I am opening this topic in hope someone will know/suggest/point to how to build Intensity control switch for our flashlights.
This type of switch already exists and it seems like it is manufactured in UK:
So description that stands behind this switch is following:
- made to be used with the IC range of LEDs of Nightmaster and Venom Strike flashlights (so probably they have moded drivers to accept that rheostat?)
- forward clicky tail switch, click to turn on - click to turn off.
- Adjustable brightness by turning left or right… Once a brightness level has been chosen, the remote switch memorises that level and will activate at the level every time you switch on, unless a new level has been chosen or the tail-cap is removed from the torch.
The IC tail cap comes into its own when you have set the beam for a particular range but actually want to shoot something much closer. The fast brightness control means you can make a quick adjustment. ”
So I said if they can build that BLF respective members certainly knows how they did it?
Some will say that simple mods(hi-mid-low) are enough and yes they probably are for regular flashaholic but this switch aims toward hunters(and I know there are lot of hunters here).
Most hunters wants momentary on action. Sometimes high power flashlight is to powerful for close feeders… Sometimes to strong IR light is simply to bright for certain night vision equipment, This rheostat could allow us to adjust the light way we like.
It can be in this version also:
So maybe we could build our own version of this if we find appropriate parts?
I really hope someone will have idea how to start with building this kind of switch?
