M4D M4X deals - NEW DEALS: Astrolux S43/S43S copper with LH351D high CRI
5029 posts / 0 new
gchart
gchart's picture
Last seen: 10 min 43 sec ago
Martin, looks nice. But… fountain pen or GTFO Wink
Tally-ho
Tally-ho's picture
Last seen: 1 week 6 days ago
I wish they could make good looking titanium (without funky colored pattern) mechanical pencils 0.5 / 0.9 / 2.0 mm
M4D M4X
M4D M4X's picture
Last seen: 1 hour 43 min ago
Hello my dear friends!
i got the groupbuy for 2 new Lumintop flashlights:
(the links in the pictures and text below take you to the shop for additional info)
LUMINTOP Tool AA 2.0
color: Titanium Gray / Panda White
XP-L HD 550LM 3Modes
AA/14500 Mini LED Keychain Light
Features:
Utilizes XP-L HD LED with a lifespan of 50,000 hours
Powered by one AA or one 14500 rechargeable Li-ion battery, 550 lumens max output
Only 90.6mm in length, 26g in weight, handy and compact, easy to carry
Two ways to select outputs: Tail switching or twist the head
Made of aircraft-grade aluminum alloy with anti-scratching type HAIII military grade hard-anodized finish
Double-side AR coated, tempered window resists impact and thermal shock, max 99% light transmission
Waterproof to IPX-8 standard
Package included:
1 x LUMINTOP Tool AA 550LM Portable LED Flashlight (Without Magnetic Tail)
1 x O-rings
1 x Lanyard
1 x English Manual
LUMINTOP EDC Pico
130LM USB Rechargeable Super Mini EDC Flashlight
Features
Utilizes OSRAM LED with 50,000 hours lifetime
2 modes with a max 130 lumens output and an up to 7.5 hours runtime
Micro USB rechargeable with built-in charging indicator
built-in 3.7V/80mAh 10180 Li-ion battery, fully charge within 57 minutes
Tiny and light-weight design, 41.5mm in length and 11.8g in weight
Three colors optional, black, silver and pink
TIR optical lens creates a soft and balance beam
Glow-in-the-dark O-ring easily locates the light in the dark
Simplify twisty switch, easy operation within one hand control
Make of aircraft-grade aluminum alloy with military grade type III HA matt finish
IP68 rated dust and waterproof protection, impact resistance to 1.5 meters
Size: 41.5*14mm, Net weight: 11.8g
2 years free repair, limited lifetime warranty
Package Included:
1 x EDC Pico Keychain Light
1 x 10180 rechargeable li-ion battery (bult-in can not remove)
1 x Charging cable
2 x O-ring
1 x Keychain
1 x User manual
check the member deal list or use the form below to get the deal!
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
SKV89
Last seen: 16 min 44 sec ago
How is the UI like on this latest Tool?
JasonWW
JasonWW's picture
Last seen: 51 min 37 sec ago
Oh no, why would they make the 10180 Pico battery non-removable?
Is there over discharge protection in case it gets turned on while in your pocket?
The 10180 is not available in a protected version so it’s easy to ruin these little batteries.
M4D M4X
M4D M4X's picture
the tool is a Tool AA 2.0
and I saw on Facebook they announced it as panda white and black - asked for confirmation.
M4D M4X
M4D M4X's picture
confirmed itx a Tool AA 2.0
color is called "Panda White and Black"
link has changed too!
M4D M4X
M4D M4X's picture
Hello my dear friend!
Here is the groupbuy for thew new:
(links in pictures take you to the shop for detailed Productinfo)
ROFIS R4
XHP50.2 2300 lumens
6Modes Head Rotation Magnetic Charging
21700 LED Flashlight
Specifications:
Product name: ROFIS R4 XHP50.2 6Modes 2300 lumens Flashlight
Brand: ROFIS
Model: R4
Emitter Type: XHP50.2
Peak Beam Intensity: 10413cd
Max Output: 2300 lumens
Range: 204M
Mode: Low, Mid, High, Turbo, Strobe, SOS
Lumens: 20lm, 240lm, 900-600lm, 2300-900-600lm, 1200lm, 900lm
Battery Configurations: 21700 Lithium-ion(Included)
Impact Resistant 1m
Waterproof: IPX-8 Waterproof
Carrying Strap: Clip
Color: Black
Weight: 97g
Size: 134mm x 28.5mm (Length x Body)
Package included:
1 x New Arrival Rofis R4 Flashlight
1 x 21700 Battery
please use the form below to get the deal info - Member can check in my deals list
JasonWW
JasonWW's picture
Wow, do you know if the R4 is using the new 3v 50.2?
M4D M4X
M4D M4X's picture
no - sorry
buit i try to find out
M4D M4X
M4D M4X's picture
banggood listed the
FIREFLIES E01
LUMINUS SST40W N5 5700K 2300LM 21700/18650 LED FLASHLIGHT
for US$29.99 using my Code MFE01
you can find all deals in my list: M4D M4X deals
M4D M4X
M4D M4X's picture
Astrolux released a new light and their first tactical pen today!
and M4dM4X.com fans get the lowest deal again!
(the links in the pictures and text take you to the shop for additional info!)
Astrolux C8 Silver US$ 17.99
XP-L HI Long Shot 1300Lumens
7/4modes with BLF A6 Driver
Tactical EDC LED Flashlight Searching Flashlight
Features:
· Astrolux C8 is redesigned with BLF A6 driver which is more durable, more powerful, and more functional.
· Utilizes a XP-L HI LED
· High efficiency constant current circuit enables maximum output up to 1300 lumens
· Driven by one 18650 battery for maximum runtime up to 300 hours
· Boasts a peak beam intensity of 102000cd and a throw distance of up to 639 meters
· Hidden battery check
· Direct access to ultra-low and turbo output
· User selectable  "4 or 7 evenly-spaced modes".(Moon to High)
· User selectable mode memory (always starts on Moon without mode memory but easily reverses to Turbo with a click)
· Fast PWM for lower regulated modes
· Toughened ultra-clear mineral glass with anti-reflective coating
· Constructed from aerospace grade aluminum alloy
· HAIII military grade hard-anodized
· Waterproof in accordance with IPX-8 (2 meters submersible)
· Impact resistant to 1.5 meters
· Tail stand capability
Package included:
1 x Astrolux C8 XP-L 1300Lumens 7/4modes EDC LED Flashlight
1 x Lanyard
1 x O-ring
Astrolux C8 silver version  Code: MAC8  price: US$ 17.99
and the all new:
Astrolux TP01 from US$16.99
Titanium Bolt Action EDC Survival Pen Tactical Pen
Introduction:
Astrolux TP01 Tactical Pen is not only an exquisite writing instrument, but it’s also designed to be used in tactical situations.
The integration of the pen body is a unique design that is still rare on the market.
The tactical pen can be used with the 424 J2 Gel Pen to complete every great writing.
The refill can be freely removed and replaced.
424 J2 Gel Pen are durable, common and easy to buy.
Astrolux TP01 Tactical Pen is strong enough to handle any emergency, self-protection, or tactical challenge.
The body of the pen is made of aircraft-grade aluminum alloy, or a higher hardness titanium alloy or stainless steel, making it powerful enough.
Specification:
Brand: ASTROLUX
Model: TP01
Total Length: 119mm
Diameter: 12mm
Material & Weight (With Pen refile):
- Titanium Alloy: 25g
- Stainless Steel: 55g
- Aluminum Alloy: 35g
Adapted Pen refill: 424 J2 Gel Pen
Pen refill diameter: 0.5mm
 Model / color Code price
 TP01 Titanium WAVE / LIGHTNING MTP01 50.59
 TP01 Titanium primary MTP01 30.29
 TP01 Stainless Steel COLOR MTP01 28.19
 TP01 Stainless Steel primary MTP01 26.09
 TP01 Alloy Blue / RED / Yellow MTP01 16.99
Essexman
Last seen: 7 hours 1 min ago
I just placed a pre order for a Ti Pen, great deal with your code, many thanks
M4D M4X
M4D M4X's picture
M4D M4X
M4D M4X's picture
i got some very nice deals for you:
NEW ARRIVAL
Sofirn SF10, SF11, SF32 UV flashlights and 8 slot/16 slot chargers are available on AMZ US. We provide some codes for you from 17th, May to 25th, May.
SF32 UV kit: $24.99, only $21.24 after code (SOFIRNSF32UV)
https://amzn.to/30rvqDY
SF10 without battery: $12.99, only $11.04 after code (SOFIRNSF10)
https://amzn.to/2JNqH9C
SF11 without battery: $23.99, only $20.39 after code (SOFIRNSF11)
https://amzn.to/2Q8z5lm
8 slot charger: $9.99, only $8.49 after code (SOFIRN8SLOT)
https://amzn.to/2Hpq9oY
16 slot charger: $20.99, only $17.84 after code (SOFIRN16SLOT)
https://amzn.to/2YD7POV
COB headlamp: $12.99, only $11.04 after code (COBHEADLAMP)
https://amzn.to/2QeTwgA
Mini Keychain light: $9.99, only $8.49 after code (COBMINILIGHT)
https://amzn.to/2LRKlUM
Flashlight Holster: small-$5.99, medium-$6.99, large-$7.99
https://amzn.to/2YxTH9x
Beam Diffuser: small-$4.99, medium-$5.99, large-$7.99
https://amzn.to/2HoS9Jl
C8A/C8T Remote Switch: $6.59
https://amzn.to/2w70nzn
BLF Q8 Switch Assembly: $4.99
https://amzn.to/2Yxkxi1
BLF Q8 Driver Chip: $9.99
https://amzn.to/2Q9dOb6
BLF Q8 Copper DTP MCPCB: $6.99
https://amzn.to/2EaGnjN
BLF Q8 Reflector: $8.99
https://amzn.to/2Vw7j3d
Theodore41
Last seen: 1 day 5 hours ago
The BLF Q8 reflector,above, sold my amzn,is different from the original one?
JasonWW
JasonWW's picture
There should be only one version.
M4D M4X
M4D M4X's picture
got some Amazon deals for you:
Amazon.DE
Artikel:
SP70 kit
 Rabatt:
 30% off
Preis:
 € 69.99
SP70 without battery ~33% off   € 50,-
Code bitte per mail anfragen (nur wenige verfügbar!)
Amazon.COM
Sofirn SP36 BLF Anduril Powerful Flashlight, 4 LH351D LED 5000K 90 CRI, USB C Rechargeable
only US$ 49.99
NMJoe
Last seen: 1 week 1 day ago
Hi Martin,
For those of us that could not participate in their release, do you expect to offer a code to the group for the two new Imalent lights in the near future?
M4D M4X
M4D M4X's picture
Imalent is very strict about speaking in public about codes
but you can read my signature Wink
EcuBebge
Last seen: 1 month 1 week ago
Wanting to purchase the Miboxer C4-12, but the coupon code says it is expired
M4D M4X
M4D M4X's picture
i ask to renew
M4D M4X
M4D M4X's picture
Servus mitnand!
Olightstore.de hat mal wieder den Aktionsfreitag!
edc taschenlampe
oder
edc taschenlampe
Olight S30R Baton III Taschenlampe (ein Akku)
Sonderpreis:  €55.96  statt €79.95
zu der Lampe habe ich ein Review gemacht:
außerdem:
Olight H1 Nova Stirnlampe
Sonderpreis: €50.96 statt €59,95
und obendrein gibts:
Ihr wollt einen anderen Artikel?
Wenn Ihr meinen Affiliatelink nutzt könnt ihr mit dem Code "OL10FA" 10% Nachlass auf (fast) jedes Produkt außer den Aktionsartikeln bekommen!
(https://olightstore.idevaffiliate.com/105.html) den könnt ihr gerne auch als bookmark zu Olight speichern Wink
M4D M4X
M4D M4X's picture
the Olight PL-PRO valkyrie weaponlight
with:
* 1500 Lumens Cree XHP 35 HI NW LED
* Magnetic Rechargeable Weaponlight with Glock and 1913 Rail Adapter
* Built-in Battery and SkyBen goodie
released on May,24 th with a one-day 30% off promotion on Amazon.com
please use my link shortly before you order - THX)
Black Color: https://amzn.to/2K01AAC
Desert Tan Color: https://amzn.to/2Wu6lcx
Promotime time:00:00 to 24:00 PT(Pacific time),May 24 th,2019
LightObsession
Any discount codes for the Rofis R1?
M4D M4X
M4D M4X's picture
sold out on banggood
LightObsession
Okay, thanks.
M4D M4X
M4D M4X's picture
M4D M4X
M4D M4X's picture
Turboglow Bead / FW3A Button and Gasket available!
Code : HTPGLOW
HTP WORKS TurboGlow Glow Gasket for FW3A & Carclo 105xx Optic
  • HTP WORKS TurboGlow Glow Gasket for FW3A & Carclo 105xx Optic
HTP WORKS TurboGlow Glow Gasket Button Cap for FW3A
also available: Carclo 10507 for FW3A
https://www.nealsgadgets.com/search?type=product&q=FW3A&aff=3
Agro
Agro's picture
Last seen: 1 min 33 sec ago
I really like the FW3A accessories that Neal offers. Smile
