2mods for the XHP70 - Initial Video added - One light is done & BEAM SHOTS ARE UP IN POST #1 - Second light works, but still...
50 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
2m1a
More to come real soon.
 First mod is a Solarstorm SP03 that will be modded to 3x XHP70 leds in parallel and will run on a RMM FET driver for 9-10 amps per led, with 2S/4P 18650 Li-ion cells.
Second mod will be a re-make of a 4xSSC-P7 light, that will use 4x XHP70 in series with a Taskled HBFlex driver and 5x26650 Li-ion cells, in a 6D Maglite. The head and heatsink are, (I believe), a LED zeplin heat sink and a 5 mega head. I am not positive of the head, but the heat sink is a LED ZEP heat sink, that was made for SSC-P7 leds and will be modified for the XHP70.
More to come this week-end, when I have some time to work on them.
 02/13/15 - We had a cold snap here, so not much is being done in the garage. I did manage to reflow all the XHP70 leds to copper mcpcbs and I did manage to get four of them onto the copper topped heat sink, in the four-up light. The copper plate is screwed down to the big heat sink and the stars are held down to that plate with a very thin layer of Arctic Alumina thermal adhesive.
4up1a
I will still need to adjust the height of the reflectors, to get the best beam, but I will be doing that after I have the driver wired up and the light together. Then I will go back and make adjustments. I think I will need to make spacers, to lift up the reflectors, but I don't know for sure yet. That heat sink/head combo right now weighs in at 1 pound 7 ounces. Hey, I will probably need all that mass for the heat these things are going to put out.
The HBFlex is wired up. I did this setup just like I do all my other Mags. The switch is a momentary SMD switch, mounted in the stock switch housing and the driver has a copper heat sink added, to help keep it cool.
4up2a
4up2c
Once it's all in the body, the copper heat sink touches the body.
4up2b
The leds are wired and since this all has to screw together, I will run the +/- wires up in, but not solder them till the head is screwed on, so I don't have to deal with twisting wires, while screwing the head on.
4up2d
The light will use 5xMNKE 26650 cells with a copper extension, to make the length correct for the 6D Maglite.
4up2e
It works.  I have to program the Taskled driver, which should take me several hours, but hopefully, after going thru 32 pages of the manual, I will have the light working properly.
That's it for now. I consider this half of the build finished and the other light will be worked on this week-end.
The two bodies for the SP03 are done and the switch and cover is done.
sp2a
I used the drill press, with an end mill bit and a dremel #115 bit, to do all the "mill work". It took several hours and a lot of four letter sentences, but I did get them together and it looks fairly good.
sp2b
They were a tight fit, as in push together hard fit. I used JB weld on the joints, but I left enough aluminum to aluminum, to keep the bodies working as ground.
sp2c
The switch went together fairly well. I also used a little JB weld around the edges of the switch hole, so when the copper was pressed in, it will help to keep it in once it hardens.
There's not a whole lot more to do right now. I will make the copper led shelf and fit it into the head, but since RMM is doing a custom driver for this and since Oshpark usually takes 3 weeks or more, I figure this thread will sit for a month, till I can finish the SP03.
02/15/15
I finished up the rest of the head and that's the last of the work for a while, till the driver comes in.
03a1
Stars are mounted with AA and 18ga wires are used.
03a2
I had to make thin spacers between the reflector and the leds, with plastic washers. I had to dremel them out to fit and sand them thin with a sanding block.
03a3
03a4
03a5
That's it till the driver comes.
02/28/15  IT'S COLD!!
It's so cold that I don't even want to be out in the shop, but I was having withdraw symptoms, so I had to try to finish the SP03.
sp4a
The driver that RMM designed for me. It came ready to go, along with a temp sensor.
sp4b
sp4c
The temp sensor got fried, my bad. I will have to get another one, but the driver is fine and ready to go.
sp4d
Snaps in place real well.
sp4e
The tail end. Working on the spring plate. I removed the stock springs and went with heavier ones, along with copper braid.
sp4f
sp4g
8 brand new Efest purple 18650s. Time to light it up.
sp4i
It even works, but after about 15 seconds on high, smoke comes out. Probably not good.
sp4j
The smoke is the spacer rings that I made, to go under the reflector. The ceramic substrate gets so hot, that the rings melted where they touched the edges of the leds. I will have to figure something else out. Maybe metal, but I can't put that on the stars, for fear of shorting, so possibly metal stand offs between the leds, to rest the reflector on them. I don't know for sure yet, but I hope the answer eludes me till spring time. IT'S COLD out HERE!
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 02/28/2015 - 16:26
Old-Lumens
Here are some beam shots for the 4X XHP70 light. They were done at work, inside and outside the closed Carrier plant.
4x1a
4x1b
4x1c
4x1d
4x1e
4x1f
4x1g
4x2a
4x2b
4x2c
4x2d
4x2e
4x2f
4x3a
4x3b
pilotdog68
pilotdog68's picture
I see lots of copper….. Can’t wait for more!
wolfdog1226
wolfdog1226's picture
Last seen: 10 months 23 hours ago
Thanks,,,,,,,,,,,look forward to following your mods! Smile
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
Ronin42
Ronin42's picture
Last seen: 4 months 4 weeks ago
finally a mod for my 6D MAG
would 6× 32600 cells work with that driver?
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
MRsDNF
MRsDNF's picture
Last seen: 20 hours 55 min ago
Ronin42 wrote:
finally a mod for my 6D MAG would 6x 32600 cells work with that driver?
I'm not sure what driver OL is using but if its the one I'm thinking its 21 volts. I have spoken to George the manufacturer of the driver and he does not recommend 6 cells in series due to the components on the driver itself.
wolfdog1226
MRsDNF……….I had to laugh,,,,I looked at your posts [at this exact moment!] and it is my DOB-6460!!!!
        WOLFDOG
zoom zoom
Last seen: 9 months 6 days ago
Can I preorder? Lol just kidding, not really can I?
nickzom
nickzom's picture
Last seen: 3 years 11 months ago
holy lumens!
MRsDNF
MRsDNF's picture
wolfdog1226 wrote:
MRsDNF..........I had to laugh,,,,I looked at your posts [at this exact moment!] and it is my DOB-6460!!!!
Now that's telling.Smile
What about a collaboration build light?
Old-Lumens
5 cells maximum for the HBFlex driver. It boosts up to 26 volt, (I think), but no more than 5 cells input.
Can anyone buy it? It's for a customer, so it's already owned by someone.
MRsDNF
MRsDNF's picture
Sorry about this. I must have had to many posts open and copied it into the wrong thread.
I've just watched the video OL. All I can say is I wish I was there. Thanks and cheers.
M4D M4X
M4D M4X's picture
Last seen: 4 hours 45 min ago
subscribed to be blinded!
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
Old-Lumens
One light is finished and posted in the OP.
DBSAR
DBSAR's picture
Last seen: 1 day 16 hours ago
nice work once again! looking forward to Beamshots. Smile
MRsDNF
MRsDNF's picture
Its nice to see all four leds light up.Smile Me not being the brightest guy here found it easier to program the driver hooked up to a single led on the bench before the light was assembled. I'd be interested to here your thoughts on the driver itself.
DayLighter
DayLighter's picture
Last seen: 2 years 10 months ago
Can’t wait for the beam shots.. it’s going to be awesome! Beer
The only way to do a great work is to love what you do.
Old-Lumens
BEAM SHOTS IN POST #1
Old-Lumens
George makes very good drivers and the absolute most complicated set of adjustable parameters I have ever seen. 32 printed pages of information on the three main groups and the 14 separate adjustable parameters. Great for a young genius, but very bad for an old fart man like me, who can't wrap his head around all that stuff and who can't "quick press" fast enough to execute the steps.Frown
M4D M4X
M4D M4X's picture
O M G Shocked
great beamshot location – great pictures!
blueb8llz
Last seen: 1 day 13 hours ago
One of the best beam shots I’ve seen. Veeeery bright and looks to have decent throw too! Can’t wait to see the sp03 version
Old-Lumens
Yep, I like the location and it's different than the norm. I do believe the SP03 will not be as bright. Even with 9 amps per led, I think this 4-up will give more total lumens, but I am hoping the SP03 will give more throw, due to larger reflectors.
One thing for sure is that whenever I do these monsters, I just don't appreciate a single led light any more. The HD2010 with an MT-G2 was what I carried every night, but now I don't even want to turn it on.
DB Custom
DB Custom's picture
Last seen: 6 days 23 hours ago
Once you’ve seen an entire football field light up like daylight, everything else is just wimpy.
dchomak
Last seen: 1 year 9 months ago
Ever since I have joined this forum I have noticed an utter disdain for multi emitter lights greater than 3. Probably a throw back to the early days when the brightest LED lights were those 9 emitter 3xAAA ones. Back then as is the case now, the most effective way to get a lot of light is to use a lot of emitters.
Maybe now attitudes will change and it will be OK to build these kinds of lights again.
Edit:
I say this because, in effect, OL just built himself a 16 emitter light. Wink
FmC
FmC's picture
Last seen: 16 hours 21 sec ago
Great work Beer
With these new larger LEDs arriving, it’s becoming ‘Bye-Bye to my budget’ Budget Light Forum again… Cash
Old-Lumens
More photos in the OP. This thread will probably sit for a month, as the custom driver that RMM just designed, has to go thru Oshpark and then to him, so a good month, knowing how Oshpark works.
Old-Lumens
dchomak wrote:
Ever since I have joined this forum I have noticed an utter disdain for multi emitter lights greater than 3. Probably a throw back to the early days when the brightest LED lights were those 9 emitter 3xAAA ones. Back then as is the case now, the most effective way to get a lot of light is to use a lot of emitters. Maybe now attitudes will change and it will be OK to build these kinds of lights again. Edit: I say this because, in effect, OL just built himself a 16 emitter light. ;)
I agree and then again, I don't. Multi emitter lights are great if you; have a lot of money for components, have a huge heat sink and great heat transfer, have tons of high amp batteries and have a sling to carry the heavy beast. They are super bright and if you do want to light up a football field, a huge building, a cave, or just a huge area, they are great. But... they will never have long run times and they are not very practical or compact.
I do think everyone needs something like this, just to be able to show it off. Imagine this in a football stadium? Just before the cops took you buddy away.Wink (here hold this for a minute).  Well, you wouldn't want to get arrested yourself would ya?Tongue Out
southland
southland's picture
Last seen: 2 weeks 2 days ago
Might hold some type of world record for hand held led lights.
Old-Lumens
If I send it to China, it could be a 1,000,000 lumen light!
tristanxoxo
Last seen: 8 months 4 weeks ago
Holy crap, my jab just hit the floor! Awesome work!
slow2go
Last seen: 2 days 12 hours ago
Talk about a Wall of light….. That thing is a monster..
Great work O-L..
