Flashlight Firmware Repository
2223 posts / 0 new
Tom E
Tom E's picture
Last seen: 1 hour 18 min ago
Something like this:
if (++mode_idx == (sizeof(modes) - 2))
   ++mode_idx;
if (mode_idx >= sizeof(modes))
Ok - you'd be adding the first 2 lines, and modding the 3rd line to remove the ++. This is all in the function: next_mode().
Hope I made this clear enough. Basically you detect if the mode is incrementing to the 2nd highest mode. If so, increment the mode index again.
pilotdog68
pilotdog68's picture
I think I have everything working now. I haven’t actually tested LVP yet, but I don’t know why it wouldn’t work as the mode order is now back to “normal”.
Would one of you mind looking over it to make sure there isn’t some hidden screw-up that will cause me grief later? thanks
once again, mine is on the right, stock STAR is the left.
Diff check
edit: JK, now I’m back to having the problem that when power is cycled when in mode “0” it doesn’t come on in mode “3”. Sad
plot twist: So if I hold the button for 2.5 seconds it enters mode “0” (off). If I then remove power for 5 seconds before reapplying, it comes on in mode “3” as it should. Any ideas here?
Tom E
Tom E's picture
There's something that's keeping power goin for 5 secs - no other explanation I can think of. Cap? Something?
pilotdog68
Oops, forgot to update here.
That issue was on my “power supply.” I decided it wasn’t a big deal, so I installed it in the light anyways. Miracle of miracles, once in the light that weird behavior went away.
Tom E
Tom E's picture
U mean a bench PS? Ohhh - if so, would explain the 5 secs shutdown... My bench PS is super slow on shutting down.
ToyKeeper
ToyKeeper's picture
Last seen: 9 hours 31 min ago
FWIW, I did some tests a while ago for the mem-decay method of detecting short presses. If I drain the OTC, it seems to take about 0.5s for the memory to decay. If I leave the OTC fully charged, it seems to take about 4s for memory to decay.
Just a thought. I don’t even know if you’re using that method.
pilotdog68
Tom E wrote:
U mean a bench PS? Ohhh – if so, would explain the 5 secs shutdown… My bench PS is super slow on shutting down.
It’s actually just a cheap buck converter I use to test drivers, but I have a omten switch in series anyways.
Tom E
Tom E's picture
Hhhmmm. Something wasn't right bout that setup I guess? if it worked once in the light.
pilotdog68
Tom E wrote:
Hhhmmm. Something wasn’t right bout that setup I guess? if it worked once in the light.
I’ve had other issues with it before, especially with turbo timers. Idk if it’s ripple or what.
For instance on this driver, I have the timer set to 2 minutes. Its 6*7135 (2.3amps). If I have my buck converter limited to a lower output, like 1.5amps, the turbo timer steps down wayyyy early, like 1 minute instead of 2. But if I don’t limit output on the “power supply”, the timer works just fine.
I don’t understand it, but I’m slowly learning that if something isn’t acting the way the firmware says it should, try it on a battery before freaking out.
Tom E
Tom E's picture
I do my initial tests on a batt 90% of the time - an old TrustFire in a holder w/red&black wires ended with alligator clips. Sometimes if it's more risky, I'll go slowly up with the bench PS. I'm usually carefully continuity testing everything out first, so not much risk applying power.
ToyKeeper
ToyKeeper's picture
Oh, on a variable current / voltage power supply, with current limited, the voltage can do some weird things. You can only limit one or the other, basically, and the other will adjust itself accordingly.
I’ve been finding that even voltage calibration seems to work better with a battery than with a power supply (and a DMM to confirm voltage in real time).
Mitko
Mitko's picture
Last seen: 4 months 1 week ago
Do we have a Yezl Y3 Star firmware – el switch and a tail switch, several modes switched through the el switch and an offtime memory?
Tom E
Tom E's picture
Mitko wrote:
Do we have a Yezl Y3 Star firmware - el switch and a tail switch, several modes switched through the el switch and an offtime memory?
I do. On the 25/45/85 thread, have a dnld link but it requires a 45 or 85. Blew past 2KB code, so the 25 won't cut it. It's also fully programmable (64 possible mode combos) and I posted an instruction manual (2 pages) on it's operation. Didn't upgrade a Y3 yet, but I'll have to do 4 of them shortly. Have the dual switch (e-switch/power) version dnld'ed in a X6R and works well so far.
Mitko
Mitko's picture
Great, but can it be applied on wight`s A17dd ver 0.44 and tinny13? The last Y3 i modded was with that driver, el and tail switch and TK Ramping UI table firmware, V6 1D dedomed and 210k cds, came out exellent but now i need the firmware i mentioned
Tom E
Tom E's picture
No tiny13 support, only a 45 or 85 on a FET+1 driver. I've only used the FET+1 wight drivers, like the BLF A6 driver, in 17 and 22 mm sizes. All my e-switch build/mods are or will be 85 based. It can be changed to work with a conventional FET or 7135 (only) driver but I don't see it worth the effort for now. There are some newer OSHPark boards available now for the larger footprint of the 45/85, but mostly I'm doing the "bent in pin" technique to retrofit.
Mitko
Mitko's picture
thanks, fet+1 will do fine too, have to start trying 85 out now Wink
chouster
Last seen: 4 months 3 days ago
Hi,
I’m thinking about giving bistro a try. I have components for wight’s 17mm FET+7135 and I recently ordered an Attiny 25. Unfortunately I got the normal 25, not 25V. Would I have to make some important changes to the code for the use of the “standard” 25?
Tom E
Tom E's picture
chouster wrote:
Hi, I'm thinking about giving bistro a try. I have components for wight's 17mm FET+7135 and I recently ordered an Attiny 25. Unfortunately I got the normal 25, not 25V. Would I have to make some important changes to the code for the use of the "standard" 25?
Nope, no changes. In fact Richard at MtnE sells the 25, not the 25V. Only difference is low operating voltage, but the LVP kciks in before you should get that low anyway.
ToyKeeper
ToyKeeper's picture
It should work on a non-V model. That’s actually what I used to write it.
chouster
Thanks Tom and TK. I will give it a try. I succeeded in flashing all different kinds of firmware from TK’s repository, but now I’ll have to find out how to work with these new *.h files. Will do some research now. If I think that’s over my head, I could just use the bistro.hex file, right?
edit: ok, I think I found out how to deal with these header files.
ToyKeeper
ToyKeeper's picture
The headers are something I’m still deciding how best to set up.
Originally, I told the code to include “../foo.h” so it would automatically look in the right place. But that makes it not work when all the sources are copied to a single directory, or when a project is one layer deeper. To fix that, I can include “foo.h” without the .. for parent directory, but the build options will then need a “-I..” to add the parent to the default include path. Maybe a “-I../..” too. Simple fix on a command line, but it means one more step when using AVRstudio.
It’s weird trying to support foreign build systems. Normal software doesn’t have these issues. Normally you’d ship a Makefile and force everyone to build in the same way, but AVRstudio doesn’t like that approach. As builds get more complex though, it gets harder to build with different tools. So I’ve tried to keep it pretty simple, but duplicating code all the time feels like scratching a chalk board.
chouster
@ TK and other awesome people
Ok, most of what you’re saying might be over my head, don’t even know what that foo.h is. I really don’t understand much of programming and flashing, and I wouldn’t be able to flash my drivers if there wasn’t some good tutorials here at BLF. My workflow is: compiling the code with Atmel Studio and than flashing the .hex-file with avrdude via command line, just like in hoop’s tutorial.
Now with your new headers, it’s not that hard to do it, in fact it’s easy once you know how it works. I just right-clicked the project in the solution explorer at Atmel Studio->add->existing file, search for the directory, chose the file, click add. That’s what I did with all the headers that need to be included.
Another change from the way it is in hoop’s tutorial, quite important for someone inexperienced like me, is, because we’re using Attiny25 now, I had to adjust the command lines. t25 instead of t13 and other fuses.
test:
avrdude -p t25 -c usbasp -n
erase:
avrdude -p t25 -c usbasp -u -e
flash bistro:
avrdude -p t25 -c usbasp -u -Uflash:w:bistro.hex:a -Ulfuse:w:0xd2:m -Uhfuse:w:0xde:m -Uefuse:w:0xff:m
I know it’s really basic stuff for people like you or Tom…
When I found out how to do the above, compiling and flashing went just fine.
But it’s not my day today, hand-soldered the A17-HybridS, flashed it (wanted to check if firmware and driver are running as they should and do calibration afterwards), however, ruined a Convoy C8 then, because I destroyed the driver retaining threads. By the way the Convoy C8 has one of the worst driver retaining rings I’ve come across, really crappy. As if that wan’t enough my 60W soldering iron flew of the bench and in a really stupid reflex I caught it, ouch, that hurt, still does. Should’ve stopped there. But wanted to test out this awesome firmware. With the C8 ruined, I went ahead and grabbed a EE X6, thought something like “yeah, feels more like quality” and installed the driver. Works, but first mode doesn’t. Maybe too low of a value for the LED to light up?
I haven’t even read how the UI works and all, but one thing I noticed in an instant: it has soft transitions between modes and I LOVE THAT! This is something I’ve dreamed about for quite a while now. That is just awesome, you, TK, are just awesome!
No more typing for me, my hand really hurts…
pilotdog68
Thanks for the tips chouster. I follow the same process as you, so I’ll probably reference this post when I get around to using the bigger mcu’s
ToyKeeper
ToyKeeper's picture
The lowest mode is probably just too low for the hardware it’s running on. I’ve seen anything from 1 to 9 as the lowest effective PWM level, and it varies depending on the exact type of 7135 chip, the emitter, the battery voltage, etc.
Things aren’t going so well for me today either. I’ve managed to fry and replace a 7135 chip, and the new one needs a higher moon mode. I accidentally flowed a FET right off a board, burned myself three times, made a mess of flux, keep breaking things, and can’t seem to get anything to flash today… except for a bright emitter flash followed by an unexpected moon mode.
I feel a bit like this dude now:
Halo...
Halo...'s picture
Last seen: 3 years 7 months ago
Reflex catch…. Oww Tired I’ve had that impulse to catch falling hot objects.
I liked that change. Noticed it shortly after you added it but neglected to comment.
Tom E
Tom E's picture
For my e-switch 45/85 version, I provide the whole set of files, all folders, all headers, ZIP'ed up, 100% ready to be built using Atmel Studio 7.0. Its easy - one UNZIP. I'm using all or most of TK's header files. I hope you (TK) don't change it. I understand not everyone uses Atmel Studio 7.0 for Windoze, but it is probably the most popular development environment.
Jaimelito
hi there.
Is the LD-1 or LD-2 firmware open to public??
And what is the mcu an LPC1343 ?
Tom E
Tom E's picture
Jaimelito wrote:
hi there. Is the LD-1 or LD-2 firmware open to public?? And what is the mcu an LPC1343 ?
Unless something has changed, definitely not public. led4power explained why in a lot of detail early on when I asked, but basically he would like compensation for the time/effort - can't blame him at all for that. Not sure bout the MCU, but pics show the MCU's marking, like here: http://budgetlightforum.com/node/34812 and here: http://budgetlightforum.com/node/39824. It's a product like other products we buy, but also he contributes to the forum and seems to have good support.
pilotdog68
Am I crazy, or is there a spreadsheet or tool I can use in conjunction with battcheck that calculates the ADC values for me? Like I plug in the ADC values that battcheck reads out for 4.2v, 4v, and 3.7v, and it will spit out the ADC values for 2.9v or 3.1v?
18sixfifty
18sixfifty's picture
Howdy, everyone.
I’m pulling my hair out trying to program a nanjg driver.
It doesn’t seem to matter what I do but I can’t get the low modes to work at all. It just skips them no matter what firmware I’m using. Do I need to change the caps or something?
This is for a fellow member who is taking the light on a trip with him and it’s really important that I get it right.
This is what he wants on the light.
20ma, 60 ma, 160ma, 750 ma, 3 amp turbo with memory.
I’m trying to start with a simple 3 amp nanjg. I put an new atiny13a on it but nothing is working on the low modes.
Any ideas?
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
