M4D M4X deals - on vacation... NEW: Astrolux FT03 Mini $30.99 + accessories // FW21 PRO
5135 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 32 min 43 sec ago
Thanks M8 Smile
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
Itsme
Last seen: 1 hour 38 min ago
Just grabbed an EA11, thanks. Any idea when the Imalent HR70 will be in stock? Interested in getting one of those
Thanks Martin
M4D M4X
M4D M4X's picture
M4D M4X wrote:
you can find the deals in M4D M4X deals
IMALENT HR70
XHP70.2 3000LM Brightness Magnetic Charging LED Flashlight Hiking Headlamp Torch
IMALENT HR70 XHP70.2 3000LM Brightness Magnetic Charging LED Flashlight Hiking Headlamp Torch
ready to preorder
be fast before its sold out again!
deals.m4dm4x.com
CoolJB
Last seen: 2 months 4 weeks ago
M4D M4X wrote:
IMALENT HR70
ready to preorder
Just pre-ordered one using your link and code. Thanks! Thumbs Up
vresto
vresto's picture
Last seen: 27 min 40 sec ago
does this make a sense?bad cooling…what do you all think about this new imalent? its crazy…lets say useless….or? btw.chinese new year is over?
EDC...no one yet
Headlamp-Thrunite th30
alevana
Last seen: 9 months 4 weeks ago
Banggood say that the HR70 has been ship to me today. Cool
but I’m very confuse.. one guy on reddit had the HR70 and it DIED in several day..! Facepalm
ssschen
ssschen's picture
Last seen: 9 hours 30 min ago
Any chance of getting a code (better than 20% discount) on the following flashlight?
Astrolux S42 18650 Version 4xNichia 219C/XP-G3 2023LM USB EDC LED Flashlight + INR18650 30Q Battery
Lazy-R-us
Last seen: 2 weeks 4 days ago
M4D M4X,
Now that CNY is over, any chance you can swing a code on a 365nm UV light? It seems people around here like the Convoy, I’m not sure what else is on the market.
Lazy-R-us
M4D M4X
M4D M4X's picture
i am already poking ...
deals.m4dm4x.com
Gerrit
Last seen: 5 hours 24 min ago
Hi Martin, just ordered a Rofis MR70 at Banggood. Thumbs Up
Is there any more information regarding the Lumintop ODF30?
chooma
Last seen: 5 hours 47 min ago
Pm sent Martin…thanks
M4D M4X
M4D M4X's picture
IMALENT DX80
8x XHP70 2nd Generation  32000LM
Outdoor Search LED Flashlight 806M
€U warehouse! (less than 100 available!!)
Code:  GEDX80
price:  € 178,98
Main features
● Using of high brightness 8pcs CREE XHP70 LEDs with 32000 max luminous flux
● Ultra clear toughened glass lens, the light transmission is up to 99pct with scratch and impact resistant
● Waterproof level up to IPX – 8 ( 2m submersible ) the flashlight can work normally even in heavy rainstorms
● The shot distance is up to 806 meters with wide beam range
● Built-in battery pack includes 8pcs 3000mAh 18650 Li-ion batteries with high discharge performance
● Intelligent temperature indicator, when the body’s temperature is up to 50 Deg.C, the LED display flashes 8 times for 30s to give a warning
● When the body’s temperature is up to 50 Deg.C, the light will automatically adjust the current to keep the flashlight to work under 50 Deg.C
● When the battery voltage is under 13V, the battery symbol will flash 10 times per minute to remind user to change or replace the battery
● 5 common mode: 120Lm, 500Lm, 1500Lm, 5000Lm, 13000Lm
● In any mode, double press the button to enter 32000Lm turbo mode, double press again to enter strobe mode
deals.m4dm4x.com
M4D M4X
M4D M4X's picture
deals.m4dm4x.com
shirnask
shirnask's picture
Last seen: 2 hours 24 min ago
Miboxer C4-12 ordered !
Thanks
M4D M4X
M4D M4X's picture
Rofis R2 presale for US$43.99
Hello my dear friends!
today i can offer you a new presale deal for the:
Rofis R2
XM-L2 U3 700LM Rechargeable Magnetic Charging Head Rotation EDC LED Flashlight Headlamp
Rofis R2 XM-L2 U3 700LM Rechargeable Magnetic Charging Head Rotation EDC LED Flashlight Headlamp
Features:
-The head and body of the R2 flashlight are connected by a stainless sreel central axis,the head can be rotated and beam angle can be adjusted as well.(As illustrated in the picture).
-Accurate 45-degree inclined plane;90-degree and 180-degree position;Stainless steel center axis connection;10000 rotation tests.
-Angle surface with non-acute angle design,rotates smoothly;
-Ergonomic rotation design,one-hand operation.
-When R2 is used as headlamp,the user can put into silicone head caps without removing mental clip,which is easy to operate.It would work better with tail cap removed.
-According to the position of the switch and the rotation direction of the head,it is recommended that the user use right hand to press the switch(Put the switch stay towards right above and rotates head into appropriate position to procide lighting).
-With magnetic tail cap,metal clip and adjustable-angle head,it can achieve hands-free operation and procide accurate lightig.
-Battery power detection and low battery power reminder.
-Magnetic USB charging.
-Magnetic base connector supports cttachment to metal objects.
Package included:
1 x Rofis R2 XM-L2 U3 700LM 7Modes Brightness USB Rechargeable LED Flashlight Headlamp
1 x 14500 battery
1 x Headband
1 x Clip
1 x Charging Cable
1 x Lanyard
2 x O-ring
works with 14500 LiIon cells (included) and in case of emergency also with AA NiMh or Alkaline  !
use my Code to get $15 OFF:  MRFS2
deals.m4dm4x.com
klrman
klrman's picture
Last seen: 6 days 19 hours ago
Code for C4-12?
ohbreeeezy
ohbreeeezy's picture
Last seen: 4 days 30 min ago
Got a code for LiitoKala Lii 402?
M4D M4X
M4D M4X's picture
klrman wrote:
Code for C4-12?
https://m4dm4x.com/m4d-m4x-deals/  Wink
i need to ask...
deals.m4dm4x.com
klrman
klrman's picture
M4D M4X wrote:
klrman wrote:
Code for C4-12?
I forgot my pw to login to m4dm4x!
M4D M4X
M4D M4X's picture
you got mail man!  Wink
deals.m4dm4x.com
klrman
klrman's picture
Martin,  you're the best
C4-12 ordered!
arficus
Last seen: 2 weeks 3 days ago
Your Q8 code isn’t working now because light is on sale at BG for another day or so. Any idea if your code will work again after it’s off sale? Otherwise maybe I should buy it now…
M4D M4X
M4D M4X's picture
i am quite sure  (but there is no guarantee)
i have this code since the beginning
deals.m4dm4x.com
M4D M4X
M4D M4X's picture
I was told Haikelight will of course sell their new lineup via banggood.
aaand my code still works Big Smile
(please share my link also when you tell your friends...)
deals.m4dm4x.com
ssschen
ssschen's picture
Is this a certainty?
I am asking because Terry who is now the official Haikelite dealer for US and Canada has indicated on his Haikelite MT09R GB thread that Haikelite will stop selling their flashlights on both BG and GB websites. If true, this is no good for the rest of us that don’t reside in either US or Canada.
ulfm1
Last seen: 1 month 1 week ago
Hi M4D M4X,
is there a posibility to get a code for the Rofis TR20?
Thank you!
M4D M4X
M4D M4X's picture
ssschen wrote:
Is this a certainty? I am asking because Terry who is now the official Haikelite dealer for US and Canada has indicated on his Haikelite MT09R GB thread that Haikelite will stop selling their flashlights on both BG and GB websites. If true, this is no good for the rest of us that don't reside in either US or Canada.
i asked banggood because of the post from Terry
they asked the manufacturer about their local dealer badmouthing
they told banggood there is no stop in business relationship and
Terry might be asked to remove his post...
deals.m4dm4x.com
M4D M4X
M4D M4X's picture
ulfm1 wrote:
Hi M4D M4X, is there a posibility to get a code for the Rofis TR20? Thank you!
i already have one to get it for 50.66
easy way:
look here
not so easy:
send me a pm or mail
deals.m4dm4x.com
ssschen
ssschen's picture
M4D M4X wrote:
ssschen wrote:
Is this a certainty? I am asking because Terry who is now the official Haikelite dealer for US and Canada has indicated on his Haikelite MT09R GB thread that Haikelite will stop selling their flashlights on both BG and GB websites. If true, this is no good for the rest of us that don’t reside in either US or Canada.
Terry might be asked to remove his post…
Martin
Thank you so much for confirming this. Big Smile
M4D M4X
M4D M4X's picture
ssschen wrote:
  Martin Thank you so much for confirming this. :D
Wink
deals.m4dm4x.com
