Many of us have been looking for a good 2 cell battery holder, so I asked Dora and May at GearBest to find out if they can get the Fenix BA4C 2 Cell Battery Case seperately. May just told me they can if there is interest.
The only issue is the need to swap the existing connector with the correct connector since it has a male connector rather than a female. I doubt they will swap it for us.
is there interest in this case?
Absolutely! And others might be found in this thread: Where can I found 1x18650 and 2x18650 cases for headlights?
That’s a handsome looking case, is it in series or perellel?
I think they are in series, so 7.4v nominal. (I have use of both series and parallel, so I’m hoping I’ll be able to hack the box.)
I’d take two if they were available, I would prefer the female Magicshine compatible plug but would deal with the modification if I had to…
Been mentioned elsewhere, but thought I’d bump this and mention that there’s a presale on now:
http://www.gearbest.com/diy-parts-and-tools/pp_148900.html (case only)
http://www.gearbest.com/diy-parts-and-tools/pp_148901.html (case plus sleeve)
Ok Guys, last update. The first batch is 160 pieces because Fenix is asking for a huge order to continue to supply them so order now, first come first serve. Price is $11.99 with coupon code BT20CASE. If you already presale ordered at a higher price, email your order number to May and she will refund the difference.
Fenix is being a bit difficult with this so they now won’t supply the Nylon cases at all until again we order a large amount. So as it stands unless something changes, this batch is the last batch. Hopefully Fenix will reconsider. I think this is because the BT20 light will soon, no longer be made and to continue to make the box, they will need a commitment.
Meh, fenix was always PITA with their policy. You can always go with the Solarstorm 2s2p case…
P.S. Interestingly, it says 29 pre-orders for case + sleeve but it is out of stock!!!
Ordered 2. Thanks GJHS for making the good deals flow.
Sorry to bump this old post but it seems like it is no longer available at Geerbest.
Any Idea where can I find Fenix BA4C or any other 7.4v battery case?
