KD (kaidomain): Deals and new products thread
837 posts / 0 new
BanL
Last seen: 4 hours 20 min ago
Okay
I just a get few left.
I will PM you the details.
Thank you
kaidomain.com KD - LED Flashlights, DIY Parts and Accessories
Inquiry for KD, please feel free to contact me.
mrheosuper
Last seen: 1 hour 34 min ago
what is the size of that driver, if it’s 17mm could you send me a PM too
Forgot my pen
giorgoskok
giorgoskok's picture
Last seen: 7 hours 34 min ago
Lexel wrote:
any chance to get XHP35 HI in luminous flux bin of E2 or E4?
Ban , i think many members would be interested in xhp35 hi e2/e4 due to the GT .
If you could re-stock the xhp35 hi e2 3c it would be great .
BanL
Hi giorgoskok
I just get a limit quantity for CREE XHP35 HI D4 3A Neutral White 5000K
http://www.kaidomain.com/p/S027429.Cree-XHP35-HI-D4-3A-Neutral-White-5000K-LED-Emitter
Thank you
Ban
XXX-Man
XXX-Man's picture
Last seen: 1 hour 46 min ago
Will you have more of CREE XHP35 HI D4 3A Neutral White 5000K soon?
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F
Lexel
Lexel's picture
Last seen: 1 min 57 sec ago
Hi giorgoskok
Thank you
Ban
I guess some light manufactory bough all those emitters
maybe you should limit to 5 emitters per order and more on request?
Lexel
Lexel's picture
wstrachan
Last seen: 29 min 53 sec ago
Is anyone aware of a discount code that works for KD general orders?
light addict....yeah I've got the bug.
Haikelite MT07S
Imalent DT70
Klarus XT12GT
Olight javelin mx3x
thrunite tn32 ut
acebeam k60
many, many others...
FPV
FPV's picture
“BLF”
wstrachan
Unfortunately BLF code is only 5% off. There was a 10% off coupon floating around but it’s expired.
Haikelite MT07S
Imalent DT70
Klarus XT12GT
Olight javelin mx3x
thrunite tn32 ut
acebeam k60
ggf31416
Last seen: 9 hours 11 min ago
The drop-ins for kdlicker C8 and C8.2 are missing, are you removing the product or are they going to be relisted in their own category?
maukka
maukka's picture
Last seen: 1 min 38 sec ago
Got my C8.2 Cree XHP35 HI Warm White-) today. It has a perfect warm tint at CRI80+ in all modes. I measured 51kcd on high.
There’s visible PWM on the lowest mode and the mode spacing between mid and high is too narrow. When switching between modes it does a short strobe unless you keep the tail switch pressed for a while longer, then it cycles the modes without anomalies. Staying on one mode longer than 3 seconds and half pressing makes the light stay on the same mode. Going from high to very low makes the driver emit a quiet whine for a while.
If you memorize the lowest mode and turn the light on, there’s an annoying preflash. This doesn’t happen on other modes, or at least isn’t visible to the eye.
Construction is excellent, but the clear Convoy C8 with an XP-L HI has more throw (62kcd) and a better UI.
-X3-
-X3-'s picture
Last seen: 1 hour 7 min ago
51kCd ?
That’s lower than I hoped…
"Hey -X3-, do you have a flashlight ?"   "-X3-, can I borrow one of your flashlights ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire : 30+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
Delta_V
Last seen: 2 hours 21 min ago
Do you happen to have any way to estimate the output? That intensity seems disappointing for the XHP35. Maybe it’s just down to the particular design of the C8.2, though. Wonder what it gets with the XP-L Hi.
On other lights, it seems like the peak intensity is usually similar between the XHP35 HI and XP-L HI, with the extra 300-400 lumens of the XHP35 resulting in a larger hotspot.
Texas_Ace
Texas_Ace's picture
Last seen: 6 hours 20 min ago
X3 wrote:
51kCd ? That’s lower than I hoped…
A max driven xhp35 generally gets slightly more throw then a max driven XP-L HI. So seeing as this xhp35 is not driven to the max, I would say it is not that surprising. It should be putting out close to 2000 lumens if I had to guess though.
Know guns, know peace, know safety. No guns, no peace, no safety.
The ultimate result of shielding men from the effects of folly is to fill the world with fools. --Herbert Spencer , English Philosopher (1820-1903)
Texas Avenger Driver Series
My LED Test series - XP-L2 V5  - Nichia 219C 90+ CRILatticebright "XM-L"XHP35 & PWM efficiency - XHP50 - XP-L V5 - XM-L2 U2 - XP-G3 S5  - XP-L HI V2 - Oslon Square & direct comparison to Djozz tests - Nichia 319A - Nichia 219B 9080 CRI - Nichia 219C D320 - Nichia 229AT - XHP70.2 P2 - XHP50.2 J4 - Samsung LH351D
Easy comparison tool for all my LED tests
maukka
maukka's picture
Sadly nowhere near the advertised 2000 lumens for the C8.2 XHP35 HI
Tested on an unprotected Samsung 30Q
On high
0 sec : 1241 lumens
30 sec: 1174 lumens
1 min: 1150 lumens
2 min: 970 lumens
3 min: 905 lumens
Mid
0 sec: 728 lumens
30 sec: 717 lumens
Low
0 sec: 302 lumens
30 sec: 301 lumens
Low low
30 sec: 13 lumens
Convoy C8 Clear XP-L HI on max:
0 sec: 841 lumens
30 sec: 839 lumens
1 min: 835 lumens
2 min: 831 lumens
3 min: 828 lumens
khas
Last seen: 1 day 1 hour ago
Thanks for the test I have one on order, but I guess I will cancel it now.
Satan@103TFS
Last seen: 13 min 2 sec ago
Anyone try this http://kaidomain.com/p/S026504.H2-C-22mm-1_5A-1-or-2-cell-5-Mode-Boost-D... in Convoy L2 ,how to make it fit 20 mm space or just sanding a bit ?
Delta_V
On high
0 sec : 1241 lumens
30 sec: 1174 lumens
1 min: 1150 lumens
2 min: 970 lumens
3 min: 905 lumens
Mid
0 sec: 728 lumens
30 sec: 717 lumens
Low
0 sec: 302 lumens
30 sec: 301 lumens
Low low
30 sec: 13 lumens
0 sec: 841 lumens
30 sec: 839 lumens
1 min: 835 lumens
2 min: 831 lumens
3 min: 828 lumens
Thanks. Looks like yet another XHP35 light that falls way short of advertised output. Are there any 1×18650 lights with the XHP35 that actually hit the numbers they claim? Besides Zebralights, which advertise lower numbers to begin with.
maukka
maukka's picture
Olight M2R does 1500 lumens as advertised, but that’s HD not HI. Niwalker BK-FA30S does 2200 lumens as well.
Delta_V
Good to know about the Olight. The Niwalker isn’t surprising – it’s a big 4×18650, and appears to use a 4S arrangement. The multi-cell lights don’t have the same challenges regarding the driver – they don’t have to boost voltage as far, and they have more space to work with. It’s mostly 1×18650 lights (Klarus, Armytek, now Kaidomain, etc.) that seem to have problems.
Jerommel
Jerommel's picture
Last seen: 3 days 14 hours ago
Nitecore Concept 1 does 1800 lumen (XHP35 HD).
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
The_Driver
The_Driver's picture
Last seen: 6 hours 26 min ago
On high
0 sec : 1241 lumens
30 sec: 1174 lumens
1 min: 1150 lumens
2 min: 970 lumens
3 min: 905 lumens
Mid
0 sec: 728 lumens
30 sec: 717 lumens
Low
0 sec: 302 lumens
30 sec: 301 lumens
Low low
30 sec: 13 lumens
0 sec: 841 lumens
30 sec: 839 lumens
1 min: 835 lumens
2 min: 831 lumens
3 min: 828 lumens
The numbers do make sense though. The XHP35 HI is basically a XP-L HI with a 45% larger die. It produces around that much more lumens and that much more heat. For 2000 lumens you would need three times the power and thus heat of the XP-L HI. Who wants that?
L4M4
L4M4's picture
Last seen: 8 hours 56 min ago
Would be nice to know if this is a flood-to-throw or not.
I would like a non-FtT with a lens
EasyB
Last seen: 4 hours 56 min ago
I just sanded a bit.
http://budgetlightforum.com/comment/1142471#comment-1142471
Lexel
Lexel's picture
I got today my first prototype design boards from Schokis driver circuit with a 50W boost chip
I will test it next days, if the massive enhanced thermal connection added to the layout works well, then also some fine tuning the capacitors to get rid of switch on spikes and other stuff needed
I hope production can start end of february
