Test/Review of Shockli 18500 1100mAh (Cyan)
1 post / 0 new
HKJ
HKJ's picture
Last seen: 34 min 54 sec ago
DSC_9975
Official specifications:
  • Nominal capacity: 1100mAh
  • Nominal voltage: 3.7V
  • Discharge cut-off voltage: 2.75V
  • Standard charge: 4.2V 500mA
  • Maximum charge current: 1000mA
  • Continuous discharge current: 15A
  • Pulse discharge current: 20A
  • Initial impedance max.: 18mOhm
  • Cycle life: 500 cycles to 60%
  • Operating temperature: Charging, 0°C ~ 45°C, Discharging, -20°C~60°C
  • Storage temperature: -20°c -35°c
  • Weight: 35g
Shockli%2018500%201100mAh%20(Cyan)-info
15mm shorter than 18650 and as usual it cost a lot of the capacity.
DSC_9973 DSC_9974
DSC_9976 DSC_9977
DSC_9978
DSC_9979
Shockli%2018500%201100mAh%20(Cyan)-Capacity
There is some capacity difference between the cells, this means they are best used one at a time. They do handle high current.
Capacity is better than rated.
Shockli%2018500%201100mAh%20(Cyan)-CapacityTimeHours
Shockli%2018500%201100mAh%20(Cyan)-Energy
Shockli%2018500%201100mAh%20(Cyan)-PowerLoadTime
Shockli%2018500%201100mAh%20(Cyan)-TripCurrent
Shockli%2018500%201100mAh%20(Cyan)-Charge
Conclusion
As long as the cells are used one at a time they are acceptable and can deliver a lot of current.
Notes and links
Compare to 18650 and other batteries
Edited by: HKJ on 06/13/2015 - 12:33
