SolarForce L2i body
7 posts / 0 new
vawayne
vawayne's picture
Last seen: 8 years 5 months ago
SolarForce L2i body
I just got........ Solarforce Masterpiece Pro-1 Turbo Head King ~ Monster Thrower + Free L2i
and when I try to use 1 18650 battery it does not fit very good because the spring on pill and on the tail
anyone have any tips.. it works great with 2 cr123a and 3 AAA
monanoke
monanoke's picture
Last seen: 4 months 2 days ago
Little intensive, but should work for that loooooong spring that comes on the MPP-1
http://budgetlightforum.com/node/1922
mononoke
C
Langcjl
Langcjl's picture
Your battery is catching on the underside of the ridge that the big dropin spring sits on. Load the battery from the head, it will then clear this ridge. If you want to see what is happening, load the battey like normal from the tailcap. Replace tailcap and when it starts to get tight, stop. Now remove the head and you will see how the battery is jammed up.
Piers said " ....but who wants enough light, when you have the option for far too much "
vawayne
vawayne's picture
I think I saw some were  that sf said put on head befor putting battery not sure just asking ..
CheapThrills
CheapThrills's picture
Last seen: 22 hours 8 min ago
I had longer cells, Xtar´s, so I changed clicky and now it´s all good : http://www.shiningbeam.com/servlet/the-93/Forward-Tactical-Click-Switch/Detail
vawayne
vawayne's picture
@ Langcjl.... thanks it works no switch mod.... this is great little light too...........
Langcjl
Langcjl's picture
Another way to do it is to put the head on the empty tube just so the threads catch and hold. Load battery from tail and make sure it gets in the hole and is on the spring. Bounces when pushed. Then screw on tailcap all the way. Now the head can be tightened all the way.
