Code now public! BLF A6 FET+7135 Light. Short 18350 tubes and Unanodized Lights Available
6254 posts / 0 new
Tank
Last seen: 1 month 4 weeks ago
Hi,
Sing me up for 1 CW
Thanks
BR
//Tank
raccoon city
raccoon city's picture
Last seen: 12 hours 1 min ago
I'm signed up for one BLF Eagle Eye A6.
I would like a total of two, both NW.
Thanks.
ChibiM
ChibiM's picture
Last seen: 6 hours 48 min ago
and last but not least, the price?
it says "around $22-23"
mrcobra
Last seen: 3 years 10 months ago
Sign me up for:
2xCW
vēer
vēer's picture
Last seen: 2 months 2 days ago
Subscribed!
cajampa
Last seen: 3 years 3 months ago
Joat wrote:
chouster wrote:
Thanks Dale!
Do you think this could easily be transformed into a triple?
I’ve got a normal A6 I made into a triple, I need to get the spacer print out for quote. I’ve been carrying my non group buy A6 with a MTN Fet + 7135 board, a similar TK firmware and triple XPL’s for a couple of weeks now. These are going to be great lights stock, and easy to mod into monsters.
Please tell me the dimensions on the need spacer, so i can figure out. If this is something that i could be try and build myself, maybe by stacking mcpcbs or reflowed copper plates together, or if i need to wait for a GB for the needed spacer, because it is an tricky shape to it.
DB Custom
DB Custom's picture
Last seen: 4 hours 56 min ago
cajampa, I think it’d be pretty easy to use a couple of extra copper mcpcb’s or a disc if you have those available. A 16mm in the pocket, then stack 20’s on top of that to get the right height…probably 2 without actually measuring it out. Then there’d be more copper under the triple to sponge up the heat.
Realistically, you’re not gonna run a triple very long in this light as it will get hot fast. But the small tube shape makes it very easy to carry and a triple would be a huge flood of light from this host that overall wouldn’t be/isn’t much larger than the cell that powers it. I’ve got one of the Convoy tube lights that ComfyChair modded for Richard and it’s a potent little number to be sure! I like that it slips easily into a camera bag or almost anywhere. Wink
cajampa
Sounds good & doable Smile thanks Dale.
A triple XP-L will of course get very very hot quick, but that is what modes & off is for Big Smile
And i think IOS said something about XP-G2 3D being available soon (maybe they already are, i haven’t checked).
Could a triple XP-G2 be a not so hot option? If not 3D i wouldn’t even consider it, but now it is as far as i know the only 3D available.
It is always fun to, i would say almost half of it or more Wink work out a possible upgrade path, before i even get the light.
DB Custom
DB Custom's picture
The XP-G2’s will get hot as well as they’ll be more overdriven. Remember that they’re rated at 1.5A. A good triple with XP-G2’s will easily pull much more than 4.5A, typically 9A or more. So the heat is still there from the overdrive thing.
Drive 3 XP-L at 9A and you’re within specs, making less heat and far more lumens. Wink
(Then again, if you drive 3 XP-L at 15A…)
cajampa
Good points Smile
I guess i will have to wait for more nice tint emitters to show up in XP-L (we snagged up the last few available from Richard Big Smile but those i have already plans for), and maybe take it easy with the low resistance mods, maybe even do some high resistance mods Shocked Big Smile to keep the amp in check if needed on the triple XP-L.
ikaruz_500
Last seen: 1 week 2 days ago
I would take four of it in NW.
It is so dark here 8)
Thanks.
GnR
Last seen: 2 years 6 months ago
GnR wrote:
Nevertheless - I am in for 1x nw
+ 1x cw
So, 1x nw and 1x cw for me, pls.
Kodachrome40
Kodachrome40's picture
I have a feeling more than a thousand of these little lights will sell.
Powered by BLF ! Smile
DB Custom
DB Custom's picture
Ok, a more thorough exam… Krono wanted me to go ahead and bypass the tail pcb for him, so I put a 22 ga wire through the board to help keep it reliable and solid. Same 22 ga on the top end. They’ve already got 22 ga on the driver as it turns out, so I left that alone.
So what I’ve done to Krono’s light is put a copper Noctigon under the factory emitter, and add 2 little short pieces of 22 ga wire for the current to run through (the bypasses). Here’s the results…
0.01A at 00.93 lumens
0.03A at 13.97 lumens
0.15A at 62.45 lumens
0.38A at 191.48 lumens
1.48A at 439.19 lumens
2.96A at 852.15 lumens
5.65A at 1490.4 lumens with a 30 second run showing 1418 lumens.
I started with amp readings, then measured the lower outputs first…. so the cell wasn’t fresh full hot for the max Turbo readings. So these numbers are pretty real world like you’d see in normal use. The 30 second run in the light box had the head pretty warm, almost hot, but still it didn’t drop all that much, what, 72 lumens? So not shabby at all! Smile
With 5 of these samples in hand, I am seeing some different numbers on the mosfets and even one completely different set-up (which we knew about) The oddball one uses 2 smaller mosfets and while it pulls more current it doesn’t make as many lumens…. not as efficient so it won’t be our choice at all. There is some variance between the different samples, but it’s slight and really insignificant. Best as I can tell, with limited actual run time clocked, these look pretty much good to go. Get the copper in there on the top and call it the best group buy ever. Wink
DB Custom
DB Custom's picture
cajampa, put a 3200mA Panasonic BD in the triple… let it be the resistance, it should do some 6-7A and have the best run time to boot. Smile
Edited my miscue on the capacity of the BD. Wink
MG
Last seen: 2 hours 41 min ago
DB Custom
DB Custom's picture
Dang! I’m gonna have to be the official poster boy for Eagle Eye! lol
I LOVE their little lights! With 8 hot rodded X6’s ranging from 1800 lumens (single XM-L2) to 5500 lumens (single XHP-70) and now this little beastie, I have far more Eagle Eye lights than any other brand. Worthy, if you ask me. And I have 2 more X6’s to build to complete my top 10 EDC collection. Smile
Streamer
Streamer's picture
Last seen: 48 min 19 sec ago
[qote=DBCstm]Ok, a more thorough exam... Krono wanted me to go ahead and bypass the tail pcb for him, so I put a 22 ga wire through the board to help keep it reliable and solid. Same 22 ga on the top end. They've already got 22 ga on the driver as it turns out, so I left that alone. So what I've done to Krono's light is put a copper Noctigon under the factory emitter, and add 2 little short pieces of 22 ga wire for the current to run through (the bypasses). Here's the results... 0.01A at 00.93 lumens 0.03A at 13.97 lumens 0.15A at 62.45 lumens 0.38A at 191.48 lumens 1.48A at 439.19 lumens 2.96A at 852.15 lumens 5.65A at 1490.4 lumens with a 30 second run showing 1418 lumens. I started with amp readings, then measured the lower outputs first.... so the cell wasn't fresh full hot for the max Turbo readings. So these numbers are pretty real world like you'd see in normal use. The 30 second run in the light box had the head pretty warm, almost hot, but still it didn't drop all that much, what, 72 lumens? So not shabby at all! Smile With 5 of these samples in hand, I am seeing some different numbers on the mosfets and even one completely different set-up (which we knew about) The oddball one uses 2 smaller mosfets and while it pulls more current it doesn't make as many lumens.... not as efficient so it won't be our choice at all. There is some variance between the different samples, but it's slight and really insignificant. Best as I can tell, with limited actual run time clocked, these look pretty much good to go. Get the copper in there on the top and call it the best group buy ever. ;)[/quote]
https://www.youtube.com/watch?v=arZdeg_fL-I
DB Custom
DB Custom's picture
chouster
Last seen: 7 hours 39 min ago
just some copper boards and this will be the BLF epic edition.
Streamer
Streamer's picture
DBCstm wrote:
LOL !...Thanks D.   Couldn't figure out how to embed the video...This clip seemed MOST appropriate for your updates.  Laughing
M4D M4X
M4D M4X's picture
the final sold version will have a dtp copper MCPCB – right?
already member of M4DM4X.com ?
the best deals are waiting for YOU!
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
Tom E
Tom E's picture
Last seen: 6 min 14 sec ago
Dale - some Q's:
  • from those 7 modes listed above, looks like they are using a 380 mA 7135, not a 350 mA - think that's correct? Actually it's a pretty good idea - I should build my DD+1's that way from now on.
  • Since you think you got a neutral tint, maybe 3C, do you see the tint shift going from mode 4 (.38A) to mode 5?
  • since you are hitting close to 6A, suppose they are not using those "new" lower max amp XM-L2's. Every XM-L2 T6 4C I've gotten seems to go to 6.5A with no problem.
  • I just built a hot setup DD+1 ZY-T11 clone (UCL lens, 20 AWG LED wires, + direct from cell to LED, 20 AWG bypass's, etc.) with RMM's XM-L2 U4 1C and it max's out at about 5.12A, though still delivers about 1,700 lumens @30 secs. Wondering do you think a CW in this A6 will also have the limited high amps? Have you tested a CW? They may still be using U2 1A's, and if so, may still be high amp capable.
ToyKeeper
ToyKeeper's picture
Last seen: 3 hours 11 min ago
Looks like the timing works out so I’ll be able to test and update it as soon as I receive it.
DBCstm, thanks for the levels for each mode. It looks like the middle modes may be running a tad bit off spec, but that’s easy enough to recalibrate. The visual difference (cube-root model) between each of the modes ranges from 1.43 to 1.94 instead of being a constant value for each, so I’ll see what I can do to adjust that.
Tom E
Tom E's picture
Driver Pic from post #1623 from Dale...
Only things different is the resistors "01C" labeled, if I have that correct (Dale mentioned the FET is different as well). They appear to be connected to the FET and 7135 inputs - tied to ground. Probably to stabilize the signal transitions. I know with my DD+1 driver builds using the SIR800 FET, I get little blinks on transitioning between the 7135 and FET. It also occurs on the DD+1's when just turning an e-switch light ON where it goes to moon initially - you see an intermittently occurring brighter flash for a sec before moon kicks in. Doesn't happen every time. I tried a 100K resistor on the FET input and it helped a little - probably needs a lower resistor...
Just looked it up - a 01C is a 10K, so 10K probably eliminates the flicker. These Eagle Eye guys seem to know their driver designs!
Great Job One and All!!
Ohh - I'm not in on this GB because I'm not a fan of this tube light styling, and can build my own DD+1's anyway, but very interested in how this converison of one of our own driver/firmware combos gets to manufactured in China -- hope this works out, I'm cheering on the sidelines... Smile
kommessy
kommessy's picture
Last seen: 1 week 12 hours ago
Hi,
Sing me up for 1 N Smile W
Thanks
ToyKeeper
ToyKeeper's picture
No, the tint shift shouldn’t be noticeable. I set it up to mix both tints in the middle modes so it’ll gradually transition from the 7135 tint to the FET tint as you get brighter.
Before I set it up that way, the tint shift was very noticeable. Here’s a short video showing how it looked when both channels were set to the same lumen level. The other light here is a Nichia 219b triple, for reference.
Tom E
Tom E's picture
Ahh - ok, so the 0.38A mode then isn't the full 7135, then it's not a 380 mA chip - ok... Dunno your 7 mod values off hand - ok, I'll check out your latest code. Thanks!
cajampa
Yeah that is a good idea, strange i didn’t think about that, i like to build lights without driver, and then the battery is the driver Wink
I wish i had snagged up some of those now gone 20mm quad board Sad
@Tom, Is there really any performance to gain in light output, by using a less efficient U2/T6 XM-L2? Isn’t 1700 lumens at 30 second very good performance, are you saying, that the U2/T6 would output more lumens at 30 seconds?
Tom E
Tom E's picture
cajampa wrote:
@Tom, Is there really any performance to gain in light output, by using a less efficient U2/T6 XM-L2? Isn't 1700 lumens at 30 second very good performance, are you saying, that the U2/T6 would output more lumens at 30 seconds?
Sorry, I'm just stating what I measured... You have a higher bin, cooler LED (U4 1C) running at lower amps and it will outperform a T6 4C that runs at higher amps. The step up in bins compensates for it's lower max amps. In the XM-L2 family, neutrals and warms are still in lower bins than the best cool whites, but unfortunately, the new "revision" or new "batch" of XM-L2 LED's from CREE can't be pushed as hard as the older ones - that's why the U3's and U4's are constrained somewhat, and possibly the warms and neutrals in the T6 and below levels, though I haven't see the warms or neutrals suffer yet.
 To further confuse (everyone?), our light meters measure cooler whites higher than neutrals or warms, from what I understand (djozz proved that). So, my meaurements are all "ballpark" #'s, but Dale's and my measurements compare well because we have the same setups Smile. I could, actually do some calibration/compensation of my measured #'s based on tint, but I don't really want to get into that -- I have nothing "real" to compare to, or calibrate against, accept what djozz published, but too many variables... Frown
