Old Halogen worklight to LED
I had this old Halogen worklight with a burned out bulb. I never liked these type of worklights as they run very HOT. to the point of being dangerous. Should they tip over there will be a problem. Also, touch them in the wrong place and you will get burned.
I was in a Home Depot the other day and came across these 2 lights on a clearance bench. Recessed ceiling lights, LED, at $3 each. The regular price was $18. For $3 I thought is was worth a shot at gutting it for a repair (mod) of my blown worklight.
The origianl worklight was a 150W Halogen, the LED will be a “65 Watt” equivalent. Not a world beater I know, just some usable light.
I present this, not as a great mod, but only to show an example of thinking outside the box. I have no use for a recessed ceiling light, when I came across this deal all I saw was useful parts.
The light and driver.
I will put this aside, could be useful for some other project down the road
Lens removed from the light.
A closeup of the LED driver. Seems to have an isolation transformer and an AC to DC power supply, no doubt regulated.
I gutted the worklight of all it’s old hardware and mounted the LED and driver.
No big deal, but this works. And it doesn’t get HOT :slight_smile:
Nice mod for 3 bucks and a bit of time.
Welcome to the “Modded Halogen Work light club” :stuck_out_tongue:
Similar to what i did with one i have but i used different SMD LED modules and made this one run from 12 volts DC for use with a Battery Pack or AC adapter. I also mixed warm white and cool white modules to give it a nice neutral tint.
> DBSAR
Wow. How hot does that one get?
The glass gets only warm, and the light case stays fairly cool.
Thanks, glad to now be a member :slight_smile:
BTW, I was already a member of the “Modded Florescent Work light club” :smiley: :bigsmile:
My $3.96 florescent worklight Mod
That one cost me almost 4 bucks though, but it was worth it as it runs on AC or 12V DC
Old type Halogen Bulbs on KODAK Led Lighting
  1. 5W COB MR16 2700K GU5.3 Base
2. 6W COB WET MR16 2700K GU5.3 Base
3. 5W COB MR16 2700K GU10 Base
I’ve been trying find a product like you made without having to build my own. The closest I can find is https://www.superbrightleds.com/cat/landscape-spot-flood/ but I want one brighter and without a battery. Does anything like that exist?
Yeah, these things are getting pretty common. I just picked up a simple 1000 lumen one at Menards for under $20. They also have a (stated) 2000 lumen model for under $50, see here
Inexpensive (and cheaply made) versions can also be found on Amazon. Here’s a popular “30W” one. Note that you’d need to attach a cord or hardwire it.
If you guys followed the Home Depot deal alert thread, you would know that LED work lights were/are being sold for less than $10
These lights have a high quality BridgeLux emitter
“Daylight White, 6000K”. Haha. I like the idea though. I could work with that.
Hmm, I don’t actively watch the HD thread. Good price on that.
And if warm white is more your fancy, they offer the same light in WW:
