my first Mod
15 posts / 0 new
FlexakaMal
Last seen: 10 years 2 weeks ago
my first Mod
Started with this http://www.dealextreme.com/details.dx/sku.2097 gave light output very much like a AA powerlight very blue not so bright.
Changed emitter to http://www.dealextreme.com/details.dx/sku.11022 and now its a fantastic little thrower. Just did it for the experience really
but very happy with the results. Old emitter once desoldered just popped out added some thermal paste and replaced with the Q5 easy!!
opps almost forgot, had too ream out the plastic reflector to get the Q5 seated properly but that was a 30 sec job.
Plus an O-ring behind lens.
Edited by: FlexakaMal on 06/15/2010 - 09:00
Don
Don's picture
Last seen: 3 years 5 months ago
My first was with a CR123 light that the back end of the reflector had shorted out the driver circuit. Tossed the driver altogether and replaced the broken Luxeon 3 with a no-name 3W LED. Still have that light in the car. The head can not now be screwed down far enough to do this thanks to some hot glue on the threads.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
brted
brted's picture
Last seen: 2 weeks 4 days ago
Good job. The budget lights become an even better value if you don't mind changing stuff around on them. That way if there is a part you don't like (like the LED on  yours) you can change it out and have a much better light (and still not spend that much). I'm glad yours is working out so well.
FlexakaMal
My Ultrafire C8 Q5 change to an R5 with a 1.2a 5 mode driver. Waiting for the R5 . Ordered one from KD  on a 14mm star, have one already on a 20mm star but the driver pill looks to be 18mm
Would I be better off cutting the 20 down? or go with the 14?
Don
Don's picture
There are no components in the star so it ought to be OK to cut it down - just be a bit careful with the shears and make sure you clean up the edges - most of those stars are aluminium cored for heat sinking - make sure the aluminium core isn't touching anything it shouldn't. Remember to leave yourself a couple of solder pads to solder the wires to the thing. Obvious I know, but guess why I said it?
Charred Components'R'us - that's me.
brted
brted's picture
I'd wait on the 14mm board to arrive since you've already ordered it, though you could try grinding down the 20mm board if you don't want to wait.
Nautic
Nautic's picture
Last seen: 1 year 4 months ago
I have a 14 mm R5 pill from KD. Wonder if I can get the above light and exchange the original with the R5?
Will the driver be OK? (voltage 3-3.7)    Will the plastic reflector be Ok (heat)?
Cheap quality is good - Expensive crap isn´t
XRAYBoY
XRAYBoY's picture
Yes you can.Driver will work fine,its the same voltage but it is a poor amperage for R5.(holds up well dissipated 1400mA)
The R5 will emit less heat than the Q5 in same conditions.Reflector be OK.
ForoLinternas.com
phlowcus
Last seen: 2 years 1 month ago
Maybe Kais 'R5's have changed in the meantime but the ones I ordered ~2 months ago are noticably dimmer than R5s I bought from a local official CREE dealer (still bright though). I'd say I received R4s.
Nautic
Nautic's picture
Thanks Xrayboy. I have allready ordered the light and will try the mod when it gets here.
Nautic
Nautic's picture
I have now tried to mod the light with the R5. Much much better light than the original blue tint.
But there are and were some problems.
First: The light is now very bright, not a thrower but lots of flood, but it has a dark spot in the
center. I cant figure out what causes this. Maybe the led, maybe the reflector. Does not matter
as I have decided to try and mod it with a Q5 ordered from DX.
Second: Modding was not a big problem. The light is easy to dismantle. The R5 is 14mm only and would
have fallen through the hole as the edge is very small. But I just turned the original 16mm led base and
mounted the R5 on its back. Had to sand the reflector down 1mm to accept the new led.
Looking forward to try it with the Q5.
alfreddajero
alfreddajero's picture
Last seen: 3 weeks 1 min ago
This is the only reason why i havent really gotten into the MCE's or P7's, its like some of the Olights out there with the Hybrid Reflector--gives you a smooth beam but with a dark ring in the middle.
With Darkness, there will always be Light.
XRAYBoY
XRAYBoY's picture
On the other hand you have the Cree rings using XRE leds...
Depending on the curvature of the reflector, the black hole is typical in XPG with smooth reflectors.
Even my Fenix TK12 R5 with specific reflector,have it (though hardly noticeable).
 It is very difficult to get a perfect spot modding a flashlight with some other family LEDs.
ForoLinternas.com
Nautic
Nautic's picture
I was very disappointed when I exchanged the original led with a R5. As mensioned above
it gave a large ugly black hole in the middel. Then I saw somewhere that changing the distance
between the led and the reflector might do away with this.
So I tried to put a spacer in between there, and BINGO the black hole has gone and the light
now has a good flood with a nice big hotspot in the middle. The led is now flush with the
bottom of the reflector, where it before was a mm inside
The planned mod with an ordered Q5 will still be done though, as the R5 will go into a P60.
Nautic
Nautic's picture
As mensioned in the post above I have tried to mod the light (http://www.dealextreme.com/details.dx/sku.2097)
two times allready. Cheap little light and easy to mod.
It was very bright with the Q5 led, but then I discovered that the pill in this light has the same threads and size
as the pill in a P60 dropin. So no need to fiddle around with a solderiron anymore. Just remove reflector and
springs from the P60 pill, unscrew the original and replace it. Everybody can do that. If a black hole, remember
spacer between ledboard and reflector.
Very bright light with both a R2 and R5. Wonder if I should try with a MC_E? Must be the smallest and brightest
pocket rocket around. Be a good handwarmer too this winter I believe. Smile
