Nichia 219C, testing a 5000K 83CRI emitter, comparing with a XP-G2 S4 2B and other leds
345 posts / 0 new
Mitko
Mitko's picture
Last seen: 6 months 1 week ago
I builded today my first s2 N219C light( for my elder son): came out 800lumens ( i used EE X6 driver)
Came out a great light, the 219c is a great emitter, the tint is on of the best arround( V6 3D is the best)
pilotdog68
pilotdog68's picture
Last seen: 11 months 1 week ago
Oooh where did you get that clip? Looks great
garrybunk
garrybunk's picture
Last seen: 3 days 8 hours ago
Another question, when swapping the XP-G2 for a Nichia 219c, how do I align the Nichia? I see nichia's "cathode mark"; do I position this corner of the Nichia where the XP-G2 has its "dot"?
I searched for "XP-G2 cathode mark" but couldn't find a clear answer. Are all LEDs marked with a "cathode mark"?
Thanks,
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
DB Custom
DB Custom's picture
Last seen: 14 hours 7 min ago
If you’re looking at the pad with the positive contact strip on your right and the negtive contact strip on your left, then the Nichia 219C has the larger white blob bottom left. That out of sorts white blob is the cathode marker.
garrybunk
garrybunk's picture
How does that relate to the XP-G2? The XP-G2's dot would also be at that bottom left? (i.e. Nichia blob is same location as XP-G2's dot?  This is a quad board out of a bike light I'm working on.
-Garry
garrybunk
garrybunk's picture
Here's a pic. The XP-G2 below the one nichia is showing how it was oriented. I matched the Nichia blobs to the XP-G2 dots.
Ee
-Garry
ImA4Wheelr
You have those oriented correctly.  Here is a mix if A's and C's to help you verify.
will34
will34's picture
Last seen: 23 hours 11 min ago
garrybunk wrote:
Here’s a pic….
Garry how do you like the beam after the 219C swap?
I have a BT70 on the way and wanted to do the same.
garrybunk
garrybunk's picture
I've not tried it yet. I'll post up pics and my impression in my bike light thread when I'm done (see link in my signature). I plan to also post my emitter swap video along with pics over in the MTBR BT40S thread.
-Garry
Kenjii
Kenjii's picture
Last seen: 1 year 8 months ago
Hi,
i almost finished the mod of a Roche F8 in desert yellow.
The light got a heatsink with 18mm height with 4mm hole. The heatsink is screwed to the pill with two M3 screws. I plan to fill the gap between heatsink and head with Fujik for better heat transfer, but that is a separate step. The 3XP MCPCB is soldered to the heatsink.
Fully assembled. The light uses a Carclo 10507 optics but i will try 10508 later, because i think the beam could be i bit broader. I don´t need much throw from this one. The light is powered by a MTN FET Driver and a LG HE2 battery.
Here in comparison to 2x BLF Ti (XP-G2 S3; Nichia 219B) and a Sinner (Nichia 219B dedomed). Multicolor Wink
I measured lumens via ceiling bounce and got 2800 Lumens at startup Crown The light gets hot pretty fast but not as fast as i thought. My multimeter can only measure up to 10A but i think here are flowing more than 12A. Based on Dale´s Quad Nichia this was the plan on mine Smile I really like this light! I am still a bit scared about the tiny little tailcap switch to melt …
Greetings
Kenjii
FmC
FmC's picture
Last seen: 5 months 4 weeks ago
My 219c's from RMM's promo sale turned up today.
I just finished replacing the original warm XP-G in my CNQ Brass Beauty with one of these.
Cooler tint than I had anticipated, & great CRI. I can't imagine what the 90+ CRI variants will be like.
Manual Man
Last seen: 2 years 10 months ago
Same here. Just added one to a C8 (replaces an DD XM-L2). With a stacked 7135 driver (~2.7A) its pushing around 35K lux (XP-G2 in S4 bin should be around 38K with the same setup). With the linear driver its still pushing 2A with the battery down to 3.5V (1/3 of capacity left) so looks like the low voltage will help it stay in regulation for quite some time. I think I will be adding these to a number of Eagle Eye X6s and Convoy C8s for friends and family.
Can’t same I’m blown away by them (was hoping for a little more throw) but they are a nice alternative to XP-G2 and would be excellent for headlights, worklights etc. Cheap to.
ToyKeeper
ToyKeeper's picture
Last seen: 8 hours 22 min ago
FmC wrote:
My 219c’s from RMM’s promo sale turned up today. I just finished replacing the original warm XP-G in my CNQ Brass Beauty with one of these.
Did you get the 219C on a MCPCB, or reflow it onto one? Did you have to cut any parts down to fit?
FmC
FmC's picture
ToyKeeper wrote:
FmC wrote:
My 219c's from RMM's promo sale turned up today. I just finished replacing the original warm XP-G in my CNQ Brass Beauty with one of these.
I got the bare LED's from Richard, so I had to reflow.
I had a spare board that was the same diameter & thickness as the original, so I just flowed the 219c & it was a straight swap over, although I took the opportunity to replace the lead wires with 22awg silicone wires. I re-used the original thin insulating gasket.
Note that the board is very thin (1mm*14mm), compared to most boards (~1.5mm). With such tight clearances in this light, using a thicker board might be an issue if the cell is on the long side.
I couldn't say if a 16mm board will fit - there was plenty of clearance for the 14mm board, but I didn't test a 16mm on the pill.
shrick
shrick's picture
Last seen: 2 years 2 months ago
Do you guys think the 219C would hold up DD with a efest 10440? I’m hoping the voltage drop would be enough to keep things stable.
shrick
shrick's picture
The more I look at djozz’s figures, the less confident I am it will work… I think the amps will run away and probably damage the LED… Mmm.
djozz
djozz's picture
Last seen: 32 min 27 sec ago
shrick wrote:
The more I look at djozz's figures, the less confident I am it will work... I think the amps will run away and probably damage the LED... Mmm.
The led will be no problem, remember it easily survived 10 amps. The Efest 10440 are great but will not deliver 10A, my wild guess is 4A at start, skyrocketing down from that. The led will be fine but the battery may protest..
shrick
shrick's picture
Ok, I hope that is the case then… I was worried about initial spikes in the current. Thanks for your opinion djozz. If the battery protests – that’s fine! Rather the battery than the LED. I’m only receiving my 219Cs in a few weeks time. I’ll test and give feedback then… maybe somebody else will jump the gun in the meantime Wink
finges
Last seen: 3 days 13 hours ago
Should be fine, I have a 219C in a light with a FET driver and in the highest mode (basically DD) it did not die with a 25R.
shrick
shrick's picture
Thanks finges… It should probably do over 10 amps with the 25R. For now, Im planning use the 219C only with smaller cells, 18350, 16340 (regulated drivers at around 4 amps) & 10440 (direct driven). For 18650 and up, I’m still sticking with the XP/M range… The 219C with its low forward voltage makes it quite practical with the smaller cells.
shrick
shrick's picture
Imagine these type of forward voltages in the XP/M range LEDs… Smile
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 1 year 11 months ago
I have one from Cutter in a CNQ zoomy host, with 12 × 7135. It’s my brightest one cell light, accept possibly for my BLF A6, and probably my best flashlight now. The spot is not much smaller than that of the same host and lens with an XM-L2, and is bigger than it was with a de-domed XM-L. This is not a small die. I hope someone finds an easy way to dedome it.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
DB Custom
DB Custom's picture
I tried a 219C on a FET driver with spring bypasses and it hated me! Tint changed in seconds and dimmed, I got it shut off before it died but it just didn’t like my set-up… I was showing around 9A in that first few seconds but the meter was climbing.
A PanPD would run it around 7A and all was well. Just can’t use the top cells.
Edit: Tried again. Showing 8.55A it ran 12 seconds and the tint suddenly warmed and started shifting erratically and I killed power. This is in an A6, bare, with TK’s firmware and pulling off a 30Q.
EllaEmma
Last seen: 3 years 6 months ago
Thanks for sharing that Dale, that’s good to know. After the tint changed, did it return back to normal or is it permanently altered?
I just put together a A6 with a Nichia 219C (on Noctigon) with a LD-1. I like the results but is gets super hot pretty quickly. I’m not sure how practical it is in a light with so little mass to draw heat away. Then again, I don’t think it’s any worse than a BLF A6.
The hot spot is smaller and more defined than the XP-L and it is more intense. It seems to throw a little further but I don’t have a way to measure. Tint is pretty nice as well, but not as nice as the XP-L 3D.
I’m going to remove the LED and try it in either a S8 with a SMO to see if I can get a little more throw.
DB Custom
DB Custom's picture
So far the tint appears normal with a lesser cell. I just can’t use a 30Q or 35A or LG HE-4 or….
WhitedragonBC
WhitedragonBC's picture
Put together an A6 with a 5000k 219C and I have to say I’m pretty disappointed. Compared to my other A6 with a V2 3C XPL-HI the 219C seems inferior in every way. On a NCR18650GA it pull 5.5 amps, 1 more than the XPL-HI, to produce ~10% less light, ~35% less lux at 5m, and has a cooler tint.
The lower output isn’t unexpected; it’s the lack of throw and tint that got me.
testedandbaked
testedandbaked's picture
Last seen: 3 months 4 weeks ago
I just did this combination in my Tool build, my multimeter says 2.8A, however I know it’s more as it’s visibly brighter on shorting the leads. My guess is 3.5-4A. The 219C can take it but requires a DTP star as it goes blue if fed that much on a “normal” star. The efest gets quite warm if left for 30+s tho, but seems OK.
I have both the 4000k and the 5000k 219C now. I prefer the tint of the 5000k as it’s more neutral to my eyes, whereas the 4000k is leaning towards warm. The 5000k is quite similar in tint to the famous 92 typical CRI 4500k 219B, however the reds (in both the 4000k and 5000k 219Cs) are visibly more subdued than the 219B.
Hence Nichia’s guaranteed minimums (lower than typical values) of:
219B: Ra 90, R9 50
219C: Ra 80, R9 0
Ra being the aggregate score of the 8 colours used to calculate CRI and R9 being the colour “Natural Red” which is sadly not used in the CRI calculation. R9 values of 50+ are extremely useful in surgical lighting as many tissues and blood are shades of red.
EDIT (source): http://www.leapfroglighting.com/why-the-led-r9-value-isnt-important/
ImA4Wheelr
Wow, really good info in the above post t&b.  Thank you Smile
garrybunk
garrybunk's picture
In case you didn't see them, I posted some comparison beamshots in "My Bike Light Thread" post #46 & $47.  I modded a Nitefighter BT40S that came stock with NW XP-G2's (which I had compared tint with other lights and found to be 4C or very very close) over to Nichia 219C's.  I then compared these Nichia's to my favorite XM-L2 5B1 tint.
(So I did get around to using them without letting them sit on my workbench for months!)
-Garry
tommswpa
Last seen: 3 years 2 months ago
Hi,
I was able to get in on RMM’s recent 219C special offer, with three 219Cs mounted on a Noctigon along with Carclo optics.
My order from RMM also included the MTN-17DD FET driver loaded with Toykeeper’s excellent firmware / UI, the Convoy S2 host, the S2 copper spacer/heatsink, and Samsung INR18650-30Q battery.
Last weekend, I assembled the above S2 with the triple nichia 219C noctigon, the S2 copper heatsink/spacer, and did a switch and spring bypass (with 18 gauge wire) on the S2’s clicky. The MTN 17DD driver already had a spring bypass done by Richard with copper braid.
I kept the stock 17DD driver wires provided by Richard to attach the driver to the nichia LEDs on the noctigon. I think these are 22 gauge wires, and I am contemplating replacing these wires with something heavier, given that the projected amount of current draw with this setup (over 10 amps?) is in excess of 22 gauge wire’s rated maximum current carrying capacity. I’d like to use 18 gauge wires to attach the driver to the LEDs, but these may be too thick to solder onto the driver’s + and – pads. Additionally, the thinner 22 gauge wire, however, may be acting as a resistive “safety valve” to limit current to the nichias, and it may be better to retain the smaller gauge wires provided they don’t eventually act like fuses when running on turbo.
So far, I have run this light configuration on turbo for no longer than 15~20 seconds or so – I’m not yet brave enough to run it on turbo much longer. Wink . I’ve done this quite a few times over the last 3 days, and the 219Cs seem to be taking it just fine so far.
It’s output is truly stunning on turbo!
To my eyes, I don’t see any tint anomalies when running on turbo, just that pleasant nichia whiteness.
I don’t have a way of measuring the light output, but doing a ceiling bounce with the above S2 configuration running on turbo lights up an entire bedroom! I have a Trustfire X100 (9 LEDs) that appears, to my eyes, to have similar ceiling bounce performance. The x100 light is supposed to emit roughly 3000 OTF Lumens.
On turbo, the S2 copper spacer/heat sink and S2 flashlight body get warm pretty fast (in about 7 seconds or so), but the heat sink/spacer appears to be doing a good job at removing what must be significant amounts of heat density. This seems to help keep the nichias from burning up (at least for short turbo bursts for roughly 15 seconds).
The 30Q battery seems to be one hell of cell when coupled with the 17DD+FET driver!
I don’t think I have a way to measure the amount of current that must be flowing in the setup. My meter has a 10 amp maximum capacity. I hope to investigate means to measure the current in this setup a bit more this weekend. Don’t know that I’ll be successful, but will post any findings or observations.
Tommswpa
