Review request for HKJ [USB Power Devices]
639 posts / 0 new
MountainKing
Last seen: 1 month 1 week ago
Ok thanks Smile
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
maukka
maukka's picture
Last seen: 21 hours 35 min ago
I got my EDB-USB+ today and it is the version with a golden hs+fan even though the ebay listing shows the silver one.
Working fine too.
angerdan
angerdan's picture
Last seen: 1 hour 58 min ago
Nice 5>12V Step-Up converters with different plugs:
ebay.de/sch/m.html?_odkw=USB+5V+12V&ssn=canton-electronic
Please test at least one Smile
HKJ
HKJ's picture
Last seen: 1 hour 15 min ago
I have tested one: http://lygte-info.dk/review/Power%205V%20to%2012V%206W%20boost%20convert...
The usb input connector was not mounted, but as can be seen it has holes for it.
angerdan
angerdan's picture
Oh, great!
Thanks Smile
There are so much reviews on your website…
Can you please tell me if it’s good enough for powering small DSL-Routers like a Fritzbox 4020?
They usually have around 5W.
HKJ
HKJ's picture
angerdan wrote:
Oh, great!
Thanks Smile
This one is rated for about 0.5A at 12V, but can deliver 1A (For a short time).
angerdan
angerdan's picture
Found this on heise:
https://www.usbkill.com/
Would be a great addition to your reviews Cool
Quote:
The USB Kill 2.0 is a testing device created to test USB ports against power surge attacks. The USB Kill 2.0 tests your device’s resistance against this attack.
The USB Kill collects power from the USB power lines (5V, 1 – 3A) until it reaches ~ -240V, upon which it discharges the stored voltage into the USB data lines.
The process of rapid discharging will continue while the device is plugged in, or the device can no longer discharge – that is, the circuit in the host machine is broken.
The USB Kill Tester Shield is a dual purpose device:
- It allows you to test your USB Kill 2.0 without damaging your host device.
- It prevents data theft via ‘juice-jacking’
HKJ
HKJ's picture
I do not like that type of devices!
angerdan
angerdan's picture
HKJ
HKJ's picture
angerdan wrote:
At least the Test Shield is for good. https://www.usbkill.com/usb-killer/9-usb-killer-tester.html
When I want to zap something I uses more serious equipment and that would probably also zap the test shield.
But any equipment rated for mains usage must survive this test.
PS: That tester is a bit on the dangerous side.
maukka
maukka's picture
Such a device with a higher discharge current than 3A would be even more interesting.
http://www.banggood.com/TEC-06-Battery-Capacity-Tester-Electronic-Load-M...
angerdan
angerdan's picture
dodge_911
dodge_911's picture
angerdan wrote:
What about this two?
I own something like that 6-in-1 thingamajig. Basically it’s 3 loads you can combine : 0,5A, 1A and 2A.
At least that’s what they’re supposed to be, they’re ceramic loads, so it may ‘vary’ a little.
It’s also equipped with a bunch of LED’s on the back, which consume about 0,8A and you can connect 4 more loads/devices to it.
Don’t believe mine has the mini/micro)usb connectors, but otherwise it’s identical…
Back in the day, before I had fancy electronic testers and loads, this is what I used to test stuff. It’s quite old…
:: YouTube ::
http://bit.ly/dodgereviewsyt
:: Discord ::
http://discord.gg/fqJEDyy
:: Join the Discord ::
we need more BLF'ers!
HKJ
HKJ's picture
I might take a look at them.
The problem with usb isolators is that they only support fairly slow speeds.
angerdan
angerdan's picture
Please consider to review following devices:
YZXstudio 8th Gen powerbank DS2784
http://www.candlepowerforums.com/vb/showthread.php?421829-YZXStudio-8-Power-Bank-Review-(4×18650)
http://budgetlightforum.com/comment/912184#comment-912184
http://budgetlightforum.com/node/48561
Omnicharge PowerBank
http://budgetlightforum.com/node/48954
http://www.omnicharge.co/
PLX Devices Legion Portable Battery Charger 11000mAh
http://www.plxdevices.com/Legion-Portable-Battery-Charger-11000mAh-p/897...
HKJ
HKJ's picture
*YZXstudio 8th Gen powerbank DS2784 *
Where can I buy it?
That is a Indiegogo project, I may look at it when I can get it from a shop.
Shipping is $22, that is a bit much for a $40 device.
angerdan
angerdan's picture
HKJ wrote:
Where can I buy it?
Forum members order by email from Franky Tong, tong@franky.com
http://budgetlightforum.com/comment/1010161#comment-1010161
Shipping on the PLX Legion is a bit more than ususal, but this device has been the first powerbank with OLED. And also multiprocessor (temperature, voltage, current, etc.).
It’s currently in the selling out phase, the black one and the smaller 5.500mAh capacity already sold out.
It’s also availiable on eBay:
http://www.ebay.de/itm/152042348931
angerdan
angerdan's picture
There's currently the Vitebo VTB-28 on sale for 24€ instead of 40€ at reichelt:
reichelt.de/Mobile-Powerpacks/VTB-28/3/index.html
Also very interesting is the Vitebo VTB-80A with 2(!) microUSB inputs:
vivis-home.com/pd.jsp?id=37
L4M4
L4M4's picture
Last seen: 23 hours 16 min ago
Http://s.aliexpress.com/U7Rzyqua
I would Love to know if These things are Safe to use
HKJ
HKJ's picture
What the heck is that?
I have ordered one and maybe I will do a review (If I can figure out what it is).
For now I believe it is a usb charger (Power supply) with a bluetooth sound receiver that is routed to a jack connector.
I am taking it easy with power banks, i.e. I will not be buying any at the moment (I have some I bought a long time ago that I did not get time to review). Reason to review a power bank is:
1) It is very interesting (Like the YZX studio, but is must be possible to buy in a usable version).
2) Somebody send my one (Like Blitzwolf).
When I am lower on usb chargers I will probably review more power banks with less reasons Wink but that is a couple of months away.
xephon
xephon's picture
Last seen: 2 hours 12 min ago
https://www.aliexpress.com/store/product/Ugreen-17W-Dual-Port-Travel-Wal...USB-Charger-for-iPhone-4S-5-5S-6/301635_32393767553.html
Have you reviewed Ugreen chargers? They’re a pretty well known brand in China making quality components and cables.
dodge_911
dodge_911's picture
I’ve tested one of their cables, and they are very nice quality.
:: YouTube ::
:: Discord ::
HKJ
HKJ's picture
I have one on the way.
maukka
maukka's picture
http://www.thrunite.com/thrunite-c2-3400-mah-compact-portable-charger/
High charging and discharging rate for a single 18650 powerbank. 2.4A in 3A out. I wonder how well the NCR18650B handles those…
HKJ
HKJ's picture
Looks interesting, I have bought one.
UDO
Any chance of testing this very cheap (costs like $11) and versatile powerbank Aili 119 (6×18650 not included): http://www.ebay.com/itm/20V-Mobile-Power-Bank-UPS-6-18650-Battery-Charger-For-Laptop-Iphone-Universal-/321866773183
Beside usb output it has options to adjust output voltage from 3,3V to 21V (up to 3,3A) so that it can also be used to charge laptops. I bought this one after I read a review where the writer claimed very high efficiency when charging laptop and average when using usb output . If this test is out of the question for you, can you please take a look at the methodology of this russian test and if its even theoreticly possible that boost from 9-12V to 20V is realized with such a high efficiency (97% ?). Thank you!
Link to the test: http://review-china.com/aliexpress/8488-.html
Translated into english: https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=_t&hl=sl&...
dodge_911
dodge_911's picture
I just saw there's a new version of the YZXStudio UPM : ZY1273.
http://www.ebay.com/itm/Colour-TFT-Dual-USB-Power-Monitor-YZXstudio-ZY12...
Haven't thoroughly compared specs though, but the major difference I see is USB Type-C instead of a micro-usb connector.
:: YouTube ::
:: Discord ::
HKJ
HKJ's picture
dodge_911 wrote:
I just saw there’s a new version of the YZXStudio UPM : ZY1273.
http://www.ebay.com/itm/Colour-TFT-Dual-USB-Power-Monitor-YZXstudio-ZY1273-QC-3-0-Auto-Without-Bluetooth-/201730631141?hash=item2ef81525e5:g:IgkAAOSwiONYOpB7
Haven’t thoroughly compared specs though, but the major difference I see is USB Type-C instead of a micro-usb connector.
At first glance the specifications looks the same as ZY1270, but the display looks considerable smaller. This might be the only change and done to reduce the price.
I have ordered one.
angerdan
angerdan's picture
I’m very curious about the Soshine E3 / Tomo V8-4 Powerbank!
One is now in my Powerbank collection.
Only disadvantage so far is it can’t work as ups and has around 2,5mA drain.
budgetlightforum.com/node/33711
gearbest.com/iphone-power-bank/pp_136425.html
fasttech.com/product/1592500-soshine-e3-dual-usb-pcb-board-plastic-enclosure
dx.com/p/soshine-4-x-18650-li-ion-battery-usb-emergency-charger-power-bank-box-285415#.WEXL6mV75GE
HKJ
HKJ's picture
angerdan wrote:
I’m very curious about the Soshine E3 / Tomo V8-4 Powerbank! One is now in my Powerbank collection. Only disadvantage so far is it can’t work as ups and has around 2,5mA drain.
I have been looking at one, but it could not handle 2A current draw (It died), maybe I will get another and do a full test.
