M4D M4X deals - NEW DEALS if you want the BIGGEST discounts ;)
4938 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 29 min 25 sec ago
will try!
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
Sirius9
Sirius9's picture
Last seen: 20 hours 31 min ago
Hi Martin, any chance you could get a nice code for Aneng AN870?
M4D M4X
M4D M4X's picture
Hey
please remind me after the Promotion (no code would work now)
morpheus1301
Last seen: 3 weeks 1 day ago
Hi Martin,
any code for the
HaikeLite MT01 Trekker XHP50
M4D M4X
M4D M4X's picture
morpheus1301 wrote:
Hi Martin, any code for the HaikeLite MT01 Trekker XHP50
https://m4dm4x.com/m4d-m4x-deals/
it's in my list
if you are not member send me a pm pleaee
M4D M4X
M4D M4X's picture
clearance!
some stuff that must go...
https://m4dm4x.com/clearance-deals/
since my deals get stolen from BLF to be published on commercial pages í cannot post "exclusive" deals here atm
i hope you understand
also nice:
15% OFF a lot of items!
WHOLE SITE! - comment your best catch!
use this link: https://goo.gl/8p92MU
Code: 502C6B
M4D M4X
M4D M4X's picture
Hello my dear friends!
Neal sells a very nice light for a very nice price:
NIGHTWATCH NS22 SEEKER
SST20/SST40/XHP50.2 LED FLASHLIGHT
Specification:
Emitter:   SST20 (1250Lm available in: 3000K 95CRI / 4000K 95CRI / 5000K 75CRI)
SST40 (2100Lm)
XHP50.2 (3200Lm)
Battery:  18650 (not include)
If you want to use 21700 battery,pls add the option 21700 tube
Reflector:  38 mm,aluminum,smooth finish
Lens:         Glass with anti-reflective coating
Body:        Aluminum with Type III hard-coat anodizing
Swtich:  20mm,10A reverse switch
Ingress rating:   IP68, underwater 2 meters
Weight:      184g without cells
Dimensions:    41 mm head x141 mm length
please use my SHOPLINK and the Code: NDNS22 to get 17% discount
also available:
NITECORE MH23
CREE XHP35 HD 1800 LUMENS RECHARGEABLE LED FLASHLIGHT
Deal: https://m4dm4x.com/m4d-m4x-deals/
M4D M4X
M4D M4X's picture
Convoy L6 Promotion
51% OFF (38.99 USD)
LOWEST price ever...
mihlit
Last seen: 5 hours 6 min ago
Klarus Mi1C and Astrolux MH10 codes expired, could you get new ones?
M4D M4X
M4D M4X's picture
i just received another list with deals:
please note: do not share my deals on other places!
Item Code Coupon price
IMALENT DT70 CHBF1 165,00
Folomov A1 HBGLK 5,69
FOLOMOV 18650S drop directly 20,50
IMALENT HR70 JKLH1 53,00
LUMINTOP EDC05 BGED5 22,00
Ultrafire 7W Zoomable drop directly 2,69
Nitecore EC4S BGEC4S 58,99
Convoy L6 BGCL6 44,84
XTAR VC4 drop directly 14,80
NEW Convoy L2 drop directly 35,49
Astrolux MF02 CW BGMF02 75,00
Astrolux MF02 NW BGMF02 75,00
DQG Lighter 2.0 BGDQG1 18,22
DQG 4th BGDQG2 24,50
DQG Hobi 10180 BGDQG3 16,99
DQG Fairy Brass BGDQG4 16,99
DQG Slim BGDQG5 23,75
DQG XP-G2 BGDQG6 31,99
DQG Capsule Mini BGDQG7 6,69
ThorFire VG10S BGS70 15,99
ThorFire TG06S Upgraded Version BGT6S 11,90
ThorFire TK05 BGTK05 14,99
ThorFire C8s Suit BGC8S 19,99
ThorFire 360 BG360 6,99
5Pcs USB Mini Night Light drop directly 1,10
M4D M4X
M4D M4X's picture
due to code stealing and brainless publishing of some 4$$holes i cannot get new Klarus deals atm
teacher
teacher's picture
Last seen: 6 months 3 weeks ago
/\Facepalm …. Utterly amazing what dipshytes a very few people can be…. but messing things up for Martin & everyone else. Sad
korkfoto
Last seen: 1 day 21 hours ago
Excuse my ignorance, but how the “drop directly” works?
Thanks!
FIAT LUX!
M4D M4X
M4D M4X's picture
korkfoto wrote:
Excuse my ignorance, but how the "drop directly" works? Thanks!
i hope they fix those tomorrow - sorry
mihlit
M4X: And what about that Astrolux MH10?
M4D M4X
M4D M4X's picture
i ask for a new code
M4D M4X
M4D M4X's picture
Many of you asked me where to get the RovyVon brand with "Member Benefits" - so i pulled some strings...
banggood listed at first 2 modells (the link in the pictures take you to the shop for detailed infos)
do not forget to check my list for the deals
RovyVon Angel Eyes E300S
Features:
  1. Rectangle EDC Angle LED Flashlights
  2. Made of aluminum alloy with Hard Anodization III finish
  3. Utilizes 3 x CREE XP-G3 S5 LEDs, max output 2000 lumens
  4. Uses replaceable rechargeable Li-polymer 2200mAh battery
  5. Max 5C discharge rate
  6. Micro USB charging and quick charge
  7. Breathing charging indicator and low battery indicator
  8. Overcharge and over discharge protection
  9. An internal thermal control sensor
  10. Ergonomic design for a comfortable
  11. Heat dissipation and anti-slippery grooves
  12. Strong detachable reversible pocket clip
  13. Stand capability
Parameters:
Body Material: 6063 aerospace aluminum alloy
Clip & bezel material: Stainless steel
Dimensions: L101mm x W36.7mm x H17.3mm
Package Included:
Accessories: 1 x 1m paracord, 1 x Clip, 1 x Micro USB cable, 1 x extra USB port cover
RovyVon Aurora A5
Features
  • Semi-transparent luminous body glows in the dark
  • CREE XP-G3 LED, max output 550 lumens
  • Sidelight: White, Red, Red flash
  • Built-in Micro USB charging port
  • 130mAh lithium polymer battery
  • Charging indicator & quick charged in 45 minutes
  • Side switch prevents accidental activation
  • Ergonomic design, one-hand operation
  • Tail paracord hole
  • A lanyard and two-way clip included
  • IP65 water resistance
What's in the box
  • 1*A5 flashlight
  • 1*User manual
  • 1*Beaded chain
  • 1*Clip
  • 1*USB cable
  • 1*Lanyard
*The max output 550 lumens at High mode will step down to 65 lumens in 2 minutes to protect the user and the core components of the light from the heat produced by the light working at High mode.
lotrbfme
lotrbfme's picture
Last seen: 18 hours 14 min ago
Not a huge discount considering that banggood price is higher than MSRP and charges shipping Sad
M4D M4X
M4D M4X's picture
I was told they charge banggood rather high
M4D M4X
M4D M4X's picture
banggood created a collection for the most wanted items paired with a nice discount:
also they added some additional promotions and deals for you!
Let me know what you scored Wink
edit:
the mobile webpage (m.banggood....) has a problem today
the link above does work Wink
banggood tries to fix that asap
in the mean time use a pc or set your mobile browser to "desktop mode"
teacher
teacher's picture
The link does not work Martin…. for me anyway. Wink
M4D M4X
M4D M4X's picture
just the mobile webpage (m.banggood....)
neBstress
neBstress's picture
Last seen: 20 hours 13 min ago
Doesn’t work on my phone but works on my laptop.
[Edit]
Oops M4D M4X beat me to it and posted explanation
By the way, thank you for all the great deals M4D M4X!!
teacher
teacher's picture
M4D M4X wrote:
just the mobile webpage (m.banggood….)
in the mean time use a pc or set your mobile browser to “desktop mode”
Oh… OK, thanks Martin. Sorry about the ‘false alarm’. . Smile
Tom E
Tom E's picture
Last seen: 2 hours 38 min ago
BG is killing me with their great discounts on non-stock items though, then like what happened to my over  the holidays, ordered 2 lights at a great deal, not in stock, asked to split the order, I did and chose to keep the order alive, then they cancelled it on me with no explanation, and of course, coupon codes expired, can't be re-ordered at the same price... frown
I'm seeing the same thing in those collections of non-stocks. Is it a teaser? Well, probably not intentionally but effectively...
I still get the big XMAS code discount on a couple lights though that are shipped, so it's not everything for sure, just some.
JasonWW
JasonWW's picture
Last seen: 34 min 48 sec ago
Make an argument that they are the ones who cancelled. They should reorder at the same price you originally paid. The fault is not on you.
Click this to go to signature links.
Tom E
Tom E's picture
Got a BG order in since Dec 31st for another SP36 at a great price, but shows expected Jan 28th. Wut?? I know they are gonna cancel this order on me too...
M4D M4X
M4D M4X's picture
please do not post prices Wink
Tom E
Tom E's picture
Ohh, ok, done! I just checked - BG never credited me for the cancelled order - I just emailed them. Does anyone know what gives with cancelled orders on BG? Maybe it takes a few days or weeks to refund?
blueb8llz
Last seen: 7 min 30 sec ago
The collection list link does not work.
Can we please get code for blf GT Mini again?
