[Mod] Convoy S2+, plus...
34 posts / 0 new
FmC
FmC's picture
Last seen: 12 hours 52 min ago
  The little Convoy S series has become pretty popular. I already have a couple of S2+ triples with DD drivers, and a nice little S2 Nichia 219b that I currently have on the bed-side table.
 There’s been a few times now during the night, where I’ve needed to use the little S2 bedside torch, & wished I had the flexibility of an e-switch firmware.
  Moonlight for the toilet run? Turbo for the ‘bump in the night’? One press, no mode-cycling…. sounds great, but just not with the S2 Frown
 …Or maybe I could…
 I had another S2+ on order, along with a ticket in the KD Nichia lottery. Whilst waiting for it to arrive, I thought about how I might fit an e-switch to it….  Here is how it panned out;
 Being a small light, it needed an unobtrusive switch. I couldn’t find anything that would attach to the body, without looking out of place. I knew the S2+ pill was fairly deep, so I figured that I could mount the switch inside, & run an actuator to it.
 With the pill assembled, it was installed firmly in the head. I would have to drill through the body & pill at the same time, to ensure the actuator holes lined up on final assembly.
 With the hole drilled, I fashioned the actuator from a piece of silver-solder welding rod. A plastic sleeve was made to slip over the rod and switch pole, to keep the actuator rod aligned. An ‘O’ ring groove was cut into the rod, which keeps the rod from moving around, with the ‘O’ ring allowing just enough movement to actuate the switch.
  With the switch completed, the pill had to be removed in order to attach the driver. Care had to be taken to avoid galling the internal threads, as the brass had some sharp edges from the drill hole that had to be removed prior to winding out.
 Now to attach the driver, & re-install everything.
  This was a real PITA; the ‘O’ ring had to be rolled onto the plastic sleeve first, & placed inside the pill. The pill then screws in until firm, where the body & pill holes line up.
 The actuator is then pushed through & into the plastic sleeve, & then the ‘O’ ring rolled back onto the groove. …All with the driver & wiring in the way, deep in the top of the head…
 As you can see, I didn’t go for all-out power with this one; just a modest 1.4a driver. 5 evenly spaced modes, beautiful moonlight, buttery-soft Nichia goodness from the frosted optic.
 Here’s the finished product, with it’s family;
Thanks for reading! :Beer:
tristanxoxo
Last seen: 5 hours 23 min ago
Love it…thanks for sharing! I love those little S2+ lights.
pilotdog68
pilotdog68's picture
Last seen: 1 day 8 hours ago
Nice work! What is that thing you’re using as the spacer?
retiro675
Last seen: 9 months 3 weeks ago
Nice build! Very good imagination to make the e-swicht
Gunga
Gunga's picture
Last seen: 3 days 4 hours ago
Very nice mod !
jacktheclipper
jacktheclipper's picture
Last seen: 21 hours 12 min ago
Wow !
Nice job , sir .
FlashPilot
FlashPilot's picture
Last seen: 1 day 10 hours ago
Very well done FMC! Thanks for the detailed how-to.
FmC
FmC's picture
Cheers all Beer
It’s a copper fuel injector seal from a diesel engine. Goes between the injector & the cylinder head.
It just happens to be an almost perfect size for the S2+ w/Carclo optic.
pilotdog68
I don’t suppose there’s a cheap online source? Usually not with specific engine parts
antoninodattola
Last seen: 4 months 1 day ago
this is very cool!
really clever! Wink
To connect switch atiny13, must be made flash mod?
or just connect to the PIN reset and GND?
FmC
FmC's picture
These look like the ones, but I cant say for sure. Mine came out of a Toyota 1hd-fte. They don’t appear to be cheap (at least on fleabay).
antoninodattola wrote:
this is very cool!
really clever! Wink
Yes, you will have to flash with a e-switch type firmware, such as STAR Momentary.
Depending on the firmware, it’s usually Pin2 (or the fourth star of a 105c).
Rufusbduck
Rufusbduck's picture
Love it!
Scott
Old-Lumens
Old-Lumens's picture
Very nice idea for the switch. Really cool build!
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Firelight2
Firelight2's picture
Last seen: 2 hours 36 min ago
Nice switch! Love how it’s almost unnoticeable against the side of the light, but gives the full function of an e-switch.
I’m thinking of modding my S2+ mini 18350 into an e-switch light. My approach is much less professional looking though: Instead I’ll glue the e-switch onto the outside of the light then bulid a small casing around it out of aluminum, with a cut-down rubber boot.
Once that’s complete, the next step would be to cut down the tailcap. After all: one advantage of a sideswitch is that it’s no longer necessary to have space in the tail for a tail clicky. I figure this would will let me reduce my 84mm S2+ mini to maybe 74mm. The projecting sideswitch casing would also serve as an anti-roll mechanism. Battery would be the same IMR 18500 my S2+ mini is using now with an estimated OTF output of maybe 2500 lumens on a fresh cell.
Itinifni
Itinifni's picture
Last seen: 4 days 12 hours ago
Very nice work, I really like the Convoy S lights, so many great mods have been done with them.
I remember a time, when I searched for lights to fit my needs. Now I search for needs to fit my lights.
electricjelly
electricjelly's picture
Last seen: 5 hours 3 min ago
Very creative. I like how descret it is yet easy to feal for and locate. I might have to give this a try.
Caleb-v
Caleb-v's picture
Last seen: 9 hours 33 min ago
wow nice build. big effort with the e switch
MRsDNF
MRsDNF's picture
Last seen: 29 min 59 sec ago
Sweet. Very nice mod. This is another thread that the pictures make everything look bigger than it really is.
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
FmC
FmC's picture
If only it was bigger….
Did l mention it was a PITA…. Smile
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 days 23 hours ago
WOW!! Awesome mod…never though I would see a side clicky on a Convoy S series tube light
ImA4Wheelr
Last seen: 10 hours 13 min ago
Very sweet build.  Congratulations.
MosesM
MosesM's picture
Brilliant solution for a side switch!
Valerianis
Valerianis's picture
Last seen: 1 day 16 hours ago
It looks live a good job done! Silly
Halo...
Halo...'s picture
Last seen: 1 year 11 months ago
Great work on that switch.
Mike C
Mike C's picture
Last seen: 2 days 20 hours ago
I can imagine… But it’s a quality mod, that’s for sure.
Firelight2
Awesome side-switch mod!
I never thought of mounting the switch inside then using a plunger. Great job!
I’m thinking one of my next mods will be to mount a sideswitch on my 18350+ mini. I ordered a couple spare hosts from RMM in case I mess up my current one.
RMM
RMM's picture
Last seen: 1 day 15 hours ago
Pretty cool!  I like seeing all of the cool ideas you come up with.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
FmC
FmC's picture
Thanks all.
I’ve used this several times now during the night (mostly the ‘toilet run’). The beam is really ‘soft’, so it’s easy on the eyes. Really makes the colors ‘pop’ ….. ewww. Sorry 0:)
zoom zoom
Last seen: 11 months 2 weeks ago
I tried to do something very similar and failed because I couldn't figure out how to wire a reverse clicky into that mess. With a different host... Maybe next time I'll get it. One side ground to the body the other -to LED?
Firelight2
zoom zoom wrote:
I tried to do something very similar and failed because I couldn’t figure out how to wire a reverse clicky into that mess. With a different host… Maybe next time I’ll get it. One side ground to the body the other -to LED?
You want a reverse clicky and not an electronic switch?
Conventional switches (like the reverse clicky) must interrupt main current to the battery to function. Adding one in a sideswitch like in the original post is going to be more difficult than going with an e-switch. The e-switch just needs to have one end connected to the driver and the other to the pill or body tube. And because main current doesn’t flow directly through it, both the switch and the wiring to it can be very small.
However, if you did want to install a side reverse clicky, here are some suggestions for how to do it:
Possible locations to wire a reverse clicky sideswitch:
  • between the driver negative contact ring and the pill. This sounds quite doable and is probably the way I’d pick if I wanted to make one of these. In most drivers, the contact ring around the edge touches the pill, body tube or driver retaining ring in order to make negative contact. To do this mod, have that negative connection instead pass solely through your switch. How to do it:
1. With the driver out of the light, solder a wire from the negative contact around the upper edge of the driver to your reverse clicky switch.
2. Solder a second wire to the other end of your switch to the pill. If the light has a brass pill this shouldn’t be too hard. However, this will be a pain with an aluminum pill. For those, I recommend drilling a tiny whole in the side of the pill and then threading the wire through it. Bend the wire over and solder a glob onto the end. Should be enough for an electrical contact, though I also usually use conductive epoxy to hold it in place.
3. File a notch into the side of the pill for the switch wire from the driver (optional).
4. Insulate the contact around the wire you soldered to the driver and entire negative contact ring. Best way to do this is probably to use a toothpick to lather those parts up with arctica alumina epoxy. Wait for it to cure.
5. Mount the switch into the bottom of the light. I’d use arctic alumina epoxy. Also place the switch plunger and anything used to keep the plunger from falling out.
6. Mount the driver. I’d glue it on the back of the pill with arctic alumina epoxy. If necessary, file down the back of the pill so it has more room.
  • between the battery + terminal and the center terminal on the driver. Mount a contact plate where the driver is now, then move the driver closer to the star. Mount the clicky in the space between. Connect one end to the + contact on the driver and the other do the center contact on your contact plate. The difficulty will be in remounting the star and finding room for the contact plate. You might need to grind out your pill and/or file down your driver.
  • between the tailcap spring and the body tube. This is where conventional tailcap clickies are mounted. Not a convenient location for connecting a side clicky as you’d need to run 2 wires from the clicky to the back of the light.
musicmagic
Last seen: 3 years 4 months ago
FmC wrote:
Thanks all.
have you heard of the texaspyro piss-light ?
If you can’t blind them with your brilliance, baffle them with your bullcrap.
The real currency in the world is not money, it’s trust.
