Shadow JM35: review online - giveaway ended
Hi there!
for now that's just a teaser... ;)
I will get the Shadow JM35 with MT-G2 and XHP50 for a comparison from banggood.
after publishing the review I will draw a winner for one of them!
giveaway ends 30.6.2015!
everyone who bought a Shadow JM30 or JM35 at banggood can participate - just PM me a proof of your purchase.
Codes are ONLINE
Shadow JM30 (non-aff)
works on XP-L and MT-G2 Version (extension tube IS included)
Shadow JM35 (non-aff)
Code: M4DJM35 gives 12% OFF
for SHADOW JM30 and JM35
and KEEPPOWER 4500mAh and 5200 26650 Batteri3s
Hi my friends!
it has been a while since i received:
BOXES!
filled with Shadow JM35 flashlights !
the Sticker says one is a Cree XHP50 LED - so the other has to be a Cree MT-G2 LED
(because that are all sold options)
inside the boxes could be twins
both had the same bubblefoilbag with the same things in it:
A spare lens and a red Oring, a lanyard and a user manual (i think…)
i pulled the lights out of their foam packaging and YAY!
just kidding! - the batterytube with the rear switch was taken from a JM30 :wink:
the JM35 DOES NOT have a rear klickie - it is operated only with the side e-switch.
lockout by turning the batterytube ½ turn is possible.
UI:
a short click brings LOW-MID-HIGH-LOW-MID…
long click to OFF from any level
always starts on LOW
i found no dico and ni visible PWM
BUT the XHP50 squeaks on low and mid - the MT-G2 is quiet…
some more pics…
on the left side MT-G2 - right side XHP50
using UV light shows the “warmer” tint of the MT-G2s phosphor
a look into the driver
unfortunately i did not manage to get it open…
at the end of the battery tube sits a thin spring
some reported they had to bridge them with wire to make the light work with protected cells - more later on that.
instead of the rear swiitch the JM35 has a plug (made from plastic)
battery tube is well done
as is the lubed threads
opened up the hot end
MT-G2
quite thick aluminium MCPCB
XHP50
the side switch is well made
also well done is the machining
the anodisation looks a bit shiny and slippery…but thats just my point of view…
the JM35 is a small light when it comes to lenght…
i like the feel of the JM30 better…
or a K40
or…
but small can also be beautiful :wink:
lets use them what the was made for…
for all my tests i used keeppower cells
the XHP50 10 cm in front of a wooden plank
i had to use darker settings to get the dark cross from the 4 dies on camera
but 30 cm away the cross is gone!
if you look carefully you see that the MT-G2 (on the right side) also has a doughnuthole
30cm away….
shining upwards
upwards, in front of my home cinema canvas
the setup i used for the beamshots
look me in the eye!
look at the massive PWM!
numb3rs:
table(table#posts).
|JM35|MT-G2||JM35|XHP50||JM30|MT-G2|modded|
|low|mid|high|low|mid|high|low|mid|high|
|224 lm|1052 lm|2080 lm|228 lm|1060 lm|1940 lm|80 lm|760 lm|2980 lm|
|0,33 A|1,85 A|5,3 A|0,36 A|1,92 A|5,2 A|0,075 A|0,84 A|4,71 A|
Amperes measured at the tailcap // my BudgetLightBox gives a bit high numbers…
some things…
both lights DID work with my protected keeppower 26650!
but with none of my protected 18650s!
unprotected 18650s worked IF thes are high Amps capable !
using a bad cell resulted in a massive voltage drop which caused the drawn Amps to rise !!
a Samsung ICR1865022E (pulled cell) dropped from 4,12V to 3.0V and was squeezed 6,7A
a Sony 18650VT pull dropped from 4,1V to 3,7V and delivered 5,1A
and so did a Samsung ICR1865022P…
when the batterytube is tightened and the Driver goes to “standby” a initial flash appears (too fast for my Ampmeter) which triggers weak protection circuits…
a unprotected cell and a eachine cell (resets the protection fast!)
other cells just shut off and had to be reactivated … (tried 4 different protected cells)
Conclusion:
nice lights!
a bit too small for me tough - i have to grab the head also to hold it comfty
the need of “special cells” is mentioned at banggood - so have them prepared
word is that a bridged rear spring can make more cells to work
for that small ammount of money you get a lot of light - but you can see that its a cheap one
(but still better made than the JM30 was)
unfortunately i could not get a view of the driver (the lights will be given away so i can´t destroy them)
RuleZ:
everyone who proofes to me he bought a JM30 or JM35 at banggood haves the chance for light No.1
(winner may choose which emitter)
light No.2 will be given away after that in a separate thread for all members (maybe with some funny rules ;) )
List of participants:
1. uqs1000
2. Candil
3. khas
4. joerch
5. smaller lights
6. Bruno28
7. awi89
8. Chicken Drumstick
9. Tinn44
10. ilovejesuschrist
11. xelario
draw on 1st july 2015
khas won!
please PM me your adress and which version i should send you!
i leave for vacation from 4th to 11th july
so be fast so i can send it this week ;)
Rephrased:
Why doing a giveaway for the people who already bought one...wouldnt they already have one? Then the vast majority of this forum would not be able to join.
Thanks for the giveaway though....
if one has a MT-G2 he could add the XHP50 Version or vice versa.
I thought that’s a nice idea to make things a bit different….
I will do a giveaway for all members at 2k posts anyway
ask if I forgot something
Ich würde sehr gerne bei der Verlosung teilnehmen - aber die Grundvoraussetzung, dass man quasi das selbe Modell schonmal haben muss finde ich etwas albern und schade.
Ich habe bisher nur eine einzige Lampe mit ner MT-G2, sonst nur XM-L/2 Bomber…
Wäre nett auch mal die neueste Generation von Cree zu testen.
Gibt es in Bälde neue Coupons?
Am Besten auch für die JM-30 + Verlängerungsstück :stuck_out_tongue:
to the “I only speak one language”-People: Use babelfish ;D
It reminds me on a competition/contest I once heard on radio - there the first prize was a radio :slight_smile:
well - the first one goes to a member to make his set complete .
on the second one anyone has a chance !
I try to get a new set of codes for jm 30/35 and cells
(the mt-G2 always came with the extension tube ;))
M4D M4X nice photos of both torches. Thanks for posting along with your thoughts. On high how warm does the head of the torches get?
Thanks for the review mad max. Subscibed.
i will buy them from bg, cant wait any longer…
based on picture the xhp50 has a narrower beam so it should more throw than floodier mtg2 ?
i cant choose which emitter i’m going to buy… please advise. what do you think.
and also the coupon already expired for shadow jm35
I hope I can make real life beamshots in a few days
that should answer your questions
still waiting for beamshot before buying.
are you going to mod your jm35? like thicker wire, spring bypass?
thanks madmax
since I can’t get to the driver I have no chance to mod it…
I tried the effect of spring bypass by comparing lumens with stock tube and connecting negative from cell with thick wires direct to the drivers back
no difference - I leave it stock hence the giveaway
Giving away lights to people who already own the lights. That’s interesting…
Looking at the beams from the upside view seems the xph50 will throw better…. could you do some lux measurement if doesn’t bother you too much.
Codes seem to have expired.
Codes are ONLINE
and KEEPPOWER 4500mAh and 5200 26650 Batteries
Did I understand it right, click to turn on and change modes, hold to turn off, like Skilhunt H02, for example?
exact!
