Review request for HKJ [Rechargeable Batteries]
770 posts / 0 new
Agro
Agro's picture
Last seen: 1 min 40 sec ago
Barkuti wrote:
P.S.: A 26800 cell was reviewed by ThunderheartReviews, see Queen Battery QB26800 6800mAh 20A – the big guy!
Wow, these look really good.
volchyonok
volchyonok's picture
Last seen: 3 weeks 4 days ago
HKJ wrote:
I do usually not destroy cells in my testing, most cells can easily survive that I go a little above rated current, but that is not really the reason for my holders. The reason I use these holders is to get 4-terminal connection to the batteries, this improve the result at higher currents.
You can also solder four wires (two wires to each pole for plus and minus). It makes no difference to connect or solder the same number of wires. However, for 26800 it is still better to solder, because they will still be used only in large battery assemblies, for which there are only holders in which they are connected using electric welding or a powerful soldering iron with tin
HKJ
HKJ's picture
Last seen: 50 min 16 sec ago
volchyonok wrote:
Therefore, the HKJ master absolutely does not need any holders with their contacts, which only interfere with tests with their transition resistance.
The holders means I get as close to the battery voltage as possible, even welding strips on would not be better, but might be as good.
I can go up to 120A test current if I did the test manually, but it would require a couple of strips welded to each end of the battery.
HKJ
HKJ's picture
Soldering is a bad idea, especially for my testing. I do not want any damage to the CID, the battery must be able to vent.
volchyonok
For the 26800 elements, 30 amperes is enough, and for an additional report in the details of the test, also mention the behavior of the graph of the characteristic of the element at load currents of 40-50A. Although, even 30A will be enough for a normal assessment of these 26800, because you still should not count on their long viability when working on currents even 10A (judging by the available graphs from another tester, for QB26800 the optimal discharge current is a maximum of up to 7 amperes). Everything above these 10A can be considered stress loads, completely unsuitable for their long life.
I did not quite understand what kind of ventilation you are talking about.
1) If we are talking about the possible overheating of the elements when soldering with a soldering iron due to the high temperature, then a high soldering speed and a minimum exposure time of the soldering iron to the poles of the element are required. To do this, at the very beginning it is really necessary to clean the diamond file, having diamond spraying, plus and minus contacts, apply soldering acid and with quick movements of a powerful soldering iron (100-200W) apply tin on the surface of the contacts. Only then should you attach two bare leads from the AWG wires and solder them also quickly. After that, you need to take air into the lungs and just blow into the place of adhesions. It will turn out without overheating. During the tests, the batteries also heat up with high currents, while their internal temperature is much higher.
2) If we are talking about additional air cooling during the test with an air blowing fan aimed at a highly loaded cell, this is not entirely true, because the 26800 cells are designed to assemble large batteries that will be carefully packed in protective films and shirts and at the same time in the real place of their subsequent work they will not see any fans for forced cooling. Then what is the point of such additional ventilation, if the test tests need to be brought closer to the real life of operation, and not only to theoretical?
Barkuti
Barkuti's picture
Last seen: 20 hours 15 min ago
volchyonok, try DeepL translator sometime, please.
I think HKJ does not want to mess with soldering batteries right now, i.e. he's not interested in soldering batteries. He also said “I do not want any damage to the CID, the battery must be able to vent” because heating the battery anode/plus pole may noticeably increase the chances of damaging the CID. CID is an abbreviature which means Current Interrupt Device:
Related article: Battery Safety 101: Anatomy - PTC vs PCB vs CID @ Battery Bro
P.S: I heartily recommend using a low temperature solder for batteries.
Wed, 12/04/2019 - 11:34
The Light Innocent I am
volchyonok
Barkuti wrote:
I think HKJ does not want to mess with soldering batteries right now, i.e. he’s not interested in soldering batteries.
All right, then we’ll all stay in the same place in an endless wait.
It’s not clear how the positive terminal can be damaged if the soldered wires are to be soldered to the uppermost contact, which is located quite far from the dangerous area of the safety valve of the element, and you need to do it very quickly, having prepared in advance for normal soldering? In order for the process to take place in a matter of seconds, you still need to have a powerful 100-150W soldering iron with a copper stinger, a short touch of which will be enough not to heat the entire complex unit. I don’t know, but all over the world even ordinary people do it, i.e. not only masters of their craft.
Barkuti
Barkuti's picture
Self-quoting me back from #748…
Barkuti wrote:
pietropetris answered a couple questions concerning an NCR18650B wrapped cell here and there, Henrik got a couple cells for review, and later I found another green wrapped cell with the same top. I have to ask because the review of these cells is nowhere to be seen.
Thanks.
I think this was overlooked, so I am asking again. Did those cells arrive home and got tested?
HKJ
HKJ's picture
Barkuti
Barkuti's picture
HKJ wrote:
Is it this cell: https://lygte-info.dk/review/batteries2012/GTF%20NCR18650B%203400mAh%20(Green)%20UK.html
Thanks. What a mess. I see one cell gave ≈3135 mAh at 0.5 A, while the other ≈3321 mAh at the same rate (3228 mAh average at 0.5 A). The shape of the curves matches closely. Do you think this is attributable to cells from different production batches, i.e. an old cell mixed with a new one, or more likely different cell model numbers?
HKJ
HKJ's picture
I will not guess about that.
volchyonok
Barkuti wrote:
What a mess. I see one cell gave ≈3135 mAh at 0.5 A, while the other ≈3321 mAh at the same rate (3228 mAh average at 0.5 A). Do you think this is attributable to cells from different production batches, i.e. an old cell mixed with a new one, or more likely different cell model numbers?
This is due to the fact that elements with a GTF sticker have nothing to do with genuine Panasonic NCR18650B elements. If you carefully look at the positive exit, you will receive evidence of this fact:
Panasonic NCR18650B
https://lygte-info.dk/pic/Batteries2012/Panasonic%20NCR18650B%203400mAh%20(Green)/DSC_2681.jpg
GTF18650B
https://lygte-info.dk/pic/Batteries2012/GTF%20NCR18650B%203400mAh%20(Green)/DSC_6805.jpg
Barkuti
Barkuti's picture
We already know, volchyonok. Those “GTF” cells actually are manufactured by a chinese OEM (BAK, as far as I know), bought in bulk by someone, rewrapped with a fake wrap and then sold. Pretty common in china.
I recently ordered some cheap Colaier G35 cells, their top pole says it all:
An EBD-M05 battery tester is also on the way home, I will publish some discharge curves once I get them.
freeme
freeme's picture
Last seen: 2 hours 30 min ago
©freemex1thedeals.com
volchyonok
I did not understand what level of charging current was selected for this device in order to fill this battery with a capacity of 10 Ah in 19 minutes?
Barkuti
Barkuti's picture
Depends on its battery configuration volchyonok. For starters, it has a 37 Wh rated battery and is powered by 100 W USB PD input so, technically speaking, if both its internal converter and battery were 100% efficient, a fully discharged 37 Wh battery charged at a rate of 100 W would take t = 37 Wh / 100 W = 0.37 hours. This is 22 minutes and 12 seconds so, without any need to refine my estimations even further by taking into account losses, we already now the claimed 19 minutes recharge time must be a lie.
It could also be that the battery capacity is actually lower (a different lie) and it meets the claimed time.
Concerning recharge current a 2S 5000 mAh graphene lithium battery (7.4 V nominal) directly connected to its charging converter would need between 16 and 17 A (I presume) of charging current to go from 0 to 100% in 19 minutes. My quoted range is because it depends on how low the internal resistance of the battery is (should be ultra low).
volchyonok
If the new battery has low internal resistance, then due to its charge with high currents, this resistance eventually starts to increase noticeably, quickly turning the new battery into the old one. Unfortunately this is the case. Long-life batteries turn into fast-discharging capacitors. Therefore, batteries cannot be charged with excessively high currents, and a sufficient amount of time is required for a normal life resource to charge.
Barkuti
Barkuti's picture
The Apollo Max is a gimmick for people who wipe their asses with $100 banknotes. LOL
It is a USB power device and, unless the brand donates a review unit or a bunch of people here (!) raises funds to buy a review unit, no chance to see it reviewed.
volchyonok
I think that such a device will be useful for showing it in feature films when it comes to fantastic action films and when there is not a single extra minute during some scenarios in which everything happens very quickly. It is on the TV screen that people will like how their main characters steal information from their enemies, who, according to the plot of an interesting film, wanted to completely capture all the states completely. However, in one of the scenes, the good guys who will fight the criminals and want to save the world, at a crucial moment, the energy needed to save the USA suddenly ran out. Therefore, they urgently needed to charge their batteries. So, when they plugged it into an outlet, then interested viewers will be able to see how literally in a matter of minutes before their eyes the rescue heroes their battery will quickly charge, because rapidly growing numbers will appear on the display during charging. And after the successful completion of charging, the beloved heroes will finally save all of America. Is this happiness not worth some 100 dollars? Wink
