REVIEW: ThorFire TS05
11 posts / 0 new
lightme
lightme's picture
Last seen: 4 years 3 weeks ago
ThorFire TS05
http://www.amazon.com/ThorFire-Keychain-Flashlight-Stainless-Battery/dp/...
Moneys Paid: $20.99
Warranty: 2 years free repair
Website: www.eachine.com
Details (measured):
Material: Stainless Steel and Brass
Weight: 28g
Dimensions: 81 × 16 mm
Tube Thickness: 0.6 mm
Reflector Diameter: 16 mm
Lens: 14.2 × 1.04 mm
Voltage: 1.5v AA
Modes: High – Mid* – Low
Memory: None
LED: Cree XP-G2
Tint: Neutral
From my experience with SS lights, I expected more heft when I first picked up the TS05. With an AA installed, it weighs 10 grams less than my SK68 clone does without a cell! The reflector seems to be the only part made of aluminum with just brass showing at the pill and tail cap. It appears to take a special tool to disassemble the light any further than what’s required for cell replacement so it’s good that it comes with a 2 year warranty.
The TS05 comes in a display box with a manual, a keyring/hasp, 3 spare o-rings and an extra lens.
Same length as a standard BIC lighter and only slightly fatter. The ribs and brushed finish provide good grip.
The lens and OP reflector appear to be held in by the brass pill which requires a five pronged tool to remove(?). If so, why is there a spare lens? Is there a bezel to unscrew? There’s no visible seam but the tail cap seam is also invisible due to the brushed finish.
The switch feels good with strong spring pressure for it’s size. The lack of a rubber boot gives it a less mushy, more decisive feel. Like the pill, the switch also takes a special tool to remove.
Threads are square and shallow but feel better than they look. The o-ring is tight and requires a bit of force to screw/unscrew the tail cap as the female threads begin to make contact with it when fully tightened.
And finally, a wall shot. Spill is about 90 degrees. Output is good for a light this size without getting extremely hot. Tint is neutral, not blue as shown.
The driver seems perfectly matched to the light’s ability to dissipate heat. It never gets uncomfortably hot with a fresh cell. After being left on high for 10 hours, the output is pretty low but still usable in fairly dark areas. Letting the cell rest overnight, the light is bright again providing good output for another 10 minutes or so as it slowly dims. Under normal use, the frequent recovery periods should help get the most out each cell while putting out good light.
The good:
Price and delivery time (2 days)
2 year Warranty (assuming they stay in business)
Clean, seamless exterior
Stainless steel and brass contruction
Small and light weight
Uses readily available AA cell
Cree XP-G2 neutral tint
Robust switch/metal button
Square threads
2 oval tail cap holes
Glass lens
Tail stands
No blinkies
Doesn’t get too hot
Spare parts incuded
Tamper proof construction
The bad:
14500 not recommended
No clip but the tailcap holes can be used to attach one
Slightly noticable PWM on low (and medium*)
Tamper proof construction (not DIY friendly)
*Quality control issue:
My light goes from high to low with a quick flash of medium in between so it’s effectively a 2 mode driver which I prefer anyway because in most cases, high and medium modes are visually too close in output.
Conclusion:
Even though this particular light is missing the medium brightness mode, I can’t say anything bad about it since it works fine and using Amazon’s painless return policy or Eachine’s 2 year warranty would make things right. I already requested a return label and ordered another light. I’ll post an update when I receive it. The cons don’t affect me either. So, without nit-picking and having faith in Eachine’s warranty, I’d give the ThorFire TS05 a 5 out of 5 star rating.
UPDATE:
The new TS05 has 3 modes and is pretty much the same except the tail cap o-ring doesn’t rub the threads and the weight is closer to 27g. As expected, the 3 modes have mid and high much closer than mid to low. It’s another con that doesn’t bother me too much but it’s enough for me to lower my rating to 4.5 stars.
Also, no memory mode. Starts on high.
Edited by: lightme on 02/14/2015 - 20:10
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 1 year 4 months ago
I have flashlights that are several decades old and still working fine. So I don’t see a lot of difference between a two year warranty and and a replacement if dead on arrival policy. Are they ashamed to let us see what is inside?
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
lightme
lightme's picture
A warranty isn’t something you usually get with cheaply made products. It’s smart to make a product nearly impossible to disassemble if you’re going offer a warranty. I think it’s well made and they just don’t want the average person messing with it. Things fail and not everybody can make their own repairs even with the simplest things.
The driver seems to be a brand with a history but a google search brings up info that not in English. If someone can translate, there might be a clue as to it’s reliability. The switch is similar one I’ve heard good things about which is one of the reasons I choose the light. I would have bought it even without the warranty and if it broke, I’d make a tool out of steel tubing. Until then, I wouldn’t go thru the trouble.
blueb8llz
Last seen: 5 hours 38 min ago
too bad their AAA version is a twisty. i would have bought a clicky version. the AA is a bit too thick for a keychain. but this one does look a bit skinnier than others.
xdayveedx
Does this have any buzzing on the low and med. modes? I have a light from shiningbeam, that looks very similar to this one, the name slips my mind, but it has noticeable buzzing
lightme
lightme's picture
AA is about 14mm and this light is only 16mm thick. Can’t get any skinner and still some wiggle room. Still, I agree that an AA light is too big for a keychain.
blueb8llz
ya i just noticed that. pretty small for AA size light. i think i may consider this.
anyone know if its moddable?
lightme
lightme's picture
Not that I noticed. Right now, it’s packed up to be sent back. ETA for the new one is tomorrow and I will listen more closely.
lightme
lightme's picture
Not easily unless you just install a LiIon and chance burning something out. Also, stainless steel is terrible at conducting heat, especially something this small and light. It’s best suited for low power and high efficiency.
lightme
lightme's picture
UPDATE:
There’s audible noise on low and mid only if you stick one end in your ear. In dead silence, you might hear it a couple inches away.
xdayveedx
Good to know. Ill probably stay away from it then. Being picky i know, but id rather put my money towards another 4xaa power house that i dont need.
Thanks for the response though
