battery(not included)
Battery Quantity: 3
Battery Included or Not: No
Beam Distance: 30-80m
Impact Resistance: 1M
3.SUNREI Youdo 3 Outdoor Mountaineering Hiking Rechargeable Headlights - CELESTE
https://www.gearbest.com/headlights/pp_009704558827.html?wid=1433363
Main Emitters: CREE XPG3 R4
Luminous Flux: 190
Feature: Waterproof
Battery Type: Lithium-ion Polymer Battery
Battery Quantity: 1
Battery Included or Not: Yes
Rechargeable: Yes
July 9th New Arrival:
1.Xtar VC4 18650 4-slot Lithium-ion Ni-MH Battery Charger - BLACK
https://www.gearbest.com/chargers/pp_009676245583.html?wid=1433363
Main Features:
●Four slot
Compatible with most rechargeable lithium-ion batteries and nickel-chromium-nickel-metal hydride batteries.
●LED indicator light design
Real-time battery voltage display, each cell voltage is approximately 10 percent of the battery capacity.
● LCD display, innovative turntable style
● Charge current display, suitable for all 5V USB power supplies
● Four-slot independent
● 0V voltage activation function, over-discharged battery
● 0.5A and 1A charging current
● Overcharge / overcurrent / overvoltage protection
2.Xtar Rocket SV2 Smart Quick Charger - BLACK
https://www.gearbest.com/chargers/pp_009806508920.html?wid=1433363’
Coupon code: IT$LEDSV2
Main Features:
●Double slot
● LCD screen displays battery power, charging status and charging current
● Automatic identification for simultaneous charging of lithium-ion and nickel-metal hydride batteries
3.lii-500 18650/26650 Lithium Battery Charger with LCD Display - BLACK
https://www.gearbest.com/chargers/pp_009343206925.html?wid=1433363
Main Features:
Different specifications of batteries can be charged simultaneously such as 18650 / 26650 / AA / AA / A batteries, etc.
4 charging slots
Features 4 charging current regulator, 300mA / 500mA / 700mA / 1000mA. Each channel works independently
LCD screen
Updates every second to keep you in the loop on the charging process
Quick test mode
4 channels detect the battery capacity quicker than the Nor mode Short circuit / over-current / over-charging / over-discharging / reverse polarity protection / temperature control / charging between 1.65 - 2.2V / bad battery recognition and activation
DC input voltage: 12V / 2A
Car charger input voltage: 12V / 1A
Please NOTE: batteries are not included.
4.Allmaybe TC2 Lithium-ion Battery Charger - BLACK
https://www.gearbest.com/chargers/pp_009360164937.html?wid=1433363
Coupon code: IT$LEDTC2
Main Features:
●Double slot
● It can charge two batteries and one external device at the same time.
● Shell made of ABS fire retardant material, excellent heat dissipation design
● Ingenious display
●0-volt activation function, to save over-discharge lithium-ion battery
●Automatic identification, intelligent selects its appropriate charging gear ( 0.5A / 1A / 2A ) for battery
●The sub-capacity test function, through the release of capacity, accurately measure the actual battery capacity
July 5th New Arrival
1.Tank007 TC29B Portable LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009227476125.html?wid=1433363
Main Features:
● Aluminum material
Using aluminum material, it is non-slip, waterproof, and abrasion resistance.
● Five modes
● Powered by 1 x 18650 rechargeable battery
● Light source: CREE XR - E Q5 beads
● Voltage: 3.0 - 4.5V
● Button switch in the head
Waterproof rate: IPX - 8
Irradiation distance: 500m
Charging time: 4h
Working time: highlight 3.5 hours, low light 10 hours
2.Orcatorch D820V Waterproof Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009191031179.html?wid=1433363
Main Features:
● Powered by 1 x 26650 rechargeable battery
● Titanium alloy side key switch, convenient operation
● USB charging function
● Professional anti-pressure waterproof structure design, diving depth of up to 150 meters
● Anti-reverse design to prevent damage to the circuit caused by battery reverse mounting
● Battery over-discharge protection
● Light source: XM - L2 ( U4 ) 4pcs / XPG(R5)2pcs /(UV purple)2pcs beads
● Voltage: 3 - 8.4V
Waterproof rate: IP68
Irradiation distance: 318m
Charging time: 3.5h
July 2nd new arrival:
1.Mecarmy PS14 - A Aluminum Alloy LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009589450488.html?wid=1433363
Main Features:
● Aluminum alloy material
Using aluminum alloy material, it is non-slip, waterproof, and abrasion resistance.
● lighting modes
Turbo, high, middle, low, strobe, so many brightness options are convenient for us.
● Powered by 1 x 14550 battery
● Light source: CREE XPL - HD LED, one cool white one neutral white
● Voltage: 1 - 5V
2.Mecarmy FL10 Portable LED Flashlight - BATTLESHIP GRAY
https://www.gearbest.com/led-flashlights/pp_009629756080.html?wid=1433363
Main Features:
● Titanium material
Made of TC4 titanium, lightweight, portable, permanent color, corrosion and scratch resistant finish.
● lighting modes
Triple clicks to access turbo mode, click again for strobe
● Standard micro USB charging port with charging indicator
● Keyring attachment hole design, easy to carry
● Bottom bezel design for self-defense in the emergency
● Powered by built-in 120mAh lithium-ion polymer rechargeable battery
● Light source: CREE XP - G2 S4 LED beads
● Voltage: 3 - 5V
Waterproof rate: IPX - 5
3.NiteCore BR35 1800LM Bicycle Lamp - BLACK
https://www.gearbest.com/led-flashlights/pp_009849224740.html?wid=1433363
Main Features:
● Aluminum material
● lighting modes
Extremely high light, high light, medium light, low light, so many brightness options are convenient for us.
● Built-in 6800mAh rechargeable lithium-ion battery
● Light source: CREE XM - L2 U2 beads
● Voltage: 3.7V
Charging time: 3h
June 22th 2018
Jetbeam WL - S4 - GT Searchlight LED Flashlight
https://www.gearbest.com/led-flashlights/pp_009241569169.html?wid=1433363
Main Features:
● Button switch
● Six lighting modes
Extremely low light, high light, medium light, low light, flash, SOS, so many brightness options are convenient for us.
● Powered by 4 x CR123A or 2 x 18650 battery ( not included )
● Light source: CREE XHP70 beads
● Voltage: 5V
Irradiation distance: 400m
Charging time: 4h
Head diameter: 63mm
Body diameter: 26mm
Length: 243mm
June 8th 2018
1.JETBeam IIIM2017 Tactical LED Flashlight
https://www.gearbest.com/led-flashlights/pp_009642344021.html?wid=1433363
Main Features:
● Unique triple tail switches ( JETBeam’s patent ) and a side switch design
Using triple tail switches and a side switch design, it is and convenient and easy to use.
● Seventh gear: very bright, bright, medium light, low and medium light, low light, energy saving, flashing
● Waterproof rating: IPX - 8 ( 2 meters underwater )
2.Sofirn SD01 Professional Diving Flashlight 3000LM LED Torch
https://www.gearbest.com/led-flashlights/pp_009478408183.html?wid=1433363
Specifications:
● Brand name: Sofirn
● Lumens: 3000lm max
● Light source: CREE LED lights
● Lighting distance: 300m
● Waterproof: IPX8, underwater 100m
● Switch: enjoy the flashlight in deep water by magnet switch
● Lens: tempered glass lens with anti-reflective AR coating
● Cup material: aluminum mirror reflective cup
● Battery: Powered by 4 units 3.7 V 18650 batteries ( batteries not included )
3.Jetbeam TH15 Tactical Flashlight
https://www.gearbest.com/led-flashlights/pp_009530129764.html?wid=1433363
Main Features:
Using triple tail switches and a side switch design, it is convenient for us.
And it is easy to use.
● Seven lighting modes
Very bright, bright, medium light, low and medium light, low light, energy saving, flashing, so many brightness options are convenient for us.
● Low power indicator function reminds the user of battery replacement in time
● Powered by 1 x 18650 2600mAh rechargeable lithium-ion battery
Dec:22th
KLARUS Mi6 CREE XP - G3 Keychain LED Flashlight
https://www.gearbest.com/led-flashlights/pp_1499488.html
*2017 Dec20th
Klarus Mini One XP - G3 LED Keychain Flashlight 3 Modes
https://www.gearbest.com/led-flashlights/pp_1476219.html
Main Features:
• Finger-sized mini-might flashlight, elegant and compact
• 10180 Li-ion rechargeable battery included
• Micro-USB charging port, easy to charge
• Fast charging, only 45 minutes charging needed, no waiting
LUMINTOP Tool AA EDC LED Flashlight Cree XP - L
https://www.gearbest.com/led-flashlights/pp_1476215.html
Main Features:
● Utilizes Cree XP - L HD LED with a lifespan of 50,000 hours
● 3 brightness levels with a max output 550 lumens
● Powered by one AA or 14500 rechargeable Li-ion battery ( not included )
● Handy and compact, easy to carry
LUMINTOP Tool AAA EDC LED Flashlight CREE XP
https://www.gearbest.com/led-flashlights/pp_1476196.html
Main Features:
● Utilizes CREE XP-G2 R5 with a lifespan of 50,000 hours
● 3 brightness levels with a max output 110 lumens and max runtime 60h
● Powered by one AAA battery ( not included )
2017 Dec12th 3
HaikeLite MT07S - HI CREE XHP35 HI LED Flashlight 7 Modes
https://www.gearbest.com/led-flashlights/pp_1303517.html
The HaikeLite MT07S - HI CREE XHP35 Hi LED Flashlight is a popular and versatile multi-purpose flashlight. Equipped with a lanyard, the flashlight is portable conveniently. Using a high performance LED offering a maximum output of 3000 lumens, this light has 7 brightness levels available. Single press offers access to all functions.
2017 Dec12th 2
Nitecore GP3 CREE XP - G2 LED Action Camera Light
https://www.gearbest.com/led-flashlights/pp_986776.html
Main Features:
● Action camera light
● Onboard sliding diffuser
● Utilizes a CREE XP - G2 LED
● Max output up to 360 lumens
● Max runtime up to 235 hours
● Micro-USB rechargeable with onboard charging circuit
● Universal mounting rings to secure the GP3 onto action camera mount
2017 Dec12th 1
JETBeam TH15 CREE XHP35 E2 LED Flashlight
https://www.gearbest.com/led-flashlights/pp_1317536.html
The JETBeam TH15 CREE XHP35 E2 LED Flashlight is an incredibly widespread and versatile multi-purpose flashlight.
Equipped with a high performance LED offering a maximum output of 1300 lumens,
This light has two modes - outdoor mode and tactical mode - to choose from.
Plus the built-in rechargeable 18650 battery and onboard USB charging functionality mean you’ll always charge it conveniently.
Equipped with a lanyard and a clip, the flashlight is easy to carry.
Brightness Levels:
• Turbo - 1300LM
• High - 900LM - 1.2h
• Middle - 450LM - 3h
• Low - 180LM - 8.5h
• Ultra-low - 60LM - 30h
• Moon - 10LM - 140h
• Strobe - 900LM
2017 Sep 13th 3
Thumb-sized KLARUS Mi1C CREE XP-L HI V3 EDC Mini Flashlight, maximum output up to 600 lumens, up to 9 days running time in moon mode
Fade-in and fade-out function when the turbo mode is the initial mode for on and off.
Newest intelligent temperature protection system(ITS) monitors internal temperature
Intelligent battery capacity indicator to view remaining battery capacity at any time.
Lock-out mode prevents accidental activation; avoiding battery drains during storage or traveling and prevents unintended directly shining into eyes.
Reverse-polarity protection prevents damage due to incorrect battery orientation.
One-touch low and with mode memory function.
Aerospace aluminum alloy construction; CNC precision machining; Mil-Spec HAIII anodizing, anti-abrasive, lighter and robust.
Compatible with CR123A and 16340 Li-ion battery
KLARUS 16340 battery with a Micro- USB port is included ( installed at flashlight )
Magnetic tail can affix the flashlight to any steel surface
The access: https://www.gearbest.com/led-flashlights/pp_791915.html
Try the code: Enjoy 12% off discount with the code: GB17LED (code price 43.08:money_mouth_face:
2017 Sep 13th 2
Klarus Titanium H1A 550Lm CREE XP - L V6 Led Headlamp
Three light sources: long range main beam, floodlight, and red light
The main lamp features CREE XP - L V6 LED ( 6000 - 7000k ), maximum output up to 550L, extended range light.
Side lamp features CREE XP - E2 R2 LED ( 4000K ), flood light with even illumination, suitable for a short distance.
PMMA optical lens on the main lamp with a 92pct light transmission.
The lens of main lamp features patented design to protect user vision, improved comfort, and maximum optical advantage.
Fade-in and fade-out function when the Turbo mode is the initial mode for on and off to promote eyes safety and improve user experience.
90-degree adjustable angle illuminates from any direction.
Newest intelligent temperature protection System ( ITS ) monitors the internal temperature
Unique lock-out function to avoid accidental operation and activation during storage, preventing a risk of eye damage.
Intelligent battery indicator function displays remaining battery capacity at will to control light use.
Headband includes sweatband design for long term comfort.
Compatible with all AA alkaline, Ni-MH, and 14500 Li-ion batteries.
Comes with a 14500 rechargeable battery (battery Included).
The access: https://www.gearbest.com/headlights/pp_791949.html
Try the code: Enjoy 12% off discount with the code: GB17LED (code price 79.16:money_mouth_face:
2017 Sep 14th
KLARUS XT12S CREE XHP35 HI D4 Color Temperature: 6500-7000K High Brightness Flashlight, extreme spotlight capability and illuminates up to 402 meters.
Aerospace aluminum alloy body with CNC machining; Mil-spec HAIII hard anodizing.
Stainless bezel ring. Hardened mineral glass lens with AR coating.
Two interfaces: tactical setting; outdoor setting.
Tactical setting: classic KLARUS XT series control. One-touch strobe; one-touch turbo; versatile for all tasks.
Outdoor setting: One-touch low; One-touch turbo; multiple output levels with memory, SOS function.
Springs at bezel and tail resist shock and drop damages. Reverse polarity protection; eliminates damage from incorrect battery installing.
KLARUS 18GT-36 3600mAh 18650 battery included, 1A recharging current.
https://www.gearbest.com/led-flashlights/pp_799713.html
2017 Sep 13th 1
Brinyte M18 XP - G2 Brass LED Mini Flashlight very compact, easy to carrying, can be used as a keychain
Charged via micro USB interface; two lighting mode: low; high
Reliable tail twist switch for a quick, one-handed operation
Comes with a 3.7V 1000mAh 10180 rechargeable battery ( installed at flashlight / 1*10180 Included)
Waterproof to IPX8 standard ( submersible up to 2 meters )
Seek More: https://www.gearbest.com/led-flashlights/pp_791951.html
Try the code: Enjoy 12% off discount with the code: GB17LED (code price 21.78:money_mouth_face:
2017 Aug 28th
Brinyte DIV12S CREE XML - L2 Diving Flashlight, A newly wonderful design of led tech diving flashlight with power indicating function aiming to enhance the safety of underwater diving.
Before your diving, the flashlight will remind you of battery low power by lighting a red ( less than 30pct ) or flickering red ( less than 10pct ) indicator next to the magnetic switch
If the indicator turns red while you are diving, which means you should go back to the land as soon as possible
Built by high strength aluminum AL - 6061 - T6 material with premium military type III hard-oxidation treatment
Powered by one 18650 rechargeable battery ( not included), can be continuously lighted for 2 hours under 1000 luminance and for 15 hours under 150 luminance
10-degree narrow beam, the light is the best choice for night diving and scuba diving as the backup light
Over-heat protection design to ensure working stable and safe use; reverse polarity protection to prevent from wrong installation of battery
Two O-ring offer extremely waterproof capability of maximum 100 meters underwater
The toughened lens with thickness 5mm to ensure excellent ability to resist water press
Seek More from here: https://www.gearbest.com/led-flashlights/pp_727449.html
2017 Aug 23th
KLARUS XT2CR CREE XHP35 HD E4 LED Flashlight
6500 - 7000K 1600LM USB Powered High Brightness
● CREE XHP35 HD E4 LED with higher photoelectric efficiency, max output up to 1600 lumens
● 18GT - 36 3600mAh 18650 battery included ( installed in flashlight )
● Intelligent battery load system compatible with a wide variety of batteries
● Robust stainless steel bezel ring protects components
● Patented dual-switch tail cap for easy tactile one-hand operation
● Digital intelligent charging algorithm with currents up to 1A
● All new ITS system monitors internal temperature and adjust output to regulate heat, protects LED and internal components for perfect balance of output and safety
● Front and rear internal mounted springs protect against shocks and drops
● Aerospace aluminum alloy construction; CNC precision machining; HAIII Mil-Spec anodizing
● Reverse polarity protection to prevent damage from incorrect battery insertion
● Hardened AR-coated lens, scratch resistant
Seek More from: https://www.gearbest.com/led-flashlights/pp_702467.html?wid=21
Coupon: KKSMK
2017 Aug 14th Part 2
SUNCORE 20 x 50mm Binocular
- HD binocular with plastic + metal body for birds watching, climbing, hiking, hunting, etc.
- Fully multi coated and anti-fog lens offers clear images with improved light transmission
- Porro BAK - 4 prism provides a high definition view
- Center focus wheel and eyepiece adjustment for precisely focusing
- Compact and lightweight, easily being held by one hand
- With lanyard and storage bag, convenient to carry
Prism System: Porro System
Optical Material: BAK-4
Amplification Factor: 20X
Objective Lens (mm) : 50mm
Eyepiece Diameter: 25mm
Field of view: 168ft / 1000yds
Field Angle(degree): 2.9 degree
Exit pupil diameter: 2.5mm
Exit pupil distance: 18mm
Coating Film: FMC
Anti-fog, Foldable Eye Cup
Seek More about the item: http://www.gearbest.com/binoculars-and-telescopes/pp_638125.html
Coupon: SC25GB
Coupon Price: 31.99 $
2017 Aug 14th Part 1
Philips Hue - Your personal wireless lighting system
Philips Hue connected bulbs and bridge let you take full control of your lighting.
Whatever you want to do with your lighting, Hue can.
Get started with the Philips Hue and experience high quality white and colored light that offers you endless possibilities.
Limitless possibilities - Download the App and discover the amazing things you can do with Philips Hue
● Play with light
Play with light and choose from 16 million colors with the tap of a finger
● Create your ambiance
Set the right ambience for any moment. Set the mood, change the ambience, feel different, feel better
● Sync with movies and music
Extend your TV viewing experience to the whole room or sync light to your favorite music and enjoy every beat to the fullest
● Light schedules for home automation
Wakes you up gently for a fresh start, and helps you get to sleep each day
● Control your lights from anywhere
Check if you have forgotten to switch your lights off before you left your home, and switch them on if you are working late
● Expand your Philips Hue system
Once you’ve set up your Philips Hue system, you can go on and add up to 50 Philips Hue lights
Turn on your imagination with Philips Hue and find more possibilities
Seek More: http://www.gearbest.com/smart-lighting/pp_343492.html
Promo Price can be pretty pretty nice for you: 199$
( Coupon will be set-effective tomorrow morning )
2017 Aug 11th
ZANMAX 1101 Lockback Pocket Folding Knife - SILVER AND WOOD
http://www.gearbest.com/pocket-knives-and-folding-knives/pp_683600.html
- Blade Material: 440C stainless steel
- HRC: more than 58
- Handle: wood
- Sheath: leather
- Blade Length: 3.46 inches
- Overall Length: 8.26 inches
- Handle Thickness: 0.47 inches
- Weight: 3.53 oz.
ZANMAX 2101 Outdoor Fixed Blade Knife - BLACK AND SILVER
http://www.gearbest.com/fixed-blades-knives/pp_683599.html
- Heavy duty for hunting, camping, climbing and other outdoor activities
- Fixed blade made of 7Cr17MoV stainless steel that gives it exceptional strength, ductility, and cutting ability
- Handle is shaped to fill the hand to eliminate pressure spots during extended use
- Blade jimping provides a better grip and prevent your fingers from sliding when using the knife.
- Includes custom-molded nylon sheath for easy and safe carry
Seek More about Zanmax: http://www.gearbest.com/zanmax-\_gear/
2017 Aug 9th
zanflare B3 Bike Light
Emitters: 3 * XPL V5
Output: Low: 450LM,
Medium: 1300LM,
High: 2200LM
Runtime: High Mode: 2H
Mid Mode: 4.5H
Low Mode: 7H
Charging indicator,Constant Current Circuit,
Integrated Heat Dissipation Design,
Memory Function,Overheating Protection
Waterproof Standard: IP67
LED Lifespan: 50,000H
Impact Resistance: 1.5M
Body Material: Aluminium Alloy
http://www.gearbest.com/bike-lights/pp_690039.html?345
Presale Price : $49.99
Seek More Bike Light: http://www.gearbest.com/bike-lights-c_11508/
2017 Aug 8th
Xiaomi Yeelight Smart LED Ceiling Light
The World’s First Lamp to Support both WiFi and Bluetooth
IP60 Dustproof WiFi / Bluetooth App Remote Control Work with Amazon Alexa IFTTT, Mi Band Linkage
http://www.gearbest.com/flush-ceiling-lights/pp_687740.html?wid=21
The Yeelight smart ceiling light is deigned as sporting white color in a circular shape.
5min Fast Installation
240pcs OSRAM LEDs
color rendering index is up to 95Ra
Dual-chip Three-way Dimming System, 2700K to 6500K
eing a smart lamp, the light can be controlled by smartphones through WiFi or Bluetooth.
life is surprisingly easy!Simple, Beautiful and Intelligent
Coupon: 3RDGBYS
Coupon Price: $ 69.99
*2017 Aug 3rd
Nitecore i8 8 Charging Slots Smart Universal Quick Charger
http://www.gearbest.com/chargers/pp_683965.html
8 slots independently
Compatible with and identifies Li-ion batteries, Ni-MH and Ni-Cd rechargeable batteries
Compatible with: Li-ion / IMR: 10340, 10350, 10440, 10500, 12340, 12500, 12650, 13450, 13500, 13650, 14350, 14430, 14500, 14650,
16500, 16340 (RCR123), 16650, 17350, 17500, 17650, 17670, 18350, 18490, 18500, 18650, 22500, 22650, 25500, 26500, 26650;
Ni-MH ( Ni-Cd ): AA, AAA, C, D
three charging modes ( constant current, constant voltage, - dV / dt )
Automatically detects power level of batteries and select the appropriate voltage and charging mode
Automatically stops upon charging completion
Over-charging prevention, reverse polarity protection and short circuit protection
Activation function for over discharged protected batteries
Designed for optimal heat dissipation
Input: AC 100 - 240V 50 / 60Hz 0.5A ( max ) 30W DC 12V 3A
Output voltage: battery: 4.2V + / - 1pct, 1.48V + / - 1pct; USB: 5V + / - 5pct
Output current: battery: 2 x 1.5A, 4 x 1A, 4 x 0.75A, 8 x 0.5; USB: 5V x 2.1A
Seek more: http://www.gearbest.com/chargers/pp_683965.html
Coupon: N8Charger
Coupon Price: 39.95 $
2017 July 31th
Imalent DX80 CREE XHP70 6500K 32000Lm Search Flashlight
8pcs CREE XHP70 LEDs with 32000 max luminous flux
8pcs 3000mAh 18650 Li-ion batteries ( not included )
the light transmission is up to 99pct with scratch and impact resistant
IPX - 8 ( 2m submersible )
806 meters with wide beam range
5 modes: 120Lm, 500Lm, 1500Lm, 5000Lm, 13000Lm
Check form here:
US PLUG: http://www.gearbest.com/led-flashlights/pp_681520.html
EU PLUG: http://www.gearbest.com/led-flashlights/pp_681518.html
Coupon for both Plugs: DX80 (Coupon Price: $ 219.95 )
2017 July 22th Part 3
Xiaomi MiJIA IR Sensor and Photosensitive Night Light
http://www.gearbest.com/night-lights/pp_672506.html?wid=21
The light has 120-degree sensing angle and sensing distance is up to 5 to 7 meters.
Using advanced photosensitive sensor and human infrared sensor technology with anti-infrared interference function, the light can turn on automatically in the dark environment and light for 15 seconds
The light comes with three AA batteries and is powered by batteries, free you from socket trouble.
The choice of ultra-low power consumption of the sensing program ensures only 0.25mW power consumption when in standby mode.
There are two brightness adjustments. when in 0.7Lm mode the battery can be used for about 12 months; when in 3.8Lm mode, can be used for about 6 months
Applied Fresnel ultra-thin lens to enhance the sensor performance.
Fish scale total reflection structure reflect the light to the diffuse reflector and the light spreads evenly in the lampshade to bring a better visual experience
Minimalist Design Adds Unique Flavor to Life;D
Pre-sale code: XMNLight
Presale special price: $11.99
2017 July 22th Part 2
zanflare KU - 2835A - 24D - 0 LED Mothion Sensor Undercabinet Light
http://www.gearbest.com/led-tubes/pp_660613.html
Infrared human body induction sensor switch motion detector
Induction angle 120 degrees, sensing distance up to 4 meters
Two installtion options: tape and screw
Two connection options: connector and connection cable
SMD2835 ( 24 LED for each light bar, 3 light bars in total )
Aluminum alloy + PC Material
3 W/each
Warm white 3000K
Light output: 750 Lumen
CRI: more than 80 Ra
21.99$ after coupon: KU2835A
2017 July 22th Part 1
Geteed 3.7V 750mAh 15A 18350 Li-ion Rechargeable Battery
http://www.gearbest.com/batteries/pp_666580.html
Quick charge current is 750mA,
quick discharge current 15000mA,
max discharge current 20000mA
Geteed 3.7V 35A 2500mAh 18650 Li-ion Rechargeable Battery - 4PCS
http://www.gearbest.com/batteries/pp_666587.html
Quick charge current is 2500mA,
quick discharge current 35000mA,
max discharge current 50000mA
Geteed IMR18650 - 3040 18650 Li-ion Battery - 4PCS
http://www.gearbest.com/batteries/pp_600952.html
Battery Type: IMR
Head Type: Flat Top
Rechargeable: Yes
Protected: No
Capacity (mAh): 3000mAh
Max. Discharge Current: 40A
Suitable for: Car toys,CD Players,Digital Camera,Electric Tools,Flashlight,MD,Microphone,Multimeter,PDA,Portable Games,RC Toys
Note:
● Do not expose the battery in the sun or dispose it into fire
● Do not charge the battery in wrong terminals
● Avoid excessive shock or vibration
● Do not disassemble or deform the battery
● Do not immerse the battery in water
● Keep the children out of reach of the battery
● Battery must be charged in appropriate charging condition
● Do not use a damaged charger to charge the battery
● Do not leave the battery in charger over 24 hours
● Store the battery in a cool, dry and well-ventilated area
● Disposal battery under regulations
SEEK MORE: http://www.gearbest.com/geteed-\_gear/
Please enjoy the 12% off coupon : GB17LED
2017 July 18th
LiitoKala 18650 Li-ion Rechargeable Battery
1. LiitoKala Lii - 22A
3.7V 220mAh for Flashlight
Long life expectancy, recharge times up to 500 times
http://www.gearbest.com/batteries/pp_663621.html
2. LittoKala Lii - 25A
3.6V 2500mAh for Electronic Cigarette
Head Type: Flat Top
Protected: No
http://www.gearbest.com/batteries/pp_663875.html
3. LiitoKala Lii - 29A
3.7V 2900mAh for Electronic Cigarette
http://www.gearbest.com/batteries/pp_663880.html
4. LiitoKala Lii - 30A
3.7V 3000mAh
http://www.gearbest.com/batteries/pp_663882.html
5. LiitoKala Lii - 32A
3.7V 3200mAh for LG MH1
http://www.gearbest.com/batteries/pp_663891.html
26650 Li-ion Rechargeable Battery
1. LiitoKala Lii - 50A
3.7V 50A for Flashlight
http://www.gearbest.com/batteries/pp_663615.html
2017 June 16th
NITECORE F2 Flexible Dual-slot Battery Charger for 14500 / 16340 / 18650
http://www.gearbest.com/chargers/pp_649367.html
The F2 flexible power bank is dual-slot, outdoor power bank battery charger.
This double duty charger can power 18650, RCR123, 26650, 14500 and other IMR / lithium-ion batteries using the micro-USB, USB 3.0 cable,
be able to charge cellphones, flashlight, headlamp and other USB devices as a power bank with batteries.
Lightweight and durable, this is the perfect charger for outdoor activities such as hiking, climbing, backpacking, etc.
Compatible with: Li-lithium-ion / IMR: 26650 / 18650 / 17670 / 18490 / 17500 / 17335 / 16340 / ( RCR123 ) / 14500 / 10440
NITECORE MH12GT
http://www.gearbest.com/led-flashlights/pp_641261.html
6500 - 7000K 1000LM USB Rechargeable Light
CREE XP - L HI V3 LED
1 x 3400mAh NL1834 18650 battery ( included )
or 2 x CR123A battery ( not included )
Waterproof in accordance to IPX-8 ( two meters submersible )
Output / runtime ( 1 x 18650 ):
high: 1000LM / 1.25h,
mid: 280LM / 6h,
low: 55LM / 28h,
ultralow: 1LM / 520h
Output / runtime ( 2 x CR123A ):
high: 1000LM / 1h,
mid: 280LM / 3.25h,
low: 55LM / 20h,
ultralow: 1LM / 300h
Seek More: http://www.gearbest.com/led-flashlights/pp_641261.html
2017 June 14th
zanflare F2 LED Flashlight - 4500-5000K Cree XP-G3 IPX8 Water Resistant 4 Modes
Aerospace Grade Aluminum Body with Anti Scratching Type III Hard Anodization
http://www.gearbest.com/led-flashlights/pp_613216.html
Emitters: 1* Cree XP-G3
Mode: 4 (Low - Mid - High - Strobe)
Low: 15LM;
Medium: 50LM;
High: 200LM;
Strobe: 200LM
Mode Memory
Runtime:
High Mode: 0.63H
Mid Mode: 8H
Low Mode: 32H
Max: 30h
Luminous Flux: 200LM
Luminous Intensity: 2630 cd
Color Temperature: 6500-7000K/4500-5000K
Battery Type: 2* AA not Included
Coupon—F2DEAL
Coupon Price—- $12.99 (CW/ NW)
Please check from here:
http://www.gearbest.com/led-flashlights/pp_613216.html (CW/ NW)
2017 June 8th
NITECORE NU10, 160Lm White + Red Dual Light Source Multiple Color Options
http://www.gearbest.com/headlights/pp_605448.html
an ultra lightweight and compact solution for runners, campers and anyone needing hands-free lighting.
Equipped with dual light source and dual-switch UI, the NU10 gives out max 160Lm output and provides 3 brightness levels of white light and 2 special modes of red light to preserve night vision.
NU10 features 170 degree wide angle illumination and can be tilted 60 degree to cover your field of vision as needed.
The built-in 900mAh Li-ion battery, can withstand at least 500 recharge cycles, allows the NU10 to run up to 150 hours.
Black, white, yellow, green, blue and red 6 color options. There must be one color suits you best!
NOTE: This product will not be shipped to the United Kingdom.
Coupon —NU10GIFT
Coupon price —- 15.99 $
2017 May 27th
MecArmy SGN5 - Multifunctional EDC Alarm Flashlight
Cree XP - G2 S4 560Lm USB Rechargeable Instant Alarm / Turbo / Strobe
CREE XP-G2 S4 LED, max 560Lm in such a tiny size
Instant alarm, strobe and turbo for emergencies
USB rechargeable, charges in just 1 hour on any USB port
Charging time: 1 hours ( charging current 5V 0.5A )
Using time: 42 hours
http://www.gearbest.com/led-flashlights/pp_636669.html
Coupon: MecSGN5
Coupon Price: 24.99$
2017 May 23th
Klarus G35 CREE XHP35 HI D4 2000LM LED Flashlight
KLARUS G35 presents its new flashlight, the G30, which is sure to please fans of KLARUS flashlights.
The G35 carries an up-to-date CREE XHP35 HI D4 LED chip with a maximum output of 2000Lm.
Indeed, the G35 features both high brightness and compact size.
The design of the integrated tube and battery compartment lets the flashlight be handled much more easily.
Besides the unique dual-switch adds more convenience in use, which makes it your best EDC partner!
http://www.gearbest.com/led-flashlights/pp_635125.html
Coupon: 3afy74n
Coupon Price:$74.99
2017 May 18th
Original Xiaomi Philips LED Ceiling Lamp - WHITE
App Control Dual Light Source Intelligent Dimming AC 100 - 240V
Xiaomi Philips LED Ceiling Light - Support WiFi
It is deigned as sporting white color in a circular shape.
In addition, a moonlight mode which gives the look of the moon when turned on is surprisingly comfortable.
● 5min Fast Installation ( II electric shock resistant )
● 82Ra: 64pcs LEDs of high CRI provides museum lighting effect
● IP60 Dustproof: protects it from dust, and could get rid of the pesky insects
● 2700K to 5700K, brightness range from 0.1Lm to 2000Lm
● 25000 Hours Lifetime: constructed by premium materials and specified processes
● Efficient Heat Dissipation: unibody aluminum plate maintains highly efficient cooling
http://www.gearbest.com/flush-ceiling-lights/pp_633589.html?wid=21
coupon—- MiPhilips
price —- 89.99
Original Xiaomi Transmitter for Philips LED Ceiling Lamp
1pc CR2450 550mA battery
Integrated temperature and humidity sensor
http://www.gearbest.com/led-accessories/pp_633590.html
coupon: TSLamp
coupon price: 16.99$
expired time: 2017.06.30
2017 May 9th
IMALENT DM21T warm / Cool CCT
1000Lm Cree XPL HI Palm-sized Searchlight
Palm-sized body with chocolate structure surface offers firm grip
Intelligent thermal control module automatically adjusts brightness according to body temperature
http://www.gearbest.com/led-flashlights/pp_626560.html
1pc 18650 Li-ion ( 2600mAh ) battery is included
IPX-8 standard waterproof ( 2 meters submersible )
Coupon: DM21TDEAL
Coupon Price: 32.99$
2017 May 6th
LUMINTOP Elfin Mini LED Flashlight - WITH/ WITHOUT TRITIUM
LUMINTOP Elfin flashlight is a luxury gift flashlight with its perfect handy size and eye-catching dazzle color.
As its name Elfin, this little flashlight brings surprises of its glossy surface, for the changeable color of the flashlight in the different view.
In the length 64.8mm and weight 43.5g, you could easily hold Elfin in hand without any burden feelings.
Small and light enough to add to your everyday carry list.
Optimized ultra-precise reflector and double-side AR coated lens which resists impact and thermal shock, offer a more comfortable cool beam of Cree XP - L V5 LED.
Using a single CR123 ( or RCR123 ) battery could approach 4 useful modes for common use:
moonlight mode in 0.5 lumens for lasting long run time;
low and mid mode for indoor and short-distance use,
and high mode offers long beam distance in outdoor.
The inner copper tube body of Elfin provides a better heat dissipation.
Intelligent advanced temperature regulation system allows it to adjust output performance according to its body temperature to ensure stable and safe operation.
The comfortable clicky tail switch is very convenient for one-hand operation, and easily to recognize in the dark through tritium in the tail button.
URL: http://www.gearbest.com/led-flashlights/pp_627003.html
Coupon will be shared in new coming week
2017 May 6th
Custom capacity by 4 x 18650 li-ion battery to make your own power bank, portable external supply, provides your devices enough power.
Also a battery charger for 18650 battery, a dual-use item. Dual outputs, can charge phones, pads or other small electronic devices simultaneously
Independent battery, charging and discharging at the same time, can work together and not influence each other
When it comes to the reverse polarity, the chip inside will automatically identify and cut off the power of the reversed polarity circuit, displays an empty battery level
Reversed polarity will not affect the normal operation of other circuits
Parameters:
Battery: 4 x 18650 li-ion battery ( not included )
Input: 5V / 1.2A
Output: 5V / 1A, 2A
URL: http://www.gearbest.com/chargers/pp_627026.html
Coupon: M4GB
Coupon Price: 11.99$
2017 April 27th
1. JAXMAN M2
CREE CREE XM - L2 U2 LED 400LM: 1A 6000 - 6500K/ 3C 5000 - 5500K
http://www.gearbest.com/led-flashlights/pp_621642.html
High - low, two kind outputs meet your requirements
CNC machined 6061-T6 aircraft aluminum alloy construction
Built-in advanced protection circuit to extend the battery lifespan and reverse polarity protection to ensure users’ safety
Adjustable two brightness levels: 50Lm ( Low ), 400Lm ( High ). Slightly tap the tail switch of the torch to switch the brightness.
The default level is low level.
2. JAXMAN E2
CREE XM-L2 U2 LED 580LM: 1A 6000K, 3C 5500K
Nichia LED 350LM: 5700K, 4000K
http://www.gearbest.com/led-flashlights/pp_355970.html
High - mid - low - strobe - SOS, multiple outputs meet all your requirements
Compact and lightweight, with premium lanyard for carrying every day
IPX-8 waterproof standard, even protects your light from powerful water jets
Powered by 1pc 18650 battery (flat top)
High CRI, more than 90 RA
Switch Location: Tail Cap
Reflector: Aluminum Half an Orange Peel Reflector
3. JAXMAN E2L
CREE XP-G2 LED 900LM: 1A 6000K ( white ), 5A 4500K ( natural white ), 3C 5500K ( neutral white )
http://www.gearbest.com/led-flashlights/pp_619108.html
High - mid - low, multiple outputs meet your different requirements
CNC machined 6061 aircraft aluminum alloy construction
Built-in advanced protection circuit to extend the battery lifespan, reverse polarity protection, low-pressure slow flash tip and over-discharging protection to ensure users’ safety
Powered by 1pc flat top 18650 battery ( not included )
Running time: 29h ( Low ), 295 minutes ( Mid ), 90 minutes ( High )
Adjustable three brightness level: 50Lm ( Low ), 300Lm ( Mid ), 900Lm ( High ).
2017 April 24th
BRELONG USB Light Keychain 6 x 5730SMD LED Lamp - 5PCS
http://www.gearbest.com/night-lights/pp_624821.html
9.99$ in Flash Sale
2017 April 20th
Zanflare S2 2M USB Multicolor Indoor LED Strip Light:
http://www.gearbest.com/led-strips/pp_624660.html
Coupon: S2NEW
Wow! No danger of upsetting the MAP police with those prices. :wink:
well put Woody!
And I thought that the V11R was expensive. Little did I knew that GearBest’s V11R takes the price to the stratosphere.
They will probably have codes for them. Prices are indeed nothing spectacular right now
Would any one like this new arrival from GearBest.
Sunwayman C22C Dual-light Night Traveler
Beautiful!
Is any one interested the Olight M3XS - UT Javelot, will it make you excited, welcome to discuss.
A discussion and interest thread about this light Javelot:
my review of sunwayman C22C!
5.8 ( May 8th)
1. Shadow JM35 Cree MT G2 LED Flashlight
Main Features:
● Unique hollow design: Looks elegant and helps to improve heat dissipation, decreasing temperature at the same time
● Stainless side switch: Anti-corrosion, prevents the JM35 from corrosion and wear
● Booster circuit: Boosts a power-supply voltage to a higher level
● Reverse polarity protection: Prevents improper battery installation
● Stainless steel bezel: Offers good protection for flashlight and may be used in an emergency situation
● Vacuum aluminum orange peel reflector: Offers smoother and floodier beam throw as well as long throw, suitable for hunting, security, outdoor, EDC use etc.
● Screw thread handle: Prevents slip and be comfortable to touch handle
● Processed by CNC machining center: Tactical handing hole can be placed upside down
● Cree MT-G2 light source: Utilize Cree MT-G2 LED and max up to 2200 Lumens
● Powered by 1 x 26650 battery
2.” Shadow JM30 1800Lm Cree MT G2 4 Modes Waterproof LED Flashlight ( 1 x 26650 Battery ) “:http://www.gearbest.com/led-flashlights/pp_183130.html
Main Features:
● Tactical switch: Allowing momentary activation as well as clicking on / off
● Reverse polarity protection: To prevent improper battery installation
● 3A drive circuit: Provides double intelligent protections for LED and battery to maximizes their lifespan and ensure safe use
● Vacuum aluminum orange peel reflector: Offers smoother and flooder throw as well as long beam, suitable for hunting, security, outdoor, EDC use etc.
● Aircraft-grade aluminum body with anti-scratch type III hard anodizing: Prevents rolling and works perfectly with the various tactical techniques
● Screw thread handle: Prevents slip and be comfortable to touch the handle
● Processed by CNC machining center Tactical handing hole can be placed upside down
● Cree MT-G2 light source: Utilize Cree MT-G2 LED and max up to 1800 Lumens
Do both the JM30 and JM35 come with extension tubes
Hi ReAvenger, thanks for your interests, I will confime it next week :wink:
Is any one interested in the Sunwayman new member?
Sunwayman G25C Cree XM L2 U2 1000Lm 4 Modes Side Switch LED Flashlight ( 18650 CR123A )
Mirage is my love.
♡♡♡G25C♡♡♡
Truth be told, I’m tired of all those XML cool leds 18650 flashlights coming out. Really wanted a 1X18650 with neutral white led. Those sunwaymans, fenixes are great but I’ve become less happy about cool white (which is what I preferred when I was new)
Order placed! :heart_eyes: K60 :heart_eyes:
Thanks for your order :wink:
new arrival
1.
Nitecore EC4 CREE XM - L2 U2 1000LM LED Flashlight 2 x 18650 / 4 x CR123A
wish you like this new lights.
2. Warsun X65 Cree XM L2/L Focus Adjustable LED Flashlight 1200Lm 3 Modes Waterproof 26650 Torch
