hkequipment – Manker MK36 Palm Size for 12,000lm. Can act as Power Bank...
REGULAR PROMOTION Coupon HKE80 - 8%off for all stuff price US$30.00 or above (Still can get points, but cannot join with other coupon or promotion. This offer not apply to brands with strictly price control)
Manker MK36 Palm Size Flashlight 12,000lm with 6pc Cree XHP50.2
Nitecore CI7 IR 940nm 4+4 LED Flashlight
Nitecore NU05MI IR 940nm Signal Light
Mateminco MT18S 18x SST20 Luminus LEDs with Anduril UI
RovyVon A7 USB Keychain Flashlight with White and UV Beam
Fenix LD30 Luminus SST40 1600lm Flashlight
JETBeam WL-20 Cree XP-G3 1000lm with Red Green White Beam
UltraTac A1 v2 14500 600lm Flashligh with Diffuser Cap
JETBeam T2 Pistol Light, Powered by 16340, 520lm Output, Three switch to control Lock, Momentary On, Strobe or change mode
“Keeppower 26650 with 5500mAh now Protected/IM. Also 21700 5000mAh…”
ACEBeam K75 stock will arrive soon and accept pre-order
Fenix LD42 1000lm 4x AA Flashlight - Pre-Order
JETBeam JET-III with USB-C Now… JET-IIIMR 2000lm 21700
Thrunite T1 Cree XHP50 1500lm USB Charge, take one 18350
Thrunite TT10 Cree XHP70B 3700lm, Dual switch tactical cap, USB Charge, take one 21700
Nitecore NU05LE - May be you need a light on your helmet or bag? Especially if you are police…
Fenix HM65R, PD36R and WT50R arrived!!!.
PD36R 1600lm, Use 21700, with USB-C Charge
WT50R 3700lm, with USB-C Charge. Can act as power bank
HM65R 1400lm, Use 18650, with USB-C Charge
NEW STOCK ARRIVED ACEBeam X65 Mini 5x Cree XHP35 HI LED 12000lm 1407m Flashlight
PRE-ORDER FENIX LR40R 12000LM CREE FLOOD + SPOT LED USB-C RECHARGEABLE POWER BANK BATTERY FLASHLIGHT
NEW STOCK ARRIVED ACEBEAM TK16 CREE XP-G3 LED ALUMINUM 1800LM 16340 LED FLASHLIGHT
NEW STOCK ARRIVED FENIX E30R LUMINUS SST-40 1600LM USB RECHARGEABLE LED FLASHLIGHT
NEW STOCK ARRIVED ACEBeam W30 LEP 500lm 2408m USB Rechargeable 21700 Laser Flashlight+Red Filter
NEW STOCK ARRIVED Fenix HL18R - Dual Beam Profile, Dual Power Source…
NEW STOCK ARRIVED NITECORE TIP2 DUAL CREE XP-G3 S3 720LM MAGNETIC USB RECHARGEABLE KEYCHAIN
ACCEPT PRE-ORDER NITECORE TIP2 DUAL CREE XP-G3 S3 720LM MAGNETIC USB RECHARGEABLE KEYCHAIN
NEW STOCK ARRIVED ACEBeam TK16…Pocket Size EDC Copper stuff, 1800lm…Triple Cree XP-G3
:zap::zap:SALE ITEM​:zap::zap: MANKER U12 CREE XHP50.2 2000LM USB RECHARGEABLE 20700 FLASHLIGHT
NEW STOCK ARRIVED Nitecore P18 Tactical Flashlight 1800lm (Comes with IMR18650). XHP35 with Aux Red LED. Unibody die cast!! (8u7g8w)
Special offer update for Thrunite TN36 Limited, TN40S and TN30 Mini…Offer while stock last
Klarus XT11GT Camo
Fenix PD35 v2 Camo
JETBeam JET RRT01, XP-L 950lm, Magnetic Ring Control, comes with USB 16340 Coupon RRT2019
Manker MK41 XHP35 HD and HI restock arrived…
You take thrower or brighter?
30% off with free shipping for following models:
Coupon ARCFF
Archon D32V Cree XM-L2 Diving Photography Underwater Video LED Flashlight
ARCHON D33 3x Cree XM-L2 U2 3000lm 3x 26650 LED Flashlight
Archon D37VP W43VP Cree XM-L2 U2 UV RED Diving Underwater Video Flashlight
Archon D6A Cree XM-L 3-Modes 650lm Diving Scuba 6x AA Flashlight
Archon DM10 WM16 COB LED 2700lm Diving Photography Video Underwater Flashlight
ARCHON DY01 WY07 CREE XP-L LED Diving Snorkeling Scuba 26650 Flashlight - Archon 26650 Battery and Charger
ARCHON DY02 WY08 4x CREE XP-L LED Diving Snorkeling Scuba 26650 Flashlight:
MecArmy PS14 Dual Color Temp Flashlight
Unique T20 LG 3535 UV LED Zoomable Flashlight…US$21.25 Coupon T20ZM
“:https://www.hkequipment.net/product-p/uft20uvlg.htm
“3200lm in your hand - Klarus XT11X / 360X3 15% off - Coupon KR3200”
SALE - MecArmy PT10 USB Rechargeable Flashlight 30% off - Coupon PT10FF
Nitecore TM10K 10,000lm Flashlight with USB-C Charge
Coupon 10KLM
Thrunite TN50 XHP70.2 16340lm with Built-in Battery Pack
Manker EP02 Titanium Pen with Oxidation…Limited Run
Klarus AH1 360° Holster
Jaxman U1 Nichia UV 6w with Spot and Flood Beam
Klarus XT21X 4000lm Use 21700. Accept Pre-Order
MecArmy X7s with 8 combination
MecArmy PS16 Scar Copper Limited Edition
Klarus HA2C 3200lm Headlight with USB Charge
Fenix TK25 IR+XP-G2 LED Flashlight - FXIR
Other than Surefire 2211 - MecArmy CPL-T…Coupon 2211
Nitecore TUP - USB Charge 1000lm Black / Grey, pls use TUPTUP during checkout
Fenix WF05E - Flashlight ready to work in extreme environment
NW Fans…Klarus XT12GT with Neutral White
Coupon 12GTNW
Klarus ST15R upgrade to 1200lm output, comes with bike mount and diffuser. With USB Charge - K#128Y
• CREE XP-L HD V6 LED with max output up to 1200 lumens
• Compact size, lightweight, comfortable grip, CNC precision machined aluminum reflector with high reflective efficiency, max beam distance up to 260 meters
• Ultra-long runtime, max runtime up to 8.3 days
• Easy and convenient operation, ON/OFF tail switch, side mode switch, each has independent operation
• Strobe, Signal lighting and SOS for emergency uses
• Single click side switch to turn ON/OFF the flashlight during charging for emergency use
• Micro-USB charging port with protective cover, waterproof and dustproof
• Charging current up to 1A, faster charging
• Intelligent Battery Identification Systerm (IBIS): real-time monitoring of charging status to prevent overcharging, ensuring optimum charging status
• Intelligent Thermal Protection System (ITS): monitors internal temperature and adjusts brightness to protect LED and internal components to ensure safety, stability and optimum performance.
• Ring Battery Capacity Indicator: check remaining battery capacity at any time.
• Stainless bezel ring offers protection for crucial components
• Springs at bezel and tail end resist shock and drop damages.
• With mode memory function
• Reverse Polarity Protection eliminates damage from incorrect battery orientation.
• Aerospace Aluminum Alloy body with CNC machining; Mil-spec hard anodizing (HA III); lightweight yet robust construction
Package includes (with original packaging):
Klarus Flashlight
Klarus 18650 2600mAh Rechargeable Battery
USB cable
Bike Mount
Diffuser
Lanyard
Spare O-Ring
Stainless Steel Pocket Clip
ACEBeam H40 14500/AA Max 1050 Headlight
Thrunite TN50 20% off - Left Neutral White…Coupon TN5020
Imalent Carrying Bag for MS12, R90C, R70C
Fenix E16 Titanium Galaxy or Phantom ??
MecArmy PT26 3850lm Flashlight and power banks
Coupon - MPT26FF
Fenix E16 Titanium Galaxy Blue - Unboxing
Fenix E16 Ti Galaxy or Phantom?? Coupon EarlyE16 (will expiry once pre-order quota full)
Fenix CL26R USB Rechargeable Lantern - Coupon FXUSBLAN
FEATURES
Eight total lighting outputs
Two directional modes
Convenient one-switch mode cycler
Micro USB rechargeable
Comes in red, green, & black
IP66 protection from heavy rain
Works great in extreme climates
Lightweight and easy to carry
Magnetic top, tripod socket, hanging loop
Low-light can operate when charging
SPECIFICATIONS
Power Source: 18650 Li Battery (2600mAh) or 2 x CR123A
Peak Beam Diameter: 25 meters (82.02ft)
IPX Rating: IP66
Impact Resistance: 1 meters (3.28ft)
BIG SALE…up to 67% off
Including some models of Fenix, JETBeam, Nextorch, Jaxman, Klarus, MecArmy, Lumintop…
MANKER LAD II Mini USB Rechargeable Keychain Flashlight
Nitecore EC30 - Like Concept 1 but new Metal Switch, 1800lm take one IMR18650
Nitecore NU32 - Upgrade from NU30, White, CRI and Red LED, Max 550lm
Nitecore TUP - Keychain with OLED, boost up to 1000lm, accept pre-order (available for USA, UK and Australia warehouse stock)
Thrunite TC15 - XHP35 2300lm with USB charge, comes with IMR18650
Fenix E18R Compact, USB Rechargeable
Fenix HP40F - Old stuff but still brand new with box. Please use coupon for FISH to enjoy extra US$10.00 off
Nitecore MH25GTS - 1800lm, comes with NL1835HP (Coupon 25GTS)
Nitecore MH12GTS - 1800lm, comes with NL1835HP (Coupon 12GTS)
Fenix BC35R - Headlight with Anti-Theft alarm
Flood UV Beam - Jaxman U1 Nichia 6w
Nitecore NPL10…
Thrunite Catapult V6 CW/NW Beam…
Klarus XT1A 2018 version with 1000lm for AA size
Fenix LD05 v2 - Pen size with UV and White Light
Thrunite TH30 3,350lm Headlight CW/NW available
Fireflies ROT-66 Coupon BLFROT
CRAZY CLEARANCE FOR SELECTED MODEL OF KLARUS and TIABLO
For detail, please visit our web
Klarus XT11X - 3200lm XHP70.2 - USB Rechargeable - Dual Switch…XX3200
Buy Manker MK35, MK39 or TimebackII - FREE Manker TACTICAL PEN
Manker MK39 6000lm with handle!!
Nitecore Concept 2 6500lm - just half Can size!!
Fenix TK45 Brand New with box
One more target for copper fans…Nitecore TIP Cu
Something for clearance…
MecArmy SGN3 USB Rechargeable Flashlight with White/UV/Red light - US$29.90 (Clip are optional)
Real capacity…Fireworm 18650 3500mAh simple test…
FLASH DEAL up to 38% off…Limited stock including flashlight, finger spinner….
MecArmy SGN3 - US$29.9 only. Five color including Stonewashed finish available
11000lm - Thrunite TN36 Limited Edition
Thrunite TC20 - XHP70.2/3800lm/26650 USB Charge
Lumapower LM21 - Upgraded to XP-G3 R5 300lm with 10440
Ultratac K18 Black and SS Nichia version arrived
Mecarmy FL10 - Titanium Carabiner with USB rechargeable flashlight
Nitecore HC33 one of the best value headlight, please remember use IMR18650
Fenix FD65 3800lm Zoomable Flashlight
Nitecore EC23 XHP35 HD - 1800lm
Olight Special offer for S1A, S2A, X7, R50, S-Mini…
Cannot use with other coupon
JAXMAN U1s - Compact and powerful UV flashlight
Armytek Prime C2 Pro XHP35 HI with USB Rechargeable
Nitecore HC70 Headlight, also power bank
Klarus G20 Searchlight
Klarus G30 Searchlight
Armytek ELF C1/C2 Headlight
Olight HS2 Compact USB Rechargeable Headlight
Nitecore TIP SS - More choice for TIP family
Olight X7R 12000lm, with USB-C convenient charging
Lumintop IYP365 Brass/Titanium
Keeppower Ultimate 18650 3120mAh 15A Protected
Nitecore i8 Charger - 8 Channel Big Boy
Fenix TK65R Good searchlight for work
Nitecore TM38 Lite. Another big boy from Nitecore
Nitecore MT22 Cree XP-G2 S3 260lm Flashlight
Fenix HM50R 500lm USB Rechargeable Headlight
Nitecore Concept 1 - XHP35 HD 1800lm
Another 2300lm headlight - Olight H2R USB Rechargeable
Thrunite Neutron 2C - USB Rechageable, comes with 18650
Thrunite TN36-2017 Cree XHP70 10000lm Kit Set
Manker E02 just arrived, US$19.95, Black Grey Red with XPG3 and Nichia 219C
Manker E14II 2200lm Flashlight
Thrunite TN40S Neutral White just arrive. Two brother work together…
CountryMan S+ Nichia Japan 6w 365nm LED
MecArmy CL52 - Handle for PT60/PT80
Nitecore MH12GT
NiWalker Sale…BK-FA01S, BK-FA02S, MM25MB v2
Black Water SR71 Family photo…Coupon SRFAMILY
UltraTac K18 2017 Blue / Red arrived
Archon D11V-II comes with adaptor for convert flood and spot beam
Archon D15VP, may be the best value model for diving light
CountryMan S9 UV 3w/5w Flashlight
UltraTac K18 Brass 2017 version arrived
Another keychain flashlight SGN5. With Siren alarm but keep small size and price is lowest in SGN family
Nitecore GP3 Action Camera - USB Rechargeable, ARRIVED!!
Thrunite TN42 Beam shot (Coupon TN42BLF)
Pouch for Thrunite TN40, TN40S, TN42 or TN42C. Not perfect, but secure…
Thruite TN42 stock will arrive soon. Coupon TN42BLF
We wait few month already…
Nitecore MT06MD Nichia 219B CRI90 Flashlight arrived - I think not just for medical
Ultratac K18 2017 version, Upgrade to 370lm, Stainless Steel Side Switch - Coupon 2017K18
Fenix HL26R Headlight - USB Rechargeable - Coupon FXHL
Manker MK41 Cree XHP35 HI/HD 2000lm (approx.) Flashlight - Pre-Order
Price US$59.99, we will refund difference if final price lower
Manker MK35 Cree XHP35 HI 2550lm 1420m Flashlight CW/NW available
MecArmy PT26 9x XP-G2 S4 3850lm, can be act as power bank - Coupon EARLYPT26
ARRIVED
Fenix TK47UE just arrived. Equipped with XHP70+Red LED - Coupon 47UE
Spark SX5 NW upgraded to XP-L HI - Coupon HKE80
Armytek Wizard PRO XHP50 upgraded version with bigger heat sink
Coupon WZPOFF
Nitecore NU30, Coupon NCNU
Lumintop SD26 XPL HD Flashlight (Coupon LT26650)
Fenix UC02SS Gold / Blue, TK47 (Coupon TKThrow) more photo…
Fenix PD40R, TK47 and Olight H1R
Manker E12, E21 and LAD
Fenix HL60R Headlight Sands
Lumintop PRINCE Mini XP-L HD Flashlight
NiWalker BK-FA09S and MM25MB v2. Need Long throw or Blind Bright?
Spark fans…ST6-460NW with XP-L HI upgrade - Coupon SPST6
Purple and Purple…JETBeam JET II Pro and JET-ST
Coupon - purple
Nitecore TM28 Quad XHP35 HI 6000lm will arrive next week
JETBEAM JET ST CREE XP-L HI 800LM LIMITED EDITION TITANIUM LED FLASHLIGHT
Coupon - JBST
XTAR DRAGON VP4 Plus Battery Analyzer Charger, Coupon HKE80
Comes with Test Probe and Carrying Case
KeyChain Flashlight Party…Nitecore TIP (360lm), MecArmy SGN7 and SGN3
http://www.hkequipment.net/product-p/sgn7.htm
Coupon SGN7EARLY still valid until…
Armytek Wizard PRO XHP50 with USB Charge
Comes with Armytek 18650 with USB charging cord
Coupon - WZPOFF
Olight Sales…up to 20% off
:smiling_imp: Attention for Neutral White fans. Olight X7 Neutral White 5000k arrived (Not Combo)…, Coupon X79000
http://www.hkequipment.net/product-p/ox7.htm
Thrunite TN40S Pre-Order - EARLY40S
The spec same as TN40 but not rechargeable. It take 4pcs 18650 (Not included)
Pre-order accept from now, estimated ready on early Dec
http://www.hkequipment.net/product-p/tn40s.htm
Xeno ES1 Titanium / Brass, Coupon XEES
http://www.hkequipment.net/product-p/es1ti.htm
http://www.hkequipment.net/product-p/es1br.htm
MecArmy SGN7 - 550lm Light, 110db Alarm, high capacity battery can be act as portable charger during emergency
Coupon SGN7EARLY
PRE-ORDER, WILL SHIP ON NOV 17 OR AFTER
Olight H1 Headlight CW/NW (Coupon OLHL)
http://www.hkequipment.net/product-p/oh1.htm
Nitecore TIP XMas Gift box version - Green+Red / Blue+Red (HKE80)
http://www.hkequipment.net/product-p/tipx.htm
Fenix TK20R - XP-L HI, 1000lm, USB rechargeable (comes with 18650) - FXUSBXPL
http://www.hkequipment.net/product-p/tk20r.htm
Olight S-Mini Copper/Titanium arrive soon. Start accept pre-order. We understand little late to start but we need sure the arrival date…
Accept pre-order (EARLYMINI)
http://www.hkequipment.net/SearchResults.asp?Search=SMini&Submit=
Olight X7 Marauder 3x XHP70 9000lm - OL9000
Nitecore LA10 / LA10CRI…wait long time already. Just arrived…
Armytek Predator Pro v3 XHP35 HI - PP3
Thrunite TN42 / TN42C will be launch on Sep 20 or after, accept pre-order now
Nitecore TIP/TIP CRI - 360lm USB Keychain Flashlight - TIPTIP
http://www.hkequipment.net/product-p/tip.htm
http://www.hkequipment.net/product-p/tipcri.htm
Two upgraded big boy from NiWalker BK-FA01S XPL HI and BK-FA02S XHP70 - Coupon NEWNWK
http://www.hkequipment.net/SearchResults.asp?Search=BKFA&Submit=
Mecarmy PT16 with Brass / Titanium
http://www.hkequipment.net/product-p/pt16tb.htm
Another Monster - NiWalker MM25MB 7600lm 3x XHP70 - Coupon NEWNWK
http://www.hkequipment.net/product-p/mm25mb.htm
Nitecore THUMB and LA10 just arrrived…
http://www.hkequipment.net/product-p/thumb.htm
http://www.hkequipment.net/product-p/la10.htm
Nitecore HC60 XM-L2 U2 Headlight with 3400 18650 (Nitecore) - HCfreebatt
http://www.hkequipment.net/product-p/hc60.htm
Thrunite TN40 Neutral White stock arrived…
http://www.hkequipment.net/product-p/tn40.htm
Manker U11 USB Rechargeable Flashlight Cool /Neutral available
Add US$3.95 for one Fenix 18650 2300mA Battery
http://www.hkequipment.net/product-p/mku11.htm
Nitecore R25 XPL HI - with Docking and battery - NCDCK
http://www.hkequipment.net/product-p/nr25.htm
Armytek Wizard PRO XHP50 Cool White - Add US$9.99 to get Keeppower IMR and F1 USB Charger
Limited Stock, can use with coupon
Manker E01 Three Color ready, GITD diffuser available as options
http://www.hkequipment.net/product-p/mke01.htm
Manker U11…Neutral White arrived
Thrunite TN40 4x XP-L HI 4450lm Rechargeable Flashlight and FLYYE Pouch (Optional)
http://www.hkequipment.net/SearchResults.asp?Search=TN40&Submit=
Olight S2A with 4 Color, simply EDC - COLORS2
http://www.hkequipment.net/product-p/os2a.htm
Fenix RC05 - XP-G2 R5 USB Rechargeable Flashlight, comes with Fenix 14500
http://www.hkequipment.net/product-p/rc05.htm
Fenix SD20 - Diving 100m 1000lm flashlight (can order bundle with discount)
http://www.hkequipment.net/product-p/fsd20.htm
Coupon FX10
Sunwayman T16R - Ultra compact Flashlight 380lm use one CR123A
http://www.hkequipment.net/product-p/t16r.htm
Coupon T16R380
Olight R50 XHP50 2500lm USB Rechargeable Flashlight Silver/Blue - R50SK
http://www.hkequipment.net/product-p/or50.htm
Blue Bezel version comes with USB adaptor but Silver not. Price are the same for Silver/Blue
Armytek Wizard PRO XHP with IMR Battery / Nitecore Charger options
Coupon WZPOFF / MDWPXH can be use when order with IMR Battery / Charger
Xeno W01 Bezel tool arrived finally. Xeno with V3 upgrade using aluminum (old version use POM plastic, easy to damage after few use)
http://www.hkequipment.net/product-p/w01.htm
Keeppower IMR18650 3000mAh 35A - Can provide high drain flashlight
http://www.hkequipment.net/product-p/kpimr30x2.htm
Fenix TK15UE Black/Grey - Coupon TK15off
http://www.hkequipment.net/product-p/tk15ue.htm
Armytek Wizard PRO XHP50 Cool/Warm also arrived - Coupon WZPOFF
Now with option US$9.99 for One Keeppower IMR18650 3000mAh 35A High Discharge Battery
Manker PL10 - Tactical Ball Pen with flashlight
http://www.hkequipment.net/product-p/mkpl10.htm
Nitecore SC2 Quick Charger - stock arrived
http://www.hkequipment.net/product-p/nsc2.htm
MecArmy Photo Adventure…
Nitecore SC2 Charger, Dual Slot for fast charging. Ready on Jun25
Another Ultimate Edition from Fenix, TK15UE. It looks like TK22…XP-L HI V3 1000lm
Fenix CL30R, comes with 3x 18650. Can be acts as 7800mAh Power Bank…
http://www.hkequipment.net/product-p/cl30r.htm
Nitecore TM03 arrived…Tiny and Monster Bright, thank XHP70
http://www.hkequipment.net/product-p/tm03.htm
Nitecore EC4GT Black…more color option
http://www.hkequipment.net/product-p/ec4bk.htm
MecArmy FM11 Headlight, USB Rechargeable, Magnetic Tail - Coupon MAHL
http://www.hkequipment.net/ProductDetails.asp?ProductCode=FM11
SkyRC NC2600 NiMH/NiCd AA/AAA Professional Charger - Pre-Order
http://www.hkequipment.net/product-p/nc2600.htms
Another Monster…Nitecore TM03 Cree XHP70 give you 2800lm by 1x 18650
Nitecore EC4GT - Nice Pack for GT…
http://www.hkequipment.net/product-p/ec4gt.htm
Thrunite TN12-2016 upgrade with XP-L V6, Max 1100lm - Coupon HKE80
http://www.hkequipment.net/ProductDetails.asp?ProductCode=TN126
Nitecore TUBE UV version
http://www.hkequipment.net/product-p/tubeuv.htm
Nitecore MH27UV - MHUV
http://www.hkequipment.net/product-p/mh27uv.htm
SkyRC MC3000 latest stock arrived
http://www.hkequipment.net/product-p/mc3000.htm
Fenix UC01 - USB Keychain Light with Nichia LED
http://www.hkequipment.net/ProductDetails.asp?ProductCode=UC01
Fenix HL10-2016 - Adjustable Spot/Flood Light with Philips LED
http://www.hkequipment.net/ProductDetails.asp?ProductCode=HL106
Wizard PRO XHP50 - 2300lm (Stock will ready on May20), Coupon WZXHP
http://www.hkequipment.net/ProductDetails.asp?ProductCode=WZP
JETBeam TCE-1 Titanium Original/Color, Coupon TCETT
http://www.hkequipment.net/ProductDetails.asp?ProductCode=TCE1
Mecarmy SPX10/SPX18 - Coupon 360swc
http://www.hkequipment.net/SearchResults.asp?Search=SPX&Submit=
Lumapower V3X with XP-L HI upgrade now. Compact size with longer throw
Coupon V3XPL
http://www.hkequipment.net/product-p/v3x.htm
Nitecore MH20GT with XP-L HI V3
http://www.hkequipment.net/product-p/mh20.htm
JETBeam T6 with 4x XPL, Max 4350lm (Coupon JB4350)
http://www.hkequipment.net/product-p/jbt6.htm
Fenix RC09 / RC11 - FXRC
http://www.hkequipment.net/product-p/rc09bk.htm
http://www.hkequipment.net/product-p/rc11bk.htm
Thrunite Archer 1A upgraded to v3
http://www.hkequipment.net/product-p/ar1a3.htm
Spark SF3/SF5/SG3/SG5 with HCRI 3000k option. All CW/NW/HCRI also 25% off with coupon SFSGoff
http://www.hkequipment.net/product-p/sf3.htm
http://www.hkequipment.net/product-p/sf5.htm
http://www.hkequipment.net/product-p/sg3.htm
http://www.hkequipment.net/product-p/sg5.htm
Following best seller restock…
Lumintop Worm Copper (Coupon PREWORM)
http://www.hkequipment.net/product-p/wormcp.htm
Thrunite Ti (XP-L CW / XP-L HI)
http://www.hkequipment.net/product-p/titi.htm
Lumintop Tool Titanium with Cool White and Nichia 219 (Coupon LTTITAN)
http://www.hkequipment.net/product-p/toolti.htm
Another 2016 upgrade, TN30 Mini with XPL now
http://www.hkequipment.net/product-p/tn30m.htm
FLASH DEAL…Package will ship on Feb 12
http://www.hkequipment.net/dealoftheday.asp
Few AAA from Olight
Mecarmy PT Series
Fenix RC09Ti Titanium USB Flashlight
Fenix E35UE-2016 1000lm Flashlight
NiWalker MM15MB - Monster Bright
Fenix PD32-2016 with XPL HI - FXHI
Nitecore MH41 XHP 2150lm - Coupon MHXHP
Thrunite TI HI Cree XP-L LIMITED EDITION
UltraTac K18 - Gold, Brass and Stainless Steel just arrive
Thrunite TN4A HI Cree XP-L
JETBeam TCE-1 Cree XP-L Titanium Flashlight - JBTCE
LUMINTOP TOOL AAA LED COPPER FLASHLIGHT
Nitecore TM26GT Monster with XPL HI
Fenix E15-2016 XP-G2 R5 450lm…
Fenix CL05 Liplight - A light for her?
Olight S1 Copper Raw / Rose Gold arrived…CURG
Sunwayman M25C Ti Titanium Flashlight - SWMM25CEPIC
Thrunite TN4A with XPL HI version
Thrunite - more for Tix Series - Ti5 XP-G2
JAXMAN U1 UV Worth for upgrade to Nichia Japan UV?
Nitecore 4000lm - TM06S Tiny and Tiny
Order Thrunite TN12-2016 can add US$9.99 for Xtar MC1 USB Charger+18650 Battery
Thrunite Ti4T - XPL V6 PENLIGHT…CW Stock arrived
Olight S10R Baton II - Cool and Tiny design, USB Rechargeable - Coupon S10R2PVD
Olight Piston Flashlight - PL-1 with Blue Light - Coupon Valkyrie
Olight R20 Javelot Flashlight - Compact USB Rechargeable with XPL HI - Coupon R20JXPL
Olight S30 Flashlight - 1000lm US$29.95
Thrunite release few UT models recently… Order now to enjoy 5 times member point (cannot joint with coupon or promotion)
Thrunite TN36UT XHP70 - 7300lm (Neutral White will release Oct 20)
Thrunite TN32UT - XPL HI
Thrunite Catapult V5 UT XPL HI
Thrunite Ti4 Ti XPL V6 (Double Point only)
http://img.auctiva.com/imgdata/5/0/6/1/5/7/webimg/861713142_o.gif
Olight i3s-CU Cree XP-L Flashlight 180lm by one AAA (0.9-2.0v). Brass Raw / Brass with PVD-Ti Gold Finish. Pre-order now to earn 5 times member points (points will be valid after order shipped)
http://www.hkequipment.net/product-p/i3scu.htm
hkequipment - FLASH DEAL up to 50% off for selected item
Nitecore EA81 - XHP50, powered 8AA?? AA - AAXHP70
NiWalker MM15MB 6800lm Flashlight - MONSTERBRIGHT
Thrunite TN12-2016 Cree XM-L2 NW Flashlight
Olight S30R II - XM-L2 U3 - 1020lm - S30RU3
NiWalker MM18 - 2MKR+XML2 - 5210lm - MM185210
JAX Z1 with XHP50 Upgrade, Powered by 2x 26650
Thrunite TH10 Neutral White - TNHead
Thrunite Ti4 Cree XP-G2 2x AAA - TTPEN
ACEBeam K60- Cree XHP70 LED 5000lm
ACEBeam T25 - Cree XHP50 3050lm
Thrunite Ti4 Cree XP-G2 LED 2x AAA Penlight Flashlight - TNPEN
Looks like the K60 code no longer works.
Agreed… doesn’t seem to work for me either. Any idea what the price was with coupon?
Sorry. ACEBeam stopped for the coupon
Regards,
Joyce - hkequipment
How about a discount on this…
Was 130 something if i remember correctly.
Like with the K40M we’ll probably see great deals on the K60 with time, i wouldn’t rush to buy it.
That Thrunite penlight really borrowed some style from 47’s preon line.
We accept pre-order now. Thanks
Nitecore EC4 - Cree XM-L2 U2 LED, Powered by two 18650 - NCTK35
Olight M1X Striker - Tiny Size 1000lm with Crenellated Bezel - M1X1000
ACEBeam K60 Sands Color
Olight M3XS-UT - DENOMED-XPL
Olight S30 Ti with Natural, Grey and Matt. Price are the same
Its most likely the domeless XP-Ls.
Fenix PD35 TAC - Tactical Version with XP-L, 1000lm - PD35XPL
JAXMAX U1 365mn Real 3w Flashlight - JU1UV
Thrunite TH10 Cool White / Neutral White available
Is the PD35 Tactical in Stock now?
Sure, instock and ready to ship. Photo by our actual stock
Regards,
Joyce - hkequipment
Hi. Any coupon code for the TH10 neutral?
thank you.
Hi
I’ll take one too if there is a coupon :slight_smile:
JAXMAN U1 Cree UV Ultraviolet 365nm 18650 3w Money Detector Flashlight C3 TK566.
