Flashlight Firmware Repository
2239 posts / 0 new
Dutcheee
Last seen: 1 week 15 hours ago
I used Hoop’s how-to and got a positive test in AVRdude on the BLF attiny13A
How to flash
However I downloaded the latest software, and can’t find the attiny13A in the latest atmel studio. Think I’ll have to downgrade.
But the drivers for the USBasp and AVRdude work fine on my windows 10 system.
Hope this helps..
Tom E
Tom E's picture
Last seen: 32 min 17 sec ago
will34,
This is the ultimate, best source of AVR support/drivers/etc. I know of. I used this for full 8.1 support, think also for Win 10: http://www.protostack.com/accessories/usbasp-avr-programmer. Download and use the latest there. Mine works for the 5v position, not the 3.3v.
I bought my first USBasp from Protostack, then bought my 2nd from FastTech - both worked perfect. One died on my recently, so just ordered another from FT, as I always like having a backup on-hand.
Very Important: Pin #4 on the USBASP V2.0 is not ground - it's TXD. I wire grnd to pin #10 now and it solved several problems I had - originally I followed the pinout description in flashlightwiki.com and it sort of/semi worked, and it's wrong for the newer V2.0 dongles.
I updated this page: http://flashlightwiki.com/AVR_Drivers, to show the proper wiring for USBASP V2.0
Edit: Hoop thread's OP showing the wiring is wrong - I've proved this, did all the testing to prove it. Pin #4 on the dongle is not ground. It may work, it may appear to work - it's wrong. Using pin #10 for grnd is much more stable and reliable I've found.
will34
will34's picture
Last seen: 6 hours 13 min ago
I wired mine like this, following WarHawk-AVG’s guide:
Tom E
Tom E's picture
Labeling is wrong, but the wiring appears correct smile.
will34
will34's picture
Tom E wrote:
This is the ultimate, best source of AVR support/drivers/etc. I know of. I used this for full 8.1 support, think also for Win 10:“http://www.protostack.com/accessories/usbasp-avr-programmer”>http://ww.... Download and use the latest there. Mine works for the 5v position, not the 3.3v.
Thanks Tom!!! It worked! Party
Finally did my first FW flash after all these years. However it did not work with extreme burner AVR, it shows “mismatch at location 0×0000”. So I used AVRdude command instead, success in the first try.
Now I have my Courui D01 flashed with TK’s ramping FW, very nice!
Time to start desoldering leads… Smile
ToyKeeper
ToyKeeper's picture
Last seen: 8 hours 3 min ago
Tom E wrote:
Very Important: Pin #4 on the USBASP V2.0 is not ground – it’s TXD. I wire grnd to pin #10 now and it solved several problems I had – originally I followed the pinout description in flashlightwiki.com and it sort of/semi worked, and it’s wrong for the newer V2.0 dongles.
Holy cats!
You just un-bricked like a dozen of my drivers. I had a bunch which refused to flash, but I moved one wire, tried a dead driver, and it lives again! I’ve seriously had a wire in the wrong place all this time??? Wow.
Would have been nice to know this last summer. Smile
Halo...
Halo...'s picture
Last seen: 4 years 2 months ago
Shocked ToyKeeper too.
When I first got a usbasp I searched google images for the pinout. I found tons of bad pinouts so I didn’t trust any of them. It’s a little conspiracy.
The problem with the bad pinouts, as you’ve seen, is that leaving the gnd unconnected actually works on some chips.
Tom E
Tom E's picture
Oh boy, good news/bad news (smilecry). Really sorry, but I thought I made a big stink bout it at the time. Even got update access to the flashlight wiki to correct the errors, just didn't want to remove the original stuff because I really was unsure if the old dongles were still around.
Think Halo confirmed this at the time as well, also WarHawk had it right way back.
I encountered these problems early on with the 25/45/85's, researched it, then found the fix, but some others already knew about it. It's probably all in the early part of the 25/45/85 thread, I think.
Ok - looked it up, here we go:
Problem - Post #233 here: http://budgetlightforum.com/comment/822738#comment-822738
Problem - Post #241 here: http://budgetlightforum.com/comment/822832#comment-822832
Solution post #263 here: http://budgetlightforum.com/comment/824288#comment-824288
Post #265 mentioned same as just posted earlier: http://budgetlightforum.com/comment/824315#comment-824315
LightRider
LightRider's picture
Last seen: 2 years 6 months ago
Well I’ve now set up to build my own drivers. Did some practice by flashing luxdrv to a couple 105c drivers. So, I am finally ready to attempt one of these drivers. Could someone some up for me what firmware is out there that will work well with these triple down boards? I love the ability for the user to choose between two mode groups. I’ve been looking at the firmware repository, but I’m a little lost trying to sort through it all.
pilotdog68
pilotdog68's picture
Last seen: 11 months 1 week ago
So far just one firmware (that I know of) that works with the TripleDown. It’s a variation of the BLF-A6 firmware, so it does have 2 mode groups. It is linked in the OP of the TripleDown thread. As downloaded it is set up to test driver function, so you will need to edit some values to give proper function,
LightRider
Is alt pwm the third channel?
pilotdog68
ModesNx are the larger bank of 7135s. Modes1x is the single 7135. Put the word TURBO to toggle the FET
LightRider
Ok. I don’t real know what I am doing, but I might as well jump in and learn to swim:)
Can the FET only be toggled? I got the attiny85 for the added pwm, so will the 85 go to waste with this firmware, or is there still benefit? Sorry if my questions sound like I don’t know what I’m talking about. please humor my ignorance:)
pilotdog68
I don’t know how it works with anything other than a 13, or even if it will work at all. I personally have not left the 13
Tom E
Tom E's picture
PPDB22 wrote:
Ok. I don't real know what I am doing, but I might as well jump in and learn to swim:) Can the FET only be toggled? I got the attiny85 for the added pwm, so will the 85 go to waste with this firmware, or is there still benefit? Sorry if my questions sound like I don't know what I'm talking about. please humor my ignorance:)
Don't think there's any added PWM (??).  25/45/85 all have the same PWM limits, as I understand it.
LightRider
Tom E wrote:
PPDB22 wrote:
Ok. I don’t real know what I am doing, but I might as well jump in and learn to swim:) Can the FET only be toggled? I got the attiny85 for the added pwm, so will the 85 go to waste with this firmware, or is there still benefit? Sorry if my questions sound like I don’t know what I’m talking about. please humor my ignorance:)
Don’t think there’s any added PWM (??).  25/45/85 all have the same PWM limits, as I understand it.
I was talking about the number of outputs, but clearly I don’t know enough to be asking questions yet. I will keep reading. Facepalm
ToyKeeper
ToyKeeper's picture
Oh, um, the attiny13a has one PWM counter and two PWM channels. A 3-channel driver will need to use a general I/O pin for one of the channels, which is useful if you want a super-bright turbo and don’t care about the levels between turbo and 100% 7135. So, like, you could use 7135s to go smoothly from moon to about 1000 lumens, then go directly to a 3000-lumen turbo, and you wouldn’t be able to access anything between 1000 and 3000 lumens.
The tiny25/45/85 have two PWM counters and four PWM channels. So, it should be able to go smoothly all the way from moon to turbo even on a 3-channel driver.
I got a tripledown attiny25 board yesterday and am hoping to get bistro working on it soon. So far all I’ve done is update the ramp calculator to support 3 channels, and haven’t gotten into the actual driver code yet. Bistro works on it in 2-channel mode (1×7135 and 6×7135), but the third channel (FET) is currently unused.
LightRider
Ok. Thanks. I was just reading your posts in the tripledown thread. I mistakenly posted a question about the tripledown firmware here. Oh well.
I think you are working on exactly what I am looking for so I will continue to follow the tripledown thread anxiously awaiting your developments. For now I’m going to continue to practice flashing firmware with small customizations so hopefully I will advance my knowledge a bit.
ToyKeeper
ToyKeeper's picture
After someone else confirms it works, and maybe the defaults are tweaked back to a more user-focused config, I should be able to merge the tripledown-bistro code into trunk. For now, it’s working but is only in the tiny25 development branch.
For tiny13-based tripledown drivers, that’s a different matter. It can’t do PWM on the FET pin, and it has only half as much space, so it’s significantly trickier to get working.
Microa
Last seen: 8 hours 42 min ago
Dear ToyKeeper,
I have flashed your Baton FW for my light and it is great. I noticed that the green and the red indicators were turned on and off during the transition period when the voltage was dropping to the on/off threshold. Can you help me to make it turned on/off sharply.
ToyKeeper
ToyKeeper's picture
Hi, um, what exactly is it doing, and what do you want it to do?
In my testing, the indicator tends to stay green above 3.9V or so, then starts to flicker orange occasionally, and the flicker gets longer and more frequent as it gets near the next voltage threshold. Eventually it goes fully orange and stays that way. Then as the cell voltage drops more, it eventually turns red. But I haven’t seen the same soft flickering transition effect between orange and red.
I think this is because the voltage measurement is made out of phase with the PWM signal. So, sometimes it measures with the main emitter off, sometimes with it on. And this results in pretty different readings depending on when exactly the measurement was taken. It was unintentional but I kind of like the result since it gives a finer resolution, more than just green/orange/red.
At lower voltages it doesn’t seem to matter as much. The emitter isn’t using as much power so it probably doesn’t vary as much.
If you want it to not flicker orange as it nears the orange threshold, it’ll need to sync the measurements to happen at a consistent part of the PWM cycle. I’m not sure how to do this though.
Microa
Thanks for your prompt reply.
What I want to do is that you have explained. I have modified the code that
FULL BATT indicator off
LOW BATT indicator on
ALMOST EMPTY indicator blink
As you have said, the led flickered before it was stably on. I try to get rid of the flickering. It seems that is not easy to be done by changing a few lines of the code.
LightRider
ive been playing around with tk’s starry-offtime firmware(and others). Does anyone know where i can find the .h files that are referred to in the STAR firmware? Or do i not need them? Thanks for any help! These are the files i am talking about:
#include
#include
#include
#include
#include
#include
//#include
LightRider
oops!
#include <avr/pgmspace.h
#include <avr/io.h
#include <avr/interrupt.h
#include <avr/wdt.h
#include <avr/eeprom.h
#include <avr/sleep.h
//#include <avr/power.h
fixed it
Last seen: 9 months 3 weeks ago
PPDB22, they are installed with the “avr-libc” package on linux distributions. Not sure what the equivalent is on windows. If everything is installed correctly, they should be found automatically by the compiler.
LightRider
hmm. ok so are they created when i build the hex? excuse my ignorance!
LightRider
or are you saying they should be part of my avr software package? sounds like i should just build the file and give it a try then…
fixed it
Yes, they should come installed with the compiler. You won’t be able to compile most firmware without them. They’re official atmel stuff: http://www.atmel.com/webdoc/AVRLibcReferenceManual/group__avr__eeprom.html
What are you using to compile? On which OS?
LightRider
I’m on Windows 10. I’ve only flashed four drivers so far. I asked about these files because I compiled a different firmware with errors caused from missing files. I fumbled through fixing that so when I came to this firmware and saw it referenced some files I went looking for them. Thanks for you help. I’ll get to try it out tonight if my day goes well:)
ToyKeeper
ToyKeeper's picture
In C, any include with <> symbols is assumed to be provided by the host system. Includes with quotes come from the specific project being built.
So, all those mentioned should be available by default if the AVR toolchain is installed correctly.
