Test/Review of Charger Xtar VC4
63 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 31 min ago
Charger Xtar VC4
DSC_9284
DSC_9285DSC_9286
Xtar makes many LiIon chargers, this is a usb powered quad channel charger with display. The charger can charge with up to 1A for two channels or 0.5A for four channels, actual current depends on slots used and available usb power. It supports both NiMH and LiIon cells.
DSC_9278 DSC_9277 DSC_9276 DSC_9274
I got the charger in a cardboard box with the specifications printed on it.
DSC_9279
Inside the box is a fabric bag with the charger in, this can be useful for traveling and to keep the manual, charger and cable together.
DSC_9281
The bag contained the charger, a cable (charger to usb), a warranty card and a instruction manual.
DSC_9288
The charger is usb powered, but the connector is a DC barrel connector, i.e. you need the supplied cable to connect the charger. I would have preferred the ability to use a normal usb cable. The DC barrel connector is not compatible with the one used on the 12V chargers, i.e. there is no risk of connecting a 12V power supply from another Xtar charger to this charger (Very good).
Another way to handle this would have been to make the charger accept both 5V and 12V power.
I got no USB power supply with the charger (Xtar say that they will also be selling a compatible usb power supply). I have tested some usb power supplies and it is possible to find a useable one on my list (Remember it must supply at least 2A for full charge speed).
DSC_9289
There is a display, four red/green leds and one button. The button has a couple of functions:
1) Restore full background light on the display (The light will dim after a short time).
2) Turn the background light/display off or on, a long press will turn it off, any press will turn it on again.
3) Select what slots are displayed, this is only necessary if more than two batteries a charged simultaneous.
The leds are red while charging and green at all other times. This makes it very easy to see when a slot is finished.
DSC_9294
The display uses dials to show voltage and maximum current, it does also have some 7 segment digits to show charged capacity and slot number.
DSC_9296
The current dial only shows the maximum charge current, the actual current is lower when the battery is in the CV phase.
The voltage dials shows the actual voltage when in range:
0V Battery voltage is low, charger is only using low current, display may show "Err" if there is a problem with the batteries.
3.0V Voltage is high enough to start regular charge.
3.5V-4.2V Regular charge, display is within 0.1 volt.
If the charger only has two batteries in it, the display will always show them, independent of slots used, with 3 or 4 batteries the switch must be used to select between them.
DSC_9290DSC_9291
The charger can handle both button top and flat top batteries.
The slider moves smoothly and can hand cells from 30mm to 71 mm long.
supportedBatteryTypes
supportedBatterySizes
DSC_9297DSC_9298DSC_9464DSC_9465
DSC_9299DSC_9300DSC_9301DSC_9303
DSC_9304DSC_9305DSC_9306
The charger can handle 71 mm long batteries, including flat top cells.
Measurements charger
  • When charging the last digit in the capacity displays will flash.
  • The charger will charge with 100mA from 0 volt and display will show NiMH
  • Charger will not stop NiMH charging within the first 10 minutes.
  • Above 2.0 volt the charger assumes LiIon battery.
  • Between 2.0 volt and 2.9 volt charge current is 120mA on 1A range.
  • Above 2.9 volt the full charge current will be applied.
  • When charge is finished the charger will charge with 0.2mA.
  • The charger steps charge current down when the usb voltage at the charger is below 4.7 volt.
  • Charger will restart if voltage drops to 3.9 volt.
  • Charge will restart charging after power loss, or battery insertion.
  • When not connected to power it will drain about 0.6mA from a LiIon and 0.2mA from a NiMH battery.
  • Current dial will show maximum possible charge current, not actual charge current.
  • Voltage dial will show within 0.1 volt when voltage is in range.
  • The 3 volt position on the voltage dial looks like it signals "start of regular charge", i.e. 2.9 volt.
  • mAh display flashes "Full" when the corresponding battery is full.
  • With only slot #1 and #4 in use maximum charger current is 1A
  • With slot #2 or #3 in use all slots are limited to 0.5A charge current.
The light green line is usb current consumption, the dark green is charge current.
Charging LiIon
Xtar%20VC4%20(PA18650-31)%20%231
The charger does a nice CC/CV charge with a termination at about 70mA. The changing DC input current shows that this charger is using a switching charge regulator.
The display shows 2807mAh charged into the battery.
Xtar%20VC4%20(PA18650-31)%20%232
Xtar%20VC4%20(PA18650-31)%20%233
Xtar%20VC4%20(PA18650-31)%20%234
The other channels has a similar result. Slot #2 and #3 is charging with 0.5A. The termination current is the same on all slot at around 70mA
The display shows 2791mAh, 2776mAh and 2784mAh charged into the battery.
Xtar%20VC4%20(BE18650-26)%20%231
The 2600mAh battery has a long CV phase, probably because it is getting old.
The display shows 2172mAh charged into the battery.
Xtar%20VC4%20(PA18650-34)%20%231
The 3400mAh takes slightly longer to charge.
The display shows 3047mAh charged into the battery.
Xtar%20VC4%20(AW16340-IMR)%20%232
The charger has no problem with my old IMR cell, but there is not much capacity left in it.
The display shows 154mAh charged into the battery.
Xtar%20VC4%20(AW18350-IMR)%20%232
The 18350 cell is better, I uses slot #2 to limit the charger current to 0.5A
The display shows 695mAh charged into the battery.
Xtar%20VC4%20(KP14500-08)%20%232
The 14500 is also charged in slot #2
The display shows 754mAh charged into the battery.
Xtar%20VC4%20(4xPA18650-31)
Charging 4 LiIon cells at the same time is a rather slow, because the charger turns the charge current way down with my power supply and wires.
The display shows 2407mAh 2498mAh 2566mAh 2518mAh.
Xtar%20VC4%205.2V%20(4xPA18650-31)
Increasing the usb voltage to 5.2V to compensate for wire losses improves the charge speed.
The display shows 2781mAh 2764mAh 2884mAh 2857mAh.
Xtar%20VC4%205.2V%20falling%20(4xPA18650-31)
Supplying a falling voltage to the charger shows that the current regulation starts reducing the charge current rather soon, this is due to resistance in the cable and connection.
Temp1749
M1: 28,6°C, M2: 30,9°C, M3: 30,6°C, M4: 29,1°C, M5: 31,1°C, HS1: 37,1°C
The charger does not heat the batteries much during charge.
To do these photos I uses this usb power supply, it maintains the output voltage slightly above 5 volt, this allowed the charger to use full charge current.
Temp1750
M1: 28,2°C, M2: 30,0°C, M3: 30,0°C, M4: 28,1°C, HS1: 35,2°C
As usual the power connector get warm, but here the heat is very limited.
StartupLiIon
The charger needs about 10 seconds to start.
ChargeLiIon%231
The 1A current is steady, no pulsing is used.
ChargeLiIon%232
The 0.5A charge current is a reduction of charge current, not pwm regulation.
Charging NiMH
Xtar%20VC4%20(eneloop)%20%231
The charger was a bit doubtful about my 5 volt power supply and did reduce the charge current a couple of times.
The charging terminates on voltage and then does a top-off charge, as can be seen in some of the other curves this top-off takes about 2 hours. It is done after the charger reports done.
Display shows 1605mAh
Xtar%20VC4%20(eneloop)%20%232
Xtar%20VC4%20(eneloop)%20%233
The two 0.5A channels works the same way.
Display shows 1627mAh 1673mAh
Xtar%20VC4%20(eneloop)%20%234
The last channel accepts my power supply and uses full charge current all the time. On most of these charts it looks like the temperature is starting to raise, just before the charger terminates, this means the battery is fully charged.
Display shows 1661mAh
Xtar%20VC4%20(eneloopXX)%20%231
Xtar%20VC4%20(eneloopPro)%20%231
Xtar%20VC4%20(powerex)%20%231
With these batteries the temperature raise is obvious.
Display shows 1750mAh 2312mAh 2209mAh
Xtar%20VC4%20(eneloopAAA)%20%232
Here I am missing the temperature raise, i.e. the termination is a bit premature.
Xtar%20VC4%20full%20(eneloop)%20%231
Xtar%20VC4%20full%20(eneloop)%20%232
The charger can detect a full cell within a few minutes when it starts charging, but because the 10 minutes precharge it takes some time to detect the full cells.
Xtar%20VC4%20(4xeneloop)
With 4 cell the charger cannot get enough power from my 5 volt supply (due to cable and connection resistance), it need a bit more volt for full charge current.
Display shows 1676mAh 1683mAh 1746mAh 1720mAh
Xtar%20VC4%205.2V%20(4xeneloop)
Raising the voltage a bit gets the charger up to full speed.
Display shows 18526mAh 1919mAh 1858mAh 1834mAh
Xtar%20VC4%200.5ohm%20(4xeneloop)
Adding an extra 0.5ohm resistor in series with the power supply did not work, the charger needs a better power supply than that.
Temp1762
M1: 29,9°C, M2: 31,4°C, M3: 31,3°C, M4: 29,6°C, M5: 32,3°C, HS1: 38,7°C
Also NiMH cells stays very cool during charge.
StartupNiMH
For NiMH it takes 8 second from power on to precharge is started.
StartupNiMH2
The precharge runs for 10 minutes, before regular charger kicks in.
NiMHprecharge
Precharge is about 120mA with pulsing each second.
NiMHcharge%231
1A charging has the same pulsing and uses 1A as charge current in the pulses, average charge current will be a bit lower due to the pulsing.
NiMHcharge%232
0.5A charging reduces the current, there is no pwm regulation.
NiMHTopOff
The two hour top-off charge is done with pulses.
NiMHTopOff2
And the current depends on the charge current.
Charging LiIon and NiMH
Mixing LiIon and NiMH cells in the charger is no problem.
Xtar%20VC4%205.2V%20(eneloop+3xPA18650-31)
In the above curve I measure on the NiMH cell (Except temperature that is on a LiIon), the NiMH finished first.
Xtar%20VC4%205.2V%20(PA18650-31+3xeneloop)
In this curve the NiMH finished first (the DC input current drops) and I continue recording the LiIon data.
Because the charger is supplied from usb power there will not be any safety issues with it, but be careful with the usb power adapter.
Conclusion
The charger is very good at both LiIon and NiMH charging and keeps some impressive low cell temperature during charge (Like the VC2).
For charging at full current the charger is fairly demanding of the used usb power supply. It is possible to use weaker supplies, but the charging will be slower or sometimes much slower. With the current dial it is easy enough to see when that happens and it is time to get a better usb power supply. I would have liked slightly better performance with weak usb power supplies.
This type of charger is what I will call a family charger. Nearly anybody in the family can use it, just put the batteries into the charger and wait. Only caveat is that small batteries go into the two center slots or, for sets of four, in all four slots.
Final conclusion must be that it is a good charger.
Notes
The charger was supplied by XTAR for a review.
Edited by: sb56637 on 06/25/2015 - 14:21
MountainKing
Last seen: 3 weeks 1 day ago
Goody goody goody!! Finally!! Going to read it now !! Thanks HKJ! WAs waiting for it whole day Big Smile
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECT – SCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
MountainKing
Hum great stuff mate… Really liking this charger but I need a plug for it…Does those with the skull mean to AVOID?
What does the total current means? Do we need a specific “total current” from those power supplies to get maximum charge speed from the charger?
EDIT: Can I use those USB phone adapter chargers?
HKJ
HKJ's picture
MountainKing wrote:
Hum great stuff mate... Really liking this charger but I need a plug for it...Does those with the skull mean to AVOID?
Yes. One skull can be used in 120VAC country with only a minor risk.
MountainKing wrote:
What does the total current means? Do we need a specific "total current" from those power supplies to get maximum charge speed from the charger?
For multiport chargers the total current is the amount of current that can be drawn from all ports together. For single port chargers it will be the same as the port current.
You just need a port current at 2A or above.
Davx
Davx's picture
Last seen: 2 years 2 months ago
I don’t understand this point “Only caveat is that small batteries go into the two center slots or, for sets of four, in all four slots.”
Maybe i lost some detail in the test?
"There are always new jobs, women, and apartments......there is only ONE BLF." - Chicago X (27/03/2012)
HKJ
HKJ's picture
Davx wrote:
I don't understand this point "Only caveat is that small batteries go into the two center slots or, for sets of four, in all four slots." Maybe i lost some detail in the test?
The centre slots always uses a low charge current, i.e. you have to put AAA in the centre slots.
With 3 or 4 batteries all slots will use low charge current.
Mitko
Mitko's picture
Last seen: 1 day 12 hours ago
I decided to try that charger our and ordered it some time ago – planning to use it with that chunky PSU, which came originaly with my wifes Samsung S6
Its definately Samsung original, but that 5.3v bothers me a bit
netprince
Last seen: 4 hours 23 min ago
Thanks for the review. I’ve had one of these chargers for a couple weeks, and I like it a lot. I’m glad I didn’t buy a dud…
HKJ
HKJ's picture
Mitko wrote:
I decided to try that charger our and ordered it some time ago - planning to use it with that chunky PSU, which came originaly with my wifes Samsung S6 !http://s10.postimg.org/6twhl2odl/2015_04_10_19_44_28.jpg! Its definately Samsung original, but that 5.3v bothers me a bit
I doubt there will be any problems with 5.3 volt, it is only 0.05 volt above the limit.
my9221
Last seen: 12 hours 16 min ago
Beautiful review and pics. Unfortunately this unit doesn’t charge 4.35v otherwise it may be a perfect charger for me!
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 4 weeks 22 hours ago
Bet an old throw away ATX powersupply would be a GREAT way to feed this thing Wink
Awesome review…thanks!
MountainKing
HKJ, how do I know the “port current” of my phone chargers? I got some and they would fit nicely but are some ratings:
Xiaomi ch-p002: Max 0.2A. Output: 5V – 1000ma
Mlais: Max 0.2A. Output: 5V – 1000ma
Does that mean the port current is 1A? Thanks.
HKJ
HKJ's picture
MountainKing wrote:
HKJ, how do I know the "port current" of my phone chargers? I got some and they would fit nicely but are some ratings: Xiaomi ch-p002: Max 0.2A. Output: 5V - 1000ma Mlais: Max 0.2A. Output: 5V - 1000ma Does that mean the port current is 1A? Thanks.
They are specified with a 1A port current, if they can deliver it is an open question.
MountainKing
Oh crap. Looked everywhere but none of the 2A recommended wall chargers by HKJ can be easily obtained or obtained at all! Anybody knows where I can get a good 2A USB wall charger?
Ok Here are 3 I found after quite some reading and googling Big Smile Which one?
(tested ok by HKJ)
https://www.fasttech.com/products/0/10002574/1191200-4-ports-usb-ac-wall...
(Not tested but looks good)
http://www.gearbest.com/usb-gadgets/pp_70688.html
(Not tested and looking quite cheap Big Smile )
http://www.gearbest.com/usb-gadgets/pp_164731.html
khas
Last seen: 18 hours 41 min ago
I also like that it can charge 32650 batteries, but it takes a fair bit of time.
geo10
Last seen: 1 year 6 months ago
MountainKing wrote:
Oh crap. Looked everywhere but none of the 2A recommended wall chargers by HKJ can be easily obtained or obtained at all! Anybody knows where I can get a good 2A USB wall charger? Ok Here are 3 I found after quite some reading and googling Big Smile Which one? (tested ok by HKJ) https://www.fasttech.com/products/0/10002574/1191200-4-ports-usb-ac-wall... (Not tested but looks good) http://www.gearbest.com/usb-gadgets/pp_70688.html (Not tested and looking quite cheap Big Smile ) http://www.gearbest.com/usb-gadgets/pp_164731.html[/quote]
I got the first one from these that you mention, tested by HKJ, from here
http://intl-outdoor.com/ioncell-4-usb-2a-power-adapter-p-328.html
Smile
Woody
Woody's picture
Last seen: 9 hours 26 min ago
Smile
I also bought an Ioncell charger from Intl Outdoor store, on the strength of HKJ’s review. The Fasttech versions were, at the time, not described as “authentic” Ioncell, and I seem to remember a FT comment that they weren’t original. That comment seems to have disappeared, but I didn’t risk buying what looked like a fake.
I see FT still don’t use the Ioncell name in their description, which seems ominious.
Sorry to go somewhat OT.
ferongr
ferongr's picture
Last seen: 1 month 4 weeks ago
While NiMH charging is nice I really question their decision to use a USB input. For a noob-proof charger it’s likely to create a lot of confusion, especially since it doesn’t include a matching power supply. Considering it requires a power supply to output above 5.1V under load if I’m reading the charts right, then it’s likely that most people will get degraded charging speed with all bays occupied.
This reeks of some product manager getting involved and specifying that the charger must have USB input (buzzword compliance?).
Leaving aside the power supply issues, for people using matched cells in series the voltage display is pretty useless (by the time your cells are at .1V from each other after removing them from the light, it’s too late).
As I’m in the market for a 4-bay Lithium charger, it seems like the VC4 is a bad buy considering the more predictable VP4 is only a few dollars more and that the NiMH advantage of the VC4 comes with a lot of caveats.
HKJ
HKJ's picture
The problem with voltage is to some degree due to cables and connections, the charger works down to 4.7 volt. Using a power supply slightly above 5 volt improves the handling of cable and connection resistance while the charger draws full current. I do not see the usb power as a big problem, but you need a good charger, then you can power charger and other stuff from it.
When you charge cell in the charger when will be balanced to much better than 0.1 volt, if you look at my curve there is not more than 0.01 volt difference when the charger terminates.
The main difference between VP4 and VC4 is that VC4 shows the charged capacity and VP4 shows voltage with high resolution. For car usage the VP4 can be directly powered from the car, the VC4 needs a usb adapter.
MountainKing
So if my only use will be for lion cells, Nitecore I2, VP2 or VC4? Price wise I’d prefer to save bucks and I will be charging only 2 lions at any point in time.
StringBean29
Last seen: 3 years 1 month ago
Would something like this be ok for this charger using either the 1.0A port or the 2.4A?
http://www.i-tech.com.au/products/177455_Winstars_4_Port_USB_AC__SAA_app...
HKJ
HKJ's picture
StringBean29 wrote:
Would something like this be ok for this charger using either the 1.0A port or the 2.4A? http://www.i-tech.com.au/products/177455_Winstars_4_Port_USB_AC__SAA_app...
As long as the specification are correct, it would be fine.
The 1A and 2.4A ports might be in parallel, if that is the case the VC4 will use full charging speed on all ports.
StringBean29
I am not sure if they are in parallel.
HKJ
HKJ's picture
Then you have to use the 2.4A ports, but there is a high probability that they are in parallel.
MountainKing
Hi again HKJ. Can you please comment on this feature of the Xtar chargers
“0V activation function which rescues your overly discharged batteries when in most cases the batteries must be discarded. With our chargers you can bring them back to life.”
Most Xtar chargers have this. You do not include this test when testing chargers. Does this feature really work? Can it not be ‘tested’? Nitecore i4 chargers does not advertise this feature.
HKJ
HKJ's picture
MountainKing wrote:
Hi again HKJ. Can you please comment on this feature of the Xtar chargers *_"0V activation function which rescues your overly discharged batteries when in most cases the batteries must be discarded. With our chargers you can bring them back to life."_* Most Xtar chargers have this. You do not include this test when testing chargers. Does this feature really work? Can it not be 'tested'? Nitecore i4 chargers does not advertise this feature.
I do not directly test it, but in the list of various measurements I usual list current at different voltage. I it chargers from 0 volt with some current it has the function.
BUT it is not really a recommended function, LiIon manufacturers always says that you must discard cells when they are below a certain voltage (Usual 1.5 to 2 volt), Laptop cell protection will permanently disable a pack if it happens.
geo10
Thank you for the review HKJ
It is too bad that this charger does not come with a power supply, especially if one considers that at the moment it sells for ~ USD 30 / 30 euros (without the said power supply). Personally (for LiIon) I would buy a VP2 at this price -oh wait! I already have a VP2 Smile
hank
hank's picture
Last seen: 2 days 10 hours ago
FT does show the Ioncell label on their picture, so … who knows.
They often don’t really know what they’re selling there, unfortunately.
A “review” at FT claims HJK reviewed “this charger”— is that true?
(relevant to this VC4 review thread, would this Ioncell (if only one USB port is used) power the VC4 correctly?
https://www.fasttech.com/forums/1336202/t/1053121/it-is-a-original-ionce...
EDIT —- no, FT admits it’s a fake charger in their discussion thread
“This is not advertised as an brand name item.
Thank you
FastTech “
xtarflashlight
xtarflashlight's picture
Last seen: 1 hour 4 min ago
Real CC/CV for Li-ion batteries and pulse charging for Ni-MH batteries, use different charging method for different kinds of batteries to maximize the lifespan of the batteries. Thanks so much for the great review!
Mitko
Mitko's picture
Just got mine from Banggood……it charged 18650 PF was at 2.8v with 3100ma and the second one at 2.9v for 3040ma
Compapred to VP2( whitch i also have) it charged them slower, in spite of i used that Samsung PCU on the pic above
The display is kinda dim looked at the angle, also the charge indicators
Cant charge either LiPo and 4.35v ones
I am kinda disapointed from this charger,and it seems the PSU is kinda week for him, have to look for another one
If you have VP2 like me, dont even think of getting this one, if you plan getting a new charge just get VP2 or Opus
Actualy a VP2 + Nitecore I2( which is extremely cheap atm) is a great all arround combo
rddube
Last seen: 3 years 2 weeks ago
Hi,
You don’t mention if you can use a standard DC adaptor…I have one with multiple ends that I can change and I can set it to 5V and it has 2A current. Would that work?
Also, if I use a standard 5V 2A adaptor, cut the wires on both the adaptor and the USB input cable, would that work also?
Many thanks HKJ!
