Panasonic NCR18650A 3100mAh cells discharge test (2928mAh 1st cycle 3074mAh 2nd 3120mAh 3rd)
27 posts / 0 new
2100
1st cell 1st cycle, 1A, set at 2.8V termination.  3.3V unloaded.  2928mAh.  As mitro tested, it does not vary much with 1A, 3A, 5A, these cells are good.  Probably better if cycled more.
1st cell 2nd cycle, 1A, set at 2.7V termination, 3.2V unloaded. 3014mAh
2nd cell 2nd cycle, 1A, set at 2.6V termination.  3074mAh.
1st cell 3rd cycle, 1A, set at 2.6V termination. 3120mAh
2nd cell 4th cycle, 1A, set at 2.6V termination 3076mAh
$22.99 per pair / set of 2 cells, shipping inclusive.
 http://www.hkequipment.net/?p=6&id=1002&lang=en
asd
asd
asd
asd
asd
Edited by: 2100 on 08/28/2011 - 11:06
2100
Old4570, if you could, pls put this into your DB table?
DasFriek
Last seen: 8 years 6 months ago
These results don't surprise me after owning 2400mAH and 2900mAH Panasonic cells myself.
The best part is when looking at the discharge cycle on a graph you see just how linear the cell discharges and holds the Amps higher than most cells do longer.
BTW HKE is great to buy from also, I added that as they are the cheapest place to get these cells.
old4570
Last seen: 3 hours 2 min ago
Sure can ..
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
2100
Thanks, i am doing some more cycles to see what it can do up to, and on the second cell as well to give a good spread.
Oh for those new into 18650 cells, don't think that 29xx is low and under-spec.  AW's 2900 is only low 27xx and stuff like XTAR 2600 (Sanyo 2600 cells) is only 24xx.  But still better than Ultrafire stuff, which gets like what 1200mAh if you are lucky.  Big Smile  (recycled ones get only 600-700).
http://budgetlightforum.com/node/2581
2100
1st cell 2nd cycle 3014mAh! Terminate at 2.7V
Now trying out the second cell.
2nd cell 2nd cycle 3074mAh! Terminate at 2.6V
old4570
Im currently testing some older 18650 , and it might be time to retire some - maybe ?
Those results look good !   Thank you for testing .
2100
1st cell 3rd cycle. A whopping 3120mAh!
I am trying 2nd cell now, but i did the 3rd cycle together with the 1st cell on the charger..... trying 2nd cell 4th cycle so as to see if the results matches for further cycles and on a different cell so as to normalise.  Obviously i don't have the time nor $$ to try a sample base of 10 cells, but as usual we'll make do.
I'll also try the NCR18650 2900s so as to give a relative picture, as some guys do not trust the IMAX B6.
Hikelite
Last seen: 5 days 20 hours ago
Very nice.
Thanks for posting your results.
2100
2nd cell 4th cycle completed. 3076mAh.  Picture in the first post.
Tested with Panasonic 2900 cells which i purchased in May to check on relative accuracy.  Got 2871mAh.  So I think the discharger is within spec.
http://www.pbase.com/weddings_events/image/137599197/medium.jpg
beamshot
Last seen: 4 years 1 month ago
Hi...these two battery are the best or not??? and what is the best in the two???
i don't understand very well the result but it's not important for me...the important for me is know if these to panasonic is the best 18650 on the market a this time...
thanks bye bye
ri chevy
Last seen: 11 months 2 weeks ago
Any long term updates on these 3100 cells 2100?
2100
Well, nothing....i just use them. Do you want me to do another test?
ri chevy
No thank you.  I was just curious to see how they were holding up.  I had a few batteries in the past that were good at the beginning, and then after 3 or 4 charges, lost their power and would not hold a charge.  Just asking.
phantom23
phantom23's picture
Last seen: 4 months 1 day ago
I'd like to see 3A test but unfirtunately your charger can't do that.
2100
Oh...haha...definitely not for these cells.  Even the TF Flames should be ok for a good 1 or 2 years.   I even abused some Trustfire down to 1.7 volts unloaded, yes that low....and a couple of times lower than 2.5V, and they still discharged ok.   When the XM-L dims and your eyes manage to detect that difference (which is from ~ 800 lumens to ~ 200 lumens), you can be sure that under load they are already comfortably below 2.3V.
I do monitor my stuff very closely, it's part of the fun anyway and yes i am geeky enough to stare at the charger LCD momentarily while charging.  LOL! Sealed
ri chevy
I fell victim of the infamous Ultrafire 3600mAh batteries.  Embarassed  I have a few that are worthless.  I am trying to replace them with these Panasonic 3100's.  I also have a few Callie's Kustoms.  The CK are fine, and I feel a good quality battery.  Hopefully these are good too.
r1derbike
Last seen: 1 year 8 months ago
ChibiM
ChibiM's picture
Last seen: 11 hours 51 min ago
r1derbike wrote:
I jump with joy when I tear apart some laptop batteries and find the pannys.  Nice!
A bit expensive here, however:
http://www.ebay.com/itm/NEW-2X-Panasonic-18650-3-6V-3100mAh-Rechargeable-Li-ion-Battery-2-NCR-Batteries-/330634383068?_trksid=p4340.m185&_trkparms=algo%3DSIC.NPJS%26its%3DI%26itu%3DUA%26otn%3D5%26pmod%3D350509094290%26ps%3D63%26clkid%3D4737878586101385743
Oh man, if these Ebay batteries were in a laptop, wow, I cant guess what the laptop must cost!
Especially if it has 8 of those cells in it
benckie
benckie's picture
Last seen: 7 years 5 months ago
2100 wrote:
It does not vary much with 1A, 3A, 5A, these cells are good.  Probably better if cycled more.
It does vary a bit.
For people who do not understand mAh it stands for milliamp hour this means a 3100 mAh battery should be able to supply 3100 milliamps (3.1 amps) for an hour.
Here are some Panasonic NCR18650A 3100mAh cells that have been cycled 8 times and last night i charged them then today i discharged then at 3.1 amps from 4.18 volt to 2.5 volt discharged with an icharger 106B+ in lilo mode for lion batteries.
Cell A discharged at 3.1 amps from 4.18 volt to 2.5
Cell B discharged at 3.1 amps from 4.18 volt to 2.5
The cells come off the charger with a resting voltage of 3.24 and 3.23v.
If people are wondering how i come up with the above data table's i posted on this battery test, i data log using my icharger 106b+ connected to my computer for my battery tests, i use a program logVeiw V2.7.4* with icharger 106B+ with firmware v3.14 upgrade and then recalibrated the charger.
I use this program for my data log,s and for the data charts i post
http://www.logview.info/vBulletin/content.php?47-screenshots_1
I use the data tables instead of graphs becuse i find it simple and think it would be easy for other people to read and the data tables includes charge time updated every 2 seconds, voltage, watts, engery, mAh, plus induvidual cell voltage for upto 6 cells, internal temp of my charger, battery temperture, the chargers imput voltage from the power supply and so on and i can not get all that infomation on one graph.
I usualy only include the end of the charge cycle then hit the print screan button on the key board while the logVeiw program is running and opean on the screan of my computer, save the image in paint, then crop the image down with microsoft picture it! then up load the image to photobucket then post the image on the thread.
I cut out things like battery and charger tempture and induvidual cell voltage if im only doing one cell at a time to test.
ChibiM
ChibiM's picture
Does anybody know if the Protected ones can deliver 2.8A?
It looks like it cant.. from what I read before.
Benckie, do you know the max A? (with PCB)
benckie
benckie's picture
Mine could deliver 3 amps close to down to 3 volt but the battery droped about 40 to 45% of the mAh and run time and both PCB,s tripped at diffrent amp rates and diffrent voltages, so im going to have to say no they cant.
If you have not brought any yet look at this thread, 5.2 amp discharge with protected batteries no worries.
http://budgetlightforum.com/node/5854
ChibiM
ChibiM's picture
quote: down to 3 volt but the battery droped about 40 to 45% of the mAh and run time and both PCB,s tripped at diffrent amp rates and diffrent voltages, so im going to have to say no they cant.
Thanks Benckie, there is already one on its way.
(I actually didnt want to pay over $10 for 1 battery, but after seeing that the 3100mAh Panasonics were really good, I went ahead and ordered one, before your tests).
thanks again for your explanations.
benckie
benckie's picture
Panisonic suggest the maxium discharge on these batteries is 2C, 6.2 amps, so i thought ill give it a go and include some graphs.
6.2 amp discharge test from 4.16 to 2.5 volt.
Data table (at the end of cycle)
Volts VS mAh
Volts VS Wh
Battery tempture at the end of test
55.6 degrees C
2100
So you see, not that much of a diff between 3 and 6 amps.
benckie
benckie's picture
There is a diffrence between 0.5 amp and 1 amp and there is a diffrence between 1 and 3 amp and a diffrence between 3.1 amp and 6.2 amp at 6.2 amp the cell can not main the voltage as high as 3.1 amp and at 6.2 amp the discharge curve is steeper and takes a longer to level out, the diffrence in maintaining voltage is upto 0.5 volt from 0.5 amps to 6.2 amps but over all performance is good and pritty equal
marcl
Last seen: 2 years 2 months ago
I'm sorry to drag up an old post.  But I just wanted to ask if these are OK to use in my BC40.  The only batteries I have are protected.  But these seem to be a little more able to take abuse, i.e. go down to 2.5v (panasonic say 2.3v min) Therefore is protection as important on a cell like this?
Marc.
Eagles may soar, but weasels don't get sucked into jet engines!
