Test/Review of Shockli 18350 700mAh (Cyan)
Official specifications:
  • Nominal capacity: 730mAh
  • Nominal voltage: 3.7V
  • Discharge cut-off voltage: 2.75V
  • Standard charge: 4.2V 500mA
  • Maximum charge current: 1000mA
  • Continuous discharge current: 10A
  • Pulse discharge current: 15A
  • Initial impedance max.: 35mOhm
  • Cycle life: 500cycle to 60%
  • Operating temperature: Charging, 0°C ~ 45°C, Discharging, -20°C~60°C
  • Storage temperature: -20°c -35°c
  • Weight: 21g
This is a high current 18350 cell.
The curves are fairly good, but they do not track perfectly. The cell can deliver 10A when hard pressed, but definitely not 15A.
Conclusion
This cell is one of the good performing high current cells, I would have liked a bit less variation between the two cells, but as long as the cell is used stand alone it is not a problem.
Notes and links
The battery was supplied by shockli.com for review.
Comparison to other LiIon batteries
Looks to be identical in appearance, and performance, to the Windyfire 18350 700mAh. And both are the equal of the AW 700mAh 18350 at loads of 3A and lower. But do they have the consistency of AW batteries, that is the question.
Hi SubLGT
thanks your views ,You are very professional for battery .Of couse,to meet consistency ,our battery Internal resistance control in 2 mΩ .
Also dampfakkus.de test the shockli 18350 700mAh ,you can see his Views.
http://www.dampfakkus.de/akkutest.php?id=604&a=5
http://www.dampfakkus.de/akkutest.php?id=603&a=5
Hello SubLGT
Can you give some your reviews about shockli 18650 2500mAh ,shockli 18500 1100mAh and shockli 26650 3500mAh,I will give feedback to our technical engineer.thanks you .
i am glad to Communication with you here ,i am Simon .
i am glad i read your review ,good service and fast shipping from http://www.shockli.com/
very nice battery from same flashlights i get a bit more amps compared to efest purple
good battery
