5D Mag - SST-90 - 95mm Aspheric - 9+amp build - Finished on 03/17/15 and beam shots are in Post #1
93 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
It's COLD! here on the 4th of January, 2015. Well, it is for Texans and even displaced Yankees who have been here long enough for the blood to thin.Wink
Who the heck wants to work in a cold garage? Innocent
I just can't leave well enough alone. I will add photos when something more happens.
So, just from helpful posts, I have made some modifications before I did it wrong the first time.
Things have changed since the initial thoughts.
  • A 5D Maglite it is, with Tenergy premium NiMH cells.
  • Wavien Collar or homemade collar
  • Aluminum head
  • A 5D Maglite with either Tenergy Premium D Cells or 5 Series/3 Parallel Eneloops  Edit: I have to think that through. If I go by nominal, 5 cells would be 6V, which is too high for a 7135 driver. If I go with fresh off the charger at 1.4V, it's more like 7V, so that's definitely too much. Maybe 4 cells would be best overall. At Nominal, it gives me 4.8V and off the charger it gives me 5.6V. Time for some testing I guess.
  • A 4" Coupling which will extend the 4" side of the head and put the LED into the larger opening to begin with, more like a normal head would be.
  • A Wavien collar if I can get one
  • Dedome the SST-90. I figured I might be doing that anyhow, when I reflow it the domes usually want to come off and it's probably best.
Members commenting on issues is why I sometimes like to start builds early, so they can catch my mistakes.Tongue Out
01/11/2015 It's Still Cold!, but I did a little work today.
I wanted to see how the SST-90 would look with the 108mm lens, so I set up how the head would be and put the SST-90 on my aluminum rod heat sink, for some testing.
a90a
The SST-90 came from Kaidomain and it's on the stock 20mm mcpcb. It's copper, but probably not DTC. No matter, when it's on this aluminum rod, it will not get hot. Takes about 20 minutes for that long 1-3/4" diameter rod to get real warm.
a90b
I'm using the 2" to 4" PVC reducer with a 4" PVC coupling on top of it, to get the height I need, from the led to the lens. I cut a piece of 4" PVC pipe and put it down in the coupling, so the lens can sit on it. When it is done for real, the Maglite head will go in the 2" end and a custom heat sink will put the led level with the top of the Maglite head and flush with the 2" section of the pipe, so it will shine into the large diameter, instead of being constricted. Thanks to a member's post here, reminding me that I should not have the led down in the smaller diameter.
a90c
I used one of my 26650 cells direct drive. It gives me about 5.4 amps and drops from there. The bottom of the lens ended up being about 154mm from the top of the heat sink, so about 150mm from the led to the lens. The lens was quoted at 190mm, but I think it's more like 160mm to the focal plane. Anyhow, I did some testing and I really wanted to do some good photos, but no matter what I tried with this new camera, I can't get the shot I want, so I have a poor one and then some "smoke shots", to show something of the beam diameter.
a90d
The die does focus, to where I can see the lines on the die, but I just can't get a photo of it.
a90e
The smoke shots kind of give you an idea of how it focuses the light through the lens. It's a really tight spot, compared to what I would see out of a 50mm Aspheric.
a90f
Right now, it gives a reading of 104600 Lux at 1 meter with my cheapie lux meter. I will be shooting for 9 amps. I have decided on using NiMH D cells. Tenergy Premium cells, for the build, so I went with a 5D Maglite. I will test with 4D cells and 5D cells, to see which way is best.
That's all for now. It will still be a while till I get this thing finished. I have to paint the PVC and I can't do that till later on this spring.
01/22/15 UPDATE:
I decided against PVC. I went to speedymetals online and bought 4" OD 6061 Aluminum pipe. That gives me 3.750" ID and the lens is 3.740" OD. I also bought a sheet of .050" 6061 Aluminum, to use inside the pipe, to let the lens rest on. I will form it to fit in the pipe and also on top, to sandwich the lens and hold it in place. The bottom, where it reduces to the OD of the Mag head, will be a piece of 1.750" 6061 Aluminum round stock. That fits in the pipe and I will drill and dremel the opening for the Mag head. It will have to be a press fit. Inside the Mag head will be a big heat sink, that will fit tight in the head and the LED on top. It should take a bunch of heat and it will be so heavy it will need a shoulder strap, LOL.
01/25/15
The Wavien collar came today and I figured I would show a couple photos of it. It came in a large black box and there was a bunch of foam padding around it.
wav1
wav2
The outside
wav3
The inside
wav4
Close-up
wav5
SST-90 for an idea of size.
I will not be testing it till the Aluminum head is done. The Aluminum comes in this week and probably a week more till I get to work on it. Once it is ready and the lens is focused, then I will do testing for lux before and after the collar, to see what the real world results are. Well, ok, not real world, just my world. It's real only to me...
Wavien was not as forthcoming with information as I had hoped. All I got was to "buy the medium collar" and a tiny bit of sarcasm about how I could figure things out for myself, seeing as I am "so knowledgeable", (My Arse). That was a slap if I ever felt one. I tend to bring out the worst in people from the things I say.Sealed They seem somewhat closed mouthed and secretive, so I will disclose whatever I get for results. I don't like secretive.
01/26/15
In order to do a more detailed test, I decided, (thanks to prodding from a member here), to make up a "comfychair BLF collar". That is made out of a reflector from a C/D Incandescent Maglite. It should be interesting to see the results.
cd1a
cd1b
This was made up using the same basic method that comfychair did here. Hopefully, this will help determine what increase you can expect from both collars.
Here's the dimensions on both. I didn't get the BLF collar made exactly the same, but since the actual profile inside is totally different anyhow, I'm not all that worried. I will possibly paint the outside of this collar with silver paint, if I can do it before the test.
Wavien RLT
  • 16mm High
  • 20mm ID on top
  • 32mm OD on top
  • 40mm ID on the bottom
  • 46mm OD on the bottom
comfychair BLF
  • 14mm High
  • 17mm ID on top
  • 22mm OD on top
  • 37mm ID on the bottom
  • 40mm OD on the bottom
That's it for now. More when I have more...
01/27/15
I do love to get stuff in the mail. Well, UPS.
1alu1a
The pipe will hold the lens, (needs to be cut to length). The 0.050" thick flat sheet will be used in strips inside the pipe, to cradle the lens. The large round is for the back end of the pipe and the Mag head will go into it, once I make the hole. The small round is the aluminum heat sink that goes into the head.
Maybe this week-end I will get some time to work on it.
01/29/15
129a
So, the large piece of round stock that I bought has to go over the Mag head. That means making the hole. Easy to do with a thin plate. Not so easy with 1/2" thick stock. I took a 3/8 drill and chucked it in the drill press and drilled a bunch of holes, to get the center out. Then I used end mill bits, in the drill press, to start getting the hole round. Not there yet, but it's getting close. I will probably use a Dremel 115 bit for the final shaping and sizing.
129b
When it's done, it will hopefully be tight over the Mag head, but no matter what, I know I will have to drill and tap for allen set screws, to hold this all together. The 4" pipe will be going over this ring too.
129c
The smaller round stock is for the heat sink in the head. It was 0.025" too small, so I used a piece of 0.012" copper shim, which made it a tight fit.
That's all for tonight.
01/30/15
130a
I managed to get the ring sized, so the Mag head would go into it. Then I drilled holes for Four 4-40 set screws. They go in the ring and into the head, to hold that together. Then I drilled the same holes for Four 8-32 screws on the outside, so I can screw the tube to the ring. I did it that way, so that I could use the larger hole to cut down on the use of a 4-40 tap. I didn't want to try to thread 4-40 all the way through that ring. It worked out pretty good. The set screws go right into the head and the outer screws will hold the tube on tight. I will get some stainless screws for the outside holes.
130b
Progress has been kinda slow. It took a bunch of hours, to get this far. I hope to get the tube cut this weekend and get the lens fit in. I want to get the wavien testing done this weekend. I hope to get that far.
I also got the SST-90 over to a Maxtoch star and got the dome off. I heat those with the hot air gun at 225 degrees and it lets the dome come off easily and seems to leave the sealer over the die to be more clear and smooth. Maybe it's just me, but I like the heating method.
sstdd
01/31/15
The test collars:
testc1a
Maglite Incandescent C/D reflector cut down to use as a collar, on the left.
Wavien Medium RLT Collar, on the right.
testc1b
SST-90 led de-domed and mounted as it will be in the finished light.
testc1c
Lens is in the tube and adjusted for the highest lux value at one meter.
testc1d
Two different batteries. One complete test with each one.
Ten second stabilization before reading each number from the lux meter.
Results
Battery One:
Bare led - 104,000 lux@ one meter
Mag collar - 102,300 lux@ one meter
Wavien collar - 104,500 lux@ one meter
Battery two:
Bare led - 102,900 lux@ one meter
Mag collar - 101,500 lux@ one meter
Wavien collar - 103,000 lux@ one meter
Battery two, with the collars raised 2mm, with shim stock:
Mag collar - 103,200 lux@ one meter
Wavien collar - 102,900 lux@ one meter
Those are the results. I have no opinion, not this time, no way.Wink
Keep in mind that this is not a scientific test. This is a test performed by an old fart, in a garage, in East Texas. Form your own opinions from that...  Or not...
01/31/15
Well, it seems that the project is winding down to a halt again. The head is finished, as far as all the parts being ready.
sst3a
sst3b
sst3c
The good news is that come Monday, all the Aluminum parts will go to Dallas, to be Anodized!  I think it will be a lot nicer light, with the parts Anodized and so does the owner of this light.
Even the aluminum heat sink will be anodized.
So, I need to re-flow the components to the driver and then I just wait till the Aluminum parts come back.
02/10/15 Still waiting on anodized parts...  But, I did take some shots of the things I will try to reach out to.
obj1
This is from the roof of the closed plant. The green arrows are, from left to right, a Hospital, a Bank and a Water Tower.
obj2
The hospital is 2.4 miles away. The taller building in the shot.
obj3
The bank is 2.1 miles away. The tallest building in the shot.
obj4
The water tower is 2.6 miles away and it's going to be the hardest to find at night.
I was totally wrong about the three mile mark. 2.6 miles is the farthest and I doubt I can tell if I even hit it.
The camera is a Sony HX1000v. I plan on ISO 200 and probably 4 seconds shutter speed for these shots.
2/20/15 Anodized parts came in today. I will assemble this week-end.
ano1
ano2
They came flat black, which is good, especially for the interior side of the parts.
The light ended up being a 4D, due to too high of a voltage with 5x "D" cells. The rest of the story is in Post #1.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 03/17/2015 - 02:51
Old-Lumens
The light is done and it fought me from day one, till the very end. I will consider it a triumph and fail, in the same breath. It did finally light up. It did hit a building at 2.1 miles, but it did not do it as I expected. The output is much less than expected, but it worked, so in a way, it's a pass/fail kind of thing. Could be either way, depending on the individual feelings.
90as1a
90as1b
90as1c
The photos above show the finished light, with some smaller lights next to it. The lens was moved till it would give a square dir focus at roughly 1,000 yards. Best I could do and I am sticking to that story.
90asb1
It was VERY hard to align the light on a building 2 miles away and try to capture it, without being able to actually tell where you are hitting the building. The first photo could easily be mistaken as just glare, or an alien ship, or swamp gas... It's on the right side of the big building and it's right on top of a lighted window. A blueish cast over it, see it? Well, maybe not...
But the next photo does prove to me that I hit the building with the light more than once.
90asb2
Now, that might not be very impressive or very bright, but I do believe I did hit the 2 mile mark. 2.1 miles to be more exact. I did not get to my 3 mile goal, but then again, I don't have anything three miles away to aim for. I think an XM-L2 or XP-G2 pushed to higher amps, (like 8 or 10), would hit with a much brighter and smaller beam. I also think that would be even more useless than this light is.
I am determined for this to be the last long distance light I ever do.
Thanks for watching...
M4D M4X
M4D M4X's picture
Last seen: 12 hours 23 min ago
subscribed…
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
nitro
nitro's picture
Last seen: 2 years 2 months ago
Very nice build so far, cant wait to see the other build as well
strayz
Last seen: 1 week 4 days ago
Subscribing to see what Texans use to heat their garage.
Huxley
Huxley's picture
Interesting, especially as i might have a 6 d cell mag kicking about somewhere.
They got banned years ago, now you can only legally carry 4 cell mags over here iirc.
nitro
nitro's picture
i might have to pool the 2bbl aspheric lens i have and get it done after seeing this Smile
WWW
Last seen: 19 hours 9 min ago
Hehehehehe!!! That is a seriously big lens you got there, I can’t wait to see some progress!!! Looking forward sir, looking forward…
AlexGT
AlexGT's picture
Last seen: 6 hours 11 min ago
Here is the popcorn, this is gonna be good! Love
gamezawy
gamezawy's picture
Last seen: 1 month 1 week ago
I and my wife have watched your video just like a movie Love and there was a big smile on my face , i have almost 130mm Aspheric lens that i weren’t know what i could do with it, well now i know Big Smile , then i got shocked when i saw this Big black head with the 4 reflectors , what is that ? and from where you got it ?
subscribed…
Martini
Martini's picture
Last seen: 5 months 4 weeks ago
scdaf wrote:
It’s important to have your restraints within walking distance, lest someone needs restraining. Wink
Blinky1
Blinky1's picture
Last seen: 8 months 2 days ago
Interesting. Smile
..but the LED needs to be 140mm away from the lens? Looks like the PVC piping might block some of the light if the LED is moved that far away?
MRsDNF
MRsDNF's picture
Last seen: 4 hours 8 min ago
9 amps, 3 miles, 4D Maglite, 140mm. You have my attention.
dentillozie
dentillozie's picture
Last seen: 8 months 3 weeks ago
subscribed! this is going to be one epic build
licensed HAM radio opparator
Callsign: ON3DTZ
EU based flashlight modder. If you need any modding work done, make sure to PM me!
some of my mods:
- convoy meLd 4
XHP50 Maglite Mod
UF-1405 Mod
TK35 (clone) to TK35UE
LinusHofmann
LinusHofmann's picture
Definitely interested in seeing this one come together! Looks epic! 8)
I had similar thoughts as Blinky1 about the narrow neck of the adapter possibly blocking some of the emission angle of the LED at such a long focal length?
Oh and you’re sure you don’t want to splurge on an SBT-70 for this build? Seems like the ideal LED for such a monster lens, nice round projected die! :bigsmile:
Old-Lumens
No heat. No AC either, so it's either cold or hot.
Old-Lumens
gamezawy wrote:
I and my wife have watched your video just like a movie Love and there was a big smile on my face , i have almost 130mm Aspheric lens that i weren't know what i could do with it, well now i know Big Smile , then i got shocked when i saw this Big black head with the 4 reflectors , what is that ? and from where you got it ? subscribed…
That black head is a 5 mega and there's a LED ZEP heat sink in it. It was 4xP7 but it will be 4 of the XHP70, maybe someday, when the mcpcbs and some 5000k or 5700k leds come out. It's a build for a customer, just like this one is.
Old-Lumens
Blinky1 wrote:
Interesting. Smile ..but the LED needs to be 140mm away from the lens? Looks like the PVC piping might block some of the light if the LED is moved that far away?
190mm focal length. I don't know how it will come out. That's part of the fun. I am going to try to incorporate a Wavien collar and see how that works. There may very well be an issue with the 2" diameter going to 4", but time will tell. What I might end up doing is to extend the 4" pipe, so that the 2" end just sits over the Maglite head, so the led would basically be into the 4" diameter to begin with. I don't know how it's going to go yet.
Old-Lumens
LinusHofmann wrote:
Oh and you're sure you don't want to splurge on an SBT-70 for this build? Seems like the ideal LED for such a monster lens, nice round projected die! :bigsmile:
It was a thought, but I just want to see how much I can do with an SST-90. I just like those leds for some reason.
chops728
Last seen: 1 day 11 hours ago
Better test run a scrap PVC pipe in the oven before you melt or disform (don’t think that’s a word) all your hard work
LinusHofmann
I know what you mean, I’m still tempted to build something around an sst-90 myself. It’s probably that juicy looking massive die! Smile
ryansoh3
ryansoh3's picture
Last seen: 4 days 9 hours ago
Awesome, looking forward to the build. Smile
Just wondering if the 3 li-ions in parallel would give 9A to the emitter. That might not be enough because with my SST-90, I had to supply 5.00V to drive it at 11A, so I’m assuming it’ll take more than 4.2V to push it to 9A, as well as losses in the wires and the linear driver.
BLF ≠ B-grade Flashlight Forum
Old-Lumens
I don't know. Guess I will have to test it out. The last one I did was with NiMH AA, but that would have been 4.8volt. It might not be enough. I might have to think about NiMH again. 4S/3P. It would be a complicated holder at best. Never had to get to 5 volt on the last one though. If I remember it was more than 4.2 though. Probably NiMH batteries will be the thing to go with.
Old-Lumens
Or possibly 4 of the 9.5 amp D cell NiMHs.
ReyLight
ReyLight's picture
Last seen: 1 day 21 hours ago
Look forward to it.That's really awesome. However,listening is a little hard for me.
OL,did you upload the "Closed Caption"?  or it's auto generated by Youtube? (I noticed there are some words mistakes)
Old-Lumens
Auto generated by youtube most likely. I didn't do it. It was uploaded in english, so youtube must take it over.
Old-Lumens
A few more photos in the OP, of testing the SST-90 and PVC head.
LinusHofmann
Looking cool, that’s already a nicely projected die, even with all the spill that the white tube must produce!
Looks like you’re well on your way with this approach but I just had this thought.
To save yourself the trouble of painting up the plumbing pipe, finishing it all nicely etc. Have you considered looking for cheap camera lens hoods on ebay to do the job of a lens host/shell instead. They tend to be pretty cheap, nicely anodized matte black aluminium and available in all sorts of sizes and step-up step-down configurations. I’ve been looking at what’s available out there and with a bit of luck and searching for compatible bits they could give a nice looking finish on the outside for minimum hassle/cost. Of course you’d have to find something that would work with this gigantic lens. This is the closest I could find that could fit in a quick search.
105mm lens hood
That’s 105mm at the filter thread at the back and about 115 at the front, should fit the lens nicely. It’s also 80mm long so you’re already half way to your focal length goal. Find another hood with a front filter size of 105mm to mate to this one and you’ll have yourself a suitably long and purdy looking host?
The nice thing about these is they all use standard filter size threads on the front and back, so you can lego them together rather nicely and use filter adapters to get down close to the OD of your maglight. I think you can basically build an entire flashlight host that way. This build and my desire for a dedicated large lens aspheric have really gotten the mental gears turning a bit on this, I could see it working quite well.
Anyway, just a thought, I’m sure you’ve got this all covered already and I’ll be keeping a close eye on how you get on with that lens and the lovely SST-90 that’s for sure Smile
Cheers
ImA4Wheelr
Last seen: 4 days 10 hours ago
Very cool.  The faint spill could be very helpful in the wild.  Enough light to move around without bumping into stuff, but not enough to ruin night vision.  Watching with interest.
Old-Lumens
@LinusHoffman - Yes, I have thought about hoods, but with the fact that I need almost 175mm total distance, it's hard to use a hood. Two or three, but not just one. I have used hoods before, the last SST-90 build was with a hood. Thanks for the thoughts though. They do work well for builds.
nitro
nitro's picture
OL i have my large 4inch 2bbl aspheric build im working on and i considered using a stainless steel muffler might sound funny but will look sweet when done Smile
what im using http://www.ebay.com/itm/130868231716?_trksid=p2055119.m1438.l2649&ssPage...
then im going to polish a mag tube to match the stainless
