This will probably be a kind of strange thread. I did some beam shots of a couple lights, at the closed Carrier plant and I really liked how they came out, so I am going to do some more.
A BLF/CPF member sent me some lights to play with and to mod to the new XHP series of leds, so I thought I would go ahead and do some before and after shots.
Amongst the lights are an Elektro Lumens ST90, (already modded by someone, with an XM-L2), a BTU Shocker, a JAX Z1, as well as others. I will do beam shots of them as they are and describe each light and it's leds. Then when I mod them, I will do beam shots again, for comparison. I do not know right now, if I can even mod them from 3.7V leds to 6V leds. It may not work out at all, but hopefully I will be able to do a couple of them somehow.
At least, that is the plan. You know how that usually goes, but I can hope it works out.
OK, I don't know everything about these lights and my descriptions only state what I "Think" they have for leds. I did not take them all apart, so I can't guarantee which led for sure. It's my best guess, just by looking from the front. E-L is short for Elektro Lumens.
1.- Brass EDC, (Maybe Sinner?), 1x18650, XP-G2? Deep OP reflector
2.- E-L Black EDC, 1x18650, XM-L, Deep faceted reflector
3.- E-L Silver EDC, 1x18650 P7, Shallow SMO reflector
4.- Orange EDC, 1x26650, XP-E?? or XB-D?? Dedomed., Deep SMO reflector
5.- JAX, 1x26650, XM-L2, Aspheric lens
6.- E-L ST90, 4x18650, XM-L2 Dedomed, (not the SST-90 led), Deep Faceted reflector
7.- BTU Shocker, 3x18650, 3x XM-L2 Dedomed, 3-up deep SMO reflector
Beam Shots - 271 yards
Beam Shots - 78 yards
Beam Shots - 30 yards
OK, you can draw your own conclusions from there. When I take these lights apart, I will verify the leds, though most of them should be correct.
In the next few weeks, these lights will be modified. Some will get XHP70 leds in them, some will get XHP50 leds in them and some may just get a higher amp driver in them. I am not sure, till I get to each one. As they are done, I will post new beam shots showing results.
