Test/Review of Samsung INR18650-25R 2500mAh (Green)
30 posts / 0 new
HKJ
HKJ's picture
Last seen: 53 min 49 sec ago
DSC_8641
Official specifications:
  • Nominal discharge capacity: 2,500mAh
  • Nominal voltage: 3.6V
  • Standard charge: CCCV, 1.25A, 4.20 ± 0.05 V, 100mA cut-off
  • Rapid charge: CCCV, 4A, 4.20 ± 0.05 V, 100mA cut-off
  • Charging time: Standard charge : 180min / 100mA cut-off
  • Rapid charge: 60min (at 25°C) / 100mA cut-off
  • Max. continuous discharge: 20A(at 25°C), 60% at 250 cycle
  • Discharge cut-off voltage: 2.5V
  • Cell weight: 45.0g max
  • Cell dimension: Height : 64.85 ± 0.15mm, Diameter : 18.33 ± 0.07mm
  • Operating temperature (surface temperature): Charge : 0 to 50°C (recommended recharge release re-discharge release Storage temperature (Recovery 90% after storage): 1.5 year -30~25°C, 3 months -30~45°C, 1 month -30~60°C
Samsung%20INR18650-25R%202500mAh%20(Green)-info
This is the high capacity, high current cell from Samsung.
DSC_8640
DSC_8642 DSC_8643
DSC_8644
DSC_8645
Samsung%20INR18650-25R%202500mAh%20(Green)-Capacity
There is good trakcing between the two cells and the capacity does only drop slowly with load. The 30A discharge is to high for this battery.
Samsung%20INR18650-25R%202500mAh%20(Green)-CapacityTimeHours
Samsung%20INR18650-25R%202500mAh%20(Green)-Energy
Samsung%20INR18650-25R%202500mAh%20(Green)-PowerLoadTime
Samsung%20INR18650-25R%202500mAh%20(Green)-TripCurrent
Samsung%20INR18650-25R%202500mAh%20(Green)-Charge
Conclusion
This is one of the good high current, high capacity batteries, it has good performance, but it is not the best of them.
Notes and links
Compare to 18650 and other batteries
TheBo
TheBo's picture
Last seen: 4 weeks 1 day ago
THanks as usual for the nice work!
Known diffferences between these and the light blue wrapped on fasttech?
Also
… like what…? What are the currently available batterie that outperform these 25R…HE2/4?
Rufusbduck wrote:
Getting discouraged is normal but doesn't finish the job.
HKJ
HKJ's picture
TheBo wrote:
What are the currently available batterie that outperform these 25R...HE2/4?
Check my comparator. The Sony is best but unavailable (I believe), next is HE2.
TheBo
TheBo's picture
i suspected you were referring to the VTC5.
THanks, for the clarification!
Mitko
Mitko's picture
Last seen: 2 weeks 1 day ago
10x for the great review!
Was about time, especialy for one of the best high drain cells…maybe even the best considering the fact that it can be found in EU for under 3.5 euros…vs VTC5 at a double( even trippe) price? Thanks but no thanks…a dealer even offered me once VTC5 for 14 euros cause they were “great”..Makita uses only those you know…and he had a box hidden for special customers…right Smile
Btw at VTC5 runs hotter than 25r, i use them both in my mech mod
M4D M4X
M4D M4X's picture
Last seen: 27 min 35 sec ago
what is the difference between the green and the blue ones?
http://www.banggood.com/2PCS-INR18650-25R-2500mAh-3_6v-20A-Rechargeable-...
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
HKJ
HKJ's picture
M4D M4X wrote:
what is the difference between the green and the blue ones? http://www.banggood.com/2PCS-INR18650-25R-2500mAh-3_6v-20A-Rechargeable-...
I do not know that, but I have used your link and ordered two cells (Thanks).
M4D M4X
M4D M4X's picture
ouch – in my deals thread there is a code for them (safes nearly a Dollar Wink )
but i am looking forward to your results (because i also have a pair of them )
pilotdog68
pilotdog68's picture
Last seen: 3 weeks 3 days ago
All of the 25Rs I have are blue, until now I hadn’t seen a green one.
wolfdog1226
wolfdog1226's picture
Last seen: 6 months 1 week ago
Thanks for the review.
I have the HE2’s[K’Power version] and the Efest 35A. They both work well w/ the HE2’s with slightly less of a Voltage sag than the Efests.
Thanks to your comparator which is very helpful! One night I was comparing batteries for ~ 2 hours!! Wink ,,,,,,,,,I know,,,,,get a life!! lol! ,I just have alot of spare time!
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
Mitko
Mitko's picture
They are same, sometimes green, sometimes blue i buy those like every month from NKOL , and the seller stated there isnt any difference between blue and green
Some states that greens are fakes but thats not true, vise versa: a korean guy( it was either in FT forum or CPF) pointed out that since 10.2014 only green ones should be produced
Cula
Cula's picture
Last seen: 14 hours 46 min ago
Can you please give us a link of that shop in EU where you buy batteries, thanks. I am ordering from Fasttech but it takes way to long to get them.
TheBo
TheBo's picture
He was referring to
http://www.nkon.nl/
M4D M4X
M4D M4X's picture
banggood ships in around 14 days to Austria (atm they sell for 11.25 a pair Wink )
Ejected Filament
Ejected Filament's picture
Thanks for the review HKJ, and I knew you had a back log but these and the HE2 you recently reviewed make it clear how back logged you must be.
Mitko wrote:
… i buy those like every month from NKOL , ….
Theres a North Korean Old Lumens?
Mitko
Mitko's picture
Indeed, i ordered 2 times batteries from Banggood, and they came in like 2-3-4 weeks, but on the CN they were declared as chargers, hehe, both times
Err…..can you translate this one pls? Smile
DB Custom
DB Custom's picture
Last seen: 4 hours 8 min ago
The joke is that there is a North Korean clone of our Old Lumens (Justin) who makes and modifies lights with excellent attention to detail using minimal power tools. Known for his file work especially.
Thanks HKJ, appreciate the review. I knew the 25R was a bit below the 35A in performance, but didn’t realize exactly how the HE-2 and 35A compared. It was said that the Purple 35A was a rewrapped HE-2 but I knew better, the lights showed me. Wink Close, but no cigar.
Your comparator is awesome! I wish it could be expanded to directly compare 3 or 4 cells simultaneously but oh well. Smile
Back to MTN for more HE-2’s, Wink
shadockan
shadockan's picture
Last seen: 1 week 2 days ago
The KeepPower IMR 2500mAh with white labels ( old ) , has within the LG HE2.
The new KeepPower IMR 2500mAh black, has within the Samsung 25R.
The old is really very powerful battery .
In relation to the Efest 2500 purple, is stronger .
But if she is the black then it is weaker up to 3.8 V.
From there down, it’s better the performance.
Sorry, but I think Samsung 25R (Green), is much better.
I bought 20 such batteries (not all for me of course) from NKON and is flawless.
I am steamer Electronic Cigarettes and discharge into machine mod, is the most often from 3 Amps and can even reach 90 Amps (0.1 Oms in 3 Volts.)
Naturally me personally, do not care to 90 Amps, but for discharge of 5 – 7 Amps. , My 25R Samsung have shown to be the best.
Even the Sony VTC5.
The HE2 / 4 is the strongest of the 4.2 V up to 3.8V. After the 3.7 Volts, is the marked their weakness, more than the other two (VTC5-25R)
Measured Volts from fresh battery to 4.2V, all have almost the same performance, but from the 3.8V and then the 25R is purely the strongest battery of the three, up to 3.3V, which will go for charging.
For me it is all three (four with HE4) batteries are very good, but I personally have seen the best performance in electronic cigarette with the 25R, the Ohm these.
After the 10 Amps yes, Sony is better, but personally 10 AMPS in electronic cigarette, avoid them.
I was surprised, however, the very low yield of the test, especially since I have these batteries and I see that the same performance with the blue.
Henrik, a big thank you for your trouble, my friend.
If it was you, little would know.
Always be well man.
wolfdog1226
How come in HKJ’s review and comparator he has the IMR Keeppower Black 2014 cell listed as LG ICR18650HE2???
P.S. I quit smoking 18 years ago. I do not Vape!!! The batteries work well in my Modified search lights! 8)
        WOLFDOG
chouster
Last seen: 6 days 14 hours ago
I think I’ve read somewhere that the green 25R are the newer ones, they changed the color, so the blue ones are simply from an earlier production.
As far as I’m concerned all of my lights draw the highest amps from the HE4, higher than HE2 and 25R. If you scroll down on this page, you’ll find curves at 20A of the HE4 vs the HE2 and the HE4 vs the VTC5.
wolfdog1226
BESIDES THE GRAPHS.
I will have to get my girlfiend or neighbor to translate! Neighbor born in Bad Nauheim and girlfriend born in Kindenheim,,,,near Worms, SW of Frankfurt! :bigsmile:
        WOLFDOG
wolfdog1226
hmmmmm
Same batteries[HE2/HE4] different testers ….different results!
On HKJ’s comaparator the H4’s sag more at 20A than the H2’s??? :~
        WOLFDOG
shadockan
shadockan's picture
http://i.ebayimg.com/00/s/MTE5OVgxNjAw/z/OxkAAOSwv1RUZ4ac/$_57.JPG
http://i.ebayimg.com/00/s/NTAwWDUwMA==/z/4z4AAOSwZjJU6J-z/$_12.JPG
Look the various positive poles and the distance from the head my friend.
After eye on the original 25R – HE2 and you will see the corresponding head.
The KP Dude really had inside the LG HE2, but before the ’15 glans the 25R.
The KP black however is now in most shops, such in the 25R definitely.
I have six new KP and are all the means 25R.
But as yields are identical with the 25R.
Same length, same size and identical their heads.
I have unwrapped two KF and measuring sizes. Are identical with the 25R.
This I saw. If I’m wrong …… I apologize my friend.
wolfdog1226
Sorry,a bit of a language barrier. Not exactly clear with all you said.
I don’t KNOW who is right or wrong!,,It is NOT always a matter of that. I am simply stating One persons review[HKJ] in comparison to others reviews and opinions. Wink
p.s. I am not sure what your “links” are,,,,,,,,,but they do not work!
Enough said. I Apologize to HKJ in getting to a debate which does very little in contributing to his review!
        WOLFDOG
Werner
Werner's picture
Thanks for this review.
I have the blue ones.
I found this info about date codes:
Quote:
-SAMSUNG SDI Confidential Proprietary –
Spec. No. INR18650-25R Version No. 1.0 In-Young Jang
- 15/16 –
Additional remarks
■ Cell package : The bare cell is packed by which packaging material, PET tube.
■ Model and tube marking : there are three lines on the cell tube as follows.
Line 1 : INR18650-25R —- cell model name
Line 2 : SAMSUNG SDI —- cell manufacturer
Line 3 : 2D51 —- date code (Capacity ; “2” is over 2.0Ah, Year, Month, Week)
■ Lot marking : There are three lines on the cell metal can as follows.
Line 1 : J5D5 —- 1 st digit: Line number ( “1” for cylindrical line No.1, “J” for cylindrical line No. 8)
2 nd digit: Final number of Model Name (“5” is INR18650-25x)
3 rd digit: Year ( “D” is 2013)
4 th digit: Month ( “5” is May ; A is Oct., B is Nov., C is Dec)
Line 2 : 45221 —- 1 st digit: Negative coater number ( “7” is No. 7 coater)
2 nd ~ 4 th digit: Batch number
5 th digit: Serial No. of assembling
Line 3 : 62F1 —- 1st digit: Date (“6” is 6th day ; 10 is A, 11 is B…)
2nd digit: Serial No. of winding in a batch
3rd digit: Reel No ( “F” is F reel ; A is A reel, B is B reel, … F is F reel)
4th digit: Winding Machine No. ( “1” is No.1 winder)
Page 15/16
https://drive.google.com/file/d/0B5ce5vDCG1uyZFlNa1hHdmFyYWs/view
My blue one has this on the metal tube
J5EB
4B5A1
And 2EB2 on the wrapper.
I got it from BG some days ago…
Blue 25R
E 2014
B december
2 2nd
wolfdog1226
THE BEST post yet! ,hold on,,,you edited it!! lol!
Everyone have a nice day/evening. :bigsmile:
        WOLFDOG
ferongr
ferongr's picture
Last seen: 7 months 2 weeks ago
For all the hype this cell gets around the vaping circles, the actual performance as measured is disappointing. Could the change in wrapper color signify a change in quality grade too? Some other comparative graphs from Illumn and nkon paint a different picture (the 25R is somewhat inferior to the VTC5 in voltage drop under load but quite a bit better than the HE2).
shadockan
shadockan's picture
I accept the measurements of Henrik, almost always agree with my own. If no difference is insignificant and may be related to the equipment of everyone, but personally I saw very good performance with green 25R.
It is known that the temperature helps the performance of batteries mAh, but it can and will affect the performance of the force.
Many times there are differences in the same batteries and one may be lower than the other.
Buying more than one year from the NKON and Green bought from there, I have the measurements.
Same their performance with the blue.
Apology to Henrik for the off-topic conversation I had in some places …..
Tonylee819
Last seen: 4 years 3 months ago
The blue one and the green one have the same battery performance, but for the blue color is more popular and the green is a new color, the price differ.
You can check the official statement about INR18650-25R tube color changing from Samsung SDI. The source is from www.tomobattery.com
Mitko
Mitko's picture
Lately i ordered some of those 25rs simply cause the supplier didnt have HE2s … and it seems they are improoved, now they are as good as Sony VTC5 speaking of internal resistance, maybe even better, even reaching VTC5A
Thats ofc very crusial for our FET DD drivers!
Hope that info will be helpful, their price is lovely atm
