Noctigon Meteor M43 official sales and discussion thread
686 posts / 0 new
ven
ven's picture
Last seen: 4 months 3 days ago
myflashguy wrote:
OUT OF STOCKS! Does this means it is no longer in production?
So is the D4 on int outdoor(well sold out )……………maybe temporary till the D1 orders settle.
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 28 min ago
It’s a popular item, not easy to keep the supply high enough to meet demand. And I think Hank is busy with the D1 and other projects, so his D4 time is limited.
RMM
RMM's picture
Last seen: 8 months 2 days ago
As far as I know the M43 is still "in production", but I think that they have pretty much paused M43 production until they get caught up on D1 and D4 production.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
BeardedRaleigh
BeardedRaleigh's picture
Last seen: 2 weeks 3 days ago
I have had my M43 since January of this year and I LOVE it, i have come to find that UI3 is the best for me…….so heres my question.
Is there a way to put Narsil M on this light and maybe still have some cool functions with the switch leds?
Slow is smooth, smooth is fast.
ReManG
Last seen: 1 hour 9 min ago
UI3 is Narsil, but with three levels. If you “set” all three levels to low, then however you turn it on it will be in low, and available to ramp with a click click and hold. The Turbo is a available with a press and hold from any level, including off.
The strobe and battcheck and other fun stuff are not as easy as Narsil, but still available.
I love UI3, it is my favorite interface for all of my lights.
RMM
RMM's picture
I have had my M43 since January of this year and I LOVE it, i have come to find that UI3 is the best for me.......so heres my question. Is there a way to put Narsil M on this light and maybe still have some cool functions with the switch leds?
There is no other firmware that will work correctly with this light.  You would have to start from the ground up completely.
BeardedRaleigh
I have mine set to low with one click, then with the double click it goes brighter, then again, then I can hold for turbo. nothing wrong with this UI, its just that narsil is so simple haha.
BeardedRaleigh
Thanks for the info, Ill just have to stick with my 8 page instruction UI on this one haha.
CRX
CRX's picture
Last seen: 13 hours 7 min ago
Here’s a condensed version Wink
joechina
Last seen: 1 day 10 hours ago
Uh, that looks complicated.
goshdogit
goshdogit's picture
Last seen: 1 hour 2 min ago
It looks complicated, but it’s one of those things that is very wordy to explain but simple in execution.
I use UI 3 and love it. I have my 3 levels set like BeardedRaleigh just mentioned. Here’s my explanation from a few posts ago:
goshdogit wrote:
I set up my Meteors so that Mode 1 is low, Mode 2 is high, and Mode 3 is medium. This may seem counterintuitive, but read on.
  • Single click turns the light on in low.
  • Double click moves to medium.
  • Double click again moves to high.
While the light is on, double-clicking will continuously cycle through the three brightness settings. A ‘fast then long click’ moves backward while the light is ON.
Once you get comfortable with the operation, you can also use shortcuts to the three modes from OFF.
At any time while the light is on, holding the switch activates Turbo until you let go and it returns to the mode you were in. This is one of my favorite features.
zeroflow
Out of shear curiosity: Has anyone (maybe ToyKeeper) identified the used chips on the driver or has at least high-res photos of the driver where the markings are readable?
I found this post on TLF where I can see the components or a photo on some russian site but neither A335 for the D1 component or VT1 are readable well enough or can be found somewhere.
From the general circuit it looks like VT1 is the mosfet for the boost converter, D1 is the uC since it has pads for the switch and LEDS and D2 is some kind of OPV?
I’m just curious how they implemented everything (discrete buck IC + control µC, µC does buck in SW, …)
kiriba-ru
kiriba-ru's picture
Last seen: 13 hours 8 min ago
If you are not able to make boost driver design “from zero”, dont try to rechip meteor driver. You will get tons of issuies from hardware that you wont fix.
zeroflow
I don’t want to change it, I just want to know how it works and which components are used.
While I’m no pro, I still have a common understanding of power electronics and electronics design.
kiriba-ru
kiriba-ru's picture
Indigo_5_1m
zeroflow
Thanks, that’s a great info!
If I see correctly this is some kind of driver the M43 is based on? Because the M43 is missing some redundant parts that allow for higher currents/faster switching.
kiriba-ru
kiriba-ru's picture
Yes, this is most complicated sample schematics that is allowed for sharing and making by yourself.
ToyKeeper
ToyKeeper's picture
The M43 code and driver schematic aren’t available, but the schematic above is similar and an older version of Indigo is available. It’s written in assembly. This may be enough info for someone motivated to fill in the gaps between what is available and what is not, but nobody has created any other firmware which can run on it.
So, nothing Narsil-like on the Meteor.
However, if you want the Meteor UI (er, UIs) on your Narsil light (Q8, GT, D4/D1/D1S, etc), that can be arranged. I implemented most of it one evening while cloning UIs for my new toolkit, and could probably finish the rest in a few hours if anyone wants it.
giorgoskok
giorgoskok's picture
Last seen: 2 weeks 6 days ago
Interested ! Not for a particular light , but i would like to use it in some e-switch lights . So , i’m not in a hurry Smile
keengeorge
Last seen: 1 year 4 months ago
G'Day BLF'ers, and Meteor M43 "addicts", smile
The Noctigon Meteor M43 from intl-outdoor.com is now available with Nichia 219CT 90CRI 5000K  LEDs smile
Edit: And the Emisar D4 from intl-outdoor.com is also available with the same LEDs
Best Regards,
George
NeutralFan
NeutralFan's picture
Last seen: 4 days 2 hours ago
My Meteor M43 Nichia 219C saved the day! Tonight was my daughter’s Homecoming dance and she had 16 of her friends come over beforehand. It was raining out so they couldn’t take pictures outside. When they gathered in the living room to take pictures, we were trying to figure out the best location, but the lighting wasn’t right. So I ran down stairs and grabbed my M43. I did a ceiling bounce in turbo and the pictures turned out great! There were lots of pictures, so in between pictures I cooled the flashlight with my hands. At times it got very hot, but it never shut down and kept providing great light. Some of the parents were quite impressed with the flashlight. This is the first time I actually felt justified buying such an expensive, but worth every dollar, flashlight.
I’d rather use my flashlight around the house than turn on the lights.
Box
Great story! Should of put a fan on it to cool it
Flying Luminosity
Flying Luminosity's picture
Last seen: 9 months 3 weeks ago
keengeorge wrote:
G’Day BLF’ers, and Meteor M43 “addicts”, smile
Best Regards,
George
Thanks for the info – I’ve been waiting for it to reappear, even if that makes things a bit awkward … so many nice lights, so little money! Wanted to get a 2nd MF-01, an MT07S, and either an SRT9 or Fitorch MR35, and now the M43 is available again … someone please convince me that I don’t need any more flashlights! (or maybe just one, or two…) Cool
alberto7
Last seen: 3 weeks 3 days ago
The m43 its sold out with all leds… Anyone can confirm?
hIKARInoob
hIKARInoob's picture
Last seen: 6 days 6 hours ago
Saw this too. Specs were also changed back for the Nichia 219C to 80+ CRI (from 90+ CRI). It’s probably done because they’re busy selling the D1 and D4. My guess…
Flying Luminosity
Well, at least that means I can see a cyan D4 coming my way! Love
saypat
saypat's picture
Last seen: 1 day 1 hour ago
If I had already had a Q8 I would not have purchased an M43. Would have saved a bit of cash.
Hank Wang
Last seen: 1 hour 52 min ago
M43 matte black is back in stock again,
http://intl-outdoor.com/noctigon-418650-meteor-m43-p-864.html
The matte finish has good grip, the side effect is that the surface looks not clean, but they all new flashlights.
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
hIKARInoob
The Nichia 219C variant is 80+ or 90+ CRI? Thanks. Cool
Hank Wang
The stock one is 80CRI, but you can always request the custom 90CRI one.
