Making a light for the XHP 70 and the 95mm faceted reflector LUM 5-90. 103500 lux @ 1 meter. Beam Shots are up.
37 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
One way to make a light for the LUM 5-90 reflector and the XHP 70 led.
lum1a
The video is just an overview. I will have photos and descriptions later in the week.
 I'm going to be jumping around a bit, since I have done some of the processes here already, so I will go with the aluminum plate that will hold the SRK head and go into the bottom of the big 4" tube.
lum1b
This is a slice of 3-3/4" rod stock. 6061 aluminum. It is 5/16" thick. I will be drilling holes from the outside to the center, to lock in the SRK head and those will be #8-32 and I chose 5/16" so I would still have some metal left around the holes. I will be opening up the center to hold the SRK. I have marked where the SRK head will fit in, (outer pencil circle) and I will be drilling a bunch of holes in it, to "cut out the center". The drill is a HSS 3/8" and I will drill overlapping holes around the circle. The inner pencil line is the center point of the drill, so when I drill the hole, it should come very close to the outer circle. When I get some holes drilled, I will show you. The drill press is set for it's lowest speed, 620rpm.
Off to work soon, more when I get more.
03/24/15 After Work
So I got in a couple hours out in the garage after work. Let me caution you that you really need some safety equipment. Safety glasses or goggles are a must have and I find a good pair of leather gloves helps to protect the hands. You might want to fashion a shield of lexan too. Broken bits can happen and it can be nasty.
lum2a
I said I would use the drill bit to remove the center of the rod stock and here I am drilling overlapping holes all the way round. This is 6061 Aluminum and I like to use it because it is so easy to work with. It cuts like butter. No cutting fluid needed for this stuff, provided the drill is sharp.
lum2b
Once the center is gone, I start using an end mill bit. I have raised the drill press speed to it's max, which is 3100rpm. It's not very easy doing this, but the vise helps only because it's a lot of weight and a more stable base. What I do is to hold the vise with two hands and guide it, so that I am pushing the material against the bit. If you try to pull the material past the bit, it jumps around like crazy, but pushing works much more smoothly, plus you can see what it's cutting better.
lum2c
Once I get close to the marked ring, I will test to see just how close I am. Slow and easy does it. Rush it and you will ruin the bit and probably the part too.
lum2d
First test fit. Almost there, so I will switch bits now.
lum2e
I have switched to a Dremel #115 bit now. It does not take material off very easily and that's what I want. Smooth the hole and hit the high spots.
lum2f
It does not take much to get the fit. This is just a little loose, but it does not drop over easily, so as it gets hot, it will tighten the joint up.
Here's a photo that shows you what all this is going to achieve.
lum2g
Nuff said.
More when I get more, time for a little sleep.
03-26-15 The light is operational.
pot1a
I used masking tape, to measure around the outside of the aluminum base that the light fits into. Then I divided it into fourths and marked the aluminum to drill the four holes for set screws. The set screws are #4-40 and are 3/4" long. I put the aluminum ring in the drill press and drilled four spots with the correct drill for #4-40. Then I used another drill for #8-32 and drilled out the same holes just about halfway in from the outside. That allows me to use #4-40 set screws and use #8-32 outer screws to hold the top end onto this aluminum ring. I also drilled thru the SRK head, so the set screws go right up against the heat sink and hole it tight. The heat sink I used ended up being a thinner one. It was 3/8" thick. I have it drilled for wires and for two screws. Those screw holes are also #4-40.
zsaqw1z
Here you can see one of the four holes. The reason I did it this way was to hide the set screws, which are in below where the outer #8 screws will be. I used #4 and #8, so that I had clearance in the #8 hole, to get the tap for the #4 hole down in far enough to thread it all the way. Taps are larger diameter a shaft above the threaded section, so I needed the larger hole on the outer side.
vrwte1
Here's the head in place and held with four #8-32 Stainless screws.
dvftdt
All set to go. The XHP70 is on a 20mm star and I had to use a round file in the reflector, where the screws for the star are, to clear them. Just a simple round file to make the half rounds to clear the screws.
fgper
It really makes a compact light, as far as length. It weighs 1.93# without batteries. That's pretty light considering the only other lights that hold the 95mm reflector are mush heavier.
dgfdfgdfgn
It has a beautiful spot and it reads 103500 lux @ one meter. It's a thrower for sure. I will be doing beam shots later in the week, over at the plant where I work.
I did not talk much about the driver, because there are several you can use and it's an individual choice, so you can get what you want for it. As far as the contact plate, I just marked the original driver while it was in the light and while the body was tight in place. I went through the tail end and used a black marker to draw the outline of the inside of the body, for the four batteries. I also marked the driver and the head, so I would put it back together in the same place. I used those marks for my reference for cutting the traces and making the 2S/2P.
bgtrews
The video explains that and the spring plate pretty well.
Materials?
One SRK
One piece of Aluminum tube - 6061 - 4" OD, 3.750" ID and 2-7/8" long - speedymetals.com
One piece of Aluminum rod stock - 6061 - 5/16" thick, but it would be better to go with 1/2" thick - speedymetals.com
One piece of 2" rod stock - 6061 - 3/8" thick - speedymetals.com
One 95mm UV filter from ebay
One XHP70 - this one is from Mouser and is 6200k.
One 20mm Copper mcpcb from RMM
A driver of your choice. I would not limit it to the one I used, but you can get drivers from RMM
18ga wire and 24ga wire, (24ga if you need to rewire the momentary switch
3/8 nickel silver discs for the contacts. These were 3/8 diameter and 20ga thick
I think that is about all. Of course, I would not try this without a drill press. There needs to be some precision when drilling all the holes for proper alignment.
cdswe1a
This light illuminates the far end of the plant better than any single led light I have tried out. The beam, for me, is perfect.
vchghmdfz
vchyiu
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 03/27/2015 - 01:40
ImA4Wheelr
Last seen: 1 week 4 days ago
Like the way this is headed already. Smile
Hoop
Hoop's picture
Last seen: 22 hours 34 min ago
Good ol “soup pot” method. :bigsmile: (You know how some guys use a soup pot for the big HID sized reflectors, haha)
Looking very nice O-L!
Old-Lumens
More photos in the OP.
MRsDNF
MRsDNF's picture
Last seen: 11 hours 20 min ago
What can I say? I'll put my order in now before everyone else does. Orsm effort so far.
Old-Lumens
The light is finished, Photos in the OP. I do not think I am going to blacken the Aluminum. I think I will just use Mothers on it and leave it as is. I will do beam shots tonight or tomorrow night, inside the plant and maybe on top, going for the bank again.
MustSimon
MustSimon's picture
Last seen: 1 year 2 weeks ago
I like it! Smile
DayLighter
DayLighter's picture
Last seen: 2 years 10 months ago
Take my money please! :bigsmile: :bigsmile:
The only way to do a great work is to love what you do.
mizjif
mizjif's picture
Last seen: 2 weeks 5 days ago
Now that is cool!! As always, very creative and brilliant work.
Old-Lumens
Thanks,
If anyone really does want one, either in brushed aluminum, or in black, send me a PM. I still have 4 reflectors and I know how to do them now.
Might wait for beam shots tonight though.
Bigchelis
Last seen: 1 year 3 months ago
Wow, this is amazing.
I have the DX SST-90 Reflector(73mm) in 2 Maglite builds and I get 103k~105K lux with MTG2 at 6A (8.4V input).
So, you mastered more output with that XHP70 yet still crank out over 100K lux…. Shocked
bigC
MRsDNF
MRsDNF's picture
What an effort. l've just watched your video and loved every second of it. Even the back ground music had garage all over it. Was It MC Hammer? Smile The mods to the driver board for the battery configuration was really good info. It gives me an idea for another light mod I've been stuck on.
Anyone thinking of getting a custom OL light the offers been made and what a light it would be. Now if I could only win the lottery as the good wife refuses to get a forth job.
Thanks Justin. Simply amazing.
pinkpanda3310
pinkpanda3310's picture
Last seen: 5 hours 12 min ago
Very nice, as usual, OL. Question – have you tried a dedomed xhp-70 in any of you builds?
southland
southland's picture
Last seen: 2 weeks 2 days ago
Great build, can’t wait for the beam shots.
M4D M4X
M4D M4X's picture
Last seen: 1 hour 31 min ago
great build as ever!
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
MRsDNF
MRsDNF's picture
pinkpanda3310 wrote:
Very nice, as usual, OL. Question - have you tried a dedomed xhp-70 in any of you builds?
There was a few posts on this somewhere. I don't think it was successful.
cajampa
Last seen: 3 years 9 months ago
James3 did succeed with a XHP dedome Smile with the XHP50 at least, first a quick slice to take of most of the dome then a quick dunk in gas.
check out his thread about it
Old-Lumens
Beam shots are in the OP now.
Old-Lumens
No, I have not. I go as far as slicing the domes on any leds, but I do not de-dome with gasoline. I have been 100% unsuccessful in that and have never liked the results.
Kloepper Knife Works
Last seen: 3 years 11 months ago
Old Lumens, do you have 1-2 of those reflectors you’d like to get rid of? I’d like to do a couple of maglite builds but not sure I need 5. If not I’ll just order the 5 and figure out something to do with them. Wink
Old-Lumens
Kloepper Knife Works wrote:
Old Lumens, do you have 1-2 of those reflectors you'd like to get rid of? I'd like to do a couple of maglite builds but not sure I need 5. If not I'll just order the 5 and figure out something to do with them. ;)
At the moment, I don't know. If people want one made, I won't have any left. I also want to make one for myself, for work, so right now I would have to say I will not have any left.
FmC
FmC's picture
Last seen: 6 hours 25 min ago
Very nice outcome. This is really a ‘go big or go home’ light.
I’m tempted to do something like this if my $11.99 SRK ever turns up from that ebay deal….
DavidEF
DavidEF's picture
Last seen: 3 days 12 hours ago
How long is that distance to the far wall again?
- The YKK Philosophy
DB Custom
DB Custom's picture
Last seen: 6 days 13 hours ago
Nicely done Justin, thinking outside the box again….Love it!
I didn’t file the reflector to clear the screws in my Olight, merely removed the screws and put the reflector on, then put the screws back in.
The XHP-70 works beautifully in this reflector, I too think it’s just about a perfect beam profile.
Thanks for sharing the build, lot of work there….
Rusty Joe
Rusty Joe's picture
Last seen: 1 week 1 day ago
WOWY!
TexasLumens
TexasLumens's picture
There are folks that mod lights... then there are magicians! SO... the way I calculate it is...
1 Fantastic Mod Guy + 1 Super Duper Magician = OLD LUMENS!!!
What creative and perfect work!!!! What a beam!!! Simply Stunning Justin!!!
Dan.
Texas Lumens Website… http://www.texaslumens.com
WE LIVE IN THE LAND OF THE FREE ONLY BECAUSE OF THE BRAVE!
ChibiM
ChibiM's picture
Last seen: 11 hours 42 min ago
How much will it cost? Wink
Old-Lumens
271 yards
78 yards
and 30 yards
Old-Lumens
To buy the stuff and make one, if you have a drill press or can use someone's:
SRK - price varies, but say $30
Aluminum - varies, but from speedymetals, about $10 plus shipping and they ship UPS, so about $12 there - $22
XHP 70 about $15 - $18 from China or more from Mouser because of shipping.
mcpcb about $7
Misc- wire, solder, metal discs, etc, etc, etc. $5
Reflector - they only ship 5, so that's the hard part. About $45 for five.
So, it ain't cheap, but modding never is. If you can get just one reflector, then about $85-$95.
If I make one - $150 plus shipping.
Old-Lumens
Thanks everyone for viewing the mod and for the kind words.
I have been thinking of trying one with several short pieces of aluminum tube, telescoped, so the head looks more like a normal light, kinda, sorta. Don't know if I would do that though, as it would only add to the labor and the overall cost.
MRsDNF
MRsDNF's picture
TexasLumens wrote:
There are folks that mod lights... then there are magicians! SO... the way I calculate it is...1 Fantastic Mod Guy + 1 Super Duper Magician = OLD LUMENS!!!What creative and perfect work!!!! What a beam!!! Simply Stunning Justin!!!Dan.
Well put Dan. While we're at it a real motivator as well.
