Gearbest New Arrival: September 11th, HKV A15|MT35Plus | WUBEN A21
544 posts / 0 new
Nicolicous
Nicolicous's picture
Last seen: 4 hours 21 min ago
The price for Tank flashlight is expensive.
I remember years ago their quality is same as Ultrafire, uranusFire and many other XXXXfire brands.
Their design still look like low end Ultrafire lights and they’re charging big dollars Oops
Nico -.-
gearbest
gearbest's picture
Last seen: 3 hours 59 min ago
Thank you for your feedback, we have submitted these information to our related colleague. Wink
gearbest
gearbest's picture
May 11th 2018 update:
MHVAST TS50 XHP 50.2 LED High Power Flashlight
https://www.gearbest.com/led-flashlights/pp_1830727.html?wid=1433363
Features:
● High efficiency constant current circuit and constant current output
● Premium type III hard-anodized anti-abrasive finish
● Humanized side switch function, one button to open or close the flashlight
● Stainless steel frame, ergonomic handle with anti-roll design
● High performance aluminum peel orange reflector
● Ultra-clear glass lens tempered with a violet anti-reflective coating
Specifications:
● Emitter Type: XHP 50.2
● Material: aluminum alloy
● Battery: 3 × 18650 Li-ion battery ( not included )
● Lumen: 2920 Lumens
● Operating voltage: 8.4 – 12.6V DC
gearbest
gearbest's picture
1.1800LM 7xT6 USB Rechargeable 18650 LED Headlight
https://www.gearbest.com/headlights/pp_1836402.html?wid=1433363
Main Emitters: XM-L T6
Emitters Quantity: 7
Luminous Flux: 1800lm
Color Temperature: 6000-6500k
Battery Included or Not: No
Beam Distance: 400-500m
Body Material: Aluminium Alloy
2.MHVAST H10 Cree XM – L2 U2 LED Head Lamp – BLACK 3000-3500K 26
https://www.gearbest.com/headlights/pp_1830735.html?wid=1433363
Features:
● CREE new XM – L2 U2 LED with a lifespan of up to 50,000 hours
● Maximum output 560 lumens
● Working Voltage: 2.7V – 6V DC
● High efficient constand current circuit and output-luminance
● Durable, custom-designed micro controller drive circuit
● Side switch and mode changing infinitely variable brightness side switch
● High performance aluminum OP reflector for far throw
● Compatible Battery: 1 × 18650 battery
● Waterproof: IPX-8 standard
gearbest
gearbest's picture
Convoy C8+ XPL HI LED 1100LM Portable Flashlight – DESERT SAND
https://www.gearbest.com/led-flashlights/pp_1845626.html?wid=1433363
Main Features:
● Unique design
Deep diamond knurling, u-shape tail, it is non-slip, waterproof, and abrasion resistance.
● Eight lighting modes
0.1 percent brightness, 1 percent brightness, 10 percent brightness, 35 percent brightness, 100 percent brightness, strobe, biking and battery-check, so many brightness options are convenient for us.
● LED will give you stable and bright light, nonthermal radiation, safe and reliable
● Widely application
It is suitable for camping, fishing, hunting, hiking, searching, working
● Powered by 1 × 18650 rechargeable battery ( battery is not included )
● Light source: XPL HI beads
● Input: 4.2V
gearbest
gearbest's picture
1.HKV Flashlight Distress Signal Emergency SOS Red Flash Warning Lamp
https://www.gearbest.com/led-flashlights/pp_1844217.html?wid=1433363
Lumens Range: 200-500Lumens
Color Temperature: 6000 – 6500K (Cool White), 640 – 780nm( Red )
Feature: Waterproof,Rechargeable
Light Modes: Strobe,Red beacon
Mode: 3(Low – High – Strobe)
Battery Included or Not: Yes
Zooming Function: Yes
Rechargeable: Yes
LED Lifespan: >10000
2.MHVAST TG20 USB LED Dual Mode Flashlight
https://www.gearbest.com/led-flashlights/pp_1830730.html?wid=1433363
Specifications:
● Emitter Type: XPL V6
● Mode: high, medium, low, ECO; strobe, SOS, beacon
● Battery Configurations: 1 × 18650 or 2 x CR123 Li-ion Battery ( not included )
● Lumens Range: 235M
● Waterproof: IPX 8
● Charge: micro USB charging
Features:
● Equipped with high efficiency smart constantly current driver.
● Free Change modes from tactical to memory.
● Hardened ultra-clear glass lens with an anti-reflective violet coating.
3.XM-L T6 LED Flashlight
https://www.gearbest.com/led-flashlights/pp_1836395.html?wid=1433363
Flashlight size: Mid size
Lumens Range: >3000 Lumens
Feature: Waterproof,Cool,Strong
Power Source: Battery,Battery
Battery Quantity: 4
gearbest
gearbest's picture
1.Yeelight Pro Smart LED Eye-care Desk Lamp
https://www.gearbest.com/table-lamps/pp_1842996.html?wid=1433363
Specifications:
● Power: 15W
● Input Voltage: 100 – 240V
● Working Voltage: 12V, 1.5A
● Color Temperature: 4000K
● LED Quantity: 88pcs
● Luminous Flux: 650lm
● Adjust Angle: 60 degree up to 90 degree down
Main Features:
● A uniquely-crafted look with durable build that fits simply everywhere.
● Choose favorite color temperature and brightness level for studying, relaxing or sleeping.
●Energy-efficient LED lamp emits non-ghosting and non-flickering lighting for eye protection.
● The stand can be adjusted for better visibility.
2.Xiaomi FZ101 Portable Zoom Flashlight
https://www.gearbest.com/led-flashlights/pp_1846889.html?wid=1433363
Specifications:
● Model: FZ101
● Interface: USB Type-C
● Battery Capacity: 2600mAh
Main Features:
● Lightweight Mini Design:
With its mini size, it is portable for you to bring it outside. The body is made of premium aluminum alloy with strong and sturdy design.
● 672 Lumens Brightness:
The max brightness is 672 lumens, meeting your needs of night camping, running, observation or exploration perfectly.
● 2600mAh Large Capacity Battery:
Comes with a 2600mAh large capacity battery, bringing you a brightness endurance for 2375mins.
3.PHILIPS LED Desk Light Stand Table Lamp
https://www.gearbest.com/table-lamps/pp_1847296.html?wid=1433363
Main Features:
● Energy saving; built-in LED, as part of the system
● Energy efficient; energy saving, compared to traditional light sources
● Advanced LED light; adjustable light intensity with dimmer switch
● Bright cool white light; Philips LED desk light stand with suitable color temperature
● Philips LED desk light stand with minimize the light that is reflected from the surface
● Excellent heat dissipation; there is no risk of burns
Agro
Last seen: 33 min ago
Xiaomi included a pre-collimator? Nice!
gearbest
gearbest's picture
Dear Agro,
There is not including a pre-collimator.
gearbest
gearbest's picture
1.JETBeam BR10GT LED Rechargeable Bike Light
https://www.gearbest.com/led-flashlights/pp_1848493.html?wid=1433363
Main Features:
● Unique design, compatible with multiple platforms: bicycle, handheld, rail mount and many more
● Rechargeable by USB port with water-resistant rubber cover
● Maximum output of 1100 lumen reach out to 230 meters
● Digital stitch constant circuit control. Up to 14 hours of runtime
●Battery Included or Not: Yes
2.ZHISHUNJIA 3-Mode XM-L2 White Light Flashlight / IPX8 100m Diving Depth
https://www.gearbest.com/led-flashlights/pp_1847019.html?wid=1433363
Feature: Waterproof,Diving,Charging indicator,Adjustable brightness,Power Indicator,Side Switch
Photographing,EDC,Rescue,Search
Battery Quantity: built-in 5400 mAh lithium-ion battery
Rechargeable: Yes
3.Folomov CAMP D4 Flashlight Campact and Portable Outdoor Torch 1080 Lumens
https://www.gearbest.com/led-flashlights/pp_1847023.html?wid=1433363
Flashlight size: EDC
Emitters: Cree XP-L V6
Emitters Quantity: 1
Luminous Intensity: 1080 Lumens
Feature: Waterproof,Lightweight,Portable,Popular,Adjustable brightness,Water Resistant,Pocket Clip,Anti-Roll Rugged Design,Lanyard,Integrated Heat Dissipation Design,Strong
Mode: 4(High – Mid – Low – SOS)
Rechargeable: No
Waterproof Standard: IPX-8 Standard Waterproof
Agro
gearbest wrote:
Dear Agro,
On the picture we can see that the light uses 2 lenses. In this rare setup we call the one closer to the LED a pre-collimator.
gearbest
gearbest's picture
1.ROFIS R2 700LM Tail Magnetic USB Rechargeable Flashlight
https://www.gearbest.com/led-flashlights/pp_1853796.html?wid=1433363
Main Features:
● Adjustable angle head
Flashlight head and body can be adjusted from 0 – 90 degrees. It is very convenient and practical.
● Indicator reminder
It has charging indicator, power detection, low battery reminder, active temperature control circuit, etc.
● Five lighting modes
700lm in extreme light, lighting time ( 330lm after 3 minutes ), 300lm in highlight, 98 minutes in lighting, 90lm in mid light, and 253 minutes in lighting; low profile 5lm, lighting time 43 hours; moonlight 0.5lm, lighting time 125 hours.
● Uses a 14500 800mAh lithium-ion battery
● Compatible with alkaline AA batteries and Ni-MH AA batteries
● IPX 8 ( 2 meters underwater ) waterproof, 1.5 meters drop-proof
ROFIS R3 Multifunction Bright Flashlight
https://www.gearbest.com/led-flashlights/pp_1849552.html?wid=1433363
Main Features:
● Magnetic tail cap
The powerful magnetic tail cap can be attached to the metal object, combining with head rotation, which enriches its usage scenarios.
It can be used as a headlamp, flashlight and so on.
● Uses a 18650 3400mAh lithium-ion battery
gearbest
gearbest's picture
Features:
Introductions:
● Press the side switch to turn the flashlight on / off ( High mode comes on first ).
● With the flashlight on, press and hold the side switch to ramp through the infinite variable brightness system. When the desired mode is reached, release the switch to memorize the mode.
● With the flashlight on, double click the side switch to access the hidden strobe mode. Double click again to access SOS mode.
ON THE ROAD MX3-HL USB Charging LED Head Lamp (Exclude Battery Pack)
https://www.gearbest.com/headlights/pp_1687029.html?wid=1433363
Main Features:
1.Mini type
2.Light weight
3.Smart Temperature Control in Real-time
Using Methods:
1.Wire Control Switch, double click and direct access to Turbo.
2.Triple – click, and direct access to Strobe.
3.Wire Control Switch is optional, some products have no wire control.
No wire control need to press the switch to activate Turbo and Strobe.
gearbest
gearbest's picture
SKILHUNT M200 USB Compact EDC Flashlight – NATURAL WHITE 4500 – 5000K
https://www.gearbest.com/led-flashlights/pp_009560930996.html?wid=1433363
Main Features:
● Unique design
Unique compact design, it is non-slip, waterproof, and abrasion resistance.
● Brightness level
Press side switch to low, mid, high, turbo, cycle.
● Super bright and latest CREE XP – L LED, max 1200lm, high-performance, high-efficiency, and energy conservation
● Built-in magnetic charging system, fast charge and convenient
● Automatic memory function, remember last used setting and can be preset to specific output mode for instant access.
● Low-voltage prompts function
The light will flash when the battery is low, remind the user to replace the battery on time.
● Powered by 1 × 18650, 2 x CR123A, 2 x RCR123A ( battery is not included )
● Voltage: 2.7 – 8.4V
Waterproof rate: IPX – 8
gearbest
gearbest's picture
Main Features:
● Springs at both ends mitigate shock for increased reliability
Emitters: Cree XML-T6
Emitters Quantity: 12
Battery Quantity: 4
Specifications:
● Lumens: 1250 Lumens
● Waterproof: IPX 8
● Input Voltage: 2.7 – 6V DC
gearbest
gearbest's picture
1. Jetbeam TH15 Tactical Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009530129764.html?wid=1433363
Main Features:
● Unique triple tail switches ( JETBeam’s patent ) and a side switch design
Using triple tail switches and a side switch design, it is convenient for us.
● Seven lighting modes
Very bright, bright, medium light, low and medium light, low light, energy saving, flashing, so many brightness options are convenient for us.
● Powered by 1 × 18650 2600mAh rechargeable lithium-ion battery
● Waterproof rating: IPX – 8 ( 2 meters underwater )
● Voltage: 5V
Irradiation distance: 228m
2.Nitecore LR12 1000lm Flashlight Camping Light
https://www.gearbest.com/led-flashlights/pp_009307968687.html?wid=1433363
Main Features:
● Unique design
Tail cover rotary switch design, it is non-slip, waterproof, and abrasion resistance.
Signal light, low light, medium light, high light, extremely bright, so many brightness options are convenient for us.
● Light source: CREE XP – L HD V6 beads
● Voltage: 3.7V
Irradiation distance: 200m
3.Nitecore MT21C Tail Magnetic Flashlight
https://www.gearbest.com/led-flashlights/pp_009877396626.html?wid=1433363
Main Features:
● Aluminum material
Using aluminum material, it is non-slip, waterproof, and abrasion resistance.
● lighting modes
Extremely high light, high light, medium light, low light, energy-saving gear, flash, SOS, beacon light, so many brightness options are convenient for us.
● Voltage: 3.7V
4.Nitecore GEM10UV Stepless Dimmable Flashlight
https://www.gearbest.com/led-flashlights/pp_009998598739.html?wid=1433363
Main Features:
● Aluminum material
● 3000mW UV light
It is suitable for identification jewelry and so on.
● Powered by 1 × 18650 rechargeable battery ( not included )
● Voltage: 3.7V
gearbest
gearbest's picture
Jetbeam WL – S4 – GT Searchlight LED Flashlight
https://www.gearbest.com/led-flashlights/pp_009241569169.html?wid=1433363
Main Features:
● Aluminum alloy material
Using aluminum alloy material, it is non-slip, waterproof, and abrasion resistance.
● Button switch
● Six lighting modes
Extremely low light, high light, medium light, low light, flash, SOS, so many brightness options are convenient for us.
● Powered by 4 x CR123A or 2 × 18650 battery ( not included )
● Light source: CREE XHP70 beads
● Voltage: 5V
Irradiation distance: 400m
Charging time: 4h
Head diameter: 63mm
Body diameter: 26mm
Length: 243mm
gearbest
gearbest's picture
New Arrival June 27th
1.Convoy S9 XML2 Direct Charge Side Switch Flashlight – BLACK 6000 – 6500K
https://www.gearbest.com/led-flashlights/pp_009210413813.html?wid=1433363
Main Features:
● Side switch
● lighting modes
When the flashlight is off, press and hold the button to start the moonlight file 0.1 percent.
When the flashlight is off, click the button, you can turn on the gear after the last flashlight was turned off ( the gear is 0.1 percent moon – 3 percent low – 30percent mid – 100 percent high, double-click strobe flash )
When the flashlight is turned on, long press the button, you can turn off the flashlight.
● Powered by 1 × 18650 battery ( battery is not included )
● Light source: CREE XML2 beads
● Voltage: 4.2V
Waterproof rate: IPX – 6
2.Convoy C8+ XPL HI Portable LED Flashlight – BLACK 4000-5000K
https://www.gearbest.com/led-flashlights/pp_009317032402.html?wid=1433363
Main Features:
● Tail switch
● 12 groups of 55 modes
● Light source: CREE XPL HI beads
● Voltage: 4.2V
3.TANK007 TK360 – 1 R5 Outdoor Portable LED Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009441545082.html?wid=1433363
Main Features:
● Aluminum material
● Tail button switch
● One mode
● Powered by 1 x CR123 or 1 × 16340 battery ( battery is not included )
● Light source: CREE XP – G2 beads
● Voltage: 0.8 – 4.2V
4.Outdoor Lighting Multifunctional Aluminum Alloy Charging LED Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009309728890.html?wid=1433363
Main Features:
● Aluminum material
● One mode
5.Convoy M2 Portable LED Flashlight – BLACK 6000 – 6500K
https://www.gearbest.com/led-flashlights/pp_009917547179.html?wid=1433363
Main Features:
● Unique design
Simple design, it is non-slip, waterproof, and abrasion resistance.
● Light source: XML2 beads
● Voltage: 4.2V
Wieselflinkpro
Last seen: 50 min 10 sec ago
Yippie! I was waiting verry long for the next XR-E Flashlight! Big Smile
Main Features:
● Aluminum material
● One mode
gearbest
gearbest's picture
Main Features:
● Aluminum material
● One mode
Hi friend,
Thank you for your attention to Gearbest.
Once we have now item we will listed here.
gearbest
gearbest's picture
July 2nd new arrival:
1.Mecarmy PS14 – A Aluminum Alloy LED Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009589450488.html?wid=1433363
Main Features:
● lighting modes
Turbo, high, middle, low, strobe, so many brightness options are convenient for us.
● Powered by 1 × 14550 battery
● Light source: CREE XPL – HD LED, one cool white one neutral white
● Voltage: 1 – 5V
2.Mecarmy FL10 Portable LED Flashlight – BATTLESHIP GRAY
https://www.gearbest.com/led-flashlights/pp_009629756080.html?wid=1433363
Main Features:
● Titanium material
Made of TC4 titanium, lightweight, portable, permanent color, corrosion and scratch resistant finish.
● lighting modes
Triple clicks to access turbo mode, click again for strobe
● Standard micro USB charging port with charging indicator
● Keyring attachment hole design, easy to carry
● Bottom bezel design for self-defense in the emergency
● Powered by built-in 120mAh lithium-ion polymer rechargeable battery
● Light source: CREE XP – G2 S4 LED beads
● Voltage: 3 – 5V
Waterproof rate: IPX – 5
3.NiteCore BR35 1800LM Bicycle Lamp – BLACK
https://www.gearbest.com/led-flashlights/pp_009849224740.html?wid=1433363
Main Features:
● Aluminum material
● lighting modes
Extremely high light, high light, medium light, low light, so many brightness options are convenient for us.
● Built-in 6800mAh rechargeable lithium-ion battery
● Light source: CREE XM – L2 U2 beads
● Voltage: 3.7V
Charging time: 3h
gearbest
gearbest's picture
July 5th New Arrival
1.Tank007 TC29B Portable LED Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009227476125.html?wid=1433363
Main Features:
● Aluminum material
● Five modes
● Light source: CREE XR – E Q5 beads
● Voltage: 3.0 – 4.5V
● Button switch in the head
Irradiation distance: 500m
Charging time: 4h
Working time: highlight 3.5 hours, low light 10 hours
2.Orcatorch D820V Waterproof Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009191031179.html?wid=1433363
Main Features:
● Powered by 1 × 26650 rechargeable battery
● Titanium alloy side key switch, convenient operation
● USB charging function
● Professional anti-pressure waterproof structure design, diving depth of up to 150 meters
● Anti-reverse design to prevent damage to the circuit caused by battery reverse mounting
● Battery over-discharge protection
● Light source: XM – L2 ( U4 ) 4pcs / XPG(R5)2pcs /(UV purple)2pcs beads
● Voltage: 3 – 8.4V
Waterproof rate: IP68
Irradiation distance: 318m
Charging time: 3.5h
Wieselflinkpro
Main Features:
● Aluminum material
● One mode
Hi friend,
Sorry, this was ironic. It’s a verry old LED with not up to date efficiensy.
I dont want to by a Flashlight with Cree XR-E LED.
gearbest
gearbest's picture
July 9th New Arrival:
1.Xtar VC4 18650 4-slot Lithium-ion Ni-MH Battery Charger – BLACK
https://www.gearbest.com/chargers/pp_009676245583.html?wid=1433363
Main Features:
●Four slot
Compatible with most rechargeable lithium-ion batteries and nickel-chromium-nickel-metal hydride batteries.
●LED indicator light design
Real-time battery voltage display, each cell voltage is approximately 10 percent of the battery capacity.
● LCD display, innovative turntable style
● Charge current display, suitable for all 5V USB power supplies
● Four-slot independent
● 0V voltage activation function, over-discharged battery
● 0.5A and 1A charging current
● Overcharge / overcurrent / overvoltage protection
2.Xtar Rocket SV2 Smart Quick Charger – BLACK
https://www.gearbest.com/chargers/pp_009806508920.html?wid=1433363’
Coupon code: IT$LEDSV2
Main Features:
●Double slot
● LCD screen displays battery power, charging status and charging current
● Automatic identification for simultaneous charging of lithium-ion and nickel-metal hydride batteries
3.lii-500 18650/26650 Lithium Battery Charger with LCD Display – BLACK
https://www.gearbest.com/chargers/pp_009343206925.html?wid=1433363
Main Features:
Different specifications of batteries can be charged simultaneously such as 18650 / 26650 / AA / AA / A batteries, etc.
4 charging slots
Features 4 charging current regulator, 300mA / 500mA / 700mA / 1000mA. Each channel works independently
LCD screen
Updates every second to keep you in the loop on the charging process
Quick test mode
4 channels detect the battery capacity quicker than the Nor mode Short circuit / over-current / over-charging / over-discharging / reverse polarity protection / temperature control / charging between 1.65 – 2.2V / bad battery recognition and activation
DC input voltage: 12V / 2A
Car charger input voltage: 12V / 1A
Please NOTE: batteries are not included.
4.Allmaybe TC2 Lithium-ion Battery Charger – BLACK
https://www.gearbest.com/chargers/pp_009360164937.html?wid=1433363
Coupon code: IT$LEDTC2
Main Features:
●Double slot
● It can charge two batteries and one external device at the same time.
● Shell made of ABS fire retardant material, excellent heat dissipation design
● Ingenious display
●0-volt activation function, to save over-discharge lithium-ion battery
●Automatic identification, intelligent selects its appropriate charging gear ( 0.5A / 1A / 2A ) for battery
●The sub-capacity test function, through the release of capacity, accurately measure the actual battery capacity
gearbest
gearbest's picture
July 12th New Arrival:
You can use the coupon code: CA%LA704
1.SUNREI Rechargeable Smart Sensor Fishing Headlight – DARK KHAKI
https://www.gearbest.com/headlights/pp_009850577828.html?wid=1433363
4 Lighting Modes, Last up to 110 Hours,
Adjustable Strap,
IPX6 Waterproof Headlamp for Camping Running Hiking
Product Specification
Technical Parameters (Mode, Lumen, Lighting distance, Burn time):
Middle in Spotlight (70 lumen, 46m, 18hours)
High in Spotlight (230 lumen, 85m, 5.6 hours)
Low in Spotlight (9 lumen, 15m, 110 hours)
Sensing (140 lumen, 65m, 5.6hours)
2.SUNREI Youdo2s Outdoor LED Waterproof Super Bright Hiking Headlights – GREEN YELLOW
https://www.gearbest.com/headlights/pp_009440823245.html?wid=1433363
Headlight Brand: SUNREI
Type: LED Headlamp
Main Emitters: Cree XP-G2
Emitters Quantity: 3
Luminous Flux: 190
Battery Type: 3 x AAA battery(not included)
Battery Quantity: 3
Beam Distance: 30-80m
Impact Resistance: 1M
3.SUNREI Youdo 3 Outdoor Mountaineering Hiking Rechargeable Headlights – CELESTE
https://www.gearbest.com/headlights/pp_009704558827.html?wid=1433363
Main Emitters: CREE XPG3 R4
Luminous Flux: 190
Feature: Waterproof
Battery Type: Lithium-ion Polymer Battery
Battery Quantity: 1
Rechargeable: Yes
gearbest
gearbest's picture
August 4th New Arrival:
1.NiteCore C2 6500 Lumen Rechargeable Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009157651840.html?wid=1433363
Main Features:
• Powerful output, blazing bright 6500 lumen max output and maximum range of 398m
• Compact body, easy to carry and comfortably fit in your palm
• 5 brightness levels and 3 special modes through the single button control
• Memory feature to access the previously used brightness
• Charging time is 3 hours
2.Xtar D26 Outdoor Portable LED Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009173812850.html?wid=1433363
Main Features:
• Using high-quality CREE XM – L2 U3 chip, max output of 1100lm and beam distance of 310m
• Features 4 brightness modes, ( 1100lm / 600lm / 200lm / 60lm ), suitable for using in different situations
•Mid-size and lightweight, convenient to carry
• Power supply: 1 × 18650 ( not included ) / 1 × 26650 battery ( included )
3.Mecarmy PS16 Stainless Steel Flashlight – DARK GRAY
https://www.gearbest.com/led-flashlights/pp_009412356782.html?wid=1433363
Main Features:
●Stainless steel material
Ultra bright USB rechargeable flashlight, constructed from CNC precision machined stainless steel, it is non-slip, waterproof, and abrasion
resistance.
●lighting modes
● Powered by 1 × 16340 battery ( included)
● Light source: CREE XP – G3 S5 LED beads
● Voltage: 3 – 4.5V
4.Mecarmy PS14 – A Aluminum Alloy LED Flashlight – BLACK
Main Features:
●Aluminum alloy material
●lighting modes
● Voltage: 1 – 5V
5.Mecarmy FL10 Portable LED Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009546450146.html?wid=1433363
Main Features:
●Titanium material
●lighting modes
● Unique titanium switch prevents accidental activation
● Voltage: 3 – 5V
blantek
Last seen: 7 months 1 week ago
Hi GearBest!
Is there any chance you add this product to your store?
Nitecore NU25
gearbest
gearbest's picture
August 13th New Arrival:
1.WUBEN A21 Portable Super Bright LED Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009529056619.html?wid=1433363
Main Features:
●Aluminum body material
Using aluminum body material, it is non-slip, waterproof, and abrasion resistance.
● Side button switch design, easy to use
●Light modes
5 modes / strobe / stepless dimming design, so many brightness options are convenient for us.
●IP – X8 waterproof
● Powered by 1 × 21700 battery ( included )
● Light source: CREE XHP70 LED beads
2.Brinyte DIV15S Portable 4-LED Diving Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009610893343.html?wid=1433363
Main Features:
• Using high-quality CREE XPL – Hi V3 bead, max output of 3800lm and beam distance of 442m
• High / medium / low / super low / beacon / SOS / flash seven modes, suitable for using in different situations
• Side switch, easy to use
•Made of aluminum alloy, comfortable hand feeling
• Rotatable adjustable dive handle bracket for easy use
• Mid-size and lightweight, convenient to carry
•IPX – 8 waterproof, can sneak into the water 200 meters
• Power supply: 2 × 26650 battery ( not included )
gearbest
gearbest's picture
August 21st New Arrival:
1.Boruit BC09 Super Bright Portable LED Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009895787548.html?wid=1433363
Main Features:
• Using high-quality CREE XM – L2 chip, max output of 750lm and beam distance of 180m
• Power supply: 1 × 18650 ( not included ) / 2 x CR123A battery ( not included )
• LED will give you stable and bright light, nonthermal radiation, safe and reliable
• IPX – 8 waterproof
2.Nitecore C1 Portable 1800lm Waterproof LED Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009933401264.html?wid=1433363
Main Features:
● Featuring a premium CREE XHP35 HD E3 LED for a super bright 1800 lumens max output
●High efficient constant current circuit board provides constant illumination
● Crystal coating technology combined with precision digital optics technology for an extreme reflector performance
●Power indicator beneath the side switch displays remaining battery power and blinks to report battery voltage to the nearest 0.1V
● The built-in ATR module automatically regulates its output and adapts to the ambient environment, maintaining optimal performance
● Powered by one 18650 battery or two CR123A batteries ( battery not included ), the C1 offers up to 300 hours of runtime on low and up to 30 minutes on the turbo
● Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish with a magnetic tail cap
● Toughened ultra-clear mineral glass with anti-reflective coating; waterproof level is up to IPX8, two meters submersible
3.Boruit BC05 Super Bright Portable LED Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009823667715.html?wid=1433363
Main Features:
• Using high-quality CREE XP – L2 chip, max output of 1180lm and beam distance of 285m
• High / medium / low / strobe / SOS modes, suitable for using in different situations
• Power supply: 1 × 18650 ( not included ) / 2 x CR123 battery ( not included )
MascaratumB
MascaratumB's picture
Last seen: 6 hours 32 min ago
This image is wrong, both here and on your site! Facepalm
It is related to the Nitecore Concept 1… Flat Stare
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 /// KLARUS: XT1C
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8  TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
 MY GIVEAWAY (FW3A)
