Greetings from Singapore, my IMALENT DDt 40 has just arrived and I would like to do a short review about this light. I have sumarized a few PROs and CONs about this light.
PROs:
Super bright flood beam, around 2x brighter than my SKYRAY KING.
High quality build (Threads, finishing and anodizing).
Accepts either 18650s or 16340s, making it a versitile light. Parallel battery connection also means no danger of unbalanced lithium cell reverse charging.
Integrated battery holder.
Flood and Spot light modes.
Strobe, SOS fuction brightness can also be adjusted.
Ultra Low Mode (Firefly)
Built in charging function
CONs:
Always starts at high (No memory)
Too many buttons which complicates the ease of operation
Capacitive brightness adjustment button, making adjustment under wet condition erratic
Features:
Taken from their website
Unboxing
Light was nicely packed with adequate protection against rough shipment handling.
Things included in the package are:
1x DDT40 torch
1x IR Remote
1x Holster
1xO Rings and screen protector for OLED display
1x Charger
1x Manual
1x Warranty Card
Side by side comparsion with some of the lights that I currently have. (From left to right : Solarforce L2, Nitecore E4A, SKYRAY KING and finally IMALENT DDT40)
The size of the light is comparable to the SKYRAY KING as both accepts 4x18650.
The top battery contacts seems to be made of thick solid brass/copper, which should provide for long lasting durability. However, the inner ring is slightly recessed when compared to the outer ring, prohibiting the use of flat top batteries.
A Close up of the remote, shows 4 buttons. A power button, changing of modes and up/down brightness adjustment. The remote itself have a solid feel to it, like it is made of real metal. The remote uses IR, therefore, there is a need to aim the remote directly at the torchlight. The flashlight have to be physically switched on for the first time before the remote is able to operate.
Front View
Contains an OLED screen, which displays the battery voltage, the torchlight temperature, the brightness and a magnetic compass.
Two capacitive buttons which controls the brightness.
Left View
Silver metallic button used to switch between flood and spot light
One XP-L flood lamp
Right View
Silver metallic button used to turn on/off the OLED display as well as switching display options between the battery voltage, the torchlight temperature, the brightness and a magnetic compass.
One XP-L flood lamp
Rear View
Main On/Off power button, which also acts as a lockout switch.
Tripod Mount
Charging Port, for charging with the supplied adapter
Top View
Four XM-L2 Cool White Lamp with smooth reflector and AR coated lenses
Light in Holster
Holster has some heavy duty feeling to it. However it appears to be slightly too tight for the light, making insertion quite difficult.
Overall, this is quite a fun light with plenty of features to play with. The infinite brightness adjustment also makes this light quite versatile. I would give this light 4/5. When I have more time to play with this light I would edit my review and include more details.
Welcome xeonsaga88 . Many people are worried of the over-charging issue. Able to help us to test out the in-body charging function for us? Thank you in advance. Nice review!
Hi, freeme. I have tested the built in charger. Straight after the display shows charge complete (battery stop blinking), i use a DMM and it shows 4.12v for all 4 cells. I assume my unit is one of those that they mentioned they have fixed the overcharging issue. Right now it seems to me that it is not charging the cells completely till 4.2v.
Yes, the button above and below the screen are capacitive. There is a chance when you are gripping the light any skin contact with the buttons will activate them.They only response to touch when the OLED is ON. So either you can wait for the OLED to ‘timeout’ or press the button on the right to off the OLED. You can also press the power button again to lock out the capacitive buttons. Hope this helps.
Maybe you can wait a bit longer, like 15mins after it changes state? What batteries are you using? I know first the batch terminate slightly (<0.1V) above to 4.2V.
Nice review xeonsaga88! More interested in the remote control function of the light. So it turns on with HIGH, can change the modes, and can turn up and turn down the brightness? How far is the range?
I have tested the range is around 9-11 meters. Pressing the mode cycles between spot/flood/strobe/SOS. The up/down arrows are used for brightness adjustment.
I am using LG 2500mAh Bare cells (LGDBB41865) which are only a few weeks old. Two hours after status changed, my fluke DMM is registering around 4.12-4.13v
Very good flashlight, i had received today. but my question is Why the manufacturer announces 5180lumens if you can only have 4000lm or 1180lumens? NEVER 5180 LUMENS!!!
You can not turn on together 4xXML2 (Spot light) and 2xXPL(Flood light)
Imalent this is a misleading advertising. I buyed for the 5180lm and only can turn on 4000l
Why this trick?
