Mag mods and a "linger" XM-L flooder
14 posts / 0 new
dorpmuller
dorpmuller's picture
Last seen: 16 hours 39 min ago
Pic at end of post. Also on CPF.
I finally got around to doing some Mag mods at last. They were fun but not the easiest lights to work on. Once I got the TK70 and NIMH cells, the floodgates opened! Here goes:
(BTW, all lights are XM-L T6 with variously configured Shiningbeam drivers FYI) I can't afford these super drivers that would send me to bankruptcy court! All 3 lights have UCL's.
Left: 2D. Dropin started life as a dim 3X Q5 from a Trustfire. I gutted everything and swapped in new emitters. Added a 2X stacked parallel SB driver setup that delivers ~7.5A on high. Ground threads at top of dropin to make it fit in the head. Fortunately the dropin hits the barrel of the light so I did thermal grease there. Not much contact area but better than nothing. About as bright as my Skyray triple. I run it on four sub-C NIMH's. I really wanted to put this in a 3C body but didn't have another. I spritzed the reflectors with Krylon Crystal Clear, held far away, to diffuse the beam as I use this for walking. Has hotspot but not a distracting one.
Middle: An experiment but I love it! 3C "Linger" flooder. I took two bare emitters and flowed them onto one 16mm star next to each other. This setup was in a Trustfire C2 (got too hot fast) but I found that the TF pill fit perfectly into a copper plumbing sleeve and the lights went on to do this mod, as the sleeve in turn fit right into the C mag tube. So I tapped it into the Mag, and jammed the Trustfire pill into the copper sleeve. Hack job but works fine. Driver is a Shiningbeam stacked with 5 extra 7135's and delivers ~5A on one IMR 18650 rigged in with a plastic sleeve and spacer I made up. I fitted the original Mag reflector and used Krylon matte coat to dull it. This light is another wonderful walking light as it has almost no hotspot (slight) and evenly floods a huge area in the immediate vicinity where I don't have to keep panning back and forth. I wanna do another one with XML neutrals-that'd be the cat's meow!
Right: My baby! First off, many thanks to Techjunkie (CPF) who put up with my ranting and raving while getting this thing working. I followed his instructions, using 3 Shiningbeam drivers, stacked, wired in the same way as his Everyman's Mag. The problem was, I was trying to use 3 cells instead of four as I really wanted to get this into a 3D body. Not to be-as soon as I added the 4th cell everything came alive. I used Ledil MC-E reflectors on a heatsink from the Sandwich Shoppe. (the few they have left) As a cosmetic touch, I fashioned a plastic trim piece to cover the spaces between the reflectors from an old credit card, sprayed flat black. The brightness of this thing is insane, easily keeping up with the TK-70 but much floodier with a really big hotspot with nice gradual transition-just how I like it. I run it on four Tenergy D's, the ones from the TK70. Runs almost 10A on high, turns everything into daylight!
Enjoy!
Rich
"I am the flashlight king! I can light anything!"
jacktheclipper
jacktheclipper's picture
Last seen: 2 hours 59 min ago
WOW .
spottie
Last seen: 1 year 3 months ago
very nice
okyeung
okyeung's picture
Last seen: 4 years 3 months ago
Mag light will be on top if they made it like that from the factory.Smile
3
df2dot
Last seen: 2 years 5 months ago
the 2 on the ends are nice but i like the c cell mags vs the D myself
that middle one is nice !! i'd love to see the guts- i am shocked you are using the stock reflector
 good name too, sounds like its from LOTR : )
cd520
cd520's picture
Last seen: 6 years 6 months ago
Nicely done! Which heatsink did you use from Sandwich Shoppe?
DasFriek
Last seen: 8 years 1 month ago
GREAT looking lights!
I always knew those dinosaurs had a purpose in life still somewhere. You definitely have some skills at modding thats for sure. Im gonna have to get over to CPF in their modding section and learn to stack drivers and do some modding on cheap multi emitter Q5's i can find cheaply.
I love my Sky Ray 3800 for its output and beam style, But to build my own to my specs and looks would be much more rewarding.
Again, I love the work.
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 4 months ago
Beautiful work, Rich! I'd love to see some beam shots of them.
fishinfool
fishinfool's picture
Last seen: 8 months 4 days ago
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
2100
Last seen: 1 year 4 months ago
The last one is very nice!
thommy
Very nice mods DorpmullerCool
Funny, yesterday I recieved my first Maglite 2D Magled.
Bought it for 22 euro incl shipping by Ibood.
Thinking of modding this very nice light.
But this is new for me.
reading a lot topics for modding Mag's...
Is there enough possibility for modding a 2D into a lightsaber ? Smile
All yours proffessionel knowledge is more than welcome
Davx
Davx's picture
Last seen: 4 years 1 month ago
Great mods! Congratulations!
"There are always new jobs, women, and apartments......there is only ONE BLF." - Chicago X (27/03/2012)
keltex78
keltex78's picture
I would like to see the assembly of the middle one myself! How is heat sinking on the third lamp? Does it heat up much? Nice job with masking around the reflectors on that lamp too, gives it a much more finished look...
Where did you get the aftermarket switch covers? I tried the GITD ones from DX and they turned out to be a 1-2mm too small and fall off the light very easily.
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
Hill
Hill's picture
Last seen: 1 year 1 month ago
Yeah, but to the average non flashaholic, the cost would be prohibitively expensive!
My lights here and here
