Skilhunt H02 headlamp with throw
(still editing, will add information for parts)
I was thrilled with the discount code obtained here for the Skilhunt H02. I promised a report on my modification. For hiking, skiing, climbing and mountaineering I like a headlamp with a versatile wide beam for trail use but with the option of throw for routefinding. So I add a throw reflector to my headlamps. This pushes the useful
range out to about 200 meters.
A warm xpg-2 has its Noctigon base soldered directly to the brass pill. The reflector is wonderful but the threading on the pill is atrociously loose fitting. I tried spacing it with aluminum foil but couldn’t get a tight enough fit so I wasn’t happy with the heat gradient between the pill and the aluminum reflector. I added a thick layer of super soft pure indium solder to the threads. When turned into the reflector threads are formed in the solder. With the high thermal conductivity of indium the temperature differential is gone! Maybe you know a better way? The solder is only on one half of the pill to correct centering.
Copper strip soldered to grounding ring of 7135 driver. This strip is expoxied to the pill for heatsinking.
Switch epoxied to head and driver card removed. There is a web of aluminum just under the led that bisects the cylinder. Appears to be well heat-sinked.
Red wire on right added as a positive power source going to switch.
Black wire added to ground ring. A hole is then drilled on the led side of the driver board. The wires are fed through to the switch and to the ground of the 7135 card
Reflector Dremeled to avoid contacting the solder points on the Noctigon board
I left the 7135 driver board visible with a coat of transparent epoxy. The wires are similarly coated. Maybe next time I will try to use thin copper strips inside the battery compartment for conductors. This would be prettier but somewhat difficult since the extra space around the battery isn’t much. Reflector is simply expoxied to the body of the Skilhunt. Crude but effective.
Red plastic ring came from the lid of either of these two bottles. Same dimensions, I cut one for this light the other for another.
Wire path
Headlamp will bob some of course. You can reduce it by rethreading the stretch bands through the silicone rings right next to the lamp. You can eliminate it by using a stiff plastic base instead of silicone.
White wall shot from 5 meters. This is how the focused beams hotspot appears to the naked eye.
Beautiful beam, shorter exposure, almost no artifacts. Graininess is actually the texturing on the wall.
Skilhunts wide beam. Neutral white and perfect.
Skilhunt beam centered at about 10 meters
Tiablo A9 xr-e q5 1A; premium thrower from a few years ago; 150 meters to trees; f/5.6 2.5s ISO-800 focal length 55mm
mag-lite modified with xm-l 3A same camera settings as above
Skilhunt thrower reflector; warm xpg-2; 2A same settings
i get the idea, but what you did was pretty stupid, all you had to do was remove the flood lens, make it detachable and you would have a thrower/flood in one, you will break your neck trying to aim your spotter
@Baron: calling someone's hard work right out stupid is not a very subtle response! (and concerning your argument: he would never have got the throw he has now with the large reflector with that tiny stock reflector, even with the flood lens removed)
@clockclimb: nice work, very functional and the beam throws extremely well! It will not get the price for the most elegant design around, but I assume that was never the intention :-)
Very creative. Reminds me of a spike light, but without the hassle of a external battery pack
Thanks for sharing
Wow. Where are all those aggressive people coming from. Bumped into 2 such ‘new’ members since morning….
Thanks for sharing. Unfortunately pics do not work at home and my work PC is not working. I will view it as soon as it is repaired :smiley:
True it’s not pretty, but does it ever throw! I’m going to build another one and make it a little prettier, maybe I’ll post it. The headlamp does not bob up and down at all now after making a very simple modification.
Hit me with any comments I’m pretty thick skinned.
Good on you Clockclimb. I’m about as sensitive as a rhinos buttock as well :smiley:
Just watching it on a laptop…
A+ for effort!
A+ for full filing your needs
A+ for uniqueness
A+ for modding
F for water proofing :smiley:
E for looks :smiley:
Good work dude.
Edit: A for posting your pic. Not many would have the balls :smiley: including me!
Put your money where your mouth is:
Lets see yours! and remimber it did not happen without photos.
Put up or shut up.
I was blown away! You did not mod simply by swapping LED, optic or driver like most sre used to, you added a working reflectored emitter!! That’s really re-purposing, and it works great, beamshots talk!
I like your get-stuff-working-first-then-improve-it attitude, that’s sort of agile development applied to flashlight related projects. :slight_smile:
Thanks for posting your mod up. I love the creativity and it works to boot. Nice. Theres nothing quite like a good home brewed light to do just what you want a light to do. Well done.
Nice mod, I like it!
Always good to get some feedback :bigsmile:
Very creative and effective solution to creating a good throwing headlamp. Simply removing the flood lens would have resulted in a less smooth flood beam. You only get throw with a larger reflector and your solution might be rough looking but works great. Trying to use the original reflector without the diffuser lens and expecting throw would be incredibly stupid. It would be even more stupid here since it's a TIR optic and not a reflector at all. Removing it would make it an even more floody mule.
You surely don't look like a pencil neck so I'm sure you won't strain your neck with those few extra grams of aluminum added to the light. Maybe a newborn infant might be thrown off a tad but toddler and up should have no issue wearing that.
Looking forward to seeing how you improve on the next one. Nice job!
+1 +1
:beer: +1
Excuse my sarcasm, but I’m really not fond of the way Baron chooses to give feedback… and that after 4 posts.
clockclimb… I have RESPECT for your effort! :wink:
