old to new
31 posts / 0 new
hamedshh
hamedshh's picture
Last seen: 1 week 4 days ago
old to new
i myself made an led lantern
it was an oil lantern but i changed it to led
cool light for nights
It gives you a royal and dreamy moment when you wanna use it
God is the light of the heavens and the earth. A metaphor for His light is a niche in which there is a lamp placed in a glass. The glass is like a shining star which is lit from a blessed olive tree that is neither eastern nor western. Its oil almost lights up even though it has not been touched by the fire. It is light upon light. God guides to His light whomever He wants. God uses various metaphors. He has the knowledge of all things. (35)
Edited by: hamedshh on 07/22/2017 - 18:27
eebowler
eebowler's picture
Last seen: 15 hours 45 min ago
Sounds interesting. Smile Can you post pictures?
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
hamedshh
hamedshh's picture
yes of course!
here is two image of that when on and off :
southland
southland's picture
Last seen: 18 sec ago
Nice build.
hamedshh
hamedshh's picture
southland wrote:
Nice build.
good
when oil is available just give out LED and battery and just do fire the wick and gave bright
it is best to use it with led to brighten
lekvar
Last seen: 1 year 8 months ago
That’s a great mod!
eebowler
eebowler's picture
That is cool! What batteries are you using?
hamedshh
hamedshh's picture
an old nokia phone li-ion battery in 3*3 centimeters size any type of that battery size might used to bright led just in 3.7v at 1amper
eebowler
eebowler's picture
Smile I’ve done that too!
hamedshh
hamedshh's picture
eebowler wrote:
:) I've done that too!
be carefull about li-ion batteries if any mistakes like short circuit appear may cause battey explosions or fire burning.
MRsDNF
MRsDNF's picture
Last seen: 3 hours 11 min ago
Sweet mod. Thanks for showing.
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
eebowler
eebowler's picture
Cell phone batteries have built in protection. No need to worry about those.
breinrules
breinrules's picture
Last seen: 1 month 2 days ago
Nice mod, though im scared to put lithium and fire
In close proximity
Rolz
Last seen: 1 hour 29 min ago
Nice work. That seems to work quite nicely.
JohnnyMac
JohnnyMac's picture
That is really cool!  I'd love to see some close ups of the LED setup and battery and how you make it easily reversible.
hamedshh
hamedshh's picture
see how i assemble it
so easy and fun i get a lot of picture taken see its cool:
hamedshh
hamedshh's picture
hi
another my product is old flashlight that use incandescent bulb and two  C size battery
i change the incandescent torch bulb with Cree XR-E white color LED and put in that a Li-ion battery in size  3*4 centimeter 3.7V 1A
i made a handmade charger via capacitors and pool diodes to change 220 V AC to 220 V DC  and use a  400V electrolytic capacitor at 200 micro farad and use a DC motor to convert 220V DC to swirl power and use another DC generator like that motor and connect motor to generator directly and when power on charger DC motor start swirl and it even swirl DC generator it produce almost 1 watt energy(6V 250 mA) connect to battery via a rectifier diode this is for that the battery never swirl the motor because diode block the power of battery and then when ac power connected battery get charged and synchronous the LED give power to brighten it meant you free to use when it is in charging and when charge gave and take LED to brightness release
even battery if full charged get out AC power socket and work with it perfectly until battery get discharged and charge it again while you use it
hamedshh
hamedshh's picture
hi...
i want to make an mechanical power supply to provide power of LED bright or all thing that take battery to work
let you know that i thinks an cranker connect directly to spiral spring when you crank the spiral spring almost spiral spring become twisted at end point and give your hand arm energy in to potential energy then it keep by an micro toggle if you release the toggle the spiral spring it got to the first situation strongly and swiftly then i wanna to connect big gear then connect big gear to little gear and little gear to smaller gear until the spiral spring power get from strong and powerful and swiftly into extra high more round and quickly swirl it let spiral spring give energy tranquilly and instead of fast and less time swirl into sluggish and more time swirl via the gear system end gear must be connect to DC generator
when you crank the spiral spring you give it your energy then the toggle keep thats early then when you take out toggle your strong potential energy sent to generator in long time and until generator swirl the power of led provided so when you see led get off it mean
the generator stop swirling then you crank the main spiral spring again will give you another arm power to bright LED or supply any gadgets
it is good to remove batteries in all gadgets like cell phones even laptops or any electronic instruments  at all
 i cannot to execute my idea because i have not necessary requirement equipments to do that job
if anyone do that job and industrialize it meant help greenish to the nature and earth
never every one lost
no need to cut trees
many of energy sources saved
and a lot of issue .....
hamedshh
hamedshh's picture
hi
let me to show you how we can snatch free energy for all long life almost it give you electricity energy at all moment and it not need to recharge at all and you never pay energy cost for all consumer
see this topic about permanent magnet motor and generator connected to that:
 http://www.greenoptimistic.com/free-energy-magnetic-motor/
hamedshh
hamedshh's picture
when can i pickup a heavy sinker from your shoulder with   impression kindness
hank
hank's picture
Last seen: 3 hours 15 min ago
hamedshh
hamedshh's picture
hank wrote:
For hamedshh: http://gravitylight.org/gravitylight[/quote]
like hourglass in old era it give us perfect energy while the sinker pulled down
it meant good use of old technology to produce light instead of measure time in past
much idea can be actualize if we can belive that like such things that i thinks about free energy source for all humans worlds
hamedshh
hamedshh's picture
How you see free infinite light source for all your life?
could new technology provide that situation that any one not to pay cost for lighting consumption?
in that case we can produce free electricity energy via free light source via solar panels that they keep near light sources.
i thinks it happens in future!!!!
hamedshh
hamedshh's picture
We are happy with your comment SmileBig Smile :bigsmile:
DBSAR
DBSAR's picture
Last seen: 1 hour 12 min ago
Nice work! Smile
hamedshh
hamedshh's picture
DBSAR wrote:
Nice work! :)
thanks to you!
JamesB
Last seen: 5 hours 15 min ago
Your lantern looks fantastic and your led conversion very clever, thanks for sharing.
hamedshh
hamedshh's picture
thank again
and see my comment about my spring driven handy power supply too!!
and time that i pragmatic it
snakebite
snakebite's picture
Last seen: 1 week 5 hours ago
looks easily reversible too.
i though of doing that to an antique railroad lantern.in my case it has to be 100% reversible as these are around 150 years old.
but real looking modern reproductions are doing fine.hate to have a nice antique and damage it doing something silly.
hamedshh
hamedshh's picture
oh never do that if you are not experienced you may damage it but take this job for a gas mantle if you have it in your property not to‏ need too much manipulate it just add wire to it carefully be care about small parts like little toggles they may become broken if you shake it too much almost a welding equipment like solder you need if any sabotage occur to soldering its broken parts
snakebite
snakebite's picture
male bovine excrement.
btw i have a bridge for sale.
a little rusty.
you have to figure out how to move it.
its in new york.
hamedshh wrote:
hi
