TIMs ( Thermal interfacial materials ), thermal grease
Thermal interfacial material / thermal grease is not easy to find, especially if you are not living in US or Europe ( or maybe if you don't live in a large city ). Even if you do manage to find it, even online, it is generally not cheap.
Anyway, I was looking for some TIM and these are the good deals I found online. Warning : I use it for computer CPUs and GPUs - I don't know if these TIMs are suitable for flashlights. The more experienced forum members could comment.
I got Tuniq TX2 for $8 shipped thru ebay : http://cgi.ebay.com/NEW-Most-Effecitive-Tuniq-TX-2-CPU-Thermal-Compound-/120749594408?pt=LH_DefaultDomain_0&hash=item1c1d3c9728 .
Quick delivery.
I then found a better site for TIMs, very reasonable shipping rates : http://www.quietpc.com/gb-en-gbp/products/heatsinkacc?sort=price&descending=yes&set=Set
For eg, Arctic Cooling MX2 is approx $7 shipped.
Plenty of reviews for the above two, google. Reviews for TIMS often contradict one another.
http://www.xbitlabs.com/articles/coolers/display/thermal-interface-roundup-1.html
http://skinneelabs.com/tim/comparison-2011/
Then there’s Arctic Silver 5, the most popular and most acclaimed paste on the market. And it’s basically rubbish. In no metric is it better than MX-2, on average it’s over 2C worse than MX-2 and costs twice as much. MX-2, while it is great overall, isn’t even a great performing paste (it’s the baseline for good performance) and AS5 is far behind it. And on top of that, AS5 is capacitive, meaning it shouldn’t be used anywhere near exposed traces or SMD components (basically, should only be used on CPUs and GPUs with an IHS).
If I was in the US I would have got this : http://www.tim-consultants.com/matrix2.html
Review : http://xsreviews.co.uk/reviews/coolers/thermal-grease-tim-round-up-six-times-the-grease/4/
Post other good deals / TIMs.
If you mix AS5 and the AS adhesive you get a nice, slower drying, semi-permanent solution.
From : http://skinneelabs.com/as5-asc-asc2-review/5/
For a CPU a two degree difference can make a significant difference in how far you can overclock it. Personally I doubt that a two degree difference is likely to be of as much importance in flashlights unless you are trying to overdrive (i.e. the equivalent of overclocking) an emitter to the very extreme. Conclusion = Go with Fujik.
It all depend on how you want it to turn out, but yes, that ratio would be fine. :slight_smile:
My general thought is that there are a dozen other things more important in getting the most out of a light than the TIM used (as long as there is some!). The difference in output using AS5 vs. MX2 vs. whatever is most likely equivalent to having an extra speck of dust on the lens or not.
Only for a few days. Dust tends to migrate to non-dusty surfaces.
.. hmm. or you can store your shelf queens face-down, like mafia informers in a highschool swimming pool..
If normal operation of a computer depends on a 2deg difference, better not turn the lights on/heat up/breath on it much less use it outside.
It's also probably worth noting that in the review above, there's often greater variation between mounting attempts with the same compounds than between difference ones.
would a Thermally Conductive Adhesive Tape be better than Fujik ? Can be cut to size too.
I wasn't talking about normal operation. I was talking about extreme overclocking on-air, just enough stability for a crackingly good Super-Pi run.
Any suggestions for budget alternative on these thermal compounds?
Had some old silicone pastes left over from installing Zamlan GPU heatsinks, ran out of them and my Nexus silver is also going to be out soon...
Ok, I ordered FUJIK and 1 set of these:
http://www.dealextreme.com/p/stars-professional-thermal-compound-with-injection-tube-10-pack-13915
Bad methodology...
When you use AS5, you should know that AS needs several days up to weeks (200 hours with hot/cold cycles) to cure and reach final effectiveness. The difference can get up to 2 to 5 °C after it's finally cured. If you take that into account you'll see the AS5 will be more or less on par with any top TIM.
Want a serious TIM test? Try here: http://benchmarkreviews.com/index.php?option=com_content&task=view&id=150&Itemid=62 it may not be up to date, but it shows how such tests should be done. Much of it is still relevant.
Grind a piece of soft annealed copper on a fine wheel until you get a heap of fine copper dust. Mix with a drop or 2 of silicone oil. Apply under CPU or Diode and press down. Also, apply copper dust mix to the part you are going to thread in, like a C8 pill.
It's kind of like with Vitamins....you can spend a fortune on pills....or you can just Eat Your F**king Vegetables.
Maybe that's OK for flashlights, but for the real use of TIMs your vegetables may have a far to big particle size. A TIM must fill gaps, nothing more. Your copper grindings aren't quite likely to be squished out of the contacting surfaces very smoothly.
I don't think I've ever heard of anyone using copper grindings for CPU heatsinking...
Get a big syringe of Ceramique 2 or something, it's worth every penny.
For CPU´s etc I would have bought some more expensive stuff. Arctic silver maybe.
With flashlights I don´t care that much. If theres something between pill and body, I´m happy. Difference is usually quite easy to notice, more likely if the threads are loosely machined...
This page tells you all you will ever need to know about thermal compounds. Marmite/Vegemite works incredibly well - till it dries out....
http://www.dansdata.com/goop.htm
This graph made me think...
TOOTHPASTE?! So I'm researching what grease to buy and I can use toothpaste? my flashlight will even smell nice?!
ok, so it'd dry out and make a mess if you dissassemble. Anyway, I'm going with white silicone grease, and next time I order aluminum powder (no, not for thermite for strengthening epoxy) I will mix up enough to last the rest of my life lol (for the cost of AS5)
The only problem is that Vegemite tastes like Vietnam Fish Sauce.
To make it, you gut some fish, then let it rot for a long time.
